Hi, I need you help. Sound not wouking. DVI-> HDMI
Welcome to Manjaro forum
Please post more information about system
inxi -Fazy
And more information about audio devices
pactl list cards
inxi -Fazy
Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=7e5ac013-1a43-4ba3-8e4c-296e3818bceb rw quiet splash
resume=UUID=7cad1afc-738f-496a-87b3-8be29aead997 udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop System: HP product: HP 280 G2 MT (Non-Legacy) v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: HP model: 2B5E v: 1.00 serial: <superuser required>
part-nu: V7Q77EA#ABD uuid: <superuser required> UEFI: AMI v: A0.58
date: 04/28/2021
Info: model: Intel Core i3-6100 bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x5E (94) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2975 high: 3700 min/max: 800/3700 scaling:
driver: intel_pstate governor: powersave cores: 1: 3700 2: 3700 3: 3700
4: 800 bogomips: 29608
Type: gather_data_sampling status: Vulnerable: No microcode
vulnerable
Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: HDMI-A-1 empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:1912
class-ID: 0300
Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 046d:0825
class-ID: 0102 serial: <filter>
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: HDMI-A-1 res: 1920x1080 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
device-ID: 8086:1912 memory: 7.35 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
name: Intel HD Graphics 530 (SKL GT2) driver: mesa intel v: 24.0.9-manjaro1.1
device-ID: 8086:1912 surfaces: xcb,xlib,wayland
Device-1: Intel 100 Series/C230 Series Family HD Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
API: ALSA v: k6.6.32-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, smbd, systemd-timesyncd
Local Storage: total: 912.89 GiB used: 27.78 GiB (3.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Gigabyte model: GP-GSTFS31480GNTD
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 61.5 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500413AS
tech: HDD rpm: 7200 serial: <filter> fw-rev: HP63 scheme: GPT
ID-1: / raw-size: 438.03 GiB size: 430.09 GiB (98.19%) used: 27.78 GiB (6.5%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 324 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 40.0 C pch: 49.5 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 8 GiB note: est. available: 7.53 GiB used: 5.05 GiB (67.1%)
Processes: 250 Power: uptime: 1h 32m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1514 libs: 459 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
pactl list cards
Card #42
Driver: alsa
Owner Module: n/a
Properties:
api.acp.auto-port = "false"
api.alsa.card = "0"
api.alsa.card.longname = "USB Device 0x46d:0x825 at usb-0000:00:14.0-6, high speed"
api.alsa.card.name = "USB Device 0x46d:0x825"
api.alsa.path = "hw:0"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1.Priority = "-20"
device.api = "alsa"
device.bus = "usb"
device.bus-id = "usb-046d_0825_97919D00-02"
device.bus_path = "pci-0000:00:14.0-usb-0:6:1.2"
device.description = "Webcam C270"
device.enum.api = "udev"
device.form_factor = "webcam"
device.icon_name = "camera-web-analog-usb"
device.name = "alsa_card.usb-046d_0825_97919D00-02"
device.nick = "USB Device 0x46d:0x825"
device.plugged.usec = "6067036"
device.product.id = "0x0825"
device.product.name = "Webcam C270"
device.serial = "046d_0825_97919D00"
device.subsystem = "sound"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.2/sound/card0"
device.vendor.id = "0x046d"
device.vendor.name = "Logitech, Inc."
