Sound becomes silent on 54%
When I switch my volume lower than 55% it becomes completely muted. I have found related topic but it was closed without any real result
Hi, a bit of system info might be helpful here. At the minimum, inxi -zv8 (paste results, including the command, highlight and click the </> button at the top of the reply window).
Also, please see the “Featured Topic” link accessible by clicking my avatar image. Cheers!
The inxi info will show us what audio you are using, e.g. Pipewire or Pulseaudio, for example, as well as at least some other potentially important information.
Hi there, i have exactly the same problem here, and i didn’t found solution on a topic.
here the result of inxi -zv8 :
  Kernel: 6.9.12-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=fa79dfd9-199f-4910-b7d9-11aa604fb3cb rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.5.0
  Type: Desktop System: Gigabyte product: B550 GAMING X V2 v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: B550 GAMING X V2 v: x.x serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: FB
    date: 11/14/2022
  System RAM: total: 32 GiB available: 31.27 GiB used: 7.3 GiB (23.3%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CM4X16GC3200C16K2E serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
    desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3709 min/max: 2200/4662 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 3709 2: 3709 3: 3709
    4: 3709 5: 3709 6: 3709 7: 3709 8: 3709 9: 3709 10: 3709 11: 3709 12: 3709
    13: 3709 14: 3709 15: 3709 16: 3709 bogomips: 108637
    stibp succor svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    xtopology
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT
    / 6900 XT] vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-3
    empty: DP-2,HDMI-A-1,Writeback-1 bus-ID: 08:00.0 chip-ID: 1002:73bf
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4520x1920 s-dpi: 96 s-size: 1195x508mm (47.05x20.00")
    s-diag: 1298mm (51.12")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,bottom-r
    model: Samsung LC34G55T serial: <filter> built: 2022 res: 3440x1440 hz: 165
    dpi: 109 gamma: 1.2 chroma: red: x: 0.651 y: 0.337 green: x: 0.310
    y: 0.624 blue: x: 0.153 y: 0.067 white: x: 0.306 y: 0.329
    size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes: 3440x1440,
    2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 832x624,
    800x600, 720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unknown tag 112
  Monitor-2: DP-3 mapped: DisplayPort-2 pos: top-left model: MSI MP243X
    serial: <filter> built: 2024 res: 1080x1920 dpi: 95 gamma: 1.2 chroma: red:
    x: 0.655 y: 0.329 green: x: 0.302 y: 0.600 blue: x: 0.149 y: 0.051 white:
    x: 0.314 y: 0.329 size: 290x530mm (11.42x20.87") diag: 604mm (23.8")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 (radeonsi navi21
    LLVM 18.1.8 DRM 3.57 6.9.12-3-MANJARO) device-ID: 1002:73bf
    memory: 15.62 GiB unified: no
  API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6800 (RADV NAVI21) driver: mesa radv v: 24.1.6-arch1.1
    device-ID: 1002:73bf surfaces: xcb,xlib
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 08:00.1 chip-ID: 1002:ab28 class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: ROCCAT Elo 7.1 Air driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:3
    chip-ID: 1e7d:3a37 class-ID: 0300 serial: <filter>
  Device-4: Divoom Ditoo usb audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:13
    chip-ID: 8888:1719 class-ID: 0300 serial: <filter>
  Device-5: KTMicro JX USB Mic driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4.1:6
    chip-ID: 31b2:0011 class-ID: 0300 serial: <filter>
  API: ALSA v: k6.9.12-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
    lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 3.64 TiB used: 469.84 GiB (12.6%)
    model: WD Blue SN570 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 234110WD temp: 43.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Crucial model: CT2000P3SSD8
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 39.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1A02 scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 33 GiB (1.8%)
    fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:6 label: N/A
    uuid: fa79dfd9-199f-4910-b7d9-11aa604fb3cb
    used: 33.2 MiB (11.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5
    label: N/A uuid: EF68-1D75
  ID-3: /mnt/Media raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
    used: 15.39 GiB (1.7%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
    label: HDD Stockage Media uuid: a05db671-159d-4d25-a9e8-9d14113631f1
  ID-4: /mnt/SSD-nvme raw-size: 638.53 GiB size: 627.43 GiB (98.26%)
