Sound Converter will not launch
Sound Converter stopped working for me today. Clicking the menu launcher does nothing. Running it from the terminal I get the following error:
$ soundconverter
  File "/usr/bin/soundconverter", line 283, in <module>
    options, files = parser.parse_args(args[1:])
TypeError: 'NoneType' object is not subscriptable
I’ve tried uninstalling it, and then reinstalling it from pamac, and it did not change anything.
Any idea what I can do about this?
I’m on Manjaro XFCE, kernel 6.18.12-1
Let me know if there is further information I can provide to diagnose this. Thank you.
Ok, same for me…
❯ soundconverter
Let me see… the same happens on my TEST user too… so it’s not you.
This on Plasma, so not XFCE either.
Git failed to build too :frowning:
Let’s BODGE the thing:
kate /usr/bin/soundconverter
Now copy and search: options, files = parser.parse_args(args[1:])
That’s Line 283… so use Find and Replace:
`options, files = parser.parse_args(args[1:] if args else [])`
Job’s a good one,
Mark it solved (for now) :check_mark:
Thank you Ben. This appears to have worked without actually trying to convert a file. At least the program opens.
For clarity sake for other people that may find this post…
You need to open /usr/bin/soundconverter with your text editor.
So in my case on XFCE, it is:
sudo mousepad /usr/bin/soundconverter
Replace mousepad with whatever you use for a text editor.
Note: Edited the comment ‘open with sudo’ - because that’s entirely dependent on editor. Using fresh-editor, or Kate editor, for example - you only enter your admin password when you SAVE the file.
