Hi,
I have issues with sound since update to kernel 5.13.12-1. My microphone is not working in chromium, and also sometimes speakers are detected as headphones. Same issue on 5.14, so now using 5.12 again to be able to work as the microphone issue is a real blocker for my work.
as recommended by this post
on 5.14
inxi
Kernel: 5.14.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.14-x86_64
root=UUID=822a4d3f-a5ca-4521-9f9a-b087338b955d rw rootflags=subvol=@
luks.name=192c3498-a49f-4232-acfc-90cc582b3436=cryptroot
luks.name=369dc21e-63d5-4dab-b211-3c29f6a5d60f=cryptextension
luks.key=192c3498-a49f-4232-acfc-90cc582b3436=/crypto_keyfile.bin
luks.key=369dc21e-63d5-4dab-b211-3c29f6a5d60f=/crypto_keyfile.bin
modprobe.blacklist=nvidia-modeset,nvidia-uvm,nvidia,nouveau quiet
udev.log_priority=3 audit=0 acpi_osi=! "acpi_osi=Windows 2009"
acpi_backlight=vendor pcie_aspm=force i915.enable_psr=1 nowatchdog
drm.vblankoffdelay=1 tsc=reliable
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: HP product: HP ZBook Studio G5 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: HP model: 8427 v: KBC Version 16.4C.00 serial: <filter> UEFI: HP
v: Q71 Ver. 01.16.00 date: 04/22/2021
ID-1: BAT0 charge: 67.8 Wh (98.0%) condition: 69.2/96.4 Wh (71.8%)
volts: 11.5 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: Discharging cycles: 494
Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 9 MiB
bogomips: 52815
Speed: 1673 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 1673 2: 1861
3: 1713 4: 2100 5: 2100 6: 2100 7: 2100 8: 1381 9: 2100 10: 1691 11: 2100
12: 2100
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107GLM [Quadro P1000 Mobile] driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus-ID: 01:00.0 chip-ID: 10de:1cbb
class-ID: 0300
Device-3: Chicony HP HD Camera type: USB driver: uvcvideo bus-ID: 1-7:3
chip-ID: 04f2:b5e7 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: intel display-ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.14.2-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.35 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
port: 5000 bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 2.75 TiB used: 2.24 TiB (81.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX950 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: SS0221B temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:8 vendor: Samsung model: MZVLW1T0HMLH-000L7
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 7L7QCXY7 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 1.69 TiB size: 2.53 TiB (149.72%) used: 2.24 TiB (88.6%)
fs: btrfs dev: /dev/dm-1 maj-min: 254:1 mapped: cryptroot
ID-2: /boot/efi raw-size: 350 MiB size: 346 MiB (98.86%)
used: 117.3 MiB (33.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.69 TiB size: 2.53 TiB (149.72%)
used: 2.24 TiB (88.6%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: cryptroot
ID-4: /tmp raw-size: 1.69 TiB size: 2.53 TiB (149.72%)
mapped: cryptroot
ID-5: /var raw-size: 1.69 TiB size: 2.53 TiB (149.72%)
mapped: cryptroot
System Temperatures: cpu: 56.0 C mobo: 46.0 C
Processes: 351 Uptime: 1m wakeups: 1 Memory: 23.26 GiB
used: 2.53 GiB (10.9%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 2244 lib: 498 flatpak: 0
Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
snd related journal entries:
Sep 20 21:30:48 nk-zbook kernel: snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
Sep 20 21:30:48 nk-zbook kernel: snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
Sep 20 21:30:48 nk-zbook kernel: snd_hda_intel 0000:01:00.1: can't change power state from D3cold to D0 (config space inaccessible)
Sep 20 21:30:48 nk-zbook kernel: snd_hda_intel 0000:01:00.1: can't change power state from D3hot to D0 (config space inaccessible)
S
Sep 20 21:30:48 nk-zbook kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
Sep 20 21:30:48 nk-zbook kernel: snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
Sep 20 21:30:48 nk-zbook kernel: snd_hda_intel 0000:01:00.1: number of I/O streams is 30, forcing separate stream tags
Sep 20 21:30:48 nk-zbook kernel: hdaudio hdaudioC1D0: no AFG or MFG node found
Sep 20 21:30:48 nk-zbook kernel: hdaudio hdaudioC1D1: no AFG or MFG node found
Sep 20 21:30:48 nk-zbook kernel: hdaudio hdaudioC1D2: no AFG or MFG node found
Sep 20 21:30:48 nk-zbook kernel: hdaudio hdaudioC1D3: no AFG or MFG node found
Sep 20 21:30:48 nk-zbook kernel: hdaudio hdaudioC1D4: no AFG or MFG node found
Sep 20 21:30:48 nk-zbook kernel: hdaudio hdaudioC1D5: no AFG or MFG node found
Sep 20 21:30:48 nk-zbook kernel: hdaudio hdaudioC1D6: no AFG or MFG node found
Sep 20 21:30:48 nk-zbook kernel: hdaudio hdaudioC1D7: no AFG or MFG node found
Sep 20 21:30:48 nk-zbook kernel: snd_hda_intel 0000:01:00.1: no codecs initialized
Sep 20 21:30:49 nk-zbook kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Sep 20 21:30:49 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: CX11970: BIOS auto-probing.
