Hello,
I’m get some type of sound module compilation error while upgrading packages. I am able to upgrade successfully but i would just like to see if i could resolve these errors. I think this might be related to the fact that i had previously tried to compile and install a sound card kernal module for a previous kernel version before linux510. Once linux510 came out i think the module was available by default. I’m not sure how this might be affect the upgrade process.
Thanks for your help! There is the info:
Relevant Upgrade Error Output
Updating module dependencies...
Install DKMS modules
==> dkms install --no-depmod -m soundwire -v 1.4.0 -k 4.14.222-1-MANJARO
Error! Bad return status for module build on kernel: 4.14.222-1-MANJARO (x86_64)
Consult /var/lib/dkms/soundwire/1.4.0/build/make.log for more information.
==> Warning, `dkms install --no-depmod -m soundwire -v 1.4.0 -k 4.14.222-1-MANJARO' returned 10
==> dkms install --no-depmod -m soundwire -v 1.4.0 -k 5.10.18-1-MANJARO
Error! Bad return status for module build on kernel: 5.10.18-1-MANJARO (x86_64)
==> Warning, `dkms install --no-depmod -m soundwire -v 1.4.0 -k 5.10.18-1-MANJARO' returned 10
==> dkms install --no-depmod -m soundwire -v 1.4.0 -k 5.4.100-1-MANJARO
Error! Bad return status for module build on kernel: 5.4.100-1-MANJARO (x86_64)
==> Warning, `dkms install --no-depmod -m soundwire -v 1.4.0 -k 5.4.100-1-MANJARO' returned 10
==> depmod 4.14.222-1-MANJARO
==> depmod 5.10.18-1-MANJARO
==> depmod 5.4.100-1-MANJARO
Restarting cronie for libc upgrade...
/var/lib/dkms/soundwire/1.4.0/build/make.log File
→ cat /var/lib/dkms/soundwire/1.4.0/build/make.log
DKMS make.log for soundwire-1.4.0 for kernel 5.4.100-1-MANJARO (x86_64)
Tue Mar 2 09:50:13 AM PST 2021
make -C /lib/modules/5.4.100-1-MANJARO/build M=/var/lib/dkms/soundwire/1.4.0/build modules
make[1]: Entering directory '/usr/lib/modules/5.4.100-1-MANJARO/build'
CC [M] /var/lib/dkms/soundwire/1.4.0/build/hda/hda_bus_type.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/regmap/regmap-slimbus.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/bus_type.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/hda/hdac_bus.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/regmap/regmap-spmi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/sound.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/hda/hdac_device.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/hda/ext/hdac_ext_bus.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/atmel/mikroe-proto.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/6fire/chip.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/oss/mixer_oss.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/hda_bind.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/oss/seq_oss.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/amd/raven/pci-acp3x.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/amd/acp-pcm-dma.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/amd/acp-da7219-max98357a.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/oss/seq_oss_init.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/atmel/snd-soc-mikroe-proto.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/amd/acp-rt5645.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/6fire/comm.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/amd/raven/acp3x-pcm-dma.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/regmap/regmap-w1.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/bus.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/master.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/oss/seq_oss_timer.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/oss/seq_oss_ioctl.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/oss/pcm_oss.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/hda/ext/hdac_ext_controller.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/hda_codec.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/hda_jack.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/6fire/midi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/6fire/control.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/regmap/regmap-sdw-mbq.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/amd/snd-soc-acp-da7219mx98357-mach.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/amd/snd-soc-acp-rt5645-mach.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/oss/pcm_plugin.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/hda/hdac_sysfs.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/oss/seq_oss_event.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/hda_auto_parser.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/amd/raven/acp3x-i2s.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/slave.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/mipi_disco.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/6fire/firmware.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/oss/seq_oss_rw.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/amd/acp_audio_dma.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/6fire/pcm.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/hda_sysfs.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/regmap/regmap-sccb.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/regmap/regmap-i3c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/hda/ext/hdac_ext_stream.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/amd/raven/snd-pci-acp3x.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/hda/hdac_regmap.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/amd/raven/snd-acp3x-pcm-dma.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/hda/hdac_controller.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/amd/raven/snd-acp3x-i2s.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/seq.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/stream.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/oss/io.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/oss/seq_oss_synth.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/sysfs_slave.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/ac97.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/usb/6fire/snd-usb-6fire.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/hda/hdac_stream.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/bcd2000/bcd2000.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/seq_lock.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/seq_clientmgr.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/seq_memory.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/oss/copy.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/hda_controller.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/oss/seq_oss_midi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/adau-utils.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/hda_proc.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/hda_hwdep.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/hda/ext/snd-hda-ext-core.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/usb/bcd2000/snd-bcd2000.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/sysfs_slave_dpn.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/debugfs.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/caiaq/device.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/seq_queue.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/dwc/dwc-i2s.