Sound Drops to 4% When Pluggin USB-C Hub
Hello everyone,
I’m new to Manjaro—thank you for this helpful forum and for accepting me!
I recently purchased a USB-C hub from urban factory (HUBEE PLUS: STATION MOBILE USB-C 100W). When I connect it to my laptop and play a video on Vimeo or YouTube (no issue with VLC), the sound volume unexpectedly drops to 4% after about two minutes. I can’t figure out why this is happening.
I have a thinkpad L13 yoga :
CPU: 8-core AMD Ryzen 7 PRO 5850U with Radeon Graphics (-MT MCP-)
speed/min/max: 1112/400/4507 MHz Kernel: 6.11.11-1-MANJARO x86_64 Up: 13h 38m
Mem: 8.23/14.46 GiB (56.9%) Storage: 476.94 GiB (40.3% used) Procs: 380
Shell: Zsh inxi: 3.3.36
Here’s my current audio configuration:
**Audio:**
**Device-1:** Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio **driver:** snd_hda_intel
**Device-2:** Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
**driver:** N/A
**Device-3:** Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
**API:** ALSA **v:** k6.11.11-1-MANJARO **status:** kernel-api
**Server-1:** PipeWire **v:** 1.2.7 **status:** active
Here is my
  Kernel: 6.11.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: hpet avail: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
    root=UUID=c469d789-1f43-4192-b34e-f04344b28b30 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Convertible System: LENOVO product: 21AES0FT04 v: ThinkPad L13 Yoga
    Gen 2a serial: <superuser required> Chassis: type: 31
  Mobo: LENOVO model: 21AES0FT04 serial: <superuser required>
    part-nu: LENOVO_MT_21AE_BU_Think_FM_ThinkPad L13 Yoga Gen 2a
    uuid: <superuser required> UEFI: LENOVO v: R1QET49W (1.35 )
    date: 08/22/2024
  ID-1: BAT0 charge: 40.0 Wh (91.3%) condition: 43.8/46.0 Wh (95.2%)
    power: 18.8 W volts: 17.3 min: 15.4 model: SMP LNV-5B10W13933 type: Li-poly
    serial: <filter> status: charging cycles: 61
  System RAM: total: 16 GiB available: 14.46 GiB used: 6.26 GiB (43.3%)
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Hynix
    part-no: HMAA1GS6CJR6N-XN serial: N/A
  Info: model: AMD Ryzen 7 PRO 5850U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA500011
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 3349 min/max: 400/4507 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3349 2: 3349 3: 3349
    4: 3349 5: 3349 6: 3349 7: 3349 8: 3349 9: 3349 10: 3349 11: 3349 12: 3349
    13: 3349 14: 3349 15: 3349 16: 3349 bogomips: 60705
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 07:00.0 chip-ID: 1002:1638 class-ID: 0300
    temp: 56.0 C
  Device-2: Chicony ThinkPad T490 Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 04f2:b681
  Device-3: Chicony Integrated 5M Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4.1:4 chip-ID: 04f2:b616
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
    s-diag: 581mm (22.86") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1387 built: 2018 res: 1920x1080
    dpi: 166 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600
    blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 293x165mm (11.54x6.5") diag: 336mm (13.2") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
    1024x768, 800x600, 640x480
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
    LLVM 18.1.8 DRM 3.59 6.11.11-1-MANJARO) device-ID: 1002:1638
    memory: 1000 MiB unified: no
  API: Vulkan v: 1.4.303 layers: N/A device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1638
    surfaces: xcb,xlib
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
    Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1
    chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.11.11-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0f0 state: down mac: <filter>
  Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 06:00.0 chip-ID: 14c3:7961 class-ID: 0280
  IF: wlp6s0 state: up mac: <filter>
  Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter driver: btusb v: 0.8
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2
    chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0000
  Local Storage: total: 476.94 GiB used: 192.37 GiB (40.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Disco model: Go-Infinity
    lanes: 4 tech: SSD serial: <filter> fw-rev: V0530B3 temp: 44.9 C
    scheme: GPT
  ID-1: / raw-size: 222.66 GiB size: 218.6 GiB (98.18%)
    used: 192.34 GiB (88.0%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
    label: N/A uuid: c469d789-1f43-4192-b34e-f04344b28b30
  ID-2: /boot/efi raw-size: 261 MiB size: 260 MiB (99.62%)
    used: 31 MiB (11.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: SYSTEM uuid: 08CB-693C
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 252.06 GiB fs: bitlocker
