My Sony WH-1000X M3 bluetooth headphone produces various strange things for a long while. Current symptom: the sound is strongly distorted on my manjaro machine. Voice is understandable, but it is very challenging, and no fun at all. In another devices (android & windows) it works fine. I’ve tried multiple kernel versions and I’ve tried everything related I’ve found on the internet. I’ve gathered many information, but it was little help. Does anybody spot the issue from the information below?
Bluetooth status:
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2022-03-15 17:10:53 CET; 4 weeks 0 days ago
Docs: man:bluetoothd(8)
Main PID: 1383 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 18416)
Memory: 2.9M
CPU: 10min 45.688s
CGroup: /system.slice/bluetooth.service
└─1383 /usr/lib/bluetooth/bluetoothd
Apr 12 08:51:05 adrian bluetoothd[1383]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSource/sbc
Apr 12 08:51:05 adrian bluetoothd[1383]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSink/sbc_xq_453
Apr 12 08:51:05 adrian bluetoothd[1383]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSource/sbc_xq_453
Apr 12 08:51:05 adrian bluetoothd[1383]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSink/sbc_xq_512
Apr 12 08:51:05 adrian bluetoothd[1383]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSource/sbc_xq_512
Apr 12 08:51:05 adrian bluetoothd[1383]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Apr 12 08:51:05 adrian bluetoothd[1383]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSource/sbc_xq_552
Apr 12 23:40:07 adrian bluetoothd[1383]: src/adv_monitor.c:btd_adv_monitor_offload_supported() Manager is NULL, get offload support failed
Apr 12 23:40:08 adrian bluetoothd[1383]: src/adv_monitor.c:btd_adv_monitor_offload_supported() Manager is NULL, get offload support failed
Apr 12 23:40:14 adrian bluetoothd[1383]: /org/bluez/hci0/dev_38_18_4C_BE_C6_B2/sep5/fd6: fd(43) ready
After restarting the bluetooth system:
Active: active (running) since Tue 2022-04-12 23:57:12 CEST; 56s ago
Main PID: 1125647 (bluetoothd)
Status: "Running"
Memory: 2.8M
CPU: 169ms
└─1125647 /usr/lib/bluetooth/bluetoothd
Apr 12 23:57:24 adrian bluetoothd[1125647]: profiles/input/hog-lib.c:report_value_cb() bt_uhid_send: Invalid argument (22)
Apr 12 23:58:05 adrian bluetoothd[1125647]: /org/bluez/hci0/dev_38_18_4C_BE_C6_B2/sep5/fd0: fd(43) ready
I am not sure what causes the difference.
dmesg output:
[Apr12 23:43] Bluetooth: hci0: urb 000000008d53fb0f submission failed (90)
[ +0,000004] Bluetooth: hci0: sending frame failed (-90)
[ +24,623925] Bluetooth: hci0: SCO packet for unknown connection handle 3
I’ve checked the Archwiki’s Bluetooth page, but I’ve got no [IdentityResolvingKey] section.
bluetooth management:
zoltan@adrian ~ $ btmgmt info
Index list with 1 item
hci0: Primary controller
addr 00:E0:4C:AE:42:03 version 10 manufacturer 93 class 0x7c0104
supported settings: powered connectable fast-connectable discoverable bondable link-security ssp br/edr le advertising secure-conn debug-keys privacy static-addr phy-configuration
current settings: powered fast-connectable bondable ssp br/edr le secure-conn
name adrian
short name
hciconfig:
zoltan@adrian ~ $ hciconfig -a hci0
hci0: Type: Primary Bus: USB
BD Address: 00:E0:4C:AE:42:03 ACL MTU: 1021:6 SCO MTU: 255:12
UP RUNNING PSCAN
RX bytes:12846948 acl:687516 sco:3697 events:25056 errors:0
TX bytes:16237196 acl:24124 sco:2212 commands:455 errors:0
Features: 0xff 0xff 0xff 0xfe 0xdb 0xfd 0x7b 0x87
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy: RSWITCH HOLD SNIFF PARK
Link mode: PERIPHERAL ACCEPT
Class: 0x7c0104
Service Classes: Rendering, Capturing, Object Transfer, Audio, Telephony
Device Class: Computer, Desktop workstation
HCI Version: 5.1 (0xa) Revision: 0x9a9
LMP Version: 5.1 (0xa) Subversion: 0x8a6b
Manufacturer: Realtek Semiconductor Corporation (93)
zoltan@adrian ~ $ hcitool info 38:18:4C:BE:C6:B2
Requesting information ...
BD Address: xx:xx:xx:xx:xx:xx
OUI Company: Sony Home Entertainment&Sound Products Inc (38-18-4C)
Device Name: WH-1000XM3
LMP Version: 4.1 (0x7) LMP Subversion: 0x3907
Manufacturer: Cambridge Silicon Radio (10)
Features page 0: 0xff 0xff 0x8f 0xfe 0xdb 0xff 0x5b 0x87
<3-slot packets> <5-slot packets> <encryption> <slot offset>
<timing accuracy> <role switch> <hold mode> <sniff mode>
<park state> <RSSI> <channel quality> <SCO link> <HV2 packets>
<HV3 packets> <u-law log> <A-law log> <CVSD> <paging scheme>
<power control> <transparent SCO> <broadcast encrypt>
<EDR ACL 2 Mbps> <EDR ACL 3 Mbps> <enhanced iscan>
<interlaced iscan> <interlaced pscan> <inquiry with RSSI>
<extended SCO> <EV4 packets> <EV5 packets> <AFH cap. perip.>
<AFH cls. perip.> <LE support> <3-slot EDR ACL>
<5-slot EDR ACL> <sniff subrating> <pause encryption>
<AFH cap. central> <AFH cls. central> <EDR eSCO 2 Mbps>
<EDR eSCO 3 Mbps> <3-slot EDR eSCO> <extended inquiry>
<LE and BR/EDR> <simple pairing> <encapsulated PDU>
<non-flush flag> <LSTO> <inquiry TX power> <EPC>
<extended features>
Features page 1: 0x03 0x00 0x00 0x00 0x00 0x00 0x00 0x00
My system:
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=51ada9e3-e864-4f90-a085-772e9ba393fb rw quiet apparmor=1
security=apparmor resume=UUID=74ceb443-e800-4cd8-8259-072d27a86404
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: B550M Steel Legend
serial: <superuser required> UEFI: American Megatrends LLC. v: P2.20
date: 08/02/2021
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1932 high: 2984 min/max: 1400/4464 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1396 2: 1409
3: 2984 4: 2393 5: 1544 6: 1590 7: 1925 8: 2380 9: 1851 10: 2396 11: 1427
12: 1899 bogomips: 93456
STIBP: always-on, RSB filling
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: C-Media USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2.3:35 chip-ID: 0d8c:0134
class-ID: 0300
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.48 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-6:3 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Report: hciconfig ID: hci0 rfk-id: 14 state: up address: <filter>
bt-v: 3.0 lmp-v: 5.1 sub-v: 8a6b hci-v: 5.1 rev: 9a9
Info: acl-mtu: 1021:6 sco-mtu: 255:12 link-policy: rswitch hold sniff park
link-mode: peripheral accept
service-classes: rendering, capturing, object transfer, audio, telephony
Processes: 425 Uptime: 28d 6h 28m wakeups: 91 Memory: 15 GiB
used: 12.73 GiB (84.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 2380 pacman: 2357 lib: 447 flatpak: 13
snap: 10 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
