Hi,
This morning my sound stopped after working fine last time I ran my machine.
I was a long time ubuntu user and recently switched to Manjaro with i3. I really like it but I’ve had a hard time getting sound to work.
I’ve tried to poke around and see what’s happening but a lot of it is going over my head.
Any tips on how to troubleshoot the my audio problems?
output of inxi --full --admin --filter --width
Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=f5363a98-f818-48a4-b1b7-833a4c903525 rw quiet apparmor=1
security=apparmor resume=UUID=39206d97-5be9-454b-a039-f602924ae725
udev.log_priority=3
Desktop: i3 v: 4.23 with: i3bar tools: xautolock avail: i3lock vt: 7
dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Convertible System: HP product: HP EliteBook x360 1030 G8 Notebook PC
1H9W6Av v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 8720 v: KBC Version 38.3F.00 serial: <superuser required>
part-nu: 1H9W6AV uuid: <superuser required> UEFI: HP v: T93 Ver. 01.13.01
date: 03/31/2023
ID-1: BAT0 charge: 9.4 Wh (16.3%) condition: 57.5/78.4 Wh (73.3%) volts: 7.2
min: 7.7 model: Hewlett-Packard Primary type: Li-ion serial: <filter>
status: discharging cycles: 277
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
status: discharging
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xB4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 710 high: 1091 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1091 2: 996 3: 962 4: 400
5: 400 6: 400 7: 400 8: 1031 bogomips: 38720
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: HDMI-A-1,eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-2,
HDMI-A-3, HDMI-A-4, HDMI-A-5 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: Quanta HP HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 0408:5349
Display: x11 server: X.org v: 1.21.1.11 compositor: Picom v: git-89c2c
driver: X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right model: Asus VS248
serial: <filter> built: 2011 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: InfoVision Optronics/Kunshan
0x8c78 serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 158
gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9
modes: 1920x1080
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 14.95 GiB unified: yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.5.13-7-MANJARO status: kernel-api with: aoss
Server-2: PulseAudio v: 17.0 status: active tools: pacat,pactl
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
Info: services: NetworkManager,wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:6 chip-ID: 8087:0026
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 27.49 GiB (5.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1006 size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 459.8 GiB size: 451.51 GiB (98.20%) used: 27.49 GiB (6.1%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 16.84 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 15.31 GiB used: 4.55 GiB (29.7%)
Processes: 233 Power: uptime: 36m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 6.12 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1132 libs: 341 tools: pamac,yay Compilers:
clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 running-in: urxvtd inxi: 3.3.33
Thanks in advance
