Sound card alive or broken?
update to 6.11.10 went fine and few days vas excelent than troubles started and had 2 replace cpu cooler .
to make it easire i put down video and sound card.
after job done my manjaro.kde was not in full function and without sound so i rolled out all kernels but not much better, on 5.3 i could use browser … even tried 6.12 - half funciton. then rollred to 6.1.119-1 it was good but nno sound and slow.
i made few checks (sound card out and in) and reboot, it vas my good old manjaro.kde but no sound.
when wanted to make a post here, checked the kernel to my suprise it is on 6.12
  • is card broken and doing all that trouble ?
inxi -Fxz
  Kernel: 6.12.1-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
  Desktop: KDE Plasma v: 6.2.4 Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: Maximus II Formula v: Rev 1.xx
    serial: <superuser required> BIOS: American Megatrends v: 2302
    date: 04/15/2010
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
    charge: 55% (should be ignored) status: discharging
  Info: quad core model: Intel Core2 Quad Q6600 bits: 64 type: MCP
    arch: Core2 Merom rev: B cache: L1: 256 KiB L2: 8 MiB
  Speed (MHz): avg: 1607 min/max: 1603/2403 cores: 1: 1607 2: 1607 3: 1607
    4: 1607 bogomips: 19210
  Flags: ht lm nx pae sse sse2 sse3 ssse3 vmx
  Device-1: NVIDIA GK107 [GeForce GTX 650] driver: nvidia v: 470.256.02
    arch: Kepler-2 bus-ID: 01:00.0
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4 driver: X:
    loaded: N/A failed: nvidia gpu: nvidia,nvidia-nvswitch s-res: 1920x1080
    resolution: 1: 1920x1080
  API: EGL v: 1.5 drivers: kms_swrast,nvidia,swrast platforms:
    active: gbm,x11,surfaceless,device inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 470.256.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 650/PCIe/SSE2
  API: Vulkan v: 1.3.295 drivers: nvidia surfaces: xcb,xlib devices: 1
  Device-1: Intel 82801JI HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0
  Device-2: NVIDIA GK107 HDMI Audio driver: snd_hda_intel v: kernel
    bus-ID: 01:00.1
  API: ALSA v: k6.12.1-4-MANJARO status: kernel-api
  Server-1: sndiod v: N/A status: off
  Server-2: JACK v: 1.9.22 status: off
  Server-3: PipeWire v: 1.2.7 status: off
  Server-4: PulseAudio v: 17.0 status: active
  Device-1: Marvell 88E8056 PCI-E Gigabit Ethernet vendor: ASUSTeK
    driver: sky2 v: 1.30 port: c800 bus-ID: 03:00.0
  Device-2: Marvell 88E8056 PCI-E Gigabit Ethernet vendor: ASUSTeK
    driver: sky2 v: 1.30 port: d800 bus-ID: 04:00.0
  IF: enp4s0 state: down mac: <filter>
  Local Storage: total: 1.58 TiB used: 180.51 GiB (11.1%)
  ID-1: /dev/sda vendor: Western Digital model: WD5000AAKX-00ERMA0
  ID-2: /dev/sdb vendor: Western Digital model: WD10EZEX-08WN4A0
  ID-3: /dev/sdc vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB
  ID-1: / size: 219 GiB used: 180.51 GiB (82.4%) fs: ext4 dev: /dev/sdc1
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) file: /swapfile
  System Temperatures: cpu: 49.5 C mobo: 37.0 C psu: 40.0 C
  Fan Speeds (rpm): cpu: 2280 psu: 898
  Power: 12v: 12.10 5v: N/A 3.3v: 3.20 vbat: N/A
  Memory: total: 8 GiB available: 7.75 GiB used: 3 GiB (38.7%)
  Processes: 222 Uptime: 1h 13m Init: systemd
  Packages: 1546 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9
    inxi: 3.3.36
in audio setting GK107HDMI audio controler is marked as switched off and aoudio out is marked unplaged
Data shows onboard audio device Intel 82801JI HD is detected
Audio playback devices in ALSA ( aplay -l ) should look like this
HW probe of ASUSTek Maximus II Formula Desktop Computer #66a4342140: aplay
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: AD1989B Analog [AD1989B Analog]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 1: AD1989B Digital [AD1989B Digital]
  Subdevices: 1/1
card 0: Intel [HDA Intel], device 2: AD1989B Alt Analog [AD1989B Alt Analog]
  Subdevices: 1/1
ALSA mixer controls ( amixer --card=0 ) should be similar to this:
HW probe of ASUSTek Maximus II Formula Desktop Computer #66a4342140: amixer
Mixer controls can also be checked or adjusted using:
alsamixer --card=0 --view=all
Please post more information about audio devices detected in PulseAudio
pactl list cards
Also suggest try using LTS kernel v6.6 instead of v6.12 for an older system
i have downgraded kernels now am back on new because new 470 nvidia drivers are excellent fit (without any x glitches) and feel like system is a bit faster (for now). sound problems where shown on all older kernels, even on 5.3 .
