Hi, all. I’ve been running the GTK application soundconverter on my Manjaro KDE PC for a long time, without a hitch, and a few weeks ago, it just stopped working, for no apparent reason, as other GTK apps continue to run without a problem. If I run
$soundconverter --help
at the command line, the app seems to be OK, but when I try to launch the application, I can see its icon flash briefly on the task bar, and then disappear, after which HTop does not show it running at all. Any ideas on what I can do to troubleshoot this issue? Incidentally, there’s also KDE’s soundKonverter, which runs fine, except it lacks a wonderful feature soundconverter has, which is to customize the name of your converted (output) sound files any which way you want, something immensely helpful when converting large numbers of files. Any ideas would be greatly appreciated.
Thanks
Operating System: Manjaro Linux KDE Plasma Version: 5.22.5 KDE Frameworks Version: 5.86.0 Qt Version: 5.15.2 Kernel Version: 5.13.19-2-MANJARO (64-bit) Graphics Platform: X11 Processors: 8 × Intel® Core™ i7-4770K CPU @ 3.50GHz Memory: 30.8 GiB of RAM Graphics Processor: Mesa DRI Intel® HD Graphics 4600
$ soundconverter
soundconverter 4.0.1
File “/usr/bin/soundconverter”, line 241, in
gui_main(NAME, VERSION, GLADEFILE, files)
File “/usr/lib/python3.9/site-packages/soundconverter/interface/ui.py”, line 1450, in gui_main
window = SoundConverterWindow(builder)
File “/usr/lib/python3.9/site-packages/soundconverter/interface/ui.py”, line 998, in init
self.prefs = PreferencesDialog(builder, self.widget)
File “/usr/lib/python3.9/site-packages/soundconverter/interface/ui.py”, line 545, in init
self.set_widget_initial_values()
File “/usr/lib/python3.9/site-packages/soundconverter/interface/ui.py”, line 638, in set_widget_initial_values
self.change_mime_type(current_mime_type)
File “/usr/lib/python3.9/site-packages/soundconverter/interface/ui.py”, line 853, in change_mime_type
self.update_example()
File “/usr/lib/python3.9/site-packages/soundconverter/interface/ui.py”, line 739, in update_example
generator.generate_target_uri(sound_file, for_display=True)
File “/usr/lib/python3.9/site-packages/soundconverter/util/namegenerator.py”, line 451, in generate_target_uri
filename = self._get_target_filename(sound_file)
File “/usr/lib/python3.9/site-packages/soundconverter/util/namegenerator.py”, line 430, in _get_target_filename
self.fill_pattern(sound_file, self.basename_pattern),
File “/usr/lib/python3.9/site-packages/soundconverter/util/namegenerator.py”, line 371, in fill_pattern
result = pattern.format(**mapping)
ValueError: Single ‘}’ encountered in format string
I do not believe there’s anything wrong with soundconverter itself, but rather, it appears to be an issue with the KDE version of Manjaro, as this problem showed up after a recent Manjaro update, it had worked perfectly before, for a very long time. In fact, the latest (Sept 24) update of Manjaro introduced another problem. I have Firefox, Brave and Chromium installed, and while Firefox and Brave have continued to work without a problem after this latest update, Chromium now insists on never opening maximized, I have to maximize it manually each and every time. Oh, well, such is life. Thanks.
I am glad to say I have, myself, found a solution to this frustrating problem, Flatpak. I have now regained full use of soundconverter, if only by means of installing its Flatpak version.
Thanks to all who tried to help.
