Sound was working normally after the 2024-02-21 Stable Update.
All off a sudden, mp3 files play correctly in Audacious, but mp4 files do not play in mpv player or Parole media player or VLC media player.
Not sure what happened?
Built-in Audio under Volume Control Configuration panel has Analog Stereo Duplex selected.
mp4 files have sound when played in audacious.
output for command: "mpv --audio-device=help"
$ mpv --audio-device=help
List of detected audio devices:
'auto' (Autoselect device)
'pipewire' (Default (pipewire))
'pipewire/alsa_output.pci-0000_00_14.2.analog-stereo.10' (Built-in Audio Analog Stereo)
'pulse/alsa_output.pci-0000_00_14.2.analog-stereo.10' (Built-in Audio Analog Stereo)
'alsa' (Default (alsa))
'alsa/lavrate' (Rate Converter Plugin Using Libav/FFmpeg Library)
'alsa/samplerate' (Rate Converter Plugin Using Samplerate Library)
'alsa/speexrate' (Rate Converter Plugin Using Speex Resampler)
'alsa/jack' (JACK Audio Connection Kit)
'alsa/oss' (Open Sound System)
'alsa/pipewire' (PipeWire Sound Server)
'alsa/speex' (Plugin using Speex DSP (resample, agc, denoise, echo, dereverb))
'alsa/upmix' (Plugin for channel upmix (4,6,8))
'alsa/vdownmix' (Plugin for channel downmix (stereo) with a simple spacialization)
'alsa/hdmi:CARD=HDMI,DEV=0' (HDA ATI HDMI, HDMI 0/HDMI Audio Output)
'alsa/usbstream:CARD=HDMI' (HDA ATI HDMI/USB Stream Output)
'alsa/sysdefault:CARD=Generic' (HD-Audio Generic, ALC887-VD Analog/Default Audio Device)
'alsa/front:CARD=Generic,DEV=0' (HD-Audio Generic, ALC887-VD Analog/Front output / input)
'alsa/surround21:CARD=Generic,DEV=0' (HD-Audio Generic, ALC887-VD Analog/2.1 Surround output to Front and Subwoofer speakers)
'alsa/surround40:CARD=Generic,DEV=0' (HD-Audio Generic, ALC887-VD Analog/4.0 Surround output to Front and Rear speakers)
'alsa/surround41:CARD=Generic,DEV=0' (HD-Audio Generic, ALC887-VD Analog/4.1 Surround output to Front, Rear and Subwoofer speakers)
'alsa/surround50:CARD=Generic,DEV=0' (HD-Audio Generic, ALC887-VD Analog/5.0 Surround output to Front, Center and Rear speakers)
'alsa/surround51:CARD=Generic,DEV=0' (HD-Audio Generic, ALC887-VD Analog/5.1 Surround output to Front, Center, Rear and Subwoofer speakers)
'alsa/surround71:CARD=Generic,DEV=0' (HD-Audio Generic, ALC887-VD Analog/7.1 Surround output to Front, Center, Side, Rear and Woofer speakers)
'alsa/iec958:CARD=Generic,DEV=0' (HD-Audio Generic, ALC887-VD Digital/IEC958 (S/PDIF) Digital Audio Output)
'alsa/usbstream:CARD=Generic' (HD-Audio Generic/USB Stream Output)
'jack' (Default (jack))
'openal' (Default (openal))
Running the following command enables sound for the specified mp4 file:
