Hey everyone. So I am giving KDE Plasma Manjaro Linux another shot because I’m utterly disgusted with windows and unfortunately I am unable to get my audio working. I’ve spent several hours messing with alsa, pulseaudio, etc and have had no results.
When looking at the speaker icon on the taskbar, it shows audio levels fluctuation as I am running Youtube videos as a test though there is no actual output.
I’ve scoured the internet, reddit, forums, youtube, etc. and can’t seem to find anything to get it to work. The card definitely works as prior to this setup I was playing sound on Windows 10 through the same card.
Help would be greatly appreciated. Below I have posted relevant information. Tysm!
inxi -F
System: Host: DragonsDen Kernel: 5.12.16-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.22.3 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME X299-DELUXE v: Rev 1.xx serial:
UEFI: American Megatrends v: 1503 date: 08/03/2018
CPU: Info: 14-Core model: Intel Core i9-7940X bits: 64 type: MT MCP cache: L2: 19.2 MiB
Speed: 1328 MHz min/max: 1200/4500 MHz Core speeds (MHz): 1: 1328 2: 4203 3: 1921 4: 1200 5: 1398 6: 1200 7: 1357
8: 1691 9: 1200 10: 1200 11: 1395 12: 1200 13: 1200 14: 1200 15: 1200 16: 1200 17: 1200 18: 1200 19: 1200 20: 1200
21: 1202 22: 1200 23: 3812 24: 1200 25: 1200 26: 1200 27: 1200 28: 1200
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1080] driver: nouveau v: kernel
Display: x11 server: X.Org 1.20.11 driver: loaded: nouveau unloaded: modesetting resolution: 1: 1920x1080~60Hz
2: 1920x1080~60Hz
OpenGL: renderer: NV134 v: 4.3 Mesa 21.1.4
Audio: Device-1: Intel 200 Series PCH HD Audio driver: snd_hda_intel
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
Device-3: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series] driver: snd_hda_intel
Sound Server-1: ALSA v: k5.12.16-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 14.2 running: yes
Sound Server-3: PipeWire v: 0.3.31 running: yes
Network: Device-1: Intel Ethernet I219-V driver: e1000e
IF: enp0s31f6 state: down mac: 18:31:bf:ba:5f:f4
Device-2: Wilocity Wil6200 802.11ad Wireless Network Adapter driver: wil6210
IF: wlp2s0 state: down mac: 7e:65:27:4b:48:74
Device-3: Intel I211 Gigabit Network driver: igb
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: 40:16:7e:a5:25:79
Device-4: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter driver: ath10k_pci
IF: wlp5s0 state: down mac: e2:57:9c:5d:4f:7a
Device-5: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: bcma-pci-bridge
Bluetooth: Device-1: ASUSTek type: USB driver: btusb
RAID: Hardware-1: Intel SATA Controller [RAID mode] driver: ahci
Drives: Local Storage: total: 15.46 TiB used: 8.97 GiB (0.1%)
ID-1: /dev/sda vendor: Seagate model: ST2000DM009-2G4100 size: 1.82 TiB
ID-2: /dev/sdb vendor: Western Digital model: WDS100T2B0A-00SM50 size: 931.51 GiB
ID-3: /dev/sdc vendor: Western Digital model: WD80EZAZ-11TDBA0 size: 7.28 TiB
ID-4: /dev/sdd vendor: Toshiba model: DT01ACA200 size: 1.82 TiB
ID-5: /dev/sde vendor: Western Digital model: WD4004FZWX-00GBGB0 size: 3.64 TiB
Partition: ID-1: / size: 881.92 GiB used: 8.97 GiB (1.0%) fs: ext4 dev: /dev/dm-0
ID-2: /boot/efi size: 299.4 MiB used: 440 KiB (0.1%) fs: vfat dev: /dev/sdb1
Swap: ID-1: swap-1 type: partition size: 34.13 GiB used: 0 KiB (0.0%) dev: /dev/dm-1
Sensors: System Temperatures: cpu: 33.0 C mobo: N/A gpu: nouveau temp: 36.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 961
Info: Processes: 447 Uptime: 29m Memory: 31.03 GiB used: 2.84 GiB (9.1%) Shell: Bash inxi: 3.3.05
aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
sysdefault:CARD=PCH
HDA Intel PCH, ALC1220 Analog
Default Audio Device
front:CARD=PCH,DEV=0
Front output / input
surround21:CARD=PCH,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=PCH,DEV=0
HDA Intel PCH, ALC1220 Digital
IEC958 (S/PDIF) Digital Audio Output
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
hdmi:CARD=NVidia,DEV=0
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, HDMI 1
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 2
HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
HDA NVidia, HDMI 3
HDMI Audio Output