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/oss/linear.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/adau1701.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/oss/mulaw.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/oss/seq_oss_readq.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/oss/route.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/dwc/dwc-pcm.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/hda_beep.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/core/oss/snd-mixer-oss.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/oss/rate.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/seq_fifo.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/generic_bandwidth_allocation.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/adau17x1.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/hda/array.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/adau1761.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/caiaq/audio.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/adau1761-i2c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/caiaq/midi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/caiaq/control.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/caiaq/input.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/oss/seq_oss_writeq.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/hiface/chip.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/cadence_master.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/dwc/designware_i2s.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/core/oss/snd-pcm-oss.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/hda/hdmi_chmap.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/intel.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/line6/capture.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/adau1761-spi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/intel_init.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/adau7002.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/oss/snd-seq-oss.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/hda_generic.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/line6/driver.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/seq_prioq.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/hiface/pcm.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/patch_realtek.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/seq_timer.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/usb/caiaq/snd-usb-caiaq.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/misc/ua101.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/soundwire-bus.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/ak4104.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/ak4118.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/hda/trace.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/soundwire-generic-allocation.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/ak4458.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/ak4554.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/hda/hdac_component.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/seq_system.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/usb/hiface/snd-usb-hiface.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/seq_ports.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/ak4613.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/ak4642.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/generic/simple-card-utils.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/soundwire-cadence.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/hda/hdac_i915.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/hisilicon/hi6210-i2s.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soundwire/soundwire-intel.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/line6/midi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/line6/midibuf.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/line6/pcm.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/line6/playback.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/usb/misc/snd-ua101.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/seq_info.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/generic/simple-card.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/generic/audio-graph-card.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/patch_cmedia.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/ak5386.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/usx2y/usbusx2y.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/usx2y/usX2Yhwdep.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/ak5558.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/seq_dummy.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/seq_midi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/seq_midi_emul.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/seq_midi_event.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/hda/snd-hda-core.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/patch_analog.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/usx2y/usx2yhwdeppcm.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/alc5623.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/init.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/bd28623.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/line6/pod.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/line6/podhd.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/generic/snd-soc-simple-card.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cpcap.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/generic/snd-soc-audio-graph-card.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/generic/snd-soc-simple-card-utils.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/usx2y/us122l.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/img/img-i2s-in.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/seq_virmidi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/img/img-i2s-out.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/img/img-parallel-out.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/img/img-spdif-in.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/line6/toneport.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/line6/variax.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/img/img-spdif-out.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/img/pistachio-internal-dac.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/snd-seq.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs35l32.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/memory.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs35l33.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/control.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/intel/atom/sst/sst.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/sof_rt5682.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/snd-seq-dummy.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/snd-seq-midi.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/snd-seq-midi-emul.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/snd-seq-midi-event.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/core/seq/snd-seq-virmidi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/misc.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/patch_sigmatel.