Hello, I installed Manjaro recently on my Thinkpad X1 tablet Gen 3, and everything worked out of the box, even removable keyboard, touchscreen and tablet stuff.
Although, I updated some packages (there were 175 updates so I don’t have list sorry --’ ), and now, the sound does not work anymore (both with internal speakers and jack earphones). I’d also mention that when it was working, when I used Gnome Xorg, sound didn’t work (but it was okay with Gnome and Gnome Classique). Also, I have a another partition on my disc with Windows, and sound is working fine there even now.
I’ve searched for similar issues on the internet, found and tried these (sorry I ca’n’t include URLs):
- Disable Pipewire to prevent conflict → It was already disabled and everything seems in order — in topic /no-sound-maybe-update-installed-new-soundcard-still-dont-work/80340
- Verifiy Pulseaudio’s state and other associated fix described in the thread → it’s Active and running fine (audio level even shows in the pavucontrol when sound plays, and it knows when I plug or unplug my jack earphones, saying it outputs ont the proper device) — in topic /manjaro-sound-not-working-after-update/67448
So I don’t really konw what to do, I’m not really good with Linux I must say, and I’m kind of lost and confused. Thank you for your help !
Host: SCOPNgin Kernel: 5.15.21-1-MANJARO x86_64 bits: 64
Desktop: GNOME 41.3 Distro: Manjaro Linux
Type: Detachable System: LENOVO product: 20KKS1L100
v: ThinkPad X1 Tablet Gen 3 serial: <superuser required>
Mobo: LENOVO model: 20KKS1L100 v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N1ZET65W(1.21 )
date: 06/06/2018
ID-1: BAT0 charge: 26.8 Wh (81.7%) condition: 32.8/42.0 Wh (78.0%)
volts: 8.1 min: 7.7
Info: quad core model: Intel Core i5-8350U bits: 64 type: MT MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 700 min/max: 400/3600 cores: 1: 700 2: 700 3: 700
4: 700 5: 700 6: 700 7: 700 8: 700
Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
Device-2: Lite-On Integrated Camera type: USB driver: uvcvideo
Display: wayland server: X.org 1.21.1.3 driver: loaded: modesetting
Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging
Unit
driver: ipu3-imgu
Device-2: Intel CSI-2 Host driver: ipu3-cio2
Device-3: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi
IF: wlp4s0 state: up mac: a0:a4:c5:0e:f0:42
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
Local Storage: total: 476.77 GiB used: 97.14 GiB (20.4%)
ID-1: /dev/mmcblk0 model: SD256 size: 238.3 GiB
ID-2: /dev/sda vendor: Samsung model: MZNLN256HAJQ-000L7 size: 238.47 GiB
ID-1: / size: 77.48 GiB used: 18.93 GiB (24.4%) fs: ext4 dev: /dev/sda5
ID-2: /boot/efi size: 96 MiB used: 25.6 MiB (26.6%) fs: vfat
dev: /dev/sda1
System Temperatures: cpu: 32.0 C pch: 35.5 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 267 Uptime: 28m Memory: 7.52 GiB used: 3.7 GiB (49.2%)
Shell: Zsh inxi: 3.3.12
