Sound Unusual Behaviour
Hi All,
I have been using Manjaro for few weeks and I am having this problem where when I play any audio via VLC player or video via Firefox/Chrome browser, there is no audio. The video plays but there is no sound. So I have to go sound settings and change from current profile for example - Audio Stereo Output to Audio Stereo Duplex. Then I can hear audio. When the video stops playing or I have to play another video, I have to change the profile again from Audio Stereo Duplex to Audio Stereo Ouput. Another unsual behaviour is that when I play a youtube video, after changing the profile, the audio works. Then when I close the browser, and open VLC player, the audio does not work. I have to change the profile again. So I am not sure what changes I have to do to my settings to ensure this does not happen. I am using PulseAudio. Since I am new to Manjaro I am not sure what settings I have to make to make audio work permanently.
Thank you!
Please post more information about system and audio devices detected in PulseAudio
inxi -SMAa
pactl list cards
pacmd dump
Thank you for responding!
Here is the output of those three commands.
For inxi -SMAa:
  Host: GraySkull Kernel: 6.12.34-1-MANJARO arch: x86_64 bits: 64
    compiler: gcc v: 15.1.1 clocksource: tsc avail: hpet,acpi_pm
    root=UUID=819d27f0-016e-4f13-9c49-241cfe8ff454 rw splash
    udev.log_priority=3 nvidia-drm.modset=1
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.15.0
  Type: Desktop System: Gigabyte product: Z270X-Ultra Gaming v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: Z270X-Ultra Gaming-CF v: x.x
    serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends v: F4 date: 02/10/2017
  Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a2f0 class-ID: 0403
  Device-2: NVIDIA GP104 High Definition Audio vendor: eVga.com.
    bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
  Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.2:7
    chip-ID: 0d8c:0005 class-ID: 0300 serial: 201306
  API: ALSA v: k6.12.34-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.5 status: active with: wireplumber
    status: active tools: pw-cat,pw-cli,wpctl
  Server-4: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
For pactl list cards:
## Configuration dump generated at Wed Jun 25 14:04:59 2025
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="2" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="0" name="usb-BLUE_MICROPHONE_Blue_Snowball_201306-00" card_name="alsa_card.usb-BLUE_MICROPHONE_Blue_Snowball_201306-00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="1" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_01_00.1.hdmi-stereo 0x8a3d
set-sink-mute alsa_output.pci-0000_01_00.1.hdmi-stereo no
suspend-sink alsa_output.pci-0000_01_00.1.hdmi-stereo yes
set-sink-volume alsa_output.pci-0000_00_1f.3.analog-surround-21 0x68e4
set-sink-mute alsa_output.pci-0000_00_1f.3.analog-surround-21 no
suspend-sink alsa_output.pci-0000_00_1f.3.analog-surround-21 no
set-source-volume alsa_input.usb-BLUE_MICROPHONE_Blue_Snowball_201306-00.mono-fallback 0x10000
set-source-mute alsa_input.usb-BLUE_MICROPHONE_Blue_Snowball_201306-00.mono-fallback no
suspend-source alsa_input.usb-BLUE_MICROPHONE_Blue_Snowball_201306-00.mono-fallback yes
set-source-volume alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor no
suspend-source alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor yes
set-source-volume alsa_output.pci-0000_00_1f.3.analog-surround-21.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1f.3.analog-surround-21.monitor no
suspend-source alsa_output.pci-0000_00_1f.3.analog-surround-21.monitor no
set-card-profile alsa_card.pci-0000_01_00.1 output:hdmi-stereo
set-card-profile alsa_card.usb-BLUE_MICROPHONE_Blue_Snowball_201306-00 input:mono-fallback
set-card-profile alsa_card.pci-0000_00_1f.3 output:analog-surround-21
set-default-sink alsa_output.pci-0000_00_1f.3.analog-surround-21
set-default-source alsa_input.usb-BLUE_MICROPHONE_Blue_Snowball_201306-00.mono-fallback
### EOF
For pacmd-dump:
   Card #0
        Driver: module-alsa-card.c
        Owner Module: 6
        Properties:
                alsa.card = "2"
                alsa.card_name = "HDA NVidia"
                alsa.long_card_name = "HDA NVidia at 0xef080000 irq 17"
                device.bus_path = "pci-0000:01:00.1"
                sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2"
                device.bus = "pci"
                device.vendor.id = "10de"
                device.vendor.name = "NVIDIA Corporation"
                device.product.id = "10f0"
                device.product.name = "GP104 High Definition Audio Controller"
                device.string = "2"
                device.description = "GP104 High Definition Audio Controller"
                module-udev-detect.discovered = "1"
                device.icon_name = "audio-card-pci"
        Profiles:
                output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 38668, available: yes)
                output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
                output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
                output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
                output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
                output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
                output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
                output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
                output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
                output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
                off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
        Active Profile: output:hdmi-stereo
        Ports:
                hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, available)
                        Properties:
                                device.product.name = "LG ULTRAGEAR"
                        Part of profile(s): output:hdmi-stereo
                hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, not available)
                        Properties:
                        Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
                hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, not available)
                        Properties:
                        Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
                hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, not available)
                        Properties:
                        Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
Card #1
        Owner Module: 7
        Properties:
                alsa.card = "0"
                alsa.card_name = "Blue Snowball"
                alsa.long_card_name = "BLUE MICROPHONE Blue Snowball at usb-0000:00:14.0-2.2, full speed"
                alsa.driver_name = "snd_usb_audio"
                device.bus_path = "pci-0000:00:14.0-usb-0:2.2:1.0"
                sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2.2/1-2.2:1.0/sound/card0"
                udev.id = "usb-BLUE_MICROPHONE_Blue_Snowball_201306-00"
                device.bus = "usb"
                device.vendor.id = "0d8c"
                device.vendor.name = "C-Media Electronics, Inc."
