I’ve been experiencing a sound glitch in TF2 wherein any played sound or music repeats after about a half-second delay in worse quality. I thought that this issue might be related to PulseAudio, but none of the fixes I tried worked, so I decided to uninstall PulseAudio entirely after making a system snapshot. That didn’t fix the problem, so I restored the pre-uninstall snapshot.
This is with the game running natively; running TF2 in Steam Linux Runtime introduces framerate drops without affecting the broken audio, running the game in Proton creates graphical issues on top of framerate ones (also not fixing the sound).
Also of note is the fact that TF2 is the only Source game affected by this. Left 4 Dead 2, Garry’s Mod and Fistful of Frags run without issues.
inxi printout:
#################### inxi -Fxzc0 ########################
System: Kernel: 5.8.1-3-MANJARO x86_64 bits: 64 compiler: N/A Desktop: KDE Plasma 5.19.4
Distro: Manjaro Linux
Machine: Type: Portable System: Dell product: Inspiron 3721 v: A05 serial: <filter>
Mobo: Dell model: 0N7THG v: A00 serial: <filter> UEFI: Dell v: A05 date: 01/03/2013
CPU: Topology: Dual Core model: Intel Core i5-3337U bits: 64 type: MT MCP arch: Ivy Bridge
rev: 9 L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 14373
Speed: 2186 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 2186 2: 2376 3: 2395
4: 2394
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0
Device-2: AMD Thames [Radeon HD 7500M/7600M Series] vendor: Dell driver: radeon
v: kernel bus ID: 01:00.0
Device-3: Realtek Integrated Webcam HD type: USB driver: uvcvideo bus ID: 1-1.4:5
Display: x11 server: X.Org 1.20.8 driver: intel,radeon FAILED: ati
unloaded: modesetting resolution: 1600x900~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.1.5
direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.8.1-3-MANJARO
Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169
v: kernel port: 2000 bus ID: 07:00.0
IF: enp7s0 state: down mac: <filter>
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Dell driver: ath9k
v: kernel port: 2000 bus ID: 08:00.0
IF: wlp8s0 state: up mac: <filter>
Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-1.1:8
Drives: Local Storage: total: 931.51 GiB used: 247.31 GiB (26.5%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM024 HN-M101MBB size: 931.51 GiB
Partition: ID-1: / size: 906.94 GiB used: 247.17 GiB (27.3%) fs: ext4 dev: /dev/sda2
Swap: ID-1: swap-1 type: partition size: 8.80 GiB used: 145.2 MiB (1.6%) dev: /dev/sda3
Sensors: System Temperatures: cpu: 54.0 C mobo: N/A gpu: radeon temp: 47 C
Fan Speeds (RPM): cpu: 3200
Info: Processes: 231 Uptime: 2d 2h 36m Memory: 7.65 GiB used: 4.50 GiB (58.8%) Init: systemd
Compilers: gcc: 10.1.0 Packages: 1350 Client: Unknown Client: krunner inxi: 3.1.05
journalctl printout:
Aug 27 21:49:34 HOST org_kde_powerdevil[1401]: powerdevil: Can't contact ck
Aug 27 21:49:59 HOST org_kde_powerdevil[1401]: powerdevil: Releasing inhibition with cookie 2575
Aug 27 21:49:59 HOST org_kde_powerdevil[1401]: powerdevil: Scheduling inhibition from ":1.18" "My SDL application" with cookie 2576 and reason "Playing a game"
Aug 27 21:49:59 HOST org_kde_powerdevil[1401]: powerdevil: Can't contact ck
Aug 27 21:50:04 HOST org_kde_powerdevil[1401]: powerdevil: Enforcing inhibition from ":1.18" "My SDL application" with cookie 2576 and reason "Playing a game"
Aug 27 21:50:04 HOST org_kde_powerdevil[1401]: powerdevil: Added change screen settings
Aug 27 21:50:04 HOST org_kde_powerdevil[1401]: powerdevil: Added interrupt session
Aug 27 21:50:04 HOST org_kde_powerdevil[1401]: powerdevil: Can't contact ck
Aug 27 21:50:14 HOST plasmashell[1290]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Aug 27 21:50:30 HOST org_kde_powerdevil[1401]: powerdevil: Releasing inhibition with cookie 2576
Aug 27 21:50:30 HOST org_kde_powerdevil[1401]: powerdevil: Scheduling inhibition from ":1.18" "My SDL application" with cookie 2577 and reason "Playing a game"
Aug 27 21:50:30 HOST org_kde_powerdevil[1401]: powerdevil: Can't contact ck
Aug 27 21:50:30 HOST org_kde_powerdevil[1401]: powerdevil: Scheduling inhibition from ":1.18" "My SDL application" with cookie 2578 and reason "Playing a game"
Aug 27 21:50:35 HOST org_kde_powerdevil[1401]: powerdevil: Enforcing inhibition from ":1.18" "My SDL application" with cookie 2577 and reason "Playing a game"
Aug 27 21:50:35 HOST org_kde_powerdevil[1401]: powerdevil: Added change screen settings
Aug 27 21:50:35 HOST org_kde_powerdevil[1401]: powerdevil: Added interrupt session
Aug 27 21:50:35 HOST org_kde_powerdevil[1401]: powerdevil: Can't contact ck
Aug 27 21:50:35 HOST org_kde_powerdevil[1401]: powerdevil: Enforcing inhibition from ":1.18" "My SDL application" with cookie 2578 and reason "Playing a game"
