I installed a Soundblaster Audigy FX today. After the first start it was set to analog stereo and I could also set the audigy as output device. If I switch to “Analog Surround 5.1 Output + Analog Stereo Input”, no sound is played back and I no longer have the option to select the Audigy FX under Playback Device.
Output pacmd list cards
Memory blocks currently allocated: 2, size: 75,4 KiB.
Memory blocks allocated during the whole lifetime: 465899, size: 1,0 GiB.
Memory blocks imported from other processes: 0, size: 0 B.
Memory blocks exported to other processes: 0, size: 0 B.
Total sample cache size: 11,5 KiB.
Default sample spec: s16le 2ch 44100Hz
Default channel map: front-left,front-right
Default sink name: alsa_output.pci-0000_31_00.4.iec958-stereo
Default source name: alsa_output.pci-0000_31_00.4.iec958-stereo.monitor
Memory blocks of type POOL: 2 allocated/264500 accumulated.
Memory blocks of type POOL_EXTERNAL: 0 allocated/132313 accumulated.
Memory blocks of type APPENDED: 0 allocated/0 accumulated.
Memory blocks of type USER: 0 allocated/0 accumulated.
Memory blocks of type FIXED: 0 allocated/186744 accumulated.
Memory blocks of type IMPORTED: 0 allocated/14655 accumulated.
29 module(s) loaded.
index: 0
argument: <>
used: -1
load once: yes
properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "14.2"
index: 1
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore the volume/mute/device state of streams"
index: 2
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore profile of cards"
index: 3
argument: <>
used: -1
load once: yes
properties:
module.description = "Augment the property sets of streams with additional static information"
index: 4
argument: <>
used: -1
load once: yes
properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
index: 5
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect available audio hardware and load matching drivers"
index: 6
argument: <device_id="0" name="pci-0000_29_00.0" card_name="alsa_card.pci-0000_29_00.0" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1">
used: 0
load once: no
properties:
module.description = "ALSA Card"
index: 7
argument: <device_id="1" name="pci-0000_2f_00.1" card_name="alsa_card.pci-0000_2f_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1">
used: 0
load once: no
properties:
index: 8
argument: <device_id="2" name="pci-0000_31_00.4" card_name="alsa_card.pci-0000_31_00.4" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1">
used: 0
load once: no
properties:
index: 9
argument: <channels=2>
used: -1
load once: yes
properties:
module.description = "Adds JACK sink/source ports when JACK is started"
index: 10
argument: <>
used: -1
load once: yes
properties:
module.author = "Frédéric Dalleau, Pali Rohár"
module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
index: 11
argument: <>
used: -1
load once: yes
properties:
module.author = "João Paulo Rechi Vita"
module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
index: 12
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
index: 13
argument: <>
used: -1
load once: yes
properties:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
index: 14
argument: <>
used: -1
load once: no
properties:
module.description = "Native protocol (UNIX sockets)"
index: 15
argument: <>
used: -1
load once: yes
properties:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
index: 16
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore the default sink and source"
index: 17
argument: <>
used: -1
load once: yes
properties:
module.author = "Colin Guthrie"
module.description = "Hält stets ein Ziel geladen, selbst wenn dies ein Null-Ziel ist"
index: 18
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically set device of streams based on intended roles of devices"
index: 19
argument: <>
used: -1
load once: yes
properties:
module.description = "When a sink/source is idle for too long, suspend it"
index: 20
argument: <>
used: -1
load once: yes
properties:
module.description = "Create a client for each ConsoleKit session of this user"
index: 21
argument: <>
used: -1
load once: yes
properties:
module.description = "Create a client for each login session of this user"
index: 22
argument: <>
used: -1
load once: yes
properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
index: 23
argument: <>
used: -1
load once: yes
properties:
module.description = "Mute & cork streams with certain roles while others exist"
index: 24
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect when various filters are desirable"
index: 25
argument: <>
used: -1
load once: yes
properties:
module.description = "Load filter sinks automatically when needed"
index: 26
argument: <display=:0 xauthority=/home/michael/.Xauthority>
used: -1
load once: no
properties:
module.description = "X11 credential publisher"
index: 27
argument: <display=:0 xauthority=/home/michael/.Xauthority session_manager=local/michael-manjaro:@/tmp/.ICE-unix/2100,unix/michael-manjaro:/tmp/.ICE-unix/2100>
used: -1
load once: no
properties:
module.description = "X11 session management"
index: 28
argument: <>
used: -1
load once: no
properties:
module.description = "Command line interface protocol (UNIX sockets)"
3 sink(s) available.