this mobo was shipped without onboard sound but with pci card creative-supremeFX
is it maybe Intel chip 82801JI HD , in gui audio settings shows GK107HDMI ?
now in output is seen usb card (not good as pci card)
  Subdevices: 1/1
  Subdevices: 1/1
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
card 2: Device [USB Audio Device], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
amixer --card=0        Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 39
  Mono: Playback 39 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 39 [100%] [0.00dB] [on]
  Front Right: Playback 39 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
  Mono:
  Front Left: Playback 39 [100%] [0.00dB] [off]
  Front Right: Playback 39 [100%] [0.00dB] [off]
Simple mixer control 'Front Mic',0
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
  Mono:
  Front Left: Playback 0 [0%] [-58.50dB] [off]
  Front Right: Playback 0 [0%] [-58.50dB] [off]
Simple mixer control 'Center',0
  Mono: Playback 0 [0%] [-58.50dB] [off]
Simple mixer control 'LFE',0
Simple mixer control 'Side',0
  Mono:
Simple mixer control 'Line',0
  Mono:
Simple mixer control 'Line Boost',0
  Limits: 0 - 3
  Front Left: 3 [100%] [30.00dB]
  Front Right: 3 [100%] [30.00dB]
Simple mixer control 'CD',0
  Mono:
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [off]
Simple mixer control 'IEC958 Default PCM',0
  Mono: Playback [on]
Simple mixer control 'Beep',0
  Limits: Playback 0 - 15
  Mono: Playback 15 [100%] [0.00dB] [off]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 54
  Front Left: Capture 54 [100%] [22.50dB] [off]
  Front Right: Capture 54 [100%] [22.50dB] [off]
Simple mixer control 'Capture',1
  Front Left: Capture 0 [0%] [-58.50dB] [off]
  Front Right: Capture 0 [0%] [-58.50dB] [off]
Simple mixer control 'Capture',2
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Enabled'
Simple mixer control 'Digital',0
  Limits: Capture 0 - 120
  Front Left: Capture 60 [50%] [0.00dB]
  Front Right: Capture 60 [50%] [0.00dB]
Simple mixer control 'Independent HP',0
  Capabilities: enum
  Item0: 'Disabled'
Simple mixer control 'Input Source',0
  Capabilities: cenum
  Items: 'Rear Mic' 'Front Mic' 'Line' 'CD' 'Stereo Mix'
  Item0: 'Line'
Simple mixer control 'Input Source',1
  Capabilities: cenum
  Item0: 'Front Mic'
Simple mixer control 'Input Source',2
  Capabilities: cenum
  Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
  Mono:
Simple mixer control 'Rear Mic Boost',0
  Limits: 0 - 3
pactl list cards................................................
Kartice #1
        Naziv: alsa_card.usb-C-Media_Electronics_Inc._USB_Audio_Device-00
        Upravljački program: module-alsa-card.c
        Vlasnik modula: 7
        Svojstva:
                alsa.card = "2"
                alsa.card_name = "USB Audio Device"
                alsa.long_card_name = "C-Media Electronics Inc. USB Audio Device at usb-0000:00:1a.2-2, full speed"
                alsa.driver_name = "snd_usb_audio"
                device.bus_path = "pci-0000:00:1a.2-usb-0:2:1.0"
                sysfs.path = "/devices/pci0000:00/0000:00:1a.2/usb5/5-2/5-2:1.0/sound/card2"
                udev.id = "usb-C-Media_Electronics_Inc._USB_Audio_Device-00"
                device.bus = "usb"
                device.vendor.id = "0d8c"
                device.vendor.name = "C-Media Electronics, Inc."
