raysa
January 6, 2022, 9:39am
#1
When the sound was lost in December, a recommended update of the Dell Bios fixed it, but the sound has now gone again after the Jan 2 Manjaro update. There doesn’t appear to be another new Dell Bios, so what could be the problem now?
Here is today’s inxi read-out:
[ray@ray-dell ~]$ inxi -Fazy
Kernel: 5.10.89-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=9c7ea2e0-9118-4a42-98d6-74ea85c32f7e rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Inspiron 3505 v: 1.4.7
serial: <superuser required> Chassis: type: 10 v: 1.4.7
Mobo: Dell model: 0NMTCX v: A00 serial: <superuser required> UEFI: Dell
v: 1.4.7 date: 05/31/2021
ID-1: BAT1 charge: 38.9 Wh (100.0%) condition: 38.9/42.0 Wh (92.6%)
volts: 12.3 min: 11.4 model: Simplo 0x32,0x38,0x33,0x35,0x0B,0x0A,0x000F
type: Li-ion serial: <filter> status: Full
Info: model: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1221 high: 1225 min/max: 1400/2300 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1225 2: 1219
3: 1222 4: 1224 5: 1222 6: 1223 7: 1224 8: 1211 bogomips: 36745
disabled, RSB filling
Device-1: AMD Picasso vendor: Dell driver: amdgpu v: kernel bus-ID: 04:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 0c45:671e class-ID: 0e02
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Dell
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.89-1-MANJARO running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8136
class-ID: 0200
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 2000 bus-ID: 03:00.0
chip-ID: 10ec:c821 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-2.4:3 chip-ID: 0bda:c829 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 74.63 GiB (15.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM991a NVMe 512GB
lanes: 4 type: SSD serial: <filter> rev: 26302039 temp: 21.9 C scheme: GPT
ID-1: / raw-size: 391.04 GiB size: 383.83 GiB (98.16%)
used: 74.55 GiB (19.4%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw-size: 250 MiB size: 246 MiB (98.40%)
used: 87.3 MiB (35.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 73.6 C mobo: N/A gpu: amdgpu temp: 73.0 C
Fan Speeds (RPM): fan-1: 0
Processes: 234 Uptime: 15m wakeups: 1 Memory: 5.75 GiB
used: 2.17 GiB (37.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1290 lib: 354 Shell: Bash v: 5.1.12
running-in: xfce4-terminal inxi: 3.3.11
[ray@ray-dell ~]$
Any help appreciated.
raysa
January 6, 2022, 2:51pm
#3
Thanks. Pamac showed sof-firmware already installed, but I’ve now re-installed it with Pamac and re-booted. Still total silence!
yes my mistake. you have a amd cpu so sof-firmware
is irrelevant.
this is to show if any audio outputs or inputs are detected and configured correctly in PulseAudio:
pacmd dump
and this to show ALSA settings for audio devices:
amixer --card=0
also do you have manjaro-pulse
installed??
raysa
January 6, 2022, 4:46pm
#5
Yes, manjaro-pulse is installed.
Here is the pacmd dump output:
[ray@ray-dell ~]$ pacmd dump
### Configuration dump generated at Thu Jan 6 16:39:03 2022
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="0" name="pci-0000_04_00.1" card_name="alsa_card.pci-0000_04_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="1" name="pci-0000_04_00.6" card_name="alsa_card.pci-0000_04_00.6" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-combine-sink
load-module module-native-protocol-tcp
load-module module-zeroconf-discover
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0.0 xauthority=/home/ray/.Xauthority
load-module module-x11-xsmp display=:0.0 xauthority=/home/ray/.Xauthority session_manager=local/ray-dell:@/tmp/.ICE-unix/904,unix/ray-dell:/tmp/.ICE-unix/904
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_04_00.6.analog-stereo 0x10000
set-sink-mute alsa_output.pci-0000_04_00.6.analog-stereo no
suspend-sink alsa_output.pci-0000_04_00.6.analog-stereo yes
set-sink-volume combined 0x10000
set-sink-mute combined no
suspend-sink combined yes
set-source-volume alsa_output.pci-0000_04_00.6.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_04_00.6.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_04_00.6.analog-stereo.monitor yes
set-source-volume alsa_input.pci-0000_04_00.6.analog-stereo 0xd47a
set-source-mute alsa_input.pci-0000_04_00.6.analog-stereo no
suspend-source alsa_input.pci-0000_04_00.6.analog-stereo yes
set-source-volume combined.monitor 0x10000
set-source-mute combined.monitor no
suspend-source combined.monitor yes
set-card-profile alsa_card.pci-0000_04_00.1 off
set-card-profile alsa_card.pci-0000_04_00.6 output:analog-stereo+input:analog-stereo
set-default-sink alsa_output.pci-0000_04_00.6.analog-stereo
set-default-source combined.monitor
### EOF
[ray@ray-dell ~]$
And here is the amixer output:
[ray@ray-dell ~]$ amixer --card=0
Simple mixer control 'PCM',0
Capabilities: pvolume
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
[ray@ray-dell ~]$
As mentioned before, the sound was working fine before the latest Manjaro update.
