Somewhere on this forum there is an answer... Pantum P1200w oddness
Hello,
Back in Oct 2023 I ran some tests on various distros to see how posible it would be to leave windows at win 10’s eol. Generally things looked good, so I parked the project for nearer the time.
That time is now(ish) and I confess I am stuck with a really odd issue on Manjaro and Linux mint (the two disros I am testing). Its the same problem, but somewhere in these forums there is the solution as I found it back in 2023. Thing is I didn’t make a note of what it was (I know :/) and now cannot find the relevent post.I also no-longer have the drive that I was testing on.
So the problem. I have a Pantum P1200w network printer connected directly to my router. Cups can see this and reports it correctly. I can print to it using Firefox’s default system but I cannot print a test page or using any other app. If I try I get the error, ‘Print job cancelled at printer’.
Back in 2023, I found that by default Firefox ignores cups, which is why it works, and if I force it to use cups, I get the same error. So there seems to be some oddity in the cups config and this is where the Majoro forum, I hope, rides to my rescue.
In 2023 I found, somewhere in these pages, a post relating to changing a single setting using the cups web back end. Doing so allowed cups to print to the Pantum without any issues. As mentioned I now cannot find that post.
Has anyone any idea what I need to change to change in the cups web back end? I know its a long shot, but right now I am stuck - and annoyed I never made a note of the solution when I 1st tested.
Anyway here’s hoping.
Could it be the IPP setting? :point_down:
I think this might be the post you are looking for:
https://forum.manjaro.org/t/cups-driverless-printing-v3-11-2023-are-you-ready-any-tips/145026/5?u=scotty65
There were a few search results for ‘Pantum’, but the above has instructions for Firefox under the “Notes” heading, so I assume it is the one with the answer you seek.
Thanks for the replies, I’ll check on the IPP.
Regarding the post you kindily linked @scoty65, I cannot see it as I’m being told it either does not exist or is marked private.
Any ideas why?
I think this is the post @scotty65 was referring to:
Steps
  • Maker sure printer is on.
  • In printer, make sure ipp is on. It was already on.
  • In printer, make sure Bonjour is on. It wasn’t, so turned it on.
  • Configured /etc/cups/cups-browsed.conf
  KeepGeneratedQueuesOnShutdown Yes
  # NewIPPPrinterQueuesShared No        NOTE: default was wrong in file. Changed Yes to No
  IPPPrinterQueueType PPD
  CreateIPPPrinterQueues Driverless
  BrowseAllow xxx.xxx.xxx.xxx/xxx.xxx.xxx.xxx
  DebugLogging file
  • Create the cups printer queue.
    systemctl enable --now cups-browsed
  • Verify.
    lpstat -t
  • Disable cups-browsed, only need it for a new printers (see cups-browsed.conf)
    systemctl disable --now cups-browsed
Notes
A ppd file was created in /etc/cups/ppd when cups-browsed was enabled.
  • If all I wanted to do is print, I was done :slight_smile:
  • The device is multi-function printer/scanner. Scanning at this time requires hplip because it provides hpaio for sane.
  • I had to change the permission of /etc/cups/ppd/<hp>.ppd, from 640 to 644, so the printer could be added to Gutenprint in GIMP.
  • On linux, the HP Device Manager currently does not support ipp printer queues. However, they can be managed from the cups web interface.
  • Using the printer’s embedded web server’s Administrative feature in firefox, I had to turn on the preference below because the printer’s TLS is deprecated.
    security.tls.version.enable-deprecated : true
Right now, I’m not aware of a way to update this printer’s firmware.
  • The system is a new Manjaro minimal XFCE ISO. I very seldom use midori. It has a bug. You can not type a slash in the address bar (known bug). It’s a shortcut key for search. You can still paste the url, but it doesn’t matter, TLS in the printer is NOT supported in midori.
Thanks @Mirdarthos . I was scratching my head wondering why the post snippet did not appear when I pasted the link to it. Completely forgot that is what normally happens when the linked post is from the Member Hub :man_facepalming:
Many many thanks for the replies. I have now solved the issue and it was to do with IPP.
I started the web back end, selected the printer and then modify printer.
In other network printers I selected 'Internet Printing Protocol (ipps) ’
After clicking continue 3 times I selected Ipp everywhere from the drivers, replacing the system driver(?)
I then clicked modify printer and was told that was successful. Printing a test page worked and printing Lorem ipsum etc from Libre office also worked.
I have no idea if this will help other folks having similar issues with different printer makes.
Once again many many thanks.