Sep 20 21:30:49 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: vmaster hook already present before cdev!
Sep 20 21:30:49 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: autoconfig for CX11970: line_outs=1 (0x1d/0x0/0x0/0x0/0x0) type:speaker
Sep 20 21:30:49 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Sep 20 21:30:49 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: hp_outs=1 (0x16/0x0/0x0/0x0/0x0)
Sep 20 21:30:49 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: mono: mono_out=0x0
Sep 20 21:30:49 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: inputs:
Sep 20 21:30:49 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: Internal Mic=0x1a
Sep 20 21:30:49 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: Mic=0x19
Sep 20 21:30:49 nk-zbook alsactl[961]: alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -6
Sep 20 21:30:49 nk-zbook alsactl[961]: alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA Intel PCH at 0x404a108000 irq 159)
Sep 20 21:30:49 nk-zbook alsactl[961]: Found hardware: "HDA-Intel" "Conexant CX11970" "HDA:14f120d0,103c8427,00100001 HDA:8086280b,80860101,00100000" "0x103c" "0x8427"
Sep 20 21:30:49 nk-zbook alsactl[961]: Hardware is initialized using a generic method
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #1 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #15 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #28 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #29 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #30 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #31 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #32 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #33 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #34 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #35 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #36 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #37 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #38 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #39 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #40 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #41 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #42 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #43 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #44 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #45 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #46 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #47 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #48 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #49 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #50 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #51 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #53 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #54 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #55 (No such file or directory)
Sep 20 21:30:49 nk-zbook alsactl[961]: /usr/bin/alsactl: set_control:1339: failed to obtain info for control #56 (No such file or directory)
Sep 20 21:30:52 nk-zbook kernel: snd_hda_intel 0000:00:1f.3: azx_get_response timeout, switching to polling mode: last cmd=0x20270503
Sep 20 21:30:53 nk-zbook kernel: snd_hda_intel 0000:00:1f.3: No response from codec, disabling MSI: last cmd=0x20270503
Sep 20 21:30:54 nk-zbook kernel: snd_hda_intel 0000:00:1f.3: azx_get_response timeout, switching to single_cmd mode: last cmd=0x20270503
Sep 20 21:30:54 nk-zbook gnome-shell[1022]: Registering session with GDM
Sep 20 21:30:55 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
Sep 20 21:30:55 nk-zbook /usr/lib/gdm-wayland-session[1013]: dbus-daemon[1013]: [session uid=120 pid=1013] Successfully activated service 'org.gnome.Shell.Screencast'
Sep 20 21:30:55 nk-zbook kernel: snd_hda_codec_hdmi hdaudioC0D2: Unable to sync register 0x2f0d00. -5
Sep 20 21:30:55 nk-zbook kernel: snd_hda_codec_hdmi hdaudioC0D2: HDMI: invalid ELD buf size -1
Sep 20 21:31:04 nk-zbook kernel: snd_hda_codec_hdmi hdaudioC0D2: Unable to sync register 0x2f0d00. -5
Sep 20 21:31:04 nk-zbook kernel: snd_hda_codec_hdmi hdaudioC0D2: HDMI: invalid ELD buf size -1
Sep 20 21:31:04 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
Sep 20 22:06:43 nk-zbook kernel: azx_single_wait_for_response: 701 callbacks suppressed
Sep 20 22:06:43 nk-zbook pipewire-media-session[1517]: Failed to set volume of 'Mic Boost': Input/output error
Sep 20 22:06:43 nk-zbook pipewire-media-session[1517]: Failed to set switch of 'Speaker': Input/output error
Sep 20 22:06:43 nk-zbook kernel: snd_hda_codec_hdmi hdaudioC0D2: Unable to sync register 0x2f0d00. -5
Sep 20 22:06:43 nk-zbook kernel: snd_hda_codec_hdmi hdaudioC0D2: HDMI: invalid ELD buf size -1
Sep 20 22:06:44 nk-zbook gnome-shell[1422]: Window manager warning: last_user_time (2165988) is greater than comparison timestamp (2165958). This most likely represents a buggy client sending inaccurate timest>
Sep 20 22:06:44 nk-zbook gnome-shell[1422]: Window manager warning: W1 appears to be one of the offending windows with a timestamp of 2165988. Working around...