$ mpv --audio-device=alsa/pipewire 'my video'.mp4
/usr/share/doc/mpv/mpv.conf
# Example mpv configuration file
# Warning:
# The commented example options usually do _not_ set the default values. Call
# mpv with --list-options to see the default values for most options. There is
# no builtin or example mpv.conf with all the defaults.
# Configuration files are read system-wide from /usr/local/etc/mpv.conf
# and per-user from ~/.config/mpv/mpv.conf, where per-user settings override
# system-wide settings, all of which are overridden by the command line.
# Configuration file settings and the command line options use the same
# underlying mechanisms. Most options can be put into the configuration file
# by dropping the preceding '--'. See the man page for a complete list of
# options.
# Lines starting with '#' are comments and are ignored.
# See the CONFIGURATION FILES section in the man page
# for a detailed description of the syntax.
# Profiles should be placed at the bottom of the configuration file to ensure
# that settings wanted as defaults are not restricted to specific profiles.
# video settings #
# Start in fullscreen mode by default.
#fs=yes
# force starting with centered window
#geometry=50%:50%
# don't allow a new window to have a size larger than 90% of the screen size
#autofit-larger=90%x90%
# Do not close the window on exit.
#keep-open=yes
# Do not wait with showing the video window until it has loaded. (This will
# resize the window once video is loaded. Also always shows a window with
# audio.)
#force-window=immediate
# Disable the On Screen Controller (OSC).
#osc=no
# Keep the player window on top of all other windows.
#ontop=yes
# Specify fast video rendering preset (for --vo=<gpu|gpu-next> only)
# Recommended for mobile devices or older hardware with limited processing power
#profile=fast
# Specify high quality video rendering preset (for --vo=<gpu|gpu-next> only)
# Offers superior image fidelity and visual quality for an enhanced viewing
# experience on capable hardware
#profile=high-quality
# Force video to lock on the display's refresh rate, and change video and audio
# speed to some degree to ensure synchronous playback - can cause problems
# with some drivers and desktop environments.
#video-sync=display-resample
# Enable hardware decoding if available. Often, this does not work with all
# video outputs, but should work well with default settings on most systems.
# If performance or energy usage is an issue, forcing the vdpau or vaapi VOs
# may or may not help.
#hwdec=auto
# audio settings #
# Specify default audio device. You can list devices with: --audio-device=help
# The option takes the device string (the stuff between the '...').
#audio-device=alsa/default
#osc=no
ao=alsa
# Do not filter audio to keep pitch when changing playback speed.
#audio-pitch-correction=no
# Output 5.1 audio natively, and upmix/downmix audio with a different format.
#audio-channels=5.1
# Disable any automatic remix, _if_ the audio output accepts the audio format.
# of the currently played file. See caveats mentioned in the manpage.
# (The default is "auto-safe", see manpage.)
#audio-channels=auto
# other settings #
# Pretend to be a web browser. Might fix playback with some streaming sites,
# but also will break with shoutcast streams.
#user-agent="Mozilla/5.0"
# cache settings
# Use a large seekable RAM cache even for local input.
#cache=yes
# Use extra large RAM cache (needs cache=yes to make it useful).
#demuxer-max-bytes=500M
#demuxer-max-back-bytes=100M
# Disable the behavior that the player will pause if the cache goes below a
# certain fill size.
#cache-pause=no
# Store cache payload on the hard disk instead of in RAM. (This may negatively
# impact performance unless used for slow input such as network.)
#cache-dir=~/.cache/
#cache-on-disk=yes
# Display English subtitles if available.
#slang=en
# Play Finnish audio if available, fall back to English otherwise.
#alang=fi,en
# Change subtitle encoding. For Arabic subtitles use 'cp1256'.
# If the file seems to be valid UTF-8, prefer UTF-8.
# (You can add '+' in front of the codepage to force it.)
#sub-codepage=cp1256
# You can also include other configuration files.
#include=/path/to/the/file/you/want/to/include
# Profiles #
# The options declared as part of profiles override global default settings,
# but only take effect when the profile is active.
# The following profile can be enabled on the command line with: --profile=eye-cancer
#[eye-cancer]
#sharpen=5
$ inxi -SMAa
$ inxi -SMAa
Host: quest-dev01 Kernel: 6.6.16-2-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 13.2.1 clocksource: tsc avail: hpet,acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
root=UUID=bf2c7024-cad8-4474-a678-85ef39cbb7ee rw rootflags=subvol=@
quiet udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: Gigabyte product: N/A v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Gigabyte model: F2A88XM-D3H serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F9 date: 12/25/2015
Device-1: AMD Trinity HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9902 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
API: ALSA v: k6.6.16-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
