Lameli
10 September 2023 20:42
1
System info
Kernel: 6.5.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=d2a55327-f83c-40b1-8b9a-bc1b1919926a rw quiet
cryptdevice=UUID=4eee9d9f-29e3-4002-95e1-a9b95a5beeff:luks-4eee9d9f-29e3-4002-95e1-a9b95a5beeff
root=/dev/mapper/luks-4eee9d9f-29e3-4002-95e1-a9b95a5beeff splash
resume=/dev/mapper/luks-560ef57a-391b-4666-a575-d79d2bd0f88f
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: ASUSTeK product: ROG Strix G614JU_G614JU v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G614JU v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G614JU.317 date: 07/12/2023
ID-1: BAT0 charge: 89.0 Wh (100.0%) condition: 89.0/90.0 Wh (98.9%)
volts: 17.7 min: 16.0 model: AS3GYFG3KC R220358 type: Unknown
serial: <filter> status: full
Info: model: 13th Gen Intel Core i9-13980HX bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
microcode: 0x119
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 2210 high: 2400 min/max: 800/5400:5600:4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 930 2: 2400 3: 2400
4: 2400 5: 873 6: 2400 7: 2400 8: 2400 9: 2400 10: 2400 11: 2400 12: 900
13: 840 14: 2400 15: 2400 16: 2400 17: 2400 18: 2400 19: 2400 20: 2400
21: 2400 22: 2400 23: 2400 24: 2400 25: 2400 26: 2400 27: 2400 28: 2400
29: 2400 30: 2400 31: 2400 32: 2400 bogomips: 154880
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Raptor Lake-S UHD Graphics vendor: ASUSTeK driver: i915
v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 0000:00:02.0
chip-ID: 8086:a788 class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile] vendor: ASUSTeK
driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022-23+ bus-ID: 0000:01:00.0
chip-ID: 10de:28e1 class-ID: 0300
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:4 chip-ID: 322e:2122
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.48x10.91")
s-diag: 523mm (20.6") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: TL160ADMP03-0 built: 2022 res: 2560x1600 dpi: 188
gamma: 1.2 size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10
modes: 2560x1600
API: OpenGL v: 4.6 Mesa 23.1.6-3 renderer: Mesa Intel Graphics (RPL-S)
direct-render: Yes
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:7a50
class-ID: 0403
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:22be class-ID: 0403
API: ALSA v: k6.5.1-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.79 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 0000:00:14.3
chip-ID: 8086:7a70 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: 4000 bus-ID: 0000:6c:00.0
IF: enp108s0 state: down mac: <filter>
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0033 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 953.87 GiB used: 126.84 GiB (13.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2400 MTFDKBA1T0QFM
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: V3MA003 temp: 41.9 C
scheme: GPT
ID-1: / raw-size: 936.8 GiB size: 921.02 GiB (98.32%)
used: 126.84 GiB (13.8%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-4eee9d9f-29e3-4002-95e1-a9b95a5beeff
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 16.77 GiB used: 512 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-560ef57a-391b-4666-a575-d79d2bd0f88f
System Temperatures: cpu: 38.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2500
Processes: 491 Uptime: 4h 19m wakeups: 4 Memory: total: 16 GiB note: est.
available: 15.24 GiB used: 7.25 GiB (47.5%) Init: systemd v: 253
Packages: 1282 pm: pacman pkgs: 1258 libs: 353 tools: pamac pm: flatpak
pkgs: 24 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.29
When installing Linux, the sound is not working on my Asus ROG Strix G16 (2023) G614JU
This is a known issue . I tried solving it using this guide , but failed, even after following all the steps, still the sound didn’t work.
I think it’s better to wait for a proper update fixing this issue rather than tampering in the kernel and system internals.
If you know any other proper way to solve this issue please share it with me.
Wait until the patch gets into mainline and the latest linux-firmware is pushed. The patch is authored by a cirrus representative, you just have to be patient.
philm
11 September 2023 05:25
3
Please install either 6.4.15 or 6.5.2 kernels as we have backported those fixes there already. You may find those in unstable branch.
Lameli
11 September 2023 07:14
4
When will those 6.5.2 kernels be released as stable ?
philm
11 September 2023 07:35
5
Our internal gaming edition already has those kernels active and they work fine with ASUS ROG ALLY already. You can simply switch branches and get the update: Switching Branches - Manjaro
Lameli
11 September 2023 08:14
6
I have updated to the unstable branch, rebooted and still the sound is not working !
System info
Kernel: 6.5.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
udev.log_priority=3
microcode: 0x119
Speed (MHz): avg: 2195 high: 2400 min/max: 800/5400:5600:4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 2400 2: 654 3: 708 4: 2400
5: 2400 6: 2400 7: 2400 8: 2400 9: 2400 10: 895 11: 2400 12: 2400 13: 2400
14: 2400 15: 2400 16: 2400 17: 2400 18: 2400 19: 2400 20: 2400 21: 2400
22: 799 23: 2400 24: 2400 25: 2400 26: 2400 27: 2400 28: 2400 29: 2400
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 322e:2122
class-ID: 0e02
modes: 2560x1600
API: OpenGL v: 4.6 Mesa 23.1.7-1 renderer: Mesa Intel Graphics (RPL-S)
direct-render: Yes
class-ID: 0403
API: ALSA v: k6.5.2-1-MANJARO status: kernel-api with: aoss
lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0033 class-ID: e001
class-ID: 0104
Local Storage: total: 953.87 GiB used: 125.02 GiB (13.1%)
lanes: 4 tech: SSD serial: <filter> fw-rev: V3MA003 temp: 42.9 C
scheme: GPT
used: 125.02 GiB (13.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
ID-1: swap-1 type: partition size: 16.77 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 39.0 C mobo: N/A
Processes: 518 Uptime: 3m wakeups: 2 Memory: total: 16 GiB note: est.
available: 15.24 GiB used: 4.33 GiB (28.4%) Init: systemd v: 254
Packages: 1298 pm: pacman pkgs: 1274 libs: 355 tools: pamac pm: flatpak
inxi: 3.3.29
The guide i posted above said that this problem happens with 2023 laptops, maybe you meant Asus laptops prior to 2023.
philm
11 September 2023 08:53
7
Did you apply any DSDT overrides? If so, you have to remove them. We have applied the following patches on 6.5 series:
# No overrides ROG ally
0001-Cirrus-no-dsdt.patch
0001-ALSA-hda-cs35l41-Support-ASUS-2023-laptops-with-miss.patch
# Fixup sleep cs35l41
0001-ALSA-cs35l41-Use-mbox-command-to-enable-speaker-outp.patch
0002-ALSA-cs35l41-Poll-for-Power-Up-Down-rather-than-wait.patch
0003-ALSA-hda-cs35l41-Check-mailbox-status-of-pause-comma.patch
0004-ALSA-hda-cs35l41-Ensure-we-correctly-re-sync-regmap-.patch
0005-ALSA-hda-cs35l41-Ensure-we-pass-up-any-errors-during.patch
0006-ALSA-hda-cs35l41-Move-Play-and-Pause-into-separate-f.patch
0007-ALSA-hda-hda_component-Add-pre-and-post-playback-hoo.patch
0008-ALSA-hda-cs35l41-Use-pre-and-post-playback-hooks.patch
0009-ALSA-hda-cs35l41-Rework-System-Suspend-to-ensure-cor.patch
0010-ALSA-hda-cs35l41-Add-device_link-between-HDA-and-cs3.patch
0011-ALSA-hda-cs35l41-Ensure-amp-is-only-unmuted-during-p.patch
You can contact Luke to see if your device is not yet added to his patch . Else check with Stefan from Cirrus. He also made a patch .
Lameli
11 September 2023 12:09
8
No i didn’t change anything in the system, the Manjaro version is still fresh, i have been using Manjaro since only yesterday.