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/usb/usx2y/snd-usb-usx2y.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/usb/usx2y/snd-usb-us122l.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/intel/atom/sst/sst_ipc.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/usb/line6/snd-usb-line6.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/card.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/clock.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/usb/line6/snd-usb-pod.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/usb/line6/snd-usb-podhd.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/usb/line6/snd-usb-toneport.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/usb/line6/snd-usb-variax.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/patch_si3054.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/patch_cirrus.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/endpoint.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/intel/common/sst-dsp.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/format.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/intel/common/sst-ipc.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/intel/common/sst-acpi.o
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/atom/sst/sst.c: In function ‘sst_context_init’:
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/atom/sst/sst.c:328:2: error: implicit declaration of function ‘cpu_latency_qos_add_request’ [-Werror=implicit-function-declaration]
328 | cpu_latency_qos_add_request(ctx->qos, PM_QOS_DEFAULT_VALUE);
In file included from /var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/sof_rt5682.c:24:
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h: In function ‘soc_intel_is_byt’:
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:22:3: error: implicit declaration of function ‘X86_MATCH_INTEL_FAM6_MODEL’ [-Werror=implicit-function-declaration]
22 | X86_MATCH_INTEL_FAM6_MODEL(type, NULL), \
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:33:1: note: in expansion of macro ‘SOC_INTEL_IS_CPU’
33 | SOC_INTEL_IS_CPU(byt, ATOM_SILVERMONT);
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/atom/sst/sst.c: In function ‘sst_context_cleanup’:
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/atom/sst/sst.c:366:2: error: implicit declaration of function ‘cpu_latency_qos_remove_request’; did you mean ‘freq_qos_remove_request’? [-Werror=implicit-function-declaration]
366 | cpu_latency_qos_remove_request(ctx->qos);
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:33:23: error: ‘ATOM_SILVERMONT’ undeclared (first use in this function)
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:22:30: note: in definition of macro ‘SOC_INTEL_IS_CPU’
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:33:23: note: each undeclared identifier is reported only once for each function it appears in
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h: In function ‘soc_intel_is_cht’:
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:34:23: error: ‘ATOM_AIRMONT’ undeclared (first use in this function)
34 | SOC_INTEL_IS_CPU(cht, ATOM_AIRMONT);
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:22:3: error: initializer element is not constant
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:34:1: note: in expansion of macro ‘SOC_INTEL_IS_CPU’
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:22:3: note: (near initialization for ‘cht_cpu_ids[0].vendor’)
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:21:22: warning: braces around scalar initializer
21 | static const struct x86_cpu_id soc##_cpu_ids[] = { \
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:21:22: note: (near initialization for ‘cht_cpu_ids[0].family’)
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h: In function ‘soc_intel_is_apl’:
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:35:23: error: ‘ATOM_GOLDMONT’ undeclared (first use in this function)
35 | SOC_INTEL_IS_CPU(apl, ATOM_GOLDMONT);
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:35:1: note: in expansion of macro ‘SOC_INTEL_IS_CPU’
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:22:3: note: (near initialization for ‘apl_cpu_ids[0].vendor’)
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:21:22: note: (near initialization for ‘apl_cpu_ids[0].family’)
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h: In function ‘soc_intel_is_glk’:
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:36:23: error: ‘ATOM_GOLDMONT_PLUS’ undeclared (first use in this function)
36 | SOC_INTEL_IS_CPU(glk, ATOM_GOLDMONT_PLUS);
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:36:1: note: in expansion of macro ‘SOC_INTEL_IS_CPU’
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:22:3: note: (near initialization for ‘glk_cpu_ids[0].vendor’)
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:21:22: note: (near initialization for ‘glk_cpu_ids[0].family’)
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h: In function ‘soc_intel_is_cml’:
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:37:23: error: ‘KABYLAKE_L’ undeclared (first use in this function)
37 | SOC_INTEL_IS_CPU(cml, KABYLAKE_L);
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:37:1: note: in expansion of macro ‘SOC_INTEL_IS_CPU’
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:22:3: note: (near initialization for ‘cml_cpu_ids[0].vendor’)
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/../common/soc-intel-quirks.h:21:22: note: (near initialization for ‘cml_cpu_ids[0].family’)
cc1: some warnings being treated as errors
make[5]: *** [scripts/Makefile.build:262: /var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards/sof_rt5682.o] Error 1
make[4]: *** [scripts/Makefile.build:496: /var/lib/dkms/soundwire/1.4.0/build/soc/intel/boards] Error 2
make[4]: *** Waiting for unfinished jobs....
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/intel/common/sst-firmware.o
make[6]: *** [scripts/Makefile.build:262: /var/lib/dkms/soundwire/1.4.0/build/soc/intel/atom/sst/sst.o] Error 1
make[6]: *** Waiting for unfinished jobs....
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs35l34.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/helper.o
make[5]: *** [scripts/Makefile.build:496: /var/lib/dkms/soundwire/1.4.0/build/soc/intel/atom/sst] Error 2
make[4]: *** [scripts/Makefile.build:496: /var/lib/dkms/soundwire/1.4.0/build/soc/intel/atom] Error 2
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/intel/common/soc-acpi-intel-byt-match.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/mixer.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/device.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/mixer_quirks.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/patch_ca0110.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/mixer_scarlett.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/intel/common/soc-acpi-intel-cht-match.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs35l35.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/patch_ca0132.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/info.o
/var/lib/dkms/soundwire/1.4.0/build/soc/intel/common/sst-firmware.c:19:10: fatal error: linux/pgtable.h: No such file or directory
19 | #include <linux/pgtable.h>
compilation terminated.
make[5]: *** [scripts/Makefile.build:261: /var/lib/dkms/soundwire/1.4.0/build/soc/intel/common/sst-firmware.o] Error 1
make[5]: *** Waiting for unfinished jobs....
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs35l36.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/info_oss.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/patch_conexant.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/isadma.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/sound_oss.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/patch_via.o
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:285:21: error: variable ‘snd_info_entry_operations’ has initializer but incomplete type
285 | static const struct proc_ops snd_info_entry_operations =
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:287:3: error: ‘const struct proc_ops’ has no member named ‘proc_lseek’
287 | .proc_lseek = snd_info_entry_llseek,
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:287:16: warning: excess elements in struct initializer
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:287:16: note: (near initialization for ‘snd_info_entry_operations’)
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:288:3: error: ‘const struct proc_ops’ has no member named ‘proc_read’
288 | .proc_read = snd_info_entry_read,
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:288:15: warning: excess elements in struct initializer
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:288:15: note: (near initialization for ‘snd_info_entry_operations’)
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:289:3: error: ‘const struct proc_ops’ has no member named ‘proc_write’
289 | .proc_write = snd_info_entry_write,
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:289:16: warning: excess elements in struct initializer
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:289:16: note: (near initialization for ‘snd_info_entry_operations’)
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:290:3: error: ‘const struct proc_ops’ has no member named ‘proc_poll’
290 | .proc_poll = snd_info_entry_poll,
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:290:15: warning: excess elements in struct initializer
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:290:15: note: (near initialization for ‘snd_info_entry_operations’)
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:291:3: error: ‘const struct proc_ops’ has no member named ‘proc_ioctl’
291 | .proc_ioctl = snd_info_entry_ioctl,
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:291:16: warning: excess elements in struct initializer
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:291:16: note: (near initialization for ‘snd_info_entry_operations’)
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:292:3: error: ‘const struct proc_ops’ has no member named ‘proc_mmap’
292 | .proc_mmap = snd_info_entry_mmap,
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:292:15: warning: excess elements in struct initializer
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:292:15: note: (near initialization for ‘snd_info_entry_operations’)
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:293:3: error: ‘const struct proc_ops’ has no member named ‘proc_open’
293 | .proc_open = snd_info_entry_open,
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:293:15: warning: excess elements in struct initializer
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:293:15: note: (near initialization for ‘snd_info_entry_operations’)
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:294:3: error: ‘const struct proc_ops’ has no member named ‘proc_release’
294 | .proc_release = snd_info_entry_release,
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:294:18: warning: excess elements in struct initializer
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:294:18: note: (near initialization for ‘snd_info_entry_operations’)
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:423:21: error: variable ‘snd_info_text_entry_ops’ has initializer but incomplete type
423 | static const struct proc_ops snd_info_text_entry_ops =
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:425:3: error: ‘const struct proc_ops’ has no member named ‘proc_open’
425 | .proc_open = snd_info_text_entry_open,
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:425:15: warning: excess elements in struct initializer
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:425:15: note: (near initialization for ‘snd_info_text_entry_ops’)
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:426:3: error: ‘const struct proc_ops’ has no member named ‘proc_release’
426 | .proc_release = snd_info_text_entry_release,
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:426:18: warning: excess elements in struct initializer
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:426:18: note: (near initialization for ‘snd_info_text_entry_ops’)
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:427:3: error: ‘const struct proc_ops’ has no member named ‘proc_write’
427 | .proc_write = snd_info_text_entry_write,
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:427:16: warning: excess elements in struct initializer
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:427:16: note: (near initialization for ‘snd_info_text_entry_ops’)
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:428:3: error: ‘const struct proc_ops’ has no member named ‘proc_lseek’
428 | .proc_lseek = seq_lseek,
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:428:16: warning: excess elements in struct initializer
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:428:16: note: (near initialization for ‘snd_info_text_entry_ops’)
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:429:3: error: ‘const struct proc_ops’ has no member named ‘proc_read’
429 | .proc_read = seq_read,
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:429:15: warning: excess elements in struct initializer
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:429:15: note: (near initialization for ‘snd_info_text_entry_ops’)
/var/lib/dkms/soundwire/1.4.0/build/core/info.c: In function ‘__snd_info_register’:
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:819:10: error: passing argument 4 of ‘proc_create_data’ from incompatible pointer type [-Werror=incompatible-pointer-types]
819 | ops, entry);
| const struct proc_ops *
In file included from /var/lib/dkms/soundwire/1.4.0/build/core/info.c:17:
./include/linux/proc_fs.h:47:13: note: expected ‘const struct file_operations *’ but argument is of type ‘const struct proc_ops *’
47 | const struct file_operations *,
/var/lib/dkms/soundwire/1.4.0/build/core/info.c: At top level:
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:285:30: error: storage size of ‘snd_info_entry_operations’ isn’t known
/var/lib/dkms/soundwire/1.4.0/build/core/info.c:423:30: error: storage size of ‘snd_info_text_entry_ops’ isn’t known
make[3]: *** [scripts/Makefile.build:262: /var/lib/dkms/soundwire/1.4.0/build/core/info.o] Error 1
make[3]: *** Waiting for unfinished jobs....
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/vmaster.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/core/ctljack.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/mixer_scarlett_gen2.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/mixer_us16x08.o
make[4]: *** [scripts/Makefile.build:496: /var/lib/dkms/soundwire/1.4.0/build/soc/intel/common] Error 2
make[3]: *** [scripts/Makefile.build:496: /var/lib/dkms/soundwire/1.4.0/build/soc/intel] Error 2
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/byt.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/intel-ipc.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/hda.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/hda-loader.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/mixer_s1810c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/hda-stream.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs42l42.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs42l51.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/patch_hdmi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/hda_eld.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/pcm.o
make[2]: *** [scripts/Makefile.build:496: /var/lib/dkms/soundwire/1.4.0/build/core] Error 2
make[2]: *** Waiting for unfinished jobs....