                device.product.id = "0005"
                device.product.name = "Blue Snowball"
                device.serial = "BLUE_MICROPHONE_Blue_Snowball_201306"
                device.string = "0"
                device.description = "Blue Snowball"
                device.icon_name = "audio-card-usb"
        Profiles:
                input:mono-fallback: Mono Input (sinks: 0, sources: 1, priority: 1, available: yes)
        Active Profile: input:mono-fallback
        Ports:
                analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability unknown)
                        Properties:
                        Part of profile(s): input:mono-fallback
Card #2
        Owner Module: 8
        Properties:
                alsa.card = "1"
                alsa.long_card_name = "HDA Intel PCH at 0xef240000 irq 145"
                sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card1"
                device.bus = "pci"
                device.vendor.id = "8086"
                device.product.id = "a2f0"
                device.product.name = "200 Series PCH HD Audio"
                device.string = "1"
                device.description = "Built-in Audio"
        Profiles:
                input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
                output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 39268, available: yes)
                output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
                output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 34068, available: yes)
                output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: yes)
                output:analog-surround-40: Analog Surround 4.0 Output (sinks: 1, sources: 0, priority: 33968, available: yes)
                output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: yes)
                output:analog-surround-41: Analog Surround 4.1 Output (sinks: 1, sources: 0, priority: 34068, available: yes)
                output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: yes)
                output:analog-surround-50: Analog Surround 5.0 Output (sinks: 1, sources: 0, priority: 33968, available: yes)
                output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: yes)
                output:analog-surround-51: Analog Surround 5.1 Output (sinks: 1, sources: 0, priority: 34068, available: yes)
                output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: yes)
                output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 38268, available: yes)
                output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5565, available: yes)
                output:iec958-ac3-surround-51: Digital Surround 5.1 (IEC958/AC3) Output (sinks: 1, sources: 0, priority: 300, available: yes)
                output:iec958-ac3-surround-51+input:analog-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 365, available: no)
        Active Profile: output:analog-surround-21
        Ports:
                analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, not available)
                        Properties:
                        Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-ac3-surround-51+input:analog-stereo
                analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, not available)
                        Properties:
                analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, not available)
                analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, available)
                        Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo
                analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, not available)
                        Properties:
                iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
                        Part of profile(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo
Data shows onboard audio is set to use profile for surround 2.1 output
Card #2
        Properties:
                alsa.card = "1"
Change card profile for onboard audio card to off (to clear any old user settings for the card that might be causing problems)
pactl set-card-profile alsa_card.pci-0000_01_00.1 off
then change the profile to stereo output
pactl set-card-profile alsa_card.pci-0000_01_00.1 output:analog-stereo
and set the default sink output
pactl set-default-sink alsa_output.pci-0000_00_1f.3.analog-stereo
If audio from VLC or browser is still not working as expected, check audio from applications to PulseAudio
pactl list sink-inputs
and from PulseAudio to ALSA
pactl list sinks
Thanks I will try this out and post the result here.
I tried using the command you gave, I was able to execute the first code.
But when I tried executing the second command,
I get the error “Failure: no such entity”
How do I proceed?