                device.product.id = "0012"
                device.product.name = "USB Audio Device"
                device.serial = "C-Media_Electronics_Inc._USB_Audio_Device"
                device.string = "2"
                device.description = "USB Audio Device"
                module-udev-detect.discovered = "1"
                device.icon_name = "audio-card-usb"
        Profili:
                input:mono-fallback: Mono ulaz (slivnici: 0, izvori: 1, prioritet: 1, dostupno: da)
                output:analog-stereo: Analogni stereo izlaz (slivnici: 1, izvori: 0, prioritet: 6500, dostupno: da)
                output:analog-stereo+input:mono-fallback: Analogni stereo izlaz + Mono ulaz (slivnici: 1, izvori: 1, prioritet: 6501, dostupno: da)
                output:iec958-stereo: Digitalni stereo (IEC958) izlaz (slivnici: 1, izvori: 0, prioritet: 5500, dostupno: da)
                output:iec958-stereo+input:mono-fallback: Digitalni stereo (IEC958) izlaz + Mono ulaz (slivnici: 1, izvori: 1, prioritet: 5501, dostupno: da)
                output:iec958-ac3-surround-51: Digitalni surround 5.1 (IEC958/AC3) izlaz (slivnici: 1, izvori: 0, prioritet: 300, dostupno: da)
                output:iec958-ac3-surround-51+input:mono-fallback: Digitalni surround 5.1 (IEC958/AC3) izlaz + Mono ulaz (slivnici: 1, izvori: 1, prioritet: 301, dostupno: da)
                off: Isključeno (slivnici: 0, izvori: 0, prioritet: 0, dostupno: da)
        Aktivni profil: output:analog-stereo
        Ulazi:
                analog-input-mic: Mikrofon (vrsta: Mikrofon, prioritet: 8700, pomak latencije: 0 usek, dostupnost nepoznata)
                        Svojstva:
                        Dio profila: input:mono-fallback, output:analog-stereo+input:mono-fallback, output:iec958-stereo+input:mono-fallback, output:iec958-ac3-surround-51+input:mono-fallback
                analog-output-speaker: Zvučnici (vrsta: Zvučnik, prioritet: 10000, pomak latencije: 0 usek, dostupnost nepoznata)
                        Svojstva:
                        Dio profila: output:analog-stereo, output:analog-stereo+input:mono-fallback
                iec958-stereo-output: Digitalni izlaz (S/PDIF) (vrsta: SPDIF, prioritet: 0, pomak latencije: 0 usek, dostupnost nepoznata)
                        Dio profila: output:iec958-stereo, output:iec958-stereo+input:mono-fallback
Kartice #2
        Naziv: alsa_card.pci-0000_00_1b.0
        Vlasnik modula: 8
        Svojstva:
                alsa.card = "0"
                alsa.card_name = "HDA Intel"
                alsa.long_card_name = "HDA Intel at 0xfcff8000 irq 27"
                device.bus_path = "pci-0000:00:1b.0"
                sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
                device.bus = "pci"
                device.vendor.id = "8086"
                device.product.id = "3a3e"
                device.product.name = "82801JI (ICH10 Family) HD Audio Controller"
                device.string = "0"
                device.description = "Ugrađeni zvuk"
                device.icon_name = "audio-card-pci"
        Profili:
                input:analog-stereo: Analogni stereo ulaz (slivnici: 0, izvori: 1, prioritet: 32833, dostupno: da)
                output:analog-stereo: Analogni stereo izlaz (slivnici: 1, izvori: 0, prioritet: 6500, dostupno: ne)
                output:analog-stereo+input:analog-stereo: Analogni stereo obostrani (slivnici: 1, izvori: 1, prioritet: 6565, dostupno: da)
                output:analog-surround-21: Analogni surround 2.1 izlaz (slivnici: 1, izvori: 0, prioritet: 1300, dostupno: ne)
                output:analog-surround-21+input:analog-stereo: Analogni surround 2.1 izlaz + Analogni stereo ulaz (slivnici: 1, izvori: 1, prioritet: 1365, dostupno: da)
                output:analog-surround-40: Analogni surround 4.0 izlaz (slivnici: 1, izvori: 0, prioritet: 1200, dostupno: ne)
                output:analog-surround-40+input:analog-stereo: Analogni surround 4.0 izlaz + Analogni stereo ulaz (slivnici: 1, izvori: 1, prioritet: 1265, dostupno: da)
                output:analog-surround-41: Analogni surround 4.1 izlaz (slivnici: 1, izvori: 0, prioritet: 1300, dostupno: ne)
                output:analog-surround-41+input:analog-stereo: Analogni surround 4.1 izlaz + Analogni stereo ulaz (slivnici: 1, izvori: 1, prioritet: 1365, dostupno: da)
                output:analog-surround-50: Analogni surround 5.0 izlaz (slivnici: 1, izvori: 0, prioritet: 1200, dostupno: ne)
                output:analog-surround-50+input:analog-stereo: Analogni surround 5.0 izlaz + Analogni stereo ulaz (slivnici: 1, izvori: 1, prioritet: 1265, dostupno: da)
                output:analog-surround-51: Analogni surround 5.1 izlaz (slivnici: 1, izvori: 0, prioritet: 1300, dostupno: ne)
                output:analog-surround-51+input:analog-stereo: Analogni surround 5.1 izlaz + Analogni stereo ulaz (slivnici: 1, izvori: 1, prioritet: 1365, dostupno: da)