media.class = "Audio/Device"
factory.id = "14"
client.id = "40"
object.id = "42"
object.serial = "42"
object.path = "alsa:pcm:0"
alsa.card = "0"
alsa.card_name = "USB Device 0x46d:0x825"
alsa.long_card_name = "USB Device 0x46d:0x825 at usb-0000:00:14.0-6, high speed"
alsa.driver_name = "snd_usb_audio"
alsa.mixer_name = "USB Mixer"
alsa.components = "USB046d:0825"
alsa.id = "U0x46d0x825"
device.string = "0"
Profiles:
off: Вимкнено (sinks: 0, sources: 0, priority: 0, available: yes)
pro-audio: Професійний звук (sinks: 0, sources: 1, priority: 1, available: yes)
input:mono-fallback: Моно-вхід (sinks: 0, sources: 1, priority: 1, available: yes)
Active Profile: input:mono-fallback
Ports:
analog-input-mic: Мікрофон (type: Mic, priority: 8700, latency offset: 0 usec, availability unknown)
Properties:
port.type = "mic"
card.profile.port = "0"
Part of profile(s): input:mono-fallback
Card #43
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "1"
api.alsa.card.longname = "HDA Intel PCH at 0xdf120000 irq 129"
api.alsa.card.name = "HDA Intel PCH"
api.alsa.path = "hw:1"
api.dbus.ReserveDevice1 = "Audio1"
device.api = "alsa"
device.bus = "pci"
device.description = "Вбудоване аудіо"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_00_1f.3"
device.nick = "HDA Intel PCH"
device.plugged.usec = "5094457"
device.product.id = "0xa170"
device.product.name = "100 Series/C230 Series Chipset Family HD Audio Controller"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card1"
device.vendor.id = "0x8086"
factory.id = "14"
client.id = "40"
object.id = "43"
object.serial = "43"
object.path = "alsa:pcm:1"
alsa.card = "1"
alsa.long_card_name = "HDA Intel PCH at 0xdf120000 irq 129"
alsa.mixer_name = "Realtek ALC221"
alsa.components = "HDA:10ec0221,103c2b5e,00100103"
alsa.id = "PCH"
device.string = "1"
Profiles:
output:analog-stereo+input:analog-stereo: Аналогове двобічне стерео (sinks: 1, sources: 1, priority: 6565, available: yes)
output:analog-stereo: Аналогове стерео-вихід (sinks: 1, sources: 0, priority: 6500, available: yes)
input:analog-stereo: Аналогове стерео-вхід (sinks: 0, sources: 1, priority: 65, available: no)
pro-audio: Професійний звук (sinks: 1, sources: 2, priority: 1, available: yes)
Active Profile: output:analog-stereo+input:analog-stereo
Ports:
analog-input-linein: Лінійний вхід (type: Line, priority: 8100, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
port.type = "line"
port.availability-group = "Legacy 1"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo
analog-input-headset-mic: Мікрофон гарнітури (type: Headset, priority: 8800, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "headset"
port.availability-group = "Legacy 2"
card.profile.port = "1"
analog-output-lineout: Лінійний вихід (type: Line, priority: 9000, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "line"
port.availability-group = "Legacy 3"
card.profile.port = "2"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
analog-output-speaker: Акустичні колонки (type: Speaker, priority: 10000, latency offset: 0 usec, availability group: Legacy 4, availability unknown)
Properties:
port.type = "speaker"
port.availability-group = "Legacy 4"
card.profile.port = "3"
analog-output-headphones: Аналогові навушники (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "headphones"
card.profile.port = "4"
Isn’t DVI a video-only connector?
Or what do you connect to what?
only DVI (desktop) → HDMI (LG M2380).
If I connect this monitor to another PC in the same way, then everything works
pactl list cards
shows one output profile for analog audio
with 2 analog output ports
Online scans for similar systems show ALSA data has one playback device for Analog audio
HW probe of HP 2B5E Desktop Computer (280 G2 MT (Non-Legacy)) #42896b55bb: aplay
**** List of PLAYBACK Hardware Devices **** card 0: PCH [HDA Intel PCH], device 0: ALC221 Analog [ALC221 Analog] Subdevices: 1/1 Subdevice #0: subdevice #0
No digital output available in ALSA for DVI playback
The original specification for DVI connections does not include audio support. But modern GPU hardware uses HDMI hardware internally that can support audio playback via DVI, HDMI or DisplayPort
GPU card on my system has DVI-D, HDMI and DisplayPort connections, but ALSA only recognises them as HDMI devices
I suspect that the other system is using a proprietary OS, or possibly using the alternate Linux driver snd_soc_avs