My bad - previous commands were using card name for HDA NVidia card alsa_card.pci-0000_01_00.1
Use these commands to change profile for HDA Intel PCH card
pactl set-card-profile alsa_card.pci-0000_00_1f.3 off
pactl set-card-profile alsa_card.pci-0000_00_1f.3 output:analog-stereo
Command to set-default-sink was using correct card name and available profile
I tried the commands, but it is still the same no change. I still have to change the profile, every time I want to listen. For example, I play a video in YouTube in Firefox, it does not play till I change the profile. Same thing happens when I play video via VLC.
Another strange thing I noticed now is that before I change the profile, if I mute the YouTube video it starts to play, but when I unmute, it stops playing.
I recently update my kernel when it asked me to. Could that be the reason?
Not related to this, I get this number of updates to be made called OS updates. Some of the packgage names are org.freedesktop.Platform but even when “apply” they keep popping up again and again. Is that a bug?
Thank you for your help!
No, it’s not a bug.
It is, however, something you are perhaps not aware of;
Because flatpak applications require supporting software, that must also be regularly updated; along with packages from the official Manjaro repositories or from the AUR (if it’s used).
This should take care of it:
flatpak update
Thank you Soundofthunder!
I actually searched the forum and found the solution similar to what you have mentioned here. I tried updating the flatpak using the command you mentioned but it showed some error (which I am not able to produce here).
However, I went to the Add/Remove Software → Preferences → and checked Cache. The option “Remove only the uninstalled package” was not enabled. Once I enabled it, update packages did not show again.
But this sound issue is really bothering me. I am not really sure why it is making me switch profile everytime I want to watch of video. I tried searching the forum and google but not able to see if anyone has similar problem. It is driving me nuts!
I am not really sure about what may be causing this problem because data posted so far is not showing anything problematic, except for using 2.1 surround profile instead of stereo profile.
I suggest:
  1. Check audio playback from PulseAudio to ALSA
pactl list sinks
  1. Check for errors in PulseAudio systemd units
systemtctl --user -l --no-pager status pulseaudio.socket pulseaudio.service
  1. Check PulseAudio connections to audio playback devices
sudo fuser -av /dev/snd/pcm*p
Most welcome.
Quick tip:-
Use @ to mention another forum member. As you will see, the character triggers a small modal and you can select participating members from the dropdown.
This has a few advantages; not only does it prevent you from spelling a member’s name incorrectly, but also it notifies them that they were mentioned.
Otherwise, we may never know.
Thank you @soundofthunder and @nikgnomic I will try these commands.
The interesting thing is I found a similar issue in Arch forum two years ago but in that case there was pipewire and pulse audio both installed and it was suggested that removing one will fix the issue. However, the solution/methods to fix it was not clearly defined.
I will once again check PulseAudio connections. If not, then I have no other option to reinstall (but that is no guarantee that this issue will not appear again!)… the frustrating thing is that when I tried Manjaro in VM it worked flawlessly! Anyways… will check again!
Manjaro forum had similar misinformation from PipeWire evangelists a few years ago
pipewire is a multimedia server and pulseaudio is an audio server, but inxi used to report that they were both sound servers, but there is no sound (acoustic waves) in a digital system, only audio that requires a transducer (headphones/speakers) to produce audible sound
pulseaudio cannot be removed, but it can be replaced by pipewire-pulse.
Manjaro has manjaro-pipewire and manjaro-pulse metapackages to switch between audio servers.
If system is booted from a live ISO and audio is not working, issue is likely to be in ALSA rather than a software audio server.
Reinstalling pipewire-pulse might be a good workaround for a pulseaudio issue, but not for ALSA
That is the right direction:
This is how pipewire looks like with pipewire-pulse and pipewire-alsa:
  Server-3: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
Normally you would remove Pulseaudio in favor of Pipewire or vice versa.
See here:
Just a quick update, after I reinstalled, everything works fine. The audio issue is gone. Before I reinstalled, I tried installing Pipewire-pulse but that did not make any changes/improvement. The audio still didn’t work/paused until I changed the profile each time I want to have audio. I sincerely hope I don’t get this issue anymore.
Thank you all for the help!
For clarity, do you mean that you reinstalled Manjaro; or was it pipewire you reinstalled?
If Manjaro, this topic can be closed without a solution, as reinstalling an OS never solved the actual issue, but works around it.
The presumption is that you reinstalled the OS. If it’s not the case, just ask a Moderator (via PM) to re-open the topic, if it’s needed.
For reference, it’s usually expected that you mark the post of whosoever helped you the most, as the solution to a topic you create; that is, in all cases where an actual solution was found (the button appears under every post).