index: 0
driver: <module-alsa-card.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9030
volume: front-left: 62259 / 95% / -1,34 dB, front-right: 62259 / 95% / -1,34 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: no
current latency: 0,00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
Stereo
used by: 0
linked by: 0
configured latency: 0,00 ms; range is 0,50 .. 1999,82 ms
card: 1 <alsa_card.pci-0000_2f_00.1>
module: 7
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "HDMI 4"
alsa.id = "HDMI 4"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "10"
alsa.card = "1"
alsa.card_name = "HDA ATI HDMI"
alsa.long_card_name = "HDA ATI HDMI at 0xfcea0000 irq 82"
device.bus_path = "pci-0000:2f:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:03.1/0000:2d:00.0/0000:2e:00.0/0000:2f:00.1/sound/card1"
device.bus = "pci"
device.vendor.id = "1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "ab38"
device.product.name = "Navi 10 HDMI Audio"
device.string = "hdmi:1,4"
device.buffering.buffer_size = "352768"
device.buffering.fragment_size = "176384"
device.access_mode = "mmap+timer"
device.profile.name = "hdmi-stereo-extra4"
device.profile.description = "Digital Stereo (HDMI 5)"
device.description = "Navi 10 HDMI Audio Digital Stereo (HDMI 5)"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: yes)
properties:
device.product.name = "MSI MAG271CQR"
active port: <hdmi-output-4>
* index: 1
flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9038
volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
volume steps: 65537
muted: no
max request: 0 KiB
max rewind: 0 KiB
monitor source: 1
Stereo
used by: 0
linked by: 0
fixed latency: 100,14 ms
card: 2 <alsa_card.pci-0000_31_00.4>
module: 8
properties:
device.api = "alsa"
alsa.name = "ALC1220 Digital"
alsa.id = "ALC1220 Digital"
alsa.device = "1"
alsa.card = "2"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfcd00000 irq 84"
device.bus_path = "pci-0000:31:00.4"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:31:00.4/sound/card2"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "1487"
device.product.name = "Starship/Matisse HD Audio Controller"
device.string = "iec958:2"
device.buffering.buffer_size = "17664"
device.buffering.fragment_size = "2944"
device.access_mode = "mmap"
device.profile.name = "iec958-stereo"
device.profile.description = "Digital Stereo (IEC958)"
device.description = "Starship/Matisse HD Audio Controller Digital Stereo (IEC958)"
ports:
iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
properties:
active port: <iec958-stereo-output>
index: 4
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 23575 / 36% / -26,64 dB, front-right: 23575 / 36% / -26,64 dB
balance 0,00
volume steps: 65537
muted: no
max request: 0 KiB
max rewind: 0 KiB
monitor source: 4
Stereo
used by: 0
linked by: 0
card: 0 <alsa_card.pci-0000_29_00.0>
module: 6
properties:
device.api = "alsa"
alsa.name = "ALC898 Analog"
alsa.id = "ALC898 Analog"
alsa.device = "0"
alsa.card = "0"
alsa.card_name = "HDA Creative"
alsa.long_card_name = "HDA Creative at 0xfc904000 irq 80"
device.bus_path = "pci-0000:29:00.0"
sysfs.path = "/devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:07.0/0000:29:00.0/sound/card0"
device.bus = "pci"
device.vendor.id = "1102"
device.vendor.name = "Creative Labs"
device.product.id = "0012"
device.product.name = "Sound Core3D [Sound Blaster Recon3D / Z-Series] (SB1570 SB Audigy Fx)"
device.string = "front:0"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Sound Core3D [Sound Blaster Recon3D / Z-Series] (SB1570 SB Audigy Fx) Analog Stereo"
ports:
analog-output-lineout: Line Out (priority 9000, latency offset 0 usec, available: yes)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
active port: <analog-output-lineout>
3 source(s) available.
