Kernel 5.9.11-3 not working on my system
5.8.18-1 is running fine. But when i try to boot into 5.9, it hangs during boot and prints some message and restarts too quickly for me to read. I think it’s something about watchdog.
How can i find out what the problem with running that kernel is?
5.8 is End of life.
Let’s see what’s the issue is.
can you return
sudo journalctl -b0 -p4 ( -b -1 boot before , etc ..)
Dec 22 09:30:24 nyx-pc kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Dec 22 09:30:24 nyx-pc kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dec 22 09:30:24 nyx-pc kernel: ata2.00: supports DRM functions and may not be fully accessible
Dec 22 09:30:24 nyx-pc kernel: ata2.00: NCQ Send/Recv Log not supported
Dec 22 09:30:24 nyx-pc kernel: usb: port power management may be unreliable
Dec 22 09:30:24 nyx-pc systemd-modules-load[244]: Failed to find module 'platform-integrity'
Dec 22 09:30:24 nyx-pc systemd-modules-load[244]: Failed to find module 'nvidia'
Dec 22 09:30:24 nyx-pc systemd-modules-load[244]: Failed to find module 'nvidia-drm'
Dec 22 09:30:25 nyx-pc kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
Dec 22 09:30:25 nyx-pc kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
Dec 22 09:30:25 nyx-pc kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 0
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 1
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 2
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 3
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 4
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 6
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 8
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 9
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 10
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 11
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 15
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 16
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 18
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 19
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 20
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 21
Dec 22 09:30:25 nyx-pc kernel: iwlwifi 0000:04:00.0: WRT: Overriding region id 28
Dec 22 09:30:25 nyx-pc kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
Dec 22 09:30:25 nyx-pc systemd[1]: postgresql.service: Failed with result 'exit-code'.
Dec 22 09:30:25 nyx-pc systemd[1]: Failed to start PostgreSQL database server.
Dec 22 09:30:26 nyx-pc kernel: nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
Dec 22 09:30:26 nyx-pc kernel: ucsi_ccg 0-0008: i2c_transfer failed -110
Dec 22 09:30:26 nyx-pc kernel: ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
Dec 22 09:30:26 nyx-pc kernel: ucsi_ccg: probe of 0-0008 failed with error -110
i switched 430 drivers to 455 drivers. now it works. thanks for showing me journalctl :smiley:
