Hi, I dual booted manjaro 20.1 in my asus laptop along windows 10. After installing i updated drivers and all using package manager (it displayed 200+ updates available and i applied the changes) .
Now my sound is not working even if i connect headset to 3.5mm jack its not detected. I am able to increase/decrease volume using keyboard but ther is no sound coming from my system.
this is the output of aplay -l command
card 0: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
Thanks.
Only audio devices shown is for HDMI audio
no device is shown for onboard analog audio to speakers or headphones
Please post system information
inxi -Fazy
and this to show any error messages from audio devices
sudo dmesg | grep -E 'snd|sof'
@nikgnomic
this is the output of inxi -Fazy
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=58b69609-f67c-4b30-995e-936481c5b245 rw quiet apparmor=1
Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.1
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: TUF Gaming FX505GT_FX505GT v: 1.0
serial: <filter>
Mobo: ASUSTeK model: FX505GT v: 1.0 serial: <filter>
UEFI: American Megatrends v: FX505GT.309 date: 11/06/2020
ID-1: BAT0 charge: 20.5 Wh condition: 43.5/48.1 Wh (90%) volts: 10.9/11.7
model: Simplo SDI ICR18650 type: Li-ion serial: <filter> status: Discharging
cycles: 41
Info: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: D6
L2 cache: 8192 KiB
bogomips: 38408
Speed: 900 MHz min/max: 800/2400 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 900 8: 900
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:1f91
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 1-11:3 chip ID: 13d3:56a2 serial: <filter>
Display: wayland server: X.org 1.20.9 compositor: gnome-shell
driver: nouveau note: display driver n/a - try sudo/root display ID: 0
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.2.1
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: sof-audio-pci
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:10fa
Sound Server: ALSA v: k5.8.18-1-MANJARO
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
port: 5000 bus ID: 00:14.3 chip ID: 8086:a370
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus ID: 03:00.0
chip ID: 10ec:8168
Local Storage: total: 476.94 GiB used: 9.74 GiB (2.0%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 002C scheme: GPT
ID-1: / raw size: 44.54 GiB size: 43.59 GiB (97.87%) used: 9.70 GiB (22.3%)
fs: ext4 dev: /dev/nvme0n1p6
System Temperatures: cpu: 46.0 C mobo: 27.8 C gpu: nouveau temp: 38.0 C
Fan Speeds (RPM): cpu: 2300
Processes: 271 Uptime: 1m Memory: 7.63 GiB used: 1.14 GiB (15.0%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1243 lib: 354
flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.08
and output for sudo dmesg | grep -E 'snd|sof'
[ 0.890551] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.890556] software IO TLB: mapped [mem 0x70dd4000-0x74dd4000] (64MB)
[ 3.434590] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 3.434596] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 3.434835] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 3.434843] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 3.822370] snd_soc_skl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 3.822375] snd_soc_skl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 3.870549] snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops nv50_audio_component_bind_ops [nouveau])
[ 4.105319] sof-audio-pci 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 4.105329] sof-audio-pci 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 4.106032] sof-audio-pci 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040380
[ 4.106427] sof-audio-pci 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 4.115146] sof-audio-pci 0000:00:1f.3: use msi interrupt mode
[ 4.244679] sof-audio-pci 0000:00:1f.3: hda codecs found, mask 5
[ 4.244686] sof-audio-pci 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[ 4.244699] sof-audio-pci 0000:00:1f.3: DMICs detected in NHLT tables: 4
[ 4.244960] sof-audio-pci 0000:00:1f.3: Direct firmware load for intel/sof/sof-cfl.ri failed with error -2
[ 4.244967] sof-audio-pci 0000:00:1f.3: error: request firmware intel/sof/sof-cfl.ri failed err: -2
[ 4.244971] sof-audio-pci 0000:00:1f.3: error: failed to load DSP firmware -2
[ 4.245971] sof-audio-pci 0000:00:1f.3: error: sof_probe_work failed err: -2
Kernel: 5.8.18 has been marked End Of Life so suggest you update to kernel v5.9
Suggest you install kernel using Manjaro Settings Manager
manjaro-settings-manager -m msm_kernel
reboot system to load the new kernel and check if audio is working without error messages
If it is still not working please get more ALSA information about audio devices
alsa-info.sh --upload
@nikgnomic
I have updated kernel to 5.9.1-1-rt19 . But still there is no change.
here is the link to ALSA information , i’m unable to post lins in comment so i’m modifying the link to not look like a link. sorry.
http[://]alsa-project[.]org/db/?f=1181fc4036f2100f9895f6e20deb8166dce46784
There are 2 previous posts on here about the same model laptop
Just installed Manjaro and no sound at all
No sound in Manjaro GNOME
The ALSA data from 2nd discussion is showing OP has the correct ALSA modules loaded to detect both HDMI and onboard audio devices recognised
!!Loaded ALSA modules
snd_hda_intel
snd_soc_skl_hda_dsp
!!Soundcards recognised by ALSA
0 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xa4080000 irq 17
1 [sofhdadsp ]: sof-hda-dsp - sof-hda-dsp
ASUSTeKCOMPUTERINC.-TUFGamingFX505GT_FX505GT-1.0-FX505GT
But your latest alsa-info data is still not showing only HDMI audio device is recognised
https://alsa-project.org/db/?f=1181fc4036f2100f9895f6e20deb8166dce46784
and some of the sof-firmware modules appear to be missing from !!All Loaded Modules
snd_soc_skl
snd_soc_skl_hda_dsp
snd_soc_sst_dsp
snd_soc_sst_ipc
I suggest you install (or reinstall) sof-firmware
pamac install sof-firmware
and check dmesg and alsa-info again if onboard audio is not being detected
@nikgnomic it worked. Now i am getting sound in my laptop. But it is recognised as Headphones (When i adjust volume it is displaying headphones) and so the sound is very low.
There is still some driver mismatch or something happening i guess.
Anyways your answer helped thanks.
EDIT
Changed sound device in settings. it is working perfectly now. Thanks for all the help..
system
Closed
11 December 2020 15:08
8