I posted a question in fluke’s discord server and waiting for response.
philm
11 September 2023 12:39
9
Well, I browsed thru the article . Since 6.4.15 and 6.5.2 has those needed patches applied it might work. You may still need to use a ssdt patch for your AMP or a matching firmware. Simply check if someone has the same laptop and how far he got with it. Having latest ASUS hardware may not always work with Linux when released. Also ASUS is not supportive of Linux, hence a community has to step in.
Asus has released a BIOS firmware update G614JU.318 on 2023/09/05
ROG Strix G16 (2023) BIOS & Firmware
that might include the SSDT patch
Lameli
11 September 2023 14:37
11
I downloaded and installed the firmware using the “ASUS EZ Flash Utility”. It did not fix the sound problem.
philm
11 September 2023 18:16
12
A firmware from ASUS might not fix it. As ASUS is not planning to add the missing DST info at all. That is why Cirrus and the Linux community had to step in. A SSDT patch or DSDT patch only exists on Linux side. Both are used to fix issues ACPI tables don’t provide.
https://wiki.archlinux.org/title/DSDT
Lameli
22 September 2023 14:17
13
is the problem something in the kernel or configuration files, meaning, do i have to wait for a kernel update or the problem will not be fixed unless i explicitly change something in the configurations of the system ?
Hey guys, Have there been any updates or fixes since Sep? I have spent days scouring the internet trying every solution, but no luck. I kinda regret buying this laptop.
Lameli
14 November 2023 21:28
15
The fix for this issue is currently being added to the Linux kernel. Some users have experienced fixes . I am currently using 6.5.0 kernel. There in no sound, so i am using my headphones for sound … for now.
The laptop is powerful (24 cores) and it’s material is good quality. I originally bought it for my work cuz it has powerful CPU, not mainly for gaming. But i play some open source games like TDM , Veloren , 0ad and BAR . Performance is very good with these games especially TDM since it’s very light weighted.
New BIOS version 321 released 2023/11/10
Lameli
15 November 2023 16:24
17
Thanks for highlighting that. I just updated the BIOS using a FAT32 USB stick, but still the sound is not working. This is a kernel issue as far as i know, so it will only be solved in one of the kernel updates.
It’s annoying tho that the firmware updates are closed source (malware) and we can’t easily know what ASUS is injecting into our devices behind the scenes.
Asus firmware updates only state: ‘Optimize system performance’ (same as other manufacturers)
and would not advise if onboard audio hardware had been patched
Any audio ‘malware’ that may be included on a proprietary OS (Dolby Atmos, AI noise-canceling* technology, Microsoft Cortana) would not work on Linux
(*cancelling - Asus website typo)
ALSA developers have signed off more patches for CS35L41 Amplifiers on Asus systems earlier today
LKML: Stefan Binding: [PATCH v1 1/2] ALSA: hda/realtek: Add quirks for ASUS 2024 Zenbooks
I suggest you find the Asus subsystem ID code for the audio device: lspci -vnnd 8086:7a50:0403
The first 4 digits of this code will be 1043 for Asus - [1043:nnnn]
The 2nd 4 digits identify the audio codec and can be used to check kernel mailing list and documentation for a patch
Lameli
15 November 2023 18:43
19
lspci -vnnd 8086:7a50:0403:
0000:00:1f.3 Audio device [0403]: Intel Corporation Device [8086:7a50] (rev 11) (prog-if 80)
DeviceName: Onboard - Sound
Subsystem: ASUSTeK Computer Inc. Device [1043:1c9f]
Flags: bus master, fast devsel, latency 32, IRQ 206, IOMMU group 14
Memory at 625f230000 (64-bit, non-prefetchable) [size=16K]
Memory at 625f000000 (64-bit, non-prefetchable) [size=1M]
Capabilities: <access denied>
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_sof_pci_intel_tgl
Found my number 1c9f in the link you posted.
I tried to use the “No sound in 2023” Patch from Asus-Linux and followed the provided instructions, but unfortunately, the sound still did not work, even though it was confirmed as working on their end during testing. FYI I’m using Ubuntu 22.4
Has someone tried this patch and got it to work maybe?