In file included from /var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/byt.c:21:
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h: In function ‘soc_intel_is_byt’:
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:22:3: error: implicit declaration of function ‘X86_MATCH_INTEL_FAM6_MODEL’ [-Werror=implicit-function-declaration]
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:33:1: note: in expansion of macro ‘SOC_INTEL_IS_CPU’
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/hda-trace.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/hda-dsp.o
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:33:23: error: ‘ATOM_SILVERMONT’ undeclared (first use in this function)
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:22:30: note: in definition of macro ‘SOC_INTEL_IS_CPU’
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:33:23: note: each undeclared identifier is reported only once for each function it appears in
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h: In function ‘soc_intel_is_cht’:
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:34:23: error: ‘ATOM_AIRMONT’ undeclared (first use in this function)
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:22:3: error: initializer element is not constant
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:34:1: note: in expansion of macro ‘SOC_INTEL_IS_CPU’
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:22:3: note: (near initialization for ‘cht_cpu_ids[0].vendor’)
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:21:22: warning: braces around scalar initializer
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:21:22: note: (near initialization for ‘cht_cpu_ids[0].family’)
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/sof/xtensa/core.o
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h: In function ‘soc_intel_is_apl’:
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:35:23: error: ‘ATOM_GOLDMONT’ undeclared (first use in this function)
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:35:1: note: in expansion of macro ‘SOC_INTEL_IS_CPU’
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:22:3: note: (near initialization for ‘apl_cpu_ids[0].vendor’)
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:21:22: note: (near initialization for ‘apl_cpu_ids[0].family’)
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/power.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/sof/core.o
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h: In function ‘soc_intel_is_glk’:
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:36:23: error: ‘ATOM_GOLDMONT_PLUS’ undeclared (first use in this function)
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:36:1: note: in expansion of macro ‘SOC_INTEL_IS_CPU’
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:22:3: note: (near initialization for ‘glk_cpu_ids[0].vendor’)
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:21:22: note: (near initialization for ‘glk_cpu_ids[0].family’)
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h: In function ‘soc_intel_is_cml’:
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:37:23: error: ‘KABYLAKE_L’ undeclared (first use in this function)
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:37:1: note: in expansion of macro ‘SOC_INTEL_IS_CPU’
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:22:3: note: (near initialization for ‘cml_cpu_ids[0].vendor’)
/var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/../../intel/common/soc-intel-quirks.h:21:22: note: (near initialization for ‘cml_cpu_ids[0].family’)
make[5]: *** [scripts/Makefile.build:262: /var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel/byt.o] Error 1
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/sof/ops.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs42l51-i2c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs42l52.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs42l56.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/sof/loader.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/proc.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/sof/ipc.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/quirks.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs42l73.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/hda_intel.o
make[4]: *** [scripts/Makefile.build:496: /var/lib/dkms/soundwire/1.4.0/build/soc/sof/intel] Error 2
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs4265.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/stream.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs4270.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/sof/xtensa/snd-sof-xtensa-dsp.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs4271.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/snd-hda-codec.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs4271-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/snd-hda-codec-generic.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/snd-hda-codec-realtek.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/snd-hda-codec-cmedia.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/snd-hda-codec-analog.o
/var/lib/dkms/soundwire/1.4.0/build/pci/hda/hda_intel.c:39:10: fatal error: linux/pgtable.h: No such file or directory
39 | #include <linux/pgtable.h>
LD [M] /var/lib/dkms/soundwire/1.4.0/build/pci/hda/snd-hda-codec-idt.o
make[4]: *** [scripts/Makefile.build:262: /var/lib/dkms/soundwire/1.4.0/build/pci/hda/hda_intel.o] Error 1
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/validate.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs4271-spi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs42xx8.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/media.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs42xx8-i2c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs43130.o
make[3]: *** [scripts/Makefile.build:496: /var/lib/dkms/soundwire/1.4.0/build/pci/hda] Error 2
make[2]: *** [scripts/Makefile.build:496: /var/lib/dkms/soundwire/1.4.0/build/pci] Error 2
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs4341.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs4349.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cs53l30.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/usb/midi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/cx2072x.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/da7213.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/da7219.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/da7219-aad.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/es7134.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/dmic.o
make[3]: *** [scripts/Makefile.build:496: /var/lib/dkms/soundwire/1.4.0/build/soc/sof] Error 2
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/es7241.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/es8316.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/usb/snd-usb-audio.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/es8328.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/es8328-i2c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/es8328-spi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/gtm601.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/hdac_hdmi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/hdac_hda.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/inno_rk3036.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/lochnagar-sc.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/max9759.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/max98088.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/max98090.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/max98357a.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/max9867.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/max98927.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/max98373.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/max9860.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/msm8916-wcd-analog.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/msm8916-wcd-digital.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/usb/snd-usbmidi-lib.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/mt6351.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/mt6358.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/nau8540.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/nau8810.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/nau8822.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/nau8824.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/nau8825.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/hdmi-codec.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm1681.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm179x.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm1789-i2c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm1789.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm179x-i2c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm179x-spi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm186x.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm186x-i2c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm186x-spi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm3060.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm3060-i2c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm3060-spi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm3168a.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm3168a-i2c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm3168a-spi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm512x.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm512x-i2c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/pcm512x-spi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rk3328_codec.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rl6231.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rl6347a.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rt286.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rt298.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rt5514.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rt5514-spi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rt5616.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rt5631.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rt5640.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rt5645.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rt5651.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rt5660.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rt5663.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rt5670.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rt5677.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rt5677-spi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/rt5682.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/sgtl5000.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/sigmadsp.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/sigmadsp-i2c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/sigmadsp-regmap.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/si476x.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/spdif_receiver.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/spdif_transmitter.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/sirf-audio-codec.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/ssm2305.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/ssm2602.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/ssm2602-spi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/ssm2602-i2c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/ssm4567.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/sta32x.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/sta350.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/sti-sas.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tas2552.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tas5086.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tas571x.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tas5720.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tas6424.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tda7419.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tfa9879.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tlv320aic23.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tlv320aic23-i2c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tlv320aic23-spi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tlv320aic31xx.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tlv320aic32x4.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tlv320aic32x4-clk.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tlv320aic32x4-i2c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tlv320aic32x4-spi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tlv320aic3x.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tscs42xx.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tscs454.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/ts3a227e.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/uda1334.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wcd-clsh-v2.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wcd9335.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8510.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8523.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8524.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8580.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8711.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8728.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8731.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8737.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8741.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8750.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8753.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8770.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8776.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8782.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8804.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8804-i2c.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8804-spi.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8903.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8904.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8960.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8962.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8974.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8978.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/wm8985.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/zx_aud96p22.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/max98504.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/simple-amplifier.o