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.95 GiB fs: ntfs
    label: WinRE_DRV uuid: 9EEECE63EECE3377
  Device-1: 1-3:2 info: Chicony ThinkPad T490 Webcam type: video
    driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 04f2:b681 class-ID: 0e02 serial: <filter>
  Device-2: 1-4:3 info: Synaptics Prometheus MIS Touch Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
  Device-1: 3-3:2 info: Foxconn / Hon Hai MediaTek Bluetooth Adapter
    type: bluetooth driver: btusb interfaces: 3 rev: 2.1
  Hub-4: 3-4:3 info: Terminus Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 3-4.1:4 info: Chicony Integrated 5M Camera type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 04f2:b616 class-ID: 0e02 serial: <filter>
  Device-2: 3-4.3:5 info: Wacom Pen and multitouch sensor type: HID
    driver: usbhid,wacom interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 400mA chip-ID: 056a:51f6 class-ID: 0300
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 69.0 C mobo: 30.0 C gpu: amdgpu temp: 55.0 C
  Fan Speeds (rpm): fan-1: 4474
  Packages: 1703 pm: pacman pkgs: 1675 libs: 419 tools: octopi,pamac,yay
    pm: flatpak pkgs: 20 pm: snap pkgs: 8
    1: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    2: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    3: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    4: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    5: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    6: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    7: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    8: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 356
  1: cpu: 6.1% command: konsole pid: 184403 mem: 243.7 MiB (1.6%)
  2: cpu: 4.8% command: firefox pid: 1747 mem: 908.2 MiB (6.1%)
  3: cpu: 2.8% command: zsh pid: 184439 mem: 10.1 MiB (0.0%)
  4: cpu: 2.3% command: electron pid: 5607 mem: 774.3 MiB (5.2%)
  5: cpu: 2.2% command: firefox pid: 176126 mem: 283.1 MiB (1.9%)
  Memory top: 5 of 356
  1: mem: 908.2 MiB (6.1%) command: firefox pid: 1747 cpu: 4.8%
  2: mem: 774.3 MiB (5.2%) command: electron pid: 5607 cpu: 2.3%
  3: mem: 734.1 MiB (4.9%) command: soffice.bin pid: 87311 cpu: 0.9%
  4: mem: 575.4 MiB (3.8%) command: baloo_file_extractor pid: 1694 cpu: 0.1%
  5: mem: 516.6 MiB (3.4%) command: plasmashell pid: 1119 cpu: 0.1%
  Processes: 356 Power: uptime: 14h 7m states: freeze,mem,disk suspend: s2idle
    wakeups: 2 hibernate: platform avail: shutdown, reboot, suspend, test_resume
    image: 5.76 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.36
Has anyone else experienced this or knows a solution? Thank you!
I haven’t, but possibly someone else has.
Some housekeeping:
1. Note that the best way to provide useful system information is to ask your system and provide its output. See information below, and please provide the information indicated.
2. There are established guidelines to presenting your posts; again, read below to discover them. I have edited your post this time. In future you are expected to address this yourself.
Welcome to the Manjaro community.
As a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
Required Reading:
Update Announcements:
The Update Announcements contain update related information and a Known Issues and Solutions section that should generally be checked before posting a request for support.
System Information:
Output of the following command (formatted according to forum requirements) may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
Thank you for you kind help,
I have edited my post with the command you provided. I will do my utmost to comply with the forum rules. As a French speaker, I might encounter some difficulties with expression and comprehension. Additionally, being new here, I may not always know the correct steps to take, but I am doing my best to adapt.
Again, I sincerely thank you for the help and the warm welcome. Your support means a lot as I navigate and adapt to the forum.
Do the best you can :slight_smile:
The links provided will help you navigate the forum and learn what you need to generate quality responses from the community. Most of the formatting information can be found via the second link.
This is not strictly related to the sound issue - nonetheless the linux 6.11 kernel is EOL
mhwd-kernel -i linux612 rmc
I would use Wayland - lower left corner at login - switch session to Plasma Wayland
Check the browsers volume setting - it works separately from your system’s volume.
Thanks for your reply, I’ve updated my kernel. I also ran this command:
journalctl --user -u pipewire -f
and now everything works.
Just so you know, it was the laptop sound that was dropping, not the browser.
Thanks again
