Speaker and Headphone swapped in new Manjaro gnome Installation
Hi team,
I have an funny Problem googeling around didnt gives me any solution.
The Start, fresh install Manjaro Gnome latest ISO Image (used KDE in the past)
The Problem, No Soundout put from the Speaker.
If go to Alsamixer and move Headphone up from 0 Sound is coming out of my Speaker. And crayz enough if mute the speaker the sound is muted.
Somehow the Volume for Speaker and Headphone looks swapped the mute control is on the right spot.
As said all google findings talk of an different problem like “no headphone output” or “No line Output”
Not sure if Headphone output is affected cause not using Headphones.
Anyone an idea where to look. Never had Problem with a fresh Install.
Ah its Windows Dualboot, Windows set to full shutdown, Bios Quickstart disabled. UEFI Boot.
Any help welcome.
Welcome to Manjaro forum @PeterPan666
Please post more information about system and audio devices
inxi -SMAaz
amixer --card=0
Many onboard audio devices share a single analog stereo output channel for Headphone and Speaker outputs, and may have independent level controls for both outputs or one level control for both outputs
Here the what you’ve asked for.
inxi -SMAaz
  Kernel: 6.15.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.15-x86_64
    root=UUID=fb904a99-c6f8-446c-9e30-dae347b26fea rw rootflags=subvol=@
    quiet splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 48.2 tk: GTK v: 3.24.49 wm: gnome-shell
    base: Arch Linux
  Type: Laptop System: MONSTER product: MARKUT M7 V3.1 v: REV:1.0
  Mobo: MONSTER model: MARKUT M7 V3.1 v: REV:1.0
    serial: <superuser required> part-nu: MARKUT M7 V3.1
    uuid: <superuser required> UEFI: American Megatrends v: E17E2IF8.102
    date: 04/30/2020
  Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel alternate: nova_core pcie: gen: 2
    speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
    chip-ID: 10de:10f9 class-ID: 0403
  API: ALSA v: k6.15.3-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
amixer --card=0
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 87
  Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 0 [0%] [-65.25dB] [off]
  Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Speaker',0
  Mono:
  Front Left: Playback 87 [100%] [0.00dB] [on]
  Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 254 [100%] [-0.20dB]
  Front Right: Playback 254 [100%] [-0.20dB]
Simple mixer control 'Mic',0
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 23 [74%] [0.00dB] [on]
  Front Right: Playback 23 [74%] [0.00dB] [on]
Simple mixer control 'Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [off]
Simple mixer control 'IEC958 Default PCM',0
  Mono: Playback [on]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 63
  Front Left: Capture 58 [92%] [26.25dB] [on]
  Front Right: Capture 58 [92%] [26.25dB] [on]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Disabled'
Simple mixer control 'Internal Mic Boost',0
  Limits: 0 - 3
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Enabled'
Did try many things first searched for No Audio, then found the swap with headphone Audio mixer and Saw I run un Pipewire not pulse Audio
amixer data shows:
  1. Headphone output is muted {off} and level set to 0%
  1. Speaker output is muted [on] and level set to 100%
  1. Auto-Mute Mode is disabled
  Item0: 'Disabled'
I suggest change Auto-mute Mode to Enabled in alsamixer, or
amixer --card=0 sset 'Auto-Mute Mode' Enabled
and Speaker output should be muted when Headphones are plugged in and unmuted when Headphones jack is removed
I did try that with no result.
Auto Mute mode to Enable or disable makes no change. Do not use Headphones anyhow.
I do no changes to the above only do headphone in Alsamixer to 100% and my speaker work well, and the gnome volume controle works.
The 100% volume you see for the Speaker does nothing.
No Output from the Speaker.