index: 0
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1030
balance 0,00
volume steps: 65537
muted: yes
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 0
module: 7
properties:
device.description = "Monitor of Navi 10 HDMI Audio Digital Stereo (HDMI 5)"
device.class = "monitor"
alsa.card = "1"
device.bus = "pci"
device.string = "1"
* index: 1
state: SUSPENDED
suspend cause: IDLE
priority: 1030
balance 0,00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 1
module: 8
properties:
device.description = "Monitor of Starship/Matisse HD Audio Controller Digital Stereo (IEC958)"
alsa.card = "2"
device.bus = "pci"
device.string = "2"
index: 4
state: SUSPENDED
suspend cause: IDLE
priority: 1030
balance 0,00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 4
module: 6
properties:
device.description = "Monitor of Sound Core3D [Sound Blaster Recon3D / Z-Series] (SB1570 SB Audigy Fx) Analog Stereo"
alsa.card = "0"
device.bus = "pci"
device.vendor.name = "Creative Labs"Memory blocks currently allocated: 2, size: 75,4 KiB.
index: 0
argument: <>
used: -1
load once: yes
properties:
index: 1
argument: <>
used: -1
load once: yes
properties:
index: 2
argument: <>
used: -1
load once: yes
properties:
index: 3
argument: <>
used: -1
load once: yes
properties:
index: 4
argument: <>
used: -1
load once: yes
properties:
index: 5
argument: <>
used: -1
load once: yes
properties:
index: 6
used: 0
load once: no
properties:
index: 7
used: 0
load once: no
properties:
index: 8
used: 0
load once: no
properties:
index: 9
used: -1
load once: yes
properties:
index: 10
argument: <>
used: -1
load once: yes
properties:
index: 11
argument: <>
used: -1
load once: yes
properties:
index: 12
argument: <>
used: -1
load once: yes
properties:
index: 13
argument: <>
used: -1
load once: yes
properties:
index: 14
argument: <>
used: -1
load once: no
properties:
index: 15
argument: <>
used: -1
load once: yes
properties:
index: 16
argument: <>
used: -1
load once: yes
properties:
index: 17
argument: <>
used: -1
load once: yes
properties:
index: 18
argument: <>
used: -1
load once: yes
properties:
index: 19
argument: <>
used: -1
load once: yes
properties:
index: 20
argument: <>
used: -1
load once: yes
properties:
index: 21
argument: <>
used: -1
load once: yes
properties:
index: 22
argument: <>
used: -1
load once: yes
properties:
index: 23
argument: <>
used: -1
load once: yes
properties:
index: 24
argument: <>
used: -1
load once: yes
properties:
index: 25
argument: <>
used: -1
load once: yes
properties:
index: 26
used: -1
load once: no
properties:
index: 27
used: -1
load once: no
properties:
index: 28
argument: <>
used: -1
load once: no
properties:
index: 0
state: SUSPENDED
suspend cause: IDLE
priority: 9030
balance 0,00
volume steps: 65537
muted: no
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
Stereo
used by: 0
linked by: 0
module: 7
properties:
device.api = "alsa"
alsa.id = "HDMI 4"
alsa.device = "10"
alsa.card = "1"
device.bus = "pci"
ports:
properties:
* index: 1
state: SUSPENDED
suspend cause: IDLE
priority: 9038
balance 0,00
volume steps: 65537
muted: no
max request: 0 KiB
max rewind: 0 KiB
monitor source: 1
Stereo
used by: 0
linked by: 0
module: 8
properties:
device.api = "alsa"
alsa.device = "1"
alsa.card = "2"
device.bus = "pci"
ports:
properties:
index: 4
state: SUSPENDED
suspend cause: IDLE
priority: 9039
balance 0,00
volume steps: 65537
muted: no
max request: 0 KiB
max rewind: 0 KiB
monitor source: 4
Stereo
used by: 0
linked by: 0
module: 6
properties:
device.api = "alsa"
alsa.device = "0"
alsa.card = "0"
device.bus = "pci"
ports:
properties:
properties:
index: 0
state: SUSPENDED
suspend cause: IDLE
priority: 1030
balance 0,00
volume steps: 65537
muted: yes
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 0
module: 7
properties:
alsa.card = "1"
device.bus = "pci"
device.string = "1"
* index: 1
state: SUSPENDED
suspend cause: IDLE
priority: 1030
balance 0,00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 1
module: 8
properties:
alsa.card = "2"
device.bus = "pci"
device.string = "2"
index: 4
state: SUSPENDED
suspend cause: IDLE
priority: 1030
balance 0,00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 4
module: 6
properties:
alsa.card = "0"
device.string = "0"
8 client(s) logged in.