CC [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/tpa6130a2.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-ac97.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-adau-utils.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-adau1701.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-adau17x1.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-adau1761.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-adau1761-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-adau1761-spi.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-adau7002.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-ak4104.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-ak4118.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-ak4458.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-ak4554.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-ak4642.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-ak4613.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-ak5386.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-ak5558.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-alc5623.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-bd28623.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cpcap.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs35l32.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs35l33.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs35l34.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs35l35.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs35l36.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs42l42.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs42l51.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs42l51-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs42l52.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs42l56.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs42l73.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs4265.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs4270.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs4271.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs4271-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs4271-spi.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs42xx8.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs42xx8-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs43130.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs4341.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs4349.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cs53l30.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-cx2072x.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-da7213.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-da7219.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-dmic.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-es7134.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-es7241.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-es8316.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-es8328.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-es8328-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-es8328-spi.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-gtm601.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-hdac-hdmi.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-hdac-hda.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-inno-rk3036.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-lochnagar-sc.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-max9759.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-max98088.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-max98090.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-max98357a.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-max98927.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-max9867.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-max98373.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-max9860.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-msm8916-analog.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-msm8916-digital.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-mt6351.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-mt6358.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-nau8540.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-nau8810.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-nau8822.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-nau8824.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-nau8825.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-hdmi-codec.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm1681.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm179x-codec.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm1789-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm179x-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm179x-spi.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm1789-codec.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm186x.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm186x-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm186x-spi.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm3060.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm3060-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm3060-spi.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm3168a.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm3168a-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm3168a-spi.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm512x.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm512x-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-pcm512x-spi.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rk3328.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rl6231.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rl6347a.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rt286.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rt5514.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rt298.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rt5514-spi.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rt5616.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rt5631.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rt5640.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rt5645.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rt5651.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rt5660.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rt5663.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rt5670.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rt5677.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rt5677-spi.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-rt5682.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-sgtl5000.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-sigmadsp.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-sigmadsp-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-sigmadsp-regmap.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-spdif-rx.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-si476x.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-spdif-tx.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-ssm2305.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-ssm2602-spi.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-ssm2602.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-ssm4567.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-ssm2602-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-sta32x.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-sta350.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tas2552.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-sti-sas.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tas5086.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tas571x.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tas5720.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tas6424.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tda7419.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tfa9879.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tlv320aic23.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tlv320aic23-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tlv320aic23-spi.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tlv320aic31xx.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tlv320aic32x4.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tlv320aic32x4-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tlv320aic3x.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tlv320aic32x4-spi.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tscs42xx.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tscs454.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-ts3a227e.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-uda1334.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wcd9335.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8510.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8524.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8523.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8580.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8711.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8728.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8731.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8737.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8741.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8750.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8753.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8770.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8776.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8782.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8804.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8804-i2c.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8804-spi.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-zx-aud96p22.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8960.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8974.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-max98504.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-simple-amplifier.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-tpa6130a2.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8978.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8985.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8904.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8903.o
LD [M] /var/lib/dkms/soundwire/1.4.0/build/soc/codecs/snd-soc-wm8962.o
make[2]: *** [scripts/Makefile.build:496: /var/lib/dkms/soundwire/1.4.0/build/soc] Error 2
make[1]: *** [Makefile:1726: /var/lib/dkms/soundwire/1.4.0/build] Error 2
make[1]: Leaving directory '/usr/lib/modules/5.4.100-1-MANJARO/build'
make: *** [Makefile:10: all] Error 2
My System Info
Kernel: 5.10.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
Desktop: GNOME 3.38.3 tk: GTK 3.24.26 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Laptop System: Dell product: XPS 17 9700 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 03CPGC v: A00 serial: <filter> UEFI: Dell v: 1.4.0
date: 09/03/2020
ID-1: BAT0 charge: 87.6 Wh condition: 87.6/95.1 Wh (92%) volts: 12.9/11.4
model: BYD DELL F8CPG0A type: Li-poly serial: <filter> status: Full
Device-1: hidpp_battery_1 model: Logitech K350 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 31.11 GiB used: 10.03 GiB (32.2%)
Array-1: capacity: 64 GiB slots: 2 EC: None max module size: 32 GiB
note: est.