                output:analog-surround-71: Analog Surround 7.1 izlaz (slivnici: 1, izvori: 0, prioritet: 1200, dostupno: ne)
                output:analog-surround-71+input:analog-stereo: Analog Surround 7.1 izlaz + Analogni stereo ulaz (slivnici: 1, izvori: 1, prioritet: 1265, dostupno: da)
                output:iec958-stereo: Digitalni stereo (IEC958) izlaz (slivnici: 1, izvori: 0, prioritet: 38268, dostupno: da)
                output:iec958-stereo+input:analog-stereo: Digitalni stereo (IEC958) izlaz + Analogni stereo ulaz (slivnici: 1, izvori: 1, prioritet: 38333, dostupno: da)
                output:iec958-ac3-surround-51+input:analog-stereo: Digitalni surround 5.1 (IEC958/AC3) izlaz + Analogni stereo ulaz (slivnici: 1, izvori: 1, prioritet: 33133, dostupno: da)
        Aktivni profil: output:analog-stereo+input:analog-stereo
        Ulazi:
                analog-input-front-mic: Prednji mikrofon (vrsta: Mikrofon, prioritet: 8500, pomak latencije: 0 usek, nedostupno)
                        Svojstva:
                        Dio profila: input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:analog-surround-71+input:analog-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-ac3-surround-51+input:analog-stereo
                analog-input-rear-mic: Stražnji mikrofon (vrsta: Mikrofon, prioritet: 8200, pomak latencije: 0 usek, nedostupno)
                        Svojstva:
                analog-input-linein: Ulaz (vrsta: Ulaz, prioritet: 8100, pomak latencije: 0 usek, dostupno)
                analog-output-lineout: Izlaz (vrsta: Ulaz, prioritet: 9000, pomak latencije: 0 usek, nedostupno)
                        Dio profila: output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo, output:analog-surround-71, output:analog-surround-71+input:analog-stereo
                analog-output-headphones: Slušalice (vrsta: Slušalice, prioritet: 9900, pomak latencije: 0 usek, nedostupno)
                        Svojstva:
                        Dio profila: output:iec958-stereo, output:iec958-stereo+input:analog-stereo
on settings is seen that signal is present
Later versions of Asus/Republic of Gamers motherboards, with SupremeFX III audio, were built-in to the motherboard, But for this motherboard, the user manual shows an additional pci-e card for audio
PulseAudio data shows the internal audio card profile for output:analog-stereo (3.5mm jack) is not available (dostupno: ne), but the output:iec958-stereo (S/PDIF output) is available (dostupno: da)
pactl list cards
Kartice #2
        Svojstva:
                alsa.card = "0"
        Profili:
        Ulazi:
ALSA mixer control to use S/PDIF digital output as default is turned on
  Mono: Playback [on]
If the S/PDIF digital output is not in use, turn this off in alsamixer -c0
Audio GUI controls should then show Built-in Sound Analog stereo (Ugrađeni zvuk Analogni stereo) instead of Digital stereo (Digitalni stereo)
If audio is still not working as expected, turn off the option in Audio GUI controls for Simultaneous output to both audio devices
thank you on your time and care, feel like i waste it.
think at list physical inputs on card must be broken.
i ll remove it once more and try to work out about connectors and pins ??
If the analog output port is always shown as unplugged the sound card may just be failing to detect that the audio jack is plugged-in
Jack detection can be disabled by installing package alsa-tools and using jack retasking tool
sudo hdajackretask
To disable detection of a specific output, enable Advanced Override, enable Override for a specific output Pin and change Jack detection to Not present
Imgur
Click on Install boot override and reboot system to load the boot override
If the jack-detection is disabled, the Line Out (izlaz) output will no longer show as (unplugged) in audio GUI controls
by override settings selection, audio-gui-ctrl shows no output devices .
must be a card faliure ( m wandering if is pcix1 or card itself)
hdajackretask should show 2 audio codecs in the drop-down menu for AD1989B and GK107 HDMI, but the AD1989B card might not support use of re-tasking tool
hdajackretask is the only GUI tool that I know of that can permanently disable jack-detection. There are other ways to reconfigure ALSA (or PulseAudio) to disable or ignore jack-detection for the Line Out socket, but I cannot find any documentation for a simple and persistent solution
The pragmatic solution for this would be to replace the sound card. Motherboard has PCI and PCI-E slots, so any Asus Xonar card should work with no issues
board has 2 pci16 and 2 pci slots. as far as i remember one pci was beroken when i get used board, maybe due to pluging and unpluging sound card the pci slot connectors broke come broken.
it would be good to be shure about that before looking for new card