hdmi:CARD=NVidia,DEV=4
HDA NVidia, HDMI 4
HDMI Audio Output
hdmi:CARD=NVidia,DEV=5
HDA NVidia, HDMI 5
HDMI Audio Output
hdmi:CARD=NVidia,DEV=6
HDA NVidia, HDMI 6
HDMI Audio Output
usbstream:CARD=NVidia
HDA NVidia
USB Stream Output
sysdefault:CARD=Creative
HDA Creative, CA0132 Analog
front:CARD=Creative,DEV=0
surround21:CARD=Creative,DEV=0
surround40:CARD=Creative,DEV=0
surround41:CARD=Creative,DEV=0
surround50:CARD=Creative,DEV=0
surround51:CARD=Creative,DEV=0
surround71:CARD=Creative,DEV=0
iec958:CARD=Creative,DEV=0
HDA Creative, CA0132 Digital
usbstream:CARD=Creative
HDA Creative
USB Stream Output
dmesg | grep snd
[ 13.736784] snd_hda_intel 0000:00:1f.3: enabling device (0000 → 0002)
[ 13.737279] snd_hda_intel 0000:65:00.1: enabling device (0100 → 0102)
[ 13.737350] snd_hda_intel 0000:65:00.1: Disabling MSI
[ 13.737386] snd_hda_intel 0000:65:00.1: Handle vga_switcheroo audio client
[ 13.737473] snd_hda_intel 0000:b3:00.0: enabling device (0100 → 0102)
[ 13.737542] snd_hda_intel 0000:b3:00.0: Disabling MSI
[ 13.737544] snd_hda_intel 0000:b3:00.0: Force to non-snoop mode
[ 13.869161] snd_hda_codec_ca0132 hdaudioC2D1: autoconfig for Sound BlasterX AE-5: line_outs=3 (0xb/0xf/0x10/0x0/0x0) type:line
[ 13.869166] snd_hda_codec_ca0132 hdaudioC2D1: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 13.869169] snd_hda_codec_ca0132 hdaudioC2D1: hp_outs=1 (0x11/0x0/0x0/0x0/0x0)
[ 13.869171] snd_hda_codec_ca0132 hdaudioC2D1: mono: mono_out=0x0
[ 13.869172] snd_hda_codec_ca0132 hdaudioC2D1: dig-out=0xc/0xd
[ 13.869174] snd_hda_codec_ca0132 hdaudioC2D1: inputs:
[ 13.869175] snd_hda_codec_ca0132 hdaudioC2D1: Mic=0x12
[ 13.869176] snd_hda_codec_ca0132 hdaudioC2D1: Line=0x13
[ 13.869178] snd_hda_codec_ca0132 hdaudioC2D1: dig-in=0xe
[ 13.881399] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[ 13.881403] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 13.881405] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 13.881407] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 13.881408] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x1e/0x0
[ 13.881409] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 13.881410] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 13.881412] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 13.881413] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 14.003439] snd_hda_intel 0000:65:00.1: bound 0000:65:00.0 (ops nv50_audio_component_bind_ops [nouveau])
[ 14.563364] snd_hda_codec_ca0132 hdaudioC2D1: ca0132 DSP downloaded and running
pacmd list-cards
3 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = “0”
alsa.card_name = “HDA Intel PCH”
alsa.long_card_name = “HDA Intel PCH at 0x92ec8000 irq 87”
alsa.driver_name = “snd_hda_intel”
device.bus_path = “pci-0000:00:1f.3”
sysfs.path = “/devices/pci0000:00/0000:00:1f.3/sound/card0”
device.bus = “pci”
device.vendor.id = “8086”
device.vendor.name = “Intel Corporation”
device.product.id = “a2f0”
device.product.name = “200 Series PCH HD Audio”
device.form_factor = “internal”
device.string = “0”
device.description = “Built-in Audio”
module-udev-detect.discovered = “1”
device.icon_name = “audio-card-pci”
profiles:
input:analog-stereo: Analog Stereo Input (priority 65, available: no)
output:analog-stereo: Analog Stereo Output (priority 6500, available: no)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: no)
output:analog-surround-21: Analog Surround 2.1 Output (priority 1300, available: no)
output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (priority 1365, available: no)
output:analog-surround-40: Analog Surround 4.0 Output (priority 1200, available: no)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (priority 1265, available: no)
output:analog-surround-41: Analog Surround 4.1 Output (priority 1300, available: no)
output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (priority 1365, available: no)
output:analog-surround-50: Analog Surround 5.0 Output (priority 1200, available: no)
output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (priority 1265, available: no)
output:analog-surround-51: Analog Surround 5.1 Output (priority 1300, available: no)
