Hello,
My computer turned off for no reason yesterday and now the sound does not work at all. The default sound card on alsamixer has become “Loopback” and the only other option is Intel. Switching to Intel card doesn’t restore the sound either, I believe this is for the HDMI port. I am pretty sure I have a realtek card on my laptop but it does not show up in alsamixer.
This is my output after running alsa-info.sh
https://petercrenshaw.myeu.cloud/index.php/s/HtntJyLgzNWQKc4
ddns
27 October 2020 16:34
2
I have acer Aspire E5-771G and in my alsa-info.txt first difference is in “Sound Servers on this system” secction, i have this:
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [HDMI ]: HDA-Intel - HDA Intel HDMI
HDA Intel HDMI at 0xb3710000 irq 49
1 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xb3714000 irq 50
In your log seems like alsa-info not detects pulseaudio.
Loopback connections have taken default position as card 0
Onboard audio device is now card 1
**** List of PLAYBACK Hardware Devices ****
card 1: PCH [HDA Intel PCH], device 0: ALC255 Analog [ALC255 Analog]
(card 1 also has additional devices listed for HDMI audio)
Most of the the audio controls appear to be OK but the Master control is shown as muted [off]
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 81 [93%] [-4.50dB] [off]
suggest you go to ALSA controls
alsamixer --card=1
if Master control is shown as muted [MM] Press M to unmute it [OO]
then exit alsamixer and save ALSA settings
sudo alsactl store
If you want to remove the ALSA Loopback connections use this
sudo modprobe -r snd-aloop
Thank you for reply. The issue like you pointed out was that loopback became card 0 and all my applications were trying to use the default card. I tried to set the intel card as 0 and the loopback card as 1 as mentioned in this archwiki article.
https://wiki.archlinux.org/index.php/Advanced_Linux_Sound_Architecture#Setting_the_default_sound_card_via_defaults_node
That fixed it.
