Hello to all!
First time user at the forum and very newbie at using Linux, I need assistance in configuring my old yet reliable laptop, an HP Probook 655 G1, built and sold in 2014, which I installed Manjaro last week, with several issues at first boot.
This current issue, is about the soundcard chip, an IDT High Definition Audio 92HD81B1X that is handled as a generic device, which unfortunately does not provide sound of any kind.
I have been manually (and haphazardly) applying solutions, with varying degrees of success, yet it seems that I’ve borked the audio for good after blindly installing both Pipewire and PulseAudio.
Here is the output of inxi
inxi -Fazy
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=a2987ff4-1a0c-4e0a-8bba-3f586a5c4db0 rw quiet splash
resume=UUID=e823f6d9-7441-4322-8168-f2f70c75b31d udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Hewlett-Packard product: HP ProBook 655 G1
v: A3008DD11303 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 1992 v: KBC Version 05.34
serial: <superuser required> UEFI: Hewlett-Packard v: L72 Ver. 01.47
date: 07/30/2018
Info: model: AMD A8-5550M APU with Radeon HD Graphics bits: 64 type: MT MCP
arch: Piledriver level: v2 built: 2012-13 process: GF 32nm family: 0x15 (21)
model-id: 0x13 (19) stepping: 1 microcode: 0x600111F
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 192 KiB
desc: d-4x16 KiB; i-2x64 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 1565 high: 2100 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1361 2: 1400
3: 1400 4: 2100 bogomips: 16775
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Richland [Radeon HD 8550G] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu arch: TeraScale-3
code: Northern Islands process: TSMC 32nm built: 2010-13 ports:
active: DP-2,eDP-1 empty: DP-1,DP-3,DP-4 bus-ID: 00:01.0 chip-ID: 1002:990d
class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP HD Webcam type: USB
driver: uvcvideo bus-ID: 1-5:3 chip-ID: 05c8:0369 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: radeon unloaded: modesetting alternate: fbdev,vesa dri: r600
gpu: radeon display-ID: :0 screens: 1
Screen-1: 0 s-res: 2726x768 s-dpi: 96 s-size: 720x203mm (28.35x7.99")
s-diag: 748mm (29.45")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,left model: AOC 1943W
serial: <filter> built: 2011 res: 1360x768 hz: 60 dpi: 84 gamma: 1.2
size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9 modes:
max: 1366x768 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: right model: Samsung 0x4851 built: 2012
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
API: OpenGL v: 4.5 Mesa 22.3.1 renderer: AMD ARUBA (DRM 2.50.0 /
6.1.1-1-MANJARO LLVM 14.0.6) direct render: Yes
Device-1: AMD Trinity HDMI Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9902
class-ID: 0403
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Broadcom BCM43228 802.11a/b/g/n driver: wl v: kernel
modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 14e4:4359 class-ID: 0280
Device-1: Broadcom HP Portable Bumble Bee type: USB driver: btusb v: 0.8
bus-ID: 3-3:2 chip-ID: 0a5c:21f1 class-ID: fe01 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 2.27 TiB used: 484.91 GiB (20.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
type: SSD serial: <filter> rev: 032 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD20SDRW-11VUUS0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 1026 scheme: GPT
ID-1: / raw-size: 456.66 GiB size: 448.43 GiB (98.20%)
used: 86.14 GiB (19.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 8.8 GiB used: 512 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 46.4 C mobo: N/A gpu: radeon temp: 45.0 C
Processes: 199 Uptime: 1h 6m wakeups: 1 Memory: 6.97 GiB
used: 3.02 GiB (43.3%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1287 libs: 381 tools: pamac,yay pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
The ALSA information about my system, uploaded to the database:
http://alsa-project.org/db/?f=e2db7810ed6a346f25e3802fad9f3e5127696261
I also have the hardware probe of my current setup:
https://linux-hardware.org/?probe=e5f3b2835d
Thank you for your patience!
