SebMB
August 20, 2020, 2:11pm
#1
I have recently dualbooted manjaro with Windows 10 as the main OS. I am currently having a problem where the soundcard in Manjaro is not being detected.
So when I run the command sudo aplay -l
I get the output: aplay: device_list:274: no soundcards found...
Would anyone happen to know why this is happening? I have tried updating to the new kernel 5.8 because I had seen that it worked for some people. However for my case nothing changed.
emke
August 20, 2020, 2:23pm
#2
Can you post the output of inxi -Fx
SebMB
August 20, 2020, 2:39pm
#3
Host: sebastiano-vostro5590 Kernel: 5.8.0-2-MANJARO x86_64 bits: 64
compiler: N/A Desktop: KDE Plasma 5.19.4 Distro: Manjaro Linux
Type: Laptop System: Dell product: Vostro 5590 v: N/A
serial: <superuser/root required>
Mobo: Dell model: 051P23 v: A00 serial: <superuser/root required>
UEFI: Dell v: 1.5.1 date: 01/14/2020
ID-1: BAT0 charge: 39.4 Wh condition: 39.4/42.0 Wh (94%)
model: BYD DELL 1VX1H05 status: Full
Topology: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Kaby Lake rev: C L2 cache: 6144 KiB
bogomips: 33615
Speed: 700 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 700 2: 700
3: 700 4: 700 5: 700 6: 700 7: 700 8: 700
Device-1: Intel UHD Graphics vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-6:3
Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.1.5
direct render: Yes
Device-1: Intel vendor: Dell driver: sof-audio-pci bus ID: 00:1f.3
Sound Server: ALSA v: k5.8.0-2-MANJARO
Device-1: Intel Wireless-AC 9462 driver: iwlwifi v: kernel port: 4000
bus ID: 00:14.3
IF: wlp0s20f3 state: up mac: 9c:fc:e8:1e:40:b5
vendor: Dell driver: r8169 v: kernel port: 3000 bus ID: 01:00.0
IF: enp1s0 state: down mac: 70:b5:e8:8e:22:e2
Local Storage: total: 476.94 GiB used: 15.11 GiB (3.2%)
ID-1: /dev/nvme0n1 vendor: Toshiba
model: KBG40ZNS512G NVMe KIOXIA 512GB size: 476.94 GiB
ID-1: / size: 57.42 GiB used: 15.04 GiB (26.2%) fs: ext4
dev: /dev/nvme0n1p7
System Temperatures: cpu: 40.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 235 Uptime: 37m Memory: 7.56 GiB used: 2.48 GiB (32.8%)
Init: systemd Compilers: gcc: 10.1.0 Packages: 1232 Shell: Bash
v: 5.0.18 inxi: 3.1.05
Here it is.
emke
August 20, 2020, 2:49pm
#4
You could try to go back to kernel 5.4 or 4.19 and check if works with those.
Or you could look at this old forum post about the sof-firmware
package since audio device is being detected.
SebMB
August 20, 2020, 3:06pm
#5
Thank you so much, what I did was first I installed and updated sof-firmware
, it then detected the soundcard correctly. However it still wasn’t working.
Then I downgraded to kernel 5.4 and now it is working.
So to get it working I actually had to do both.
Thanks again
system
closed
August 23, 2020, 3:06pm
#6