Previous post suggested more than BIOS update may be needed to resolve issue with Ryzen ACP driver
Sound disappeared from Dell Inspiron 15 - #5 by nikgnomic
System data shows BIOS version: (v1.4.7 date: 05/31/2021) is the same version as previous discussion
Latest BIOS v1.4.9 was released on 27 Dec 2021
Ryzen ACP device is still not loading available driver, but the drivers are detected as alternates
Kernel v5.15 should have better support for AMD acp3x drivers but support will likely be back-ported to kernel v5.10 in the future if you would prefer to wait for that
PulseAudio data shows Card for HDMI/DP output is set to profile Off and only 1 card is active for
analog audio output.
Addition of module-combine-sinks for simultaneous output to more than one sink cannot function correctly if there is only one sink available. This module might be another potential point of failure and should be removed
I suggest turning off option for Simultaneous Output in paprefs
or removing module-combine-sink from PulseAudio configuration
Note that paprefs is available from the official repositories (extra). It was not part of the default xfce install here which is from 2018…
raysa
January 6, 2022, 7:40pm
#8
I’ve turned off the option of Simultaneous Output in paprefs and re-booted. Still total silence!
I’m out of my depth with the Bios thing - thought I’d updated it but apparently not. How can I get the latest Bios installed?
Download BIOS file from Dell. If you have Windows, execute the .exe. If you don’t have Windows, boot with a WindowsPE disk and navigate to the location of the .exe file. Execute the update. Hirens BootCD is a good example of a free, WindowsPE disk.
https://www.hirensbootcd.org/download/
Or try with `fwupdmgr. See the following:
$ pacman -Si fwupd | grep -E "Desc|URL"
Description : Simple daemon to allow session software to update firmware
URL : https://github.com/fwupd/fwupd
Never new it, learned a bit GitHub - fwupd/fwupd: A system daemon to allow session software to update firmware and just update the USB receiver:
details $ fwupdmgr get-devices
Default string
├─Samsung SSD 970 EVO Plus 500GB:
│ Device ID: 03281da317dccd2b18de2bd1cc70a782df40ed7e
│ Summary: NVM Express …
Hello guys
I would like to update the BIOS of my laptop (Thinkpad T480)
You know how to do this, since I can’t use fwupdmgr
Thanks in advance.
If you are not confident about updating firmware try installing kernel v5.15 first
Use Manjaro Settings Manager > Kernel GUI ( manjaro-settings-manager -m msm_kernel
OR
sudo mhwd-kernel --install linux515
raysa
January 6, 2022, 10:47pm
#11
I have to use Windows to get my Manjaro working properly???
You can try with fwupd, if you prefer. I have never used it as I prefer the WindowPE disk method.
https://wiki.archlinux.org/title/Fwupd
raysa
January 8, 2022, 1:13pm
#13
Well, I finally fired up the dual-boot Windows OS on the laptop … first time since I got it! Reminded me why I never use Windows, BUT it had a Dell update-system facility which included the BIOS update.
So I’ve done that and come back to Manjaro … and yippee, the sound is working fine again!
Seems bizarre to have to use Windows to fix a Manjaro problem, but hey!
system
Closed
January 11, 2022, 3:13am
#14
