Hello,
anyone got a solution why my PC won’t shutdown after i updated the Kernel?
I never had this under Windows and there was no problem with Manjaro in the past also.
Since around one month i had this problem.
I would say every third or four Shutdown my Linux just restart instead shutdown.
inxi --admin --verbosity=7 --filter --no-host --width:
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "de_DE.UTF-8",
LC_NAME = "de_DE.UTF-8",
LC_MONETARY = "de_DE.UTF-8",
LC_PAPER = "de_DE.UTF-8",
LC_IDENTIFICATION = "de_DE.UTF-8",
LC_TELEPHONE = "de_DE.UTF-8",
LC_MEASUREMENT = "de_DE.UTF-8",
LC_TIME = "de_DE.UTF-8",
LC_NUMERIC = "de_DE.UTF-8",
LANG = "en_DE.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.10-x86_64
root=UUID=eb235aa7-d461-413d-800e-ea57385703fb rw quiet apparmor=1
security=apparmor resume=UUID=a44dd3c4-f5f1-4587-8934-6f7413d28d4f
udev.log_priority=3
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: Z170X-UD3 v: N/A serial: <filter>
Mobo: Gigabyte model: Z170X-UD3-CF v: x.x serial: <filter>
UEFI-[Legacy]: American Megatrends v: F23d date: 12/01/2017
RAM: total: 15.59 GiB used: 1.87 GiB (12.0%)
Info: Quad Core model: Intel Core i7-6700K bits: 64 type: MT MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: E2 cache:
L2: 8 MiB bogomips: 64026
Speed: 800 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 802 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 460.56 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1e07 class-ID: 0300
Device-2: Oculus VR Rift CV1 Sensor type: USB driver: uvcvideo
bus-ID: 1-14:6 chip-ID: 2833:0211 class-ID: ef00 serial: <filter>
Device-3: Oculus VR Rift CV1 Sensor type: USB driver: uvcvideo bus-ID: 2-9:4
Device-4: Oculus VR Rift CV1 Sensor type: USB driver: uvcvideo bus-ID: 6-2:2
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 2560x1440 s-dpi: 122 s-size: 533x302mm (21.0x11.9")
s-diag: 613mm (24.1")
Monitor-1: DP-4 res: 2560x1440 dpi: 123 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: GeForce RTX 2080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA TU102 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f7
class-ID: 0403
Device-3: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series]
driver: snd_hda_intel v: kernel bus-ID: 0b:00.0 chip-ID: 1102:0012
class-ID: 0403
Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: yes
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: f000 bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Message: No Bluetooth data was found.
Message: No LVM data was found.
Local Storage: total: 3.87 TiB used: 351.4 GiB (8.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 2B7QCXE7 temp: 32.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 830 Series
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 3B1Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HDN724030ALE640
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: A5E0 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Samsung
model: Portable SSD T5 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B rotation: SSD serial: <filter> scheme: MBR
ID-1: / raw-size: 88.61 GiB size: 86.72 GiB (97.87%) used: 18.77 GiB (21.6%)
fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: eb235aa7-d461-413d-800e-ea57385703fb
ID-2: /boot raw-size: 200 MiB size: 189.7 MiB (94.84%)
used: 97.2 MiB (51.2%) fs: ext3 dev: /dev/sdc3 maj-min: 8:35 label: N/A
uuid: 26eda82e-b403-49b8-abca-202167417020
ID-3: /home raw-size: 332.03 GiB size: 325.82 GiB (98.13%)
used: 3.79 GiB (1.2%) fs: ext4 dev: /dev/sdc4 maj-min: 8:36 label: N/A
uuid: ada4a6a2-bd0a-4652-b386-7c637bba7ee9
ID-4: /media/games raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
used: 296.68 GiB (50.6%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18 label: games
uuid: 3CF8CC1DF8CBD2F6
ID-5: /media/os raw-size: 210.94 GiB size: 210.94 GiB (100.00%)
used: 32.07 GiB (15.2%) fs: ntfs dev: /dev/sda1 maj-min: 8:1 label: os
uuid: FA6CC1816CC138E1
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 2.93 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: a44dd3c4-f5f1-4587-8934-6f7413d28d4f
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 442.47 GiB fs: ntfs label: ssm
uuid: AE7EDC0696B158FD
ID-2: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sdb3 maj-min: 8:19 size: 1.08 TiB fs: <superuser required>
ID-4: /dev/sdb4 maj-min: 8:20 size: 1.08 TiB fs: <superuser required>
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Hub-2: 1-3:2 info: Oculus VR Rift CV1 ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2833:2031 class-ID: 0900
Device-1: 1-3.1:4 info: Oculus VR Rift CV1 type: HID
power: 100mA chip-ID: 2833:0031 class-ID: 0300 serial: <filter>
Device-2: 1-5:3 info: Saitek PLC Saitek X52 Pro Flight Control System
type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 230mA chip-ID: 06a3:0762 class-ID: 0300
Device-3: 1-13:5 info: A4Tech XL-730K / XL-750BK / XL-755BK Mice
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 09da:9090 class-ID: 0301
Device-4: 1-14:6 info: Oculus VR Rift CV1 Sensor type: Video
driver: uvcvideo interfaces: 2 rev: 2.1 speed: 480 Mb/s power: 200mA
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0 speed: 5 Gb/s
Device-1: 2-2:2 info: Samsung Portable SSD T5 type: Mass Storage driver: uas
interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA chip-ID: 04e8:61f5
class-ID: 0806 serial: <filter>
Hub-4: 2-3:3 info: Oculus VR Rift CV1 ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2833:3031 class-ID: 0900
Device-1: 2-9:4 info: Oculus VR Rift CV1 Sensor type: Video driver: uvcvideo
interfaces: 2 rev: 3.0 speed: 5 Gb/s power: 800mA chip-ID: 2833:0211
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-8: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 6-2:2 info: Oculus VR Rift CV1 Sensor type: Video driver: uvcvideo
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Processes: 218 Uptime: 15m wakeups: 1 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: pacman: 1296 lib: 389 flatpak: 0
Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.03
Thanks in advance