    used: 421.42 GiB (67.2%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    label: SSD nvme 1 uuid: 1cc4a691-b4fd-4042-af20-fa5e4e6f217d
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 292.97 GiB fs: ntfs label: N/A
    uuid: 5658FC9758FC76D9
  Device-1: 1-3:2 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-2: 1-8:3 info: Corsair Lighting Node CORE type: HID
    lanes: 1 mode: 1.1 power: 50mA chip-ID: 1b1c:0c1a class-ID: 0300
    serial: <filter>
  Device-1: 3-1:11 info: ShenZhen ShanWan Frostbite controller type: HID
    driver: betop,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 20bc:5500 class-ID: 0300
  Device-2: 3-2:3 info: ROCCAT Elo 7.1 Air type: HID,audio
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 5 rev: 2.0
  Device-3: 3-3:13 info: Divoom Ditoo usb audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 5 rev: 1.1
  Hub-4: 3-4:5 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
  Device-1: 3-4.1:6 info: KTMicro JX USB Mic type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 2.0
  Device-2: 3-4.3:7 info: ROCCAT Vulcan AIMO type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1e7d:3098 class-ID: 0300
  Device-3: 3-4.4:8 info: ROCCAT Kone Aimo 16K type: mouse,keyboard
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1e7d:2e2c class-ID: 0300
  Device-4: 3-4.5:9 info: VIA Labs USB Billboard Device type: billboard
    driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 100mA chip-ID: 2109:8817 class-ID: 1100 serial: <filter>
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 4-4:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
  System Temperatures: cpu: 56.4 C mobo: 32.0 C gpu: amdgpu temp: 54.0 C
    mem: 54.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: 1445 pm: pacman pkgs: 1433 libs: 452 tools: pamac,yay pm: flatpak
    pkgs: 12
    1: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    2: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    3: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    4: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    5: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    6: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    7: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    8: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 379
  1: cpu: 42.6% command: @lymouthd pid: 323 mem: 58.4 MiB (0.1%)
  2: cpu: 9.4% command: firefox pid: 13577 mem: 759.3 MiB (2.3%)
  3: cpu: 5.1% command: thunderbird pid: 13330 mem: 612.7 MiB (1.9%)
  4: cpu: 3.2% command: Xorg pid: 12569 mem: 206.8 MiB (0.6%)
  5: cpu: 3.0% command: spotify pid: 21588 mem: 388.2 MiB (1.2%)
  Memory top: 5 of 379
  1: mem: 1368.6 MiB (4.2%) command: pamac-manager pid: 26898 cpu: 0.2%
  2: mem: 955.2 MiB (2.9%) command: plasmashell pid: 12810 cpu: 1.8%
  3: mem: 759.3 MiB (2.3%) command: firefox pid: 13577 cpu: 9.4%
  4: mem: 612.7 MiB (1.9%) command: thunderbird pid: 13330 cpu: 5.1%
  5: mem: 433.1 MiB (1.3%) command: firefox pid: 13765 cpu: 1.0%
  Processes: 379 Power: uptime: 3h 32m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.32
    running-in: konsole inxi: 3.3.36
Im not a sound expert around Linux, i write only because no one else response to this topic:
This might be fix able with the right adjustments inside the Alsamixer.
Probably the Volume slider attached to another Value, that might need to be set higher inside alsamixer, you may need more headroom for the Mainvolume slider in KDE.
Just open Terminal and write Alsamixer and choose your Soundcard (with F6) where you have the problem with. Increase the lower Output volumes around 80%.
6.9 is also EOL, switch to a newer Version or try the latest LTS 6.6 Kernel.
Thanks you for your answer. as you say, I change my kernel to a LTS one. Also see some screenshot when i lower output. still the same problem
You may want to try to install QT version of PulseAudio Volume Control pavucontrol-qt
I just searched our Forum, but i can’t find no related Topic with your issue :man_shrugging:
Since it looks like, that this is a plasma bug, maybe the KDE Forum could provide better information.
Maybe you also want to give Wayland a try, since you have a AMD System.
You can switch between Wayland and X11 at the login menue (SDDM) at the bottom left.
The OP hasn’t posted since 21 September, but I’d suggest trying Pipewire and see if that behaves any differently, assuming the OP isn’t already using it (no system info provided as per request)?
Edit: I see the second poster is using Pipewire.
I was about to say the same thing - he posted, but never returned or responded.
… save your breath, y’all :wink:
OP alleges finding a related topic but no link
Topic was hijacked 4 hours after posting
Second poster should open a new topic to troubleshoot PipeWire and ALSA