output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (priority 1365, available: no)
output:iec958-stereo: Digital Stereo (IEC958) Output (priority 5500, available: unknown)
output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (priority 5565, available: no)
off: Off (priority 0, available: unknown)
active profile: output:iec958-stereo
sinks:
alsa_output.pci-0000_00_1f.3.iec958-stereo/#5: Built-in Audio Digital Stereo (IEC958)
sources:
alsa_output.pci-0000_00_1f.3.iec958-stereo.monitor/#6: Monitor of Built-in Audio Digital Stereo (IEC958)
ports:
analog-input-front-mic: Front Microphone (priority 8500, latency offset 0 usec, available: no)
properties:
device.icon_name = “audio-input-microphone”
analog-input-rear-mic: Rear Microphone (priority 8200, latency offset 0 usec, available: no)
properties:
analog-input-linein: Line In (priority 8100, latency offset 0 usec, available: no)
properties:
analog-output-lineout: Line Out (priority 9000, latency offset 0 usec, available: no)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
properties:
index: 1
owner module: 7
properties:
alsa.card = "1"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xd8080000 irq 88"
device.bus_path = "pci-0000:65:00.1"
sysfs.path = "/devices/pci0000:64/0000:64:00.0/0000:65:00.1/sound/card1"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "10f0"
device.product.name = "GP104 High Definition Audio Controller"
device.string = "1"
device.description = "GP104 High Definition Audio Controller"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: unknown)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: unknown)
output:hdmi-stereo-extra5: Digital Stereo (HDMI 6) Output (priority 5700, available: no)
output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6) Output (priority 600, available: no)
output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6) Output (priority 600, available: no)
output:hdmi-stereo-extra6: Digital Stereo (HDMI 7) Output (priority 5700, available: no)
output:hdmi-surround-extra6: Digital Surround 5.1 (HDMI 7) Output (priority 600, available: no)
output:hdmi-surround71-extra6: Digital Surround 7.1 (HDMI 7) Output (priority 600, available: no)
active profile: <output:hdmi-stereo-extra2>
sinks:
alsa_output.pci-0000_65_00.1.hdmi-stereo-extra2/#1: GP104 High Definition Audio Controller Digital Stereo (HDMI 3)
sources:
alsa_output.pci-0000_65_00.1.hdmi-stereo-extra2.monitor/#1: Monitor of GP104 High Definition Audio Controller Digital Stereo (HDMI 3)
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: yes)
properties:
device.product.name = "ASUS VP247"
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: yes)
properties:
hdmi-output-5: HDMI / DisplayPort 6 (priority 5400, latency offset 0 usec, available: no)
properties:
hdmi-output-6: HDMI / DisplayPort 7 (priority 5300, latency offset 0 usec, available: no)
properties:
index: 2
owner module: 8
properties:
alsa.card = "2"
alsa.card_name = "HDA Creative"
alsa.long_card_name = "HDA Creative at 0xfbe04000 irq 89"
device.bus_path = "pci-0000:b3:00.0"
sysfs.path = "/devices/pci0000:b2/0000:b2:00.0/0000:b3:00.0/sound/card2"
device.bus = "pci"
device.vendor.id = "1102"
device.vendor.name = "Creative Labs"
device.product.id = "0012"
device.product.name = "Sound Core3D [Sound Blaster Recon3D / Z-Series]"
device.string = "2"
device.description = "Sound Core3D [Sound Blaster Recon3D / Z-Series]"
profiles:
input:analog-stereo: Analog Stereo Input (priority 65, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: unknown)
output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (priority 5565, available: unknown)
active profile: <output:analog-stereo>
sinks:
alsa_output.pci-0000_b3_00.0.analog-stereo/#8: Sound Core3D [Sound Blaster Recon3D / Z-Series] Analog Stereo
sources:
alsa_output.pci-0000_b3_00.0.analog-stereo.monitor/#9: Monitor of Sound Core3D [Sound Blaster Recon3D / Z-Series] Analog Stereo
ports:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: yes)
properties:
analog-input-linein: Line In (priority 8100, latency offset 0 usec, available: unknown)
properties:
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: yes)
properties:
properties:
Thank you guys so much!