Headphone 0% Speaker 100% Automute enabled
Speaker work Normal
Headphone 100% Speaker 0% Automute Enabled
as said Automute makes no change.
please post more information about audio devices detected in ALSA and pipewire-pulse
sudo alsa-info.sh --upload
pactl list cards
Here we go
(http://alsa-project.org/db/?f=24ae1b8c49e982944d634575992a932c20916688)
Card #49
	Driver: alsa
	Owner Module: n/a
	Properties:
		api.acp.auto-port = "false"
		api.alsa.card = "1"
		api.alsa.card.longname = "HDA NVidia at 0xa5080000 irq 17"
		api.alsa.card.name = "HDA NVidia"
		api.alsa.path = "hw:1"
		api.alsa.split-enable = "true"
		api.alsa.use-acp = "true"
		api.dbus.ReserveDevice1 = "Audio1"
		api.dbus.ReserveDevice1.Priority = "-20"
		device.api = "alsa"
		device.bus = "pci"
		device.bus_path = "pci-0000:01:00.1"
		device.description = "TU106 High Definition Audio Controller"
		device.enum.api = "udev"
		device.icon_name = "audio-card-analog-pci"
		device.name = "alsa_card.pci-0000_01_00.1"
		device.nick = "HDA NVidia"
		device.plugged.usec = "3666998"
		device.product.id = "0x10f9"
		device.product.name = "TU106 High Definition Audio Controller"
		device.subsystem = "sound"
		sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
		device.vendor.id = "0x10de"
		device.vendor.name = "NVIDIA Corporation"
		media.class = "Audio/Device"
		spa.object.id = "4"
		factory.id = "15"
		client.id = "47"
		object.id = "49"
		object.serial = "49"
		object.path = "alsa:acp:NVidia"
		alsa.card = "1"
		alsa.card_name = "HDA NVidia"
		alsa.long_card_name = "HDA NVidia at 0xa5080000 irq 17"
		alsa.mixer_name = "Nvidia GPU 93 HDMI/DP"
		alsa.components = "HDA:10de0093,14621272,00100100"
		alsa.id = "NVidia"
		device.string = "1"
	Profiles:
		off: Aus (sinks: 0, sources: 0, priority: 0, available: yes)
		output:hdmi-stereo: Digitales Stereo (HDMI)-Ausgabe (sinks: 1, sources: 0, priority: 5900, available: no)
		output:hdmi-stereo-extra1: Digital Stereo (HDMI 2)-Ausgabe (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra2: Digital Stereo (HDMI 3)-Ausgabe (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra3: Digital Stereo (HDMI 4)-Ausgabe (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-surround: Digital Surround 5.1 (HDMI)-Ausgabe (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround71: Digital Surround 7.1 (HDMI)-Ausgabe (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2)-Ausgabe (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2)-Ausgabe (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3)-Ausgabe (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3)-Ausgabe (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4)-Ausgabe (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4)-Ausgabe (sinks: 1, sources: 0, priority: 600, available: no)
		pro-audio: Pro Audio (sinks: 4, sources: 0, priority: 1, available: yes)
	Active Profile: off
	Ports:
		hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 1"
				card.profile.port = "0"
			Part of profile(s): output:hdmi-stereo, output:hdmi-surround, output:hdmi-surround71
		hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 2"
				card.profile.port = "1"
			Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
		hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 3, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 3"
				card.profile.port = "2"
			Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
		hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 4, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 4"
				card.profile.port = "3"
			Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
Card #50
	Driver: alsa
	Owner Module: n/a
	Properties:
		api.alsa.card = "0"
		api.alsa.card.longname = "HDA Intel PCH at 0xa5410000 irq 150"
		api.alsa.card.name = "HDA Intel PCH"
		api.alsa.path = "hw:0"
		device.api = "alsa"
		device.bus = "pci"
		device.description = "Internes Audio"
		device.name = "alsa_card.pci-0000_00_1f.3"
		device.nick = "HDA Intel PCH"
		device.plugged.usec = "3752599"
		device.product.id = "0xa348"
		device.product.name = "Cannon Lake PCH cAVS"
		sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
		device.vendor.id = "0x8086"
		spa.object.id = "2"
		factory.id = "15"
		client.id = "47"
		object.id = "50"
		object.serial = "50"
		object.path = "alsa:acp:PCH"
		alsa.card = "0"
		alsa.long_card_name = "HDA Intel PCH at 0xa5410000 irq 150"
		alsa.mixer_name = "Realtek ALC1220"
		alsa.components = "HDA:10ec1220,146212dd,00100101 HDA:8086280b,80860101,00100000"
		alsa.id = "PCH"
		device.string = "0"
	Profiles:
		output:analog-stereo+input:analog-stereo: Analoges Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
		output:analog-stereo: Analoges Stereo-Ausgabe (sinks: 1, sources: 0, priority: 6500, available: yes)