index: 0
driver: <module-systemd-login.c>
owner module: 21
properties:
application.name = "Login Session 2"
systemd-login.session = "2"
index: 2
driver: <protocol-native.c>
owner module: 14
properties:
application.name = "QtPulseAudio:2183"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "34"
application.process.id = "2183"
application.process.user = "michael"
application.process.host = "michael-manjaro"
application.process.binary = "Enpass"
application.language = "de_DE.UTF-8"
window.x11.display = ":0"
application.process.machine_id = "749a0fe833f94d798b1d158904662d44"
application.process.session_id = "2"
index: 4
driver: <module-x11-xsmp.c>
owner module: 27
properties:
application.name = "XSMP Session on KDE as 1019c1a11acff000161305130300000021000015"
xsmp.vendor = "KDE"
xsmp.client.id = "1019c1a11acff000161305130300000021000015"
index: 9
owner module: 14
properties:
application.name = "Thunderbird"
window.x11.screen = "0"
application.process.id = "2307"
application.process.binary = "thunderbird"
application.icon_name = "thunderbird"
index: 10
owner module: 14
properties:
application.name = "QPulse"
application.process.id = "2112"
application.process.binary = "plasmashell"
index: 14
owner module: 14
properties:
application.name = "Chromium input"
application.process.id = "12164"
application.process.binary = "chromium"
application.icon_name = "chromium"
index: 20
owner module: 14
properties:
application.name = "libcanberra"
application.version = "0.30"
application.id = "org.freedesktop.libcanberra"
index: 22
driver: <cli.c>
owner module: 28
properties:
application.name = "UNIX socket client"
3 card(s) available.
index: 0
owner module: 6
properties:
alsa.card = "0"
device.bus = "pci"
device.string = "0"
device.description = "Sound Core3D [Sound Blaster Recon3D / Z-Series] (SB1570 SB Audigy Fx)"
profiles:
input:analog-stereo: Analog Stereo-Eingabe (priority 65, available: no)
output:analog-stereo: Analog Stereo-Ausgabe (priority 6500, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: no)
output:analog-surround-21: Analog Surround 2.1-Ausgabe (priority 1300, available: unknown)
output:analog-surround-21+input:analog-stereo: Analog Surround 2.1-Ausgabe + Analog Stereo-Eingabe (priority 1365, available: no)
output:analog-surround-40: Analog Surround 4.0-Ausgabe (priority 1200, available: unknown)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0-Ausgabe + Analog Stereo-Eingabe (priority 1265, available: no)
output:analog-surround-41: Analog Surround 4.1-Ausgabe (priority 1300, available: unknown)
output:analog-surround-41+input:analog-stereo: Analog Surround 4.1-Ausgabe + Analog Stereo-Eingabe (priority 1365, available: no)
output:analog-surround-50: Analog Surround 5.0-Ausgabe (priority 1200, available: unknown)
output:analog-surround-50+input:analog-stereo: Analog Surround 5.0-Ausgabe + Analog Stereo-Eingabe (priority 1265, available: no)
output:analog-surround-51: Analog Surround 5.1-Ausgabe (priority 1300, available: unknown)
output:analog-surround-51+input:analog-stereo: Analog Surround 5.1-Ausgabe + Analog Stereo-Eingabe (priority 1365, available: no)
off: Aus (priority 0, available: unknown)
active profile: <output:analog-stereo>
sinks:
alsa_output.pci-0000_29_00.0.analog-stereo/#4: Sound Core3D [Sound Blaster Recon3D / Z-Series] (SB1570 SB Audigy Fx) Analog Stereo
sources:
alsa_output.pci-0000_29_00.0.analog-stereo.monitor/#4: Monitor of Sound Core3D [Sound Blaster Recon3D / Z-Series] (SB1570 SB Audigy Fx) Analog Stereo
ports:
analog-input-front-mic: Front Microphone (priority 8500, latency offset 0 usec, available: no)
properties:
analog-input-rear-mic: Rear Microphone (priority 8200, latency offset 0 usec, available: no)
properties:
