Hello team,
I found my GNOME desktop in a situation, that audio output stopped working on second app opened. It happens since December 5, 2022 rolling update (pacman -Syu). I listed a stable repro step below. Though not 100% sure, it looks like a user mode problem, based on a fact that logging out GNOME turns out to be a workaround. Unfortunately I have not more clue for further diagnose, as I’m not an audio expert.
Could anyone share ideas for further debugging?
- DELL Vostro 13 laptop.
- Manjaro testing branch
- GNOME 43.1 desktop (system details see inxi output below).
Repro steps:
- Login to GNOME desktop environment.
- Open app A with sound playback (e.g. Firefox + youtube.com). Audio can output as expected. When app A is on and playing, more apps B, C, … can open and play sound as expected. (e.g. Podcasts to play a pod cast)
- Close all open apps on desktop to stop all playbacks.
- Open a new app D and play sound. It doesn’t matter whether the new app can be new one or prevoius ones. For example, close Firefox and Podcasts app, and launch them again.
Expected:
- App opened step 5 can play sound correctly.
Actual:
- App opened in step 5 plays no sound.
- System settings still can show device correctly (in my env it’s built-in speaker, Intel Tiger Lake-LP Smart Sound Audio)
Detected working workaround:
- Log-off GNOME and login again. Sound can playback, but still only the first app.
Diagnose:
- Replace manjaro-pulse with manjaro-pipewire. Result: No effect. Behavior is the same. I can’t switch back to manjaro-pulse due to unsatistied dependency.
====== System info ======
$ inxi -Fayz
Kernel: 5.10.157-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=4a060f7d-5cc0-4bca-a132-e4ae8ce4cca9 rw cgroup_enable=memory
swapaccount=1 quiet resume=UUID=b861fa39-f63b-4a5a-b4c3-08d3098813ac
udev.log_priority=3
Desktop: GNOME v: 43.1 tk: GTK v: 3.24.35 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Dell product: Vostro 13 5310 v: N/A
Mobo: Dell model: 0D2YGH v: A00 serial: <superuser required> UEFI: Dell
v: 2.13.0 date: 07/11/2022
ID-1: BAT0 charge: 54.0 Wh (100.0%) condition: 54.0/54.0 Wh (100.0%)
volts: 16.8 min: 15.0 model: SMP DELL XDY9K1B type: Li-poly serial: <filter>
status: full
Info: model: 11th Gen Intel Core i5-11320H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 2
microcode: 0x28
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 726 high: 1013 min/max: 400/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 701 2: 642 3: 674 4: 1013
5: 625 6: 542 7: 931 8: 684 bogomips: 39944
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:3 chip-ID: 0c45:6725 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x13b0 built: 2020 res: 2560x1600
dpi: 227 gamma: 1.2 size: 286x178mm (11.26x7.01") diag: 337mm (13.3")
ratio: 16:10 modes: 2560x1600
API: EGL/GBM Message: No known Wayland EGL/GBM data sources.
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: sof-audio-pci alternate: snd_hda_intel,snd_sof_pci bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound API: ALSA v: k5.10.157-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.61 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 99.83 GiB (20.9%)
model: PC SN530 NVMe WDC 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 21113012 temp: 44.9 C scheme: GPT
ID-1: / raw-size: 64 GiB size: 62.44 GiB (97.57%) used: 28.2 GiB (45.2%)
fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9
used: 324 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
ID-3: /home raw-size: 174.24 GiB size: 170.45 GiB (97.82%)
used: 71.63 GiB (42.0%) fs: ext4 dev: /dev/nvme0n1p10 maj-min: 259:10
ID-1: swap-1 type: partition size: 20 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p8 maj-min: 259:8
Src: /sys System Temperatures: cpu: 42.0 C mobo: N/A
Power: 12v: N/A 5v: 5 3.3v: N/A vbat: N/A
Processes: 243 Uptime: 13m wakeups: 4093 Memory: 15.38 GiB
used: 2.1 GiB (13.7%) Init: systemd v: 252 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1229 pm: pacman pkgs: 1196
libs: 291 tools: pamac,yay pm: flatpak pkgs: 33 Shell: fish v: 3.5.1
running-in: gnome-terminal inxi: 3.3.23