Sep 20 22:06:49 nk-zbook kernel: azx_single_send_cmd: 91 callbacks suppressed
Sep 20 22:09:04 nk-zbook kernel: azx_single_wait_for_response: 224 callbacks suppressed
Sep 20 22:09:04 nk-zbook kernel: snd_hda_codec_hdmi hdaudioC0D2: Unable to sync register 0x2f0d00. -5
Sep 20 22:09:04 nk-zbook kernel: snd_hda_codec_hdmi hdaudioC0D2: HDMI: invalid ELD buf size -1
Sep 20 22:09:04 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
Sep 20 22:09:04 nk-zbook pipewire-media-session[1517]: Failed to set volume of 'Internal Mic Boost': Input/output error
Sep 20 22:09:05 nk-zbook pipewire-media-session[1517]: Failed to set switch of 'Speaker': Input/output error
Sep 20 22:09:05 nk-zbook pipewire-media-session[1517]: Failed to set switch of 'Headphone': Input/output error
Sep 20 22:09:10 nk-zbook kernel: azx_single_send_cmd: 347 callbacks suppressed
on 5.12
inxi -Fazy
Kernel: 5.12.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.12-x86_64
ID-1: BAT0 charge: 37.2 Wh (54.5%) condition: 68.2/96.4 Wh (70.8%)
volts: 11.1 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: Discharging cycles: 493
bogomips: 52815
Speed: 840 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 840 2: 873 3: 900
4: 865 5: 890 6: 900 7: 900 8: 900 9: 886 10: 890 11: 900 12: 858
Type: l1tf
class-ID: 0300
direct render: Yes
Sound Server-1: ALSA v: k5.12.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Report: rfkill ID: hci0 rfk-id: 15 state: up address: see --recommends
lanes: 4 type: SSD serial: <filter> rev: SS0221B temp: 33.9 C scheme: GPT
lanes: 4 type: SSD serial: <filter> rev: 7L7QCXY7 temp: 39.9 C scheme: GPT
mapped: cryptroot
mapped: cryptroot
mapped: cryptroot
System Temperatures: cpu: 49.0 C mobo: 43.0 C
Processes: 382 Uptime: 2d 12h 41m wakeups: 23 Memory: 23.26 GiB
used: 10.44 GiB (44.9%) Init: systemd v: 248 tool: systemctl Compilers:
Sep 13 09:28:32 nk-zbook kernel: snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
Sep 13 09:28:32 nk-zbook kernel: snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
Sep 13 09:28:32 nk-zbook kernel: snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
Sep 13 09:28:32 nk-zbook kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
Sep 13 09:28:32 nk-zbook kernel: snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
Sep 13 09:28:32 nk-zbook alsactl[737]: alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:1 use case configuration -6
Sep 13 09:28:32 nk-zbook systemd[1]: Finished Save/Restore Sound Card State.
Sep 13 09:28:32 nk-zbook systemd[1]: Reached target Sound Card.
Sep 13 09:28:34 nk-zbook kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Sep 13 09:28:34 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: CX11970: BIOS auto-probing.
Sep 13 09:28:34 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: vmaster hook already present before cdev!
Sep 13 09:28:34 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: autoconfig for CX11970: line_outs=1 (0x1d/0x0/0x0/0x0/0x0) type:speaker
Sep 13 09:28:34 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Sep 13 09:28:34 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: hp_outs=1 (0x16/0x0/0x0/0x0/0x0)
Sep 13 09:28:34 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: mono: mono_out=0x0
Sep 13 09:28:34 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: inputs:
Sep 13 09:28:34 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: Internal Mic=0x1a
Sep 13 09:28:34 nk-zbook kernel: snd_hda_codec_conexant hdaudioC0D0: Mic=0x19
Sep 13 13:09:11 nk-zbook kernel: snd_hda_intel 0000:01:00.1: can't change power state from D0 to D3hot>