		output:hdmi-stereo+input:analog-stereo: Digitales Stereo (HDMI)-Ausgabe + Analoges Stereo-Eingang (sinks: 1, sources: 1, priority: 5965, available: no)
		output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2)-Ausgabe + Analoges Stereo-Eingang (sinks: 1, sources: 1, priority: 5765, available: no)
		output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3)-Ausgabe + Analoges Stereo-Eingang (sinks: 1, sources: 1, priority: 5765, available: no)
		output:iec958-stereo+input:analog-stereo: Digitales Stereo (IEC958)-Ausgabe + Analoges Stereo-Eingang (sinks: 1, sources: 1, priority: 5565, available: yes)
		output:iec958-stereo: Digitales Stereo (IEC958)-Ausgabe (sinks: 1, sources: 0, priority: 5500, available: yes)
		output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI)-Ausgabe + Analoges Stereo-Eingang (sinks: 1, sources: 1, priority: 865, available: no)
		output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI)-Ausgabe + Analoges Stereo-Eingang (sinks: 1, sources: 1, priority: 865, available: no)
		output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2)-Ausgabe + Analoges Stereo-Eingang (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2)-Ausgabe + Analoges Stereo-Eingang (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3)-Ausgabe + Analoges Stereo-Eingang (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3)-Ausgabe + Analoges Stereo-Eingang (sinks: 1, sources: 1, priority: 665, available: no)
		output:iec958-ac3-surround-51+input:analog-stereo: Digital Surround 5.1 (IEC958/AC3)-Ausgabe + Analoges Stereo-Eingang (sinks: 1, sources: 1, priority: 365, available: yes)
		output:iec958-ac3-surround-51: Digital Surround 5.1 (IEC958/AC3)-Ausgabe (sinks: 1, sources: 0, priority: 300, available: yes)
		input:analog-stereo: Analoges Stereo-Eingang (sinks: 0, sources: 1, priority: 65, available: yes)
		pro-audio: Pro Audio (sinks: 5, sources: 1, priority: 1, available: yes)
	Active Profile: output:analog-stereo+input:analog-stereo
	Ports:
		analog-input-internal-mic: Internes Mikrofon (type: Mic, priority: 8900, latency offset: 0 usec, availability group: Legacy 1, availability unknown)
			Properties:
				port.type = "mic"
			Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-ac3-surround-51+input:analog-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71+input:analog-stereo, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1+input:analog-stereo, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2+input:analog-stereo
		analog-input-mic: Mikrofon (type: Mic, priority: 8700, latency offset: 0 usec, availability group: Legacy 2, not available)
			Properties:
				port.type = "mic"
		analog-output-speaker: Lautsprecher (type: Speaker, priority: 10000, latency offset: 0 usec, availability group: Legacy 3, availability unknown)
			Properties:
				port.type = "speaker"
			Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
		analog-output-headphones: Kopfhörer (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 4, not available)
			Properties:
				port.type = "headphones"
		iec958-stereo-output: Digitalausgang (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
			Properties:
				port.type = "spdif"
				card.profile.port = "4"
			Part of profile(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo
		hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 5, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 5"
				card.profile.port = "5"
			Part of profile(s): output:hdmi-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71, output:hdmi-surround71+input:analog-stereo
		hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 6, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 6"
				card.profile.port = "6"
			Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1, output:hdmi-surround71-extra1+input:analog-stereo
		hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 7, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 7"
				card.profile.port = "7"
			Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2, output:hdmi-surround71-extra2+input:analog-stereo
Hope that helps us.
I suggest:
  1. Install alsa-tools package and run jack retasking tool with root privileges
    sudo hdajackretask
  2. Enable Override for Headphone pin (0x14) and change it to Internal Speaker
    Enable Override for Speaker pin (0x1b) and change it to Headphone
    (or Not connected if you never intend to use headphone jack)
  3. Click Install Boot Override, reboot system to load override and check alsamixer controls
Thx that worked but I have to put 0x14 and 0x1b to Internal Speaker to get it work
Tried if one is set to something different its not working.
Good Fix for now and next time will know where to check.