Device-1: DIMM A size: 16 GiB speed: spec: 3200 MT/s actual: 2933 MT/s
type: DDR4 detail: synchronous bus width: 64 bits total: 64 bits
manufacturer: 80AD00000000 part-no: HMA82GS6DJR8N-XN serial: <filter>
Device-2: DIMM B size: 16 GiB speed: spec: 3200 MT/s actual: 2933 MT/s
Info: 8-Core model: Intel Core i9-10885H bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: E0
L1 cache: 512 KiB L2 cache: 16 MiB L3 cache: 15.6 MiB bogomips: 76816
Speed: 826 MHz min/max: 800/5300 MHz base/boost: 2673/2400 volts: 0.8 V
ext-clock: 100 MHz Core speeds (MHz): 1: 826 2: 851 3: 870 4: 890 5: 807
6: 843 7: 803 8: 881 9: 859 10: 883 11: 891 12: 804 13: 846 14: 846 15: 885
16: 855
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Device-1: Intel UHD Graphics vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:9bc4 class ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Max-Q] vendor: Dell driver: nvidia
v: 460.39 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f12
class ID: 0300
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-5:4 chip ID: 0bda:5510 class ID: fe01 serial: <filter>
Display: server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: sof-audio-pci
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:06c8 class ID: 0401
Sound Server: ALSA v: k5.10.15-1-MANJARO
Device-1: Qualcomm vendor: Rivet Networks driver: ath11k_pci v: kernel
port: 3000 bus ID: 04:00.0 chip ID: 17cb:1101 class ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus ID: 6-2.4:7 chip ID: 0bda:8153 class ID: 0000 serial: <filter>
IF: enp59s0u2u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-1f274b1bb992 state: down mac: <filter>
IF-ID-2: br-2ca1237e44df state: down mac: <filter>
IF-ID-3: br-56224c823738 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-4: br-5f0a4ad4d3da state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-5: br-70efa3307528 state: down mac: <filter>
IF-ID-6: br-76688f06649a state: down mac: <filter>
IF-ID-7: br-76ce3afe3699 state: down mac: <filter>
IF-ID-8: br-974733e39bf7 state: down mac: <filter>
IF-ID-9: br-c1acdd757ee3 state: down mac: <filter>
IF-ID-10: docker0 state: down mac: <filter>
IF-ID-11: veth0efbfbd state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-12: veth1662011 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-13: veth35dd900 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-14: veth4d3f36a state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-15: veth55e0f29 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-16: veth77a8002 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-17: veth83c7a02 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-18: vethb4a5c72 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-19: vethb9efa51 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-20: vethbc594a9 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-21: vethec3dca2 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-22: vethed06897 state: up speed: 10000 Mbps duplex: full mac: <filter>
Message: No Bluetooth data was found.
