Suddenly the sound doesn’t work in Manjaro KDE plasma All info
inxi -Fazy
Kernel: 5.15.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=749efec8-1152-496e-9055-0010e51caa57 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ZenBook UX434IQ_Q407IQ v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: UX434IQ v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: UX434IQ_Q407IQ.303 date: 03/10/2021
ID-1: BAT0 charge: 41.5 Wh (100.0%) condition: 41.5/50.0 Wh (82.9%)
volts: 11.9 min: 11.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 242
Info: model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 gen: 3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x60 (96) stepping: 1 microcode: 0x8600106
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1741 high: 2669 min/max: 1400/2375 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
3: 1397 4: 1988 5: 1603 6: 2669 bogomips: 28462
STIBP: disabled, RSB filling
Device-1: NVIDIA GP107M [GeForce MX350] vendor: ASUSTeK driver: nouveau
v: kernel non-free: 515.xx+ status: current (as of 2022-06) arch: Pascal
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1c96 class-ID: 0302
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
arch: GCN 5.1 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-3: IMC Networks USB2.0 HD IR UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-2:2 chip-ID: 13d3:56cb class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu,modesetting alternate: fbdev,vesa gpu: amdgpu display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x07e9 built: 2018
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.42 5.15.49-1-MANJARO)
v: 4.6 Mesa 22.1.2 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.49-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
Local Storage: total: 238.47 GiB used: 19.68 GiB (8.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM256GDJTNG-8310A size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: 80001C00 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 117.2 GiB size: 114.8 GiB (97.95%) used: 19.65 GiB (17.1%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: N/A mobo: N/A
Fan Speeds (RPM): cpu: 2500
GPU: device: nouveau temp: 45.0 C device: amdgpu temp: 45.0 C
Processes: 313 Uptime: 43m wakeups: 2359 Memory: 7.19 GiB
used: 3.26 GiB (45.3%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1257
pacman: 1242 lib: 334 flatpak: 0 snap: 15 Shell: Zsh v: 5.9
running-in: konsole inxi: 3.3.19
### Configuration dump generated at Thu Jun 30 11:53:42 2022
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="0" name="pci-0000_04_00.1" card_name="alsa_card.pci-0000_04_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="1" name="pci-0000_04_00.6" card_name="alsa_card.pci-0000_04_00.6" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0 xauthority=/home/kilogram/.Xauthority
load-module module-x11-xsmp display=:0 xauthority=/home/kilogram/.Xauthority session_manager=local/kilogram-pc:@/tmp/.ICE-unix/836,unix/kilogram-pc:/tmp/.ICE-unix/836
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_04_00.6.analog-stereo 0x10000
set-sink-mute alsa_output.pci-0000_04_00.6.analog-stereo no
suspend-sink alsa_output.pci-0000_04_00.6.analog-stereo yes
set-source-volume alsa_output.pci-0000_04_00.6.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_04_00.6.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_04_00.6.analog-stereo.monitor yes
set-source-volume alsa_input.pci-0000_04_00.6.analog-stereo 0x3ae1
set-source-mute alsa_input.pci-0000_04_00.6.analog-stereo no
suspend-source alsa_input.pci-0000_04_00.6.analog-stereo yes
set-card-profile alsa_card.pci-0000_04_00.1 off
set-card-profile alsa_card.pci-0000_04_00.6 output:analog-stereo+input:analog-stereo
set-default-sink alsa_output.pci-0000_04_00.6.analog-stereo
set-default-source alsa_input.pci-0000_04_00.6.analog-stereo
