My Bluetooth/Wireless Sony WH-1000XM4 are not working.
I went through many forum post and articles; replaced PulseAudio server dependencies with PipeWire ones. Installed mpv Media Player and SMplayer, but still not working.
If you still have problems getting them paired as a backup plan you can use the headphone cable that comes with the headphones. That’s how I had to hook up my earphones.
Thank you for confirming problems with PipeWire packages. This might be helpful for Manjaro Team to work out how to deal with recent changes from PipeWire
manjaro-pulse appears to have installed ok so system should have pulseaudio installed pipewire-bluetooth is not present so pulseaudio-bluetooth should have replaced it for using headset
but pipewire-alsa is still installed so pulseaudio-alsa might not be installed for onboard audio
pipewire-jack is replacement for JACK and not related to PulseAudio. Installing jack2 should replace it
pipewire-session-manager is provided by either pipewire-media-session or wireplumber and is a required dependency for DE display packages, so it might not be removable on a Wayland DE
The systemctl --user commands failed because terminal is running as root (su?) and command cannot connect to user service manager. Commands must be run under normal user account
(@olli - tutorial has PulseAudio sytemctl commands that will not work with sudo or without --user option unless intended to run in insecure system-wide mode. Not a reliable source IMO)
I removed PulseAudio folder but after reboot it has not been recreated.
If PulseAudio failed to start it would not recreate the folder. PulseAudio might have been blocked from starting if PipeWire server session-manager still running
I suggest you reboot system and check PipeWire socket and services are disabled
It is probably trivial but did you check that the headphones are not connected to another source (i.e. mobile phone) while you try to pair?
I also have found some reports, that it worked when Linux Bluetooth is disabled initially - you put the headphones to pairing mode first and then enable Bluetooth on your computer and start search for devices.
1 Disable Bluetooth
2 Pair headphones
3 Add new device
After, the device appeared in the Bluetooth screen and i connected it!
And now i have sound.
You know what i also think? I think it’s because they came paired from Windows 10.
In fact when i restarted manjaro and booted to windows with the headphones on; windows recognized them as usual and the headphones played “bluetooth connected”.
This will help others.
Man so much frustration so far, i tweaked so many things and uninstalled software i did not need to…
I still have this two left and rm -r does not work.
How to force remove them?
@nikgnomic now that bluetooth is working, what steps can i take to clean everything and revert the multimedia stuff back to how it was?
The dependencies thing can be a bit complex. But that’s the beauty of Linux
I don’t understand why you are posting screenshots of a terminal when it would be easier to copy/paste text here
Terminal prompt is showing # to indicate it has root privileges
The commands systemctl --user will continue to fail when run as root in terminal
The command has to be run a normal user to work with
Could these similar effects under Multimedia be conflicting?
No. They are all provided by one package lsp-plugins
How to get rid of them?
pamac remove lsp-plugins
The dependency problems are recent, from changes in package updates
Yes, i’ve been noticing strange things, like taskbar icons disappearing and replaced by other icons when you remove some packages.
I’ve noticed it via Pamac GUI (Add/Remove Software).
I will create separate thread on this and i’m available to provide extra info and test things out, to help the devs if needed.
This will improve my knowledge in Linux anyway.
