systemctl --user --full --no-pager status pipewire pipewire-pulse wireplumber
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; preset: enabled)
Active: active (running) since Mon 2024-07-29 12:55:10 MDT; 1 week 1 day ago
Invocation: 24ad8ecbee6441619508d256941d00ea
TriggeredBy: ● pipewire.socket
Main PID: 24846 (pipewire)
Tasks: 3 (limit: 38326)
Memory: 7.5M (peak: 9.3M)
CPU: 34.588s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─24846 /usr/bin/pipewire
Jul 29 12:55:10 diana-ms7b47 systemd[24608]: Started PipeWire Multimedia Service.
● pipewire-pulse.service - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; disabled; preset: enabled)
Active: active (running) since Mon 2024-07-29 12:55:11 MDT; 1 week 1 day ago
Invocation: a321cd519acc42388b0242dddb735324
TriggeredBy: ● pipewire-pulse.socket
Main PID: 25025 (pipewire-pulse)
Memory: 14.2M (peak: 15.7M)
CPU: 1min 2.206s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
└─25025 /usr/bin/pipewire-pulse
Jul 29 12:55:11 diana-ms7b47 systemd[24608]: Started PipeWire PulseAudio.
● wireplumber.service - Multimedia Service Session Manager
Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; preset: enabled)
Invocation: b287d067afc741a8a7354a9ca717190e
Main PID: 24847 (wireplumber)
Tasks: 7 (limit: 38326)
Memory: 13.4M (peak: 15.4M)
CPU: 3.377s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/wireplumber.service
└─24847 /usr/bin/wireplumber
Jul 29 12:55:10 diana-ms7b47 systemd[24608]: Started Multimedia Service Session Manager.
Jul 29 12:55:11 diana-ms7b47 wireplumber[24847]: spa.bluez5: BlueZ system service is not available
Jul 29 12:55:11 diana-ms7b47 wireplumber[24847]: [41:21:21.540991463] [24847] ERROR IPAModule ipa_module.cpp:172 Symbol ipaModuleInfo not found
Jul 29 12:55:11 diana-ms7b47 wireplumber[24847]: [41:21:21.541005209] [24847] ERROR IPAModule ipa_module.cpp:292 v4l2-compat.so: IPA module has no valid info
Jul 29 12:55:11 diana-ms7b47 wireplumber[24847]: [41:21:21.541030147] [24847] INFO Camera camera_manager.cpp:313 libcamera v0.3.0
pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 1038
Tile Size: 65472
User Name: diana
Host Name: diana-ms7b47
Server Name: PulseAudio (on PipeWire 1.2.1)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1f.3.hdmi-stereo
Default Source: alsa_output.pci-0000_00_1f.3.hdmi-stereo.monitor
Cookie: 1dac:52b8
pactl list cards
Card #44
Driver: alsa
Owner Module: n/a
Properties:
api.acp.auto-port = "false"
api.alsa.card = "1"
api.alsa.card.longname = "HDA Creative at 0xdf104000 irq 18"
api.alsa.card.name = "HDA Creative"
api.alsa.path = "hw:1"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1 = "Audio1"
api.dbus.ReserveDevice1.Priority = "-20"
device.api = "alsa"
device.bus = "pci"
device.bus_path = "pci-0000:03:00.0"
device.description = "CA0132 Sound Core3D [Sound Blaster Recon3D / Z-Series / Sound BlasterX AE-5 Plus] (SB1570 SB Audigy Fx)"
device.enum.api = "udev"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_03_00.0"
device.nick = "HDA Creative"
device.plugged.usec = "6369552"
device.product.id = "0x0012"
device.product.name = "CA0132 Sound Core3D [Sound Blaster Recon3D / Z-Series / Sound BlasterX AE-5 Plus] (SB1570 SB Audigy Fx)"
device.subsystem = "sound"
sysfs.path = "/devices/pci0000:00/0000:00:1c.6/0000:03:00.0/sound/card1"
device.vendor.id = "0x1102"
device.vendor.name = "Creative Labs"
media.class = "Audio/Device"
factory.id = "15"
client.id = "41"
object.id = "44"
object.serial = "44"
object.path = "alsa:acp:Creative"
alsa.card = "1"
alsa.card_name = "HDA Creative"
alsa.long_card_name = "HDA Creative at 0xdf104000 irq 18"
alsa.mixer_name = "Realtek ALC898"
alsa.components = "HDA:10ec0899,11020041,00100003"
alsa.id = "Creative"
device.string = "1"
Profiles:
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: no)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: no)
output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-41: Analog Surround 4.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-51: Analog Surround 5.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-40: Analog Surround 4.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
output:analog-surround-50: Analog Surround 5.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
pro-audio: Pro Audio (sinks: 1, sources: 2, priority: 1, available: yes)
Active Profile: off
Ports:
analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
port.type = "mic"
port.availability-group = "Legacy 1"
card.profile.port = "0"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo
analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "mic"
port.availability-group = "Legacy 2"
card.profile.port = "1"
analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "line"
port.availability-group = "Legacy 3"
card.profile.port = "2"
analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "line"
port.availability-group = "Legacy 4"
card.profile.port = "3"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 5, not available)
Properties:
port.type = "headphones"
port.availability-group = "Legacy 5"
card.profile.port = "4"
Card #45
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "0"
api.alsa.card.longname = "HDA Intel PCH at 0xdf340000 irq 143"
api.alsa.card.name = "HDA Intel PCH"
api.alsa.path = "hw:0"
device.api = "alsa"
device.bus = "pci"
device.description = "Built-in Audio"
device.name = "alsa_card.pci-0000_00_1f.3"
device.nick = "HDA Intel PCH"
device.plugged.usec = "6401564"
device.product.id = "0xa2f0"
device.product.name = "200 Series PCH HD Audio"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.vendor.id = "0x8086"
factory.id = "15"
client.id = "41"
object.id = "45"
object.serial = "45"
object.path = "alsa:acp:PCH"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xdf340000 irq 143"
alsa.mixer_name = "Realtek ALC892"
alsa.components = "HDA:10ec0892,1462eb47,00100302 HDA:8086280b,80860101,00100000"
alsa.id = "PCH"
device.string = "0"
Profiles:
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5965, available: yes)
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: yes)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5565, available: yes)
output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 5500, available: yes)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:iec958-ac3-surround-51+input:analog-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 365, available: no)
output:iec958-ac3-surround-51: Digital Surround 5.1 (IEC958/AC3) Output (sinks: 1, sources: 0, priority: 300, available: yes)
output:hdmi-ac3-surround+input:analog-stereo: Digital Surround 5.1 (HDMI/AC3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 165, available: no)
output:hdmi-ac3-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2/AC3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 165, available: no)
output:hdmi-ac3-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3/AC3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 165, available: no)
output:hdmi-ac3-surround: Digital Surround 5.1 (HDMI/AC3) Output (sinks: 1, sources: 0, priority: 100, available: yes)
output:hdmi-ac3-surround-extra1: Digital Surround 5.1 (HDMI 2/AC3) Output (sinks: 1, sources: 0, priority: 100, available: yes)
output:hdmi-ac3-surround-extra2: Digital Surround 5.1 (HDMI 3/AC3) Output (sinks: 1, sources: 0, priority: 100, available: yes)
pro-audio: Pro Audio (sinks: 5, sources: 2, priority: 1, available: yes)
Active Profile: output:hdmi-stereo+input:analog-stereo
Ports:
Properties:
port.type = "mic"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-ac3-surround-51+input:analog-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-ac3-surround+input:analog-stereo, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1+input:analog-stereo, output:hdmi-ac3-surround-extra1+input:analog-stereo, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2+input:analog-stereo, output:hdmi-ac3-surround-extra2+input:analog-stereo
Properties:
port.type = "mic"
Properties:
port.type = "line"
Properties:
port.type = "line"
Properties:
iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
Properties:
port.type = "spdif"
card.profile.port = "5"
Part of profile(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 6, available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 6"
card.profile.port = "6"
device.product.name = "HP 2310"
Part of profile(s): output:hdmi-stereo, output:hdmi-stereo+input:analog-stereo
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 7, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 7"
card.profile.port = "7"
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1, output:hdmi-surround71-extra1+input:analog-stereo
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 8, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 8"
card.profile.port = "8"
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2, output:hdmi-surround71-extra2+input:analog-stereo
The HDMI one was on but got turned off at some point. I’m most interested in getting the sound card operative so my speakers work, though.
Thanks.