analog-input-linein: Line In (priority 8100, latency offset 0 usec, available: no)
properties:
properties:
properties:
index: 1
owner module: 7
properties:
alsa.card = "1"
device.bus = "pci"
device.string = "1"
device.description = "Navi 10 HDMI Audio"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI)-Ausgabe (priority 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI)-Ausgabe (priority 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI)-Ausgabe (priority 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2)-Ausgabe (priority 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2)-Ausgabe (priority 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2)-Ausgabe (priority 600, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3)-Ausgabe (priority 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3)-Ausgabe (priority 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3)-Ausgabe (priority 600, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4)-Ausgabe (priority 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4)-Ausgabe (priority 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4)-Ausgabe (priority 600, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5)-Ausgabe (priority 5700, available: unknown)
output:hdmi-stereo-extra5: Digital Stereo (HDMI 6)-Ausgabe (priority 5700, available: no)
output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6)-Ausgabe (priority 600, available: no)
output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6)-Ausgabe (priority 600, available: no)
active profile: <output:hdmi-stereo-extra4>
sinks:
alsa_output.pci-0000_2f_00.1.hdmi-stereo-extra4/#0: Navi 10 HDMI Audio Digital Stereo (HDMI 5)
sources:
alsa_output.pci-0000_2f_00.1.hdmi-stereo-extra4.monitor/#0: Monitor of Navi 10 HDMI Audio Digital Stereo (HDMI 5)
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
properties:
hdmi-output-5: HDMI / DisplayPort 6 (priority 5400, latency offset 0 usec, available: no)
properties:
index: 2
owner module: 8
properties:
alsa.card = "2"
device.bus = "pci"
device.string = "2"
device.description = "Starship/Matisse HD Audio Controller"
profiles:
output:analog-stereo: Analog Stereo-Ausgabe (priority 6500, available: no)
output:analog-surround-21: Analog Surround 2.1-Ausgabe (priority 1300, available: no)
output:analog-surround-40: Analog Surround 4.0-Ausgabe (priority 1200, available: no)
output:analog-surround-41: Analog Surround 4.1-Ausgabe (priority 1300, available: no)
output:analog-surround-50: Analog Surround 5.0-Ausgabe (priority 1200, available: no)
output:analog-surround-51: Analog Surround 5.1-Ausgabe (priority 1300, available: no)
output:iec958-stereo: Digital Stereo (IEC958)-Ausgabe (priority 5500, available: unknown)
output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958)-Ausgabe + Analog Stereo-Eingabe (priority 5565, available: no)
active profile: <output:iec958-stereo>
sinks:
alsa_output.pci-0000_31_00.4.iec958-stereo/#1: Starship/Matisse HD Audio Controller Digital Stereo (IEC958)
sources:
alsa_output.pci-0000_31_00.4.iec958-stereo.monitor/#1: Monitor of Starship/Matisse HD Audio Controller Digital Stereo (IEC958)
ports:
properties:
properties:
properties:
analog-output-lineout: Line Out (priority 9000, latency offset 0 usec, available: no)
properties:
properties:
properties:
0 sink input(s) available.
0 source output(s) available.
1 cache entrie(s) available.
index: 0
Stereo
length: 11776
duration: 0,1 s
volume: n/a
balance 0,00
lazy: no
filename: <n/a>
properties:
media.role = "event"
event.id = "audio-volume-change"
event.description = "Volume Control Feedback Sound"
media.name = "audio-volume-change"
media.filename = "/usr/share/sounds/freedesktop/stereo/audio-volume-change.oga"
