Since a week ago my integrated sound card stopped working.
I did a system upgrade but it took some time before I realized it was the software, I was checking hardware at first.
I get the startup log:
$ sudo journalctl -b0 -p4 --no-hostname
-- Logs begin at Mon 2019-12-30 02:47:04 CET, end at Sun 2020-08-16 23:25:15 CEST. --
aug 16 23:00:34 kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
aug 16 23:00:34 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html f>
aug 16 23:00:34 kernel: #5 #6 #7
aug 16 23:00:34 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
aug 16 23:00:34 kernel: ata1.00: supports DRM functions and may not be fully accessible
aug 16 23:00:34 kernel: nvidia: loading out-of-tree module taints kernel.
aug 16 23:00:34 kernel: nvidia: module license 'NVIDIA' taints kernel.
aug 16 23:00:34 kernel: Disabling lock debugging due to kernel taint
aug 16 23:00:34 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 440.100 Fri May 29 08:45:51 UTC 2020
aug 16 23:00:34 kernel: snd_hda_intel 0000:00:1f.3: CORB reset timeout#1, CORBRP = 0
aug 16 23:00:34 kernel: snd_hda_intel 0000:00:1f.3: no codecs found!
aug 16 23:00:36 kernel: snd_hda_intel 0000:00:1f.3: CORB reset timeout#1, CORBRP = 0
aug 16 23:00:37 kernel: kauditd_printk_skb: 49 callbacks suppressed
aug 16 23:00:44 kernel: kauditd_printk_skb: 4 callbacks suppressed
aug 16 23:00:51 org.a11y.Bus[984]: dbus-daemon[984]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=1000 pid=952 comm="xf>
aug 16 23:00:51 org.a11y.Bus[984]: dbus-daemon[984]: Successfully activated service 'org.a11y.atspi.Registry'
aug 16 23:00:51 kernel: kauditd_printk_skb: 6 callbacks suppressed
aug 16 23:00:52 blueman-mechani[1139]: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
And this is my alsa-info.sh: ALSA-info
Tried all the different solutions I’ve found from various Linux distros but with no luck.
I also tried upgrading the kernel with different versions (4.14, 4.19, 5.4, 5.6 and now 5.7)
@stephane, I could not find any bug report section for Manjaro.
Is it for the Arch kernel?
I tried installing 5.3 kernel instead since I saw some people had similar problems with sound missing but it seems to be some race condition.
web searches to find out what this CORB error is did not find much and it was inconclusive
I found 2 discussions on Arch forum with the same error message, but in both cases the discussion did not get anywhere because the fault disappeared before any troubleshooting could be done
this bug report had more explanation, but also ended up unresolved https://bugzilla.kernel.org/show_bug.cgi?id=114341
It appears to be a problem specific to skylake CPU and BIOS firmware in some motherboards
suggest check if there is a firmware update available for this board and update BIOS if possible
thanks for your tip.
The BIOS has not been updated since I bought the board, several years ago so it was a good idea.
I did update the motherboard to the latest version today and the error is still reported during boot up:
-- Logs begin at Tue 2020-01-14 11:47:18 CET, end at Tue 2020-09-08 21:55:19 CEST. --
Sep 08 21:51:47 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html f>
Sep 08 21:51:47 kernel: TAA CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/tsx_async_>
Sep 08 21:51:47 kernel: #5 #6 #7
Sep 08 21:51:47 kernel: resource sanity check: requesting [mem 0xfdffe800-0xfe0007ff], which spans more than pnp 00:08 [mem 0xfdb00000-0xfdffffff]
Sep 08 21:51:47 kernel: caller pmc_core_probe+0x85/0x380 mapping multiple BARs
Sep 08 21:51:47 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT0._GTF.DSSP], AE_NOT_FOUND (20200528/psargs-330)
Sep 08 21:51:47 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT0._GTF due to previous error (AE_NOT_FOUND) (20200528/psparse-529)
Sep 08 21:51:47 kernel: ata1.00: supports DRM functions and may not be fully accessible
Sep 08 21:51:47 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT1._GTF.DSSP], AE_NOT_FOUND (20200528/psargs-330)
Sep 08 21:51:47 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT1._GTF due to previous error (AE_NOT_FOUND) (20200528/psparse-529)
Sep 08 21:51:47 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT3._GTF.DSSP], AE_NOT_FOUND (20200528/psargs-330)
Sep 08 21:51:47 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT3._GTF due to previous error (AE_NOT_FOUND) (20200528/psparse-529)
Sep 08 21:51:47 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT2._GTF.DSSP], AE_NOT_FOUND (20200528/psargs-330)
Sep 08 21:51:47 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT2._GTF due to previous error (AE_NOT_FOUND) (20200528/psparse-529)
Sep 08 21:51:47 kernel: nvidia: loading out-of-tree module taints kernel.
Sep 08 21:51:47 kernel: nvidia: module license 'NVIDIA' taints kernel.
Sep 08 21:51:47 kernel: Disabling lock debugging due to kernel taint
Sep 08 21:51:47 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 450.66 Wed Aug 12 19:42:48 UTC 2020
Sep 08 21:51:47 systemd-udevd[366]: controlC1: Process '/usr/bin/alsactl restore 1' failed with exit code 99.
Sep 08 21:51:47 kernel: snd_hda_intel 0000:00:1f.3: CORB reset timeout#1, CORBRP = 0
Sep 08 21:51:47 kernel: snd_hda_intel 0000:00:1f.3: no codecs found!
Sep 08 21:51:47 systemd-udevd[355]: controlC0: Process '/usr/bin/alsactl restore 0' failed with exit code 99.
Sep 08 21:51:48 systemd-udevd[358]: controlC2: Process '/usr/bin/alsactl restore 2' failed with exit code 99.
Sep 08 21:51:50 kernel: kauditd_printk_skb: 24 callbacks suppressed
Sep 08 21:51:59 lightdm[924]: gkr-pam: unable to locate daemon control file
Sep 08 21:51:59 kernel: kauditd_printk_skb: 4 callbacks suppressed
Sep 08 21:52:01 blueman-mechani[1132]: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
Sep 08 21:52:06 kernel: kauditd_printk_skb: 10 callbacks suppressed
