How do I hardbind Super
+ Tab
to Show Desktop Grid? When I press Tab
it cancels out the custom input. I even tried exporting scheme and editing file than importing scheme but that doesn’t work either.
On my system here, Meta+Tab is bound to switching between Activities. Perhaps you should pick another combination?
I have Meta+F11 for the desktop grid here, although to be fair, I never use that shortcut because I normally bring up the desktop grid by hitting the left edge of the screen with the mouse pointer.
Hi!
I had the same problem, finally I did set meta+g
I did the following (work around):
Open
System Settings > Workspace Behavior > Desktop Effects
, and search for grid.Desktop Grid
was displayed and it is checked. -
Click on the
Desktop Grid
. On the right hand side there are two icons. The last one is the settings for theDesktop Grid
. ClickDesktop Grid
settings. -
The Kwin shortcut key is shown (
Ctrl+F8
). Click to the right ofCtrl+F8
in theGlobal Alternate
column. I see the following:
x Default: None
O Custom: None
Note: Imagine two radio buttons above. Initially Default
is selected.
Select the
Custom
radio button by clicking it. -
Click the textbox with the word
None
in it. -
Type
Meta Tab
, and in my case a popup was displayed asking me to reassign it.
When I go to System Settings > Shortcuts > Global Shortcuts
, type kwin, and click on KWin
and scroll down to Show Desktop Grid
, it shows Meta+Tab, Ctrl+F8
. I removed the Meta+Tab
and tried to enter the shortcut here. You are right, the Tab
key is not accepted as part of the shortcut, but actually acted upon (tabbing to the next control). It’s a known bug.
Bug 423080 - Impossible to use tab as custom shortcut anymore
https://bugs.kde.org/show_bug.cgi?id=423080
Reference:
Common Keyboard Shortcuts
https://docs.kde.org/trunk5/en/applications/fundamentals/kbd.html
This post reminded me that kde5 doesn’t support different wallpaper on virtual desktops any more
hi!
To fix that you can use vallpaper, it’s a desktop type
. You can get it from get a new Wallpapper
in desktop configuration
That has been relegated to the Activities now. Activities can different wallpapers, as well as different desktop widgets and different privacy settings.