Local Storage: total: 953.87 GiB used: 199.52 GiB (20.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2300 NVMe 1024GB
size: 953.87 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 23000020 temp: 30.9 C
scheme: GPT
ID-1: / raw size: 545.9 GiB size: 536.33 GiB (98.25%)
used: 99.71 GiB (18.6%) fs: ext4 block size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-30b4d1c0-50e7-4cf8-a0ef-68c0fd936f99 label: N/A
uuid: 76edf103-7623-49fd-a018-eb8a5c1bf589
ID-2: /boot/efi raw size: 150 MiB size: 146 MiB (97.33%)
used: 94.5 MiB (64.7%) fs: vfat block size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: ESP uuid: 18C0-9A77
ID-3: /var/lib/docker/overlay2/2aa0bf80ef6809e3aaf37cd7b6624bf6aa27d41ff2c9d266ef3bda651ae619d5/merged raw size: N/A size: 536.33 GiB used: 99.71 GiB (18.6%) fs: overlay
source: ERR-102 label: N/A uuid: N/A
ID-4: /var/lib/docker/overlay2/3e5f584279b68dcfc36898e09210acc1eb0097d4d1debac0d9ece013654f5d7d/merged raw size: N/A size: 536.33 GiB used: 99.71 GiB (18.6%) fs: overlay
ID-5: /var/lib/docker/overlay2/43dcfd11ad559afcf23bebae7e16039e807ae3c7cc571871ca37409b3f42ccb5/merged raw size: N/A size: 536.33 GiB used: 99.71 GiB (18.6%) fs: overlay
ID-6: /var/lib/docker/overlay2/6a44b5fac0fb3e43a4884b31b82a3d3856e86238f412dd23302fe528736b5f46/merged raw size: N/A size: 536.33 GiB used: 99.71 GiB (18.6%) fs: overlay
ID-7: /var/lib/docker/overlay2/6c9ecb65fbe82695578be6bbd6c09923d8aa3e2b3002f1bd5bec6d2bcaea149c/merged raw size: N/A size: 536.33 GiB used: 99.71 GiB (18.6%) fs: overlay
ID-8: /var/lib/docker/overlay2/8a87d61ac5227b5df49f8de78fddf0268004fdd3da481ca5f9daa088b7506e28/merged raw size: N/A size: 536.33 GiB used: 99.71 GiB (18.6%) fs: overlay
ID-9: /var/lib/docker/overlay2/9386d4e2e53749a6f6befecd257b28988993075bef9afe2c23196e31c4cafcab/merged raw size: N/A size: 536.33 GiB used: 99.71 GiB (18.6%) fs: overlay
ID-10: /var/lib/docker/overlay2/b4581bca01904ec372b595e1979650a1db08903c192430bb980547ffc6cc0cd3/merged raw size: N/A size: 536.33 GiB used: 99.71 GiB (18.6%) fs: overlay
ID-11: /var/lib/docker/overlay2/cacd6bf2f85bc7ea7f513ce80e858f4e1b8464680aabbfddbd516f35a6f63f94/merged raw size: N/A size: 536.33 GiB used: 99.71 GiB (18.6%) fs: overlay
ID-12: /var/lib/docker/overlay2/fc948f76a94f4100d41021d074334a855341ed76a70de3e8472720247fcf03f1/merged raw size: N/A size: 536.33 GiB used: 99.71 GiB (18.6%) fs: overlay
ID-13: /var/lib/docker/overlay2/fc99c1951b762a0b8d02ef362be30f0a3007c2c664ff353dcfc74cd9c6a35034/merged raw size: N/A size: 536.33 GiB used: 99.71 GiB (18.6%) fs: overlay
ID-14: /var/lib/docker/overlay2/fe8c3d2d55ffaf144e686a7008b54d7cc9c8dcd4bb739b78c4ac92a7f6ad3ac6/merged raw size: N/A size: 536.33 GiB used: 99.71 GiB (18.6%) fs: overlay
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 390.78 GiB fs: bitlocker
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 990 MiB fs: ntfs label: WINRETOOLS
uuid: 6A7C2F897C2F4EDF
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 14.6 GiB fs: ntfs label: Image
uuid: 6ACE2FCFCE2F91FD
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1.33 GiB fs: ntfs
label: DELLSUPPORT uuid: E680A2AC80A28323
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-1:2 info: Shenzhen Goodix FingerPrint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 27c6:533c
class ID: ff00
Hub-2: 1-3:18 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip ID: 2109:2211 class ID: 0900
Device-1: 1-3.2:20 info: Dell Dell DA20 Adapter type: Billboard driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 413c:b080 class ID: 1100
serial: <filter>
Device-2: 1-5:4 info: Realtek Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:5510
Hub-3: 1-13:19 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
chip ID: 2109:2817 class ID: 0900
Device-1: 1-13.1:21 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s chip ID: 046d:c52b class ID: 0300
Device-2: 1-13.3:43 info: Logitech G500s Laser Gaming Mouse type: Mouse,HID
chip ID: 046d:c24e class ID: 0300 serial: <filter>
Device-3: 1-13.5:44 info: Anker USB-C Hub Device type: Billboard driver: N/A
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 291a:8338 class ID: 1100
serial: <filter>
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip ID: 1d6b:0003 class ID: 0900
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-7: 6-1:5 info: VIA Labs USB3.0 Hub ports: 1 rev: 3.1 speed: 5 Gb/s
chip ID: 2109:0211 class ID: 0900
Hub-8: 6-2:6 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip ID: 2109:0817 class ID: 0900
Device-1: 6-2.4:7 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
Hub-9: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-10: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1
System Temperatures: cpu: 56.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1719 fan-2: 1717
Processes: 481 Uptime: 5d 1h 40m wakeups: 689 Init: systemd v: 247
Compilers: gcc: 10.2.0 Packages: 1425 pacman: 1393 lib: 386 flatpak: 22
snap: 10 Shell: Bash (sudo) v: 5.1.0 running in: gnome-terminal inxi: 3.3.01