Aug 27 21:50:43 HOST kwin_x11[1257]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48988, resource id: 14680672, major code: 3 (GetWindowAttributes), minor code: 0
Aug 27 21:50:43 HOST kwin_x11[1257]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48989, resource id: 14680672, major code: 14 (GetGeometry), minor code: 0
Aug 27 21:50:43 HOST plasmashell[1290]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Aug 27 21:51:00 HOST org_kde_powerdevil[1401]: powerdevil: Releasing inhibition with cookie 2577
Aug 27 21:51:00 HOST org_kde_powerdevil[1401]: powerdevil: Scheduling inhibition from ":1.18" "My SDL application" with cookie 2579 and reason "Playing a game"
Aug 27 21:51:00 HOST org_kde_powerdevil[1401]: powerdevil: Can't contact ck
Aug 27 21:51:04 HOST org_kde_powerdevil[1401]: powerdevil: Enforcing inhibition from ":1.18" "My SDL application" with cookie 2579 and reason "Playing a game"
Aug 27 21:51:04 HOST org_kde_powerdevil[1401]: powerdevil: Added change screen settings
Aug 27 21:51:04 HOST org_kde_powerdevil[1401]: powerdevil: Added interrupt session
Aug 27 21:51:04 HOST org_kde_powerdevil[1401]: powerdevil: Can't contact ck
Aug 27 21:51:30 HOST org_kde_powerdevil[1401]: powerdevil: Releasing inhibition with cookie 2579
Aug 27 21:51:30 HOST org_kde_powerdevil[1401]: powerdevil: Scheduling inhibition from ":1.18" "My SDL application" with cookie 2580 and reason "Playing a game"
Aug 27 21:51:30 HOST org_kde_powerdevil[1401]: powerdevil: Can't contact ck
Aug 27 21:51:33 HOST org_kde_powerdevil[1401]: powerdevil: Releasing inhibition with cookie 2580
Aug 27 21:51:33 HOST org_kde_powerdevil[1401]: powerdevil: It was only scheduled for inhibition but not enforced yet, just discarding it
Aug 27 21:51:35 HOST org_kde_powerdevil[1401]: powerdevil: Enforcing inhibition from ":1.18" "My SDL application" with cookie 2580 and reason "Playing a game"
Aug 27 21:51:35 HOST org_kde_powerdevil[1401]: powerdevil: By the time we wanted to enforce the inhibition it was already gone; discarding it
Aug 27 21:52:23 HOST org_kde_powerdevil[1401]: powerdevil: Scheduling inhibition from ":1.18" "My SDL application" with cookie 2581 and reason "Playing a game"
Aug 27 21:52:28 HOST org_kde_powerdevil[1401]: powerdevil: Enforcing inhibition from ":1.18" "My SDL application" with cookie 2581 and reason "Playing a game"
Aug 27 21:52:28 HOST org_kde_powerdevil[1401]: powerdevil: Added change screen settings
Aug 27 21:52:28 HOST org_kde_powerdevil[1401]: powerdevil: Added interrupt session
Aug 27 21:52:28 HOST org_kde_powerdevil[1401]: powerdevil: Can't contact ck
Aug 27 21:52:53 HOST org_kde_powerdevil[1401]: powerdevil: Releasing inhibition with cookie 2581
Aug 27 21:52:53 HOST org_kde_powerdevil[1401]: powerdevil: Scheduling inhibition from ":1.18" "My SDL application" with cookie 2582 and reason "Playing a game"
Aug 27 21:52:53 HOST org_kde_powerdevil[1401]: powerdevil: Can't contact ck
Aug 27 21:52:58 HOST org_kde_powerdevil[1401]: powerdevil: Enforcing inhibition from ":1.18" "My SDL application" with cookie 2582 and reason "Playing a game"
Aug 27 21:52:58 HOST org_kde_powerdevil[1401]: powerdevil: Added change screen settings
Aug 27 21:52:58 HOST org_kde_powerdevil[1401]: powerdevil: Added interrupt session
Aug 27 21:52:58 HOST org_kde_powerdevil[1401]: powerdevil: Can't contact ck
Aug 27 21:53:06 HOST org_kde_powerdevil[1401]: powerdevil: Releasing inhibition with cookie 2582
Aug 27 21:53:06 HOST org_kde_powerdevil[1401]: powerdevil: Can't contact ck
Aug 27 21:54:03 HOST org_kde_powerdevil[1401]: powerdevil: Scheduling inhibition from ":1.18" "My SDL application" with cookie 2583 and reason "Playing a game"
Aug 27 21:54:08 HOST org_kde_powerdevil[1401]: powerdevil: Enforcing inhibition from ":1.18" "My SDL application" with cookie 2583 and reason "Playing a game"
Aug 27 21:54:08 HOST org_kde_powerdevil[1401]: powerdevil: Added change screen settings
Aug 27 21:54:08 HOST org_kde_powerdevil[1401]: powerdevil: Added interrupt session
Aug 27 21:54:08 HOST org_kde_powerdevil[1401]: powerdevil: Can't contact ck
Aug 27 21:54:13 HOST org_kde_powerdevil[1401]: powerdevil: Releasing inhibition with cookie 2578
Aug 27 21:54:13 HOST org_kde_powerdevil[1401]: powerdevil: Can't contact ck
Aug 27 21:54:13 HOST kwin_x11[1257]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50277, resource id: 14680673, major code: 3 (GetWindowAttributes), minor code: 0
Aug 27 21:54:13 HOST kwin_x11[1257]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 50278, resource id: 14680673, major code: 14 (GetGeometry), minor code: 0
Aug 27 21:54:13 HOST kwin_x11[1257]: kwin_core: Compositing is not possible
