Sometimes when I try to log in to my desktop after a period of inactivity, instead of a login screen I see only a black screen and a cursor. I can move the cursor just fine, and I can switch to a TTY terminal, but I cannot log in. I have tried updating my system and switching to a different kernel but the problem persists. Only solution is to restart.
Some other issues I am having which I am not sure if they are related or not:
- When I switch to TTY and run
sudo systemctl restart sddm.service
the login screen starts back up, but when I try to log in the system keeps hanging in the logging in phase. Only solution is to restart. When I do manage to log in, all my open windows are gone. - Sometimes when this problem does not occur, i.e. I can log in just fine after sleep, there is a significant lag between moving my cursor and the login prompt becoming visible.
- Sometimes after logging in successfully the KDE Plasma taskbar is frozen. It starts working again after I run
killall plasmashell && nohup plasmashell &
Here is the output from inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 6.12.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=7d66d280-12dc-4ccd-a43d-3f2eaafe3ab5 rw quiet splash
resume=UUID=f0d8855b-ef18-40e4-bf50-9eda255ef382 udev.log_priority=3
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0
Type: Desktop System: Gigabyte product: B550M AORUS ELITE v: -CF
serial: <superuser required>
Mobo: Gigabyte model: B550M AORUS ELITE v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: FB
date: 11/14/2022
System RAM: total: 32 GiB available: 31.27 GiB used: 6.28 GiB (20.1%)
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
part-no: F4-3200C16-16GIS serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3593 min/max: 550/4468 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3593 2: 3593 3: 3593
4: 3593 5: 3593 6: 3593 7: 3593 8: 3593 9: 3593 10: 3593 11: 3593 12: 3593
bogomips: 83870
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
affected
Device-1: NVIDIA GA102 [GeForce RTX 3080] vendor: ASUSTeK driver: nvidia
v: 570.144 alternate: nouveau,nvidia_drm non-free: 550-570.xx+ status: current
(as of 2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none
off: HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2,DP-3 bus-ID: 05:00.0
chip-ID: 10de:2206 class-ID: 0300
Device-2: Logitech Webcam C310 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 046d:081b
class-ID: 0102 serial: <filter>
Device-3: Microdia Dual Mode Camera (8006 VGA) driver: hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2
chip-ID: 0c45:8006 class-ID: 0301
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 92 s-size: 1237x402mm (48.70x15.83")
s-diag: 1301mm (51.21") monitors: <missing: xrandr>
Monitor-1: HDMI-A-1 model: AOC 24G2WG3- serial: <filter> built: 2023
res: 1920x1080 dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54")
diag: 598mm (23.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-2 model: Samsung LC32G5xT serial: <filter> built: 2023
res: 2560x1440 dpi: 93 gamma: 1.2 size: 698x393mm (27.48x15.47")
diag: 806mm (31.7") ratio: 16:9 modes: max: 2560x1440 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.144
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
memory: 9.77 GiB
API: Vulkan v: 1.4.313 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3080 driver: nvidia v: 570.144 device-ID: 10de:2206
surfaces: N/A
wl: wayland-info x11: xdpyinfo,xprop
Device-1: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
bus-ID: 05:00.1 chip-ID: 10de:1aef class-ID: 0403
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: HP HyperX Cloud III driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2
chip-ID: 03f0:089d class-ID: 0300 serial: <filter>
Device-4: Logitech Webcam C310 driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.12.28-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: secondary dynamic noprefixroute scope: global
IP v6: <filter> scope: link
IF-ID-1: docker0 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 626.77 GiB (67.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 38.9 C
scheme: GPT
ID-1: / raw-size: 896.82 GiB size: 881.67 GiB (98.31%)
used: 626.76 GiB (71.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 7d66d280-12dc-4ccd-a43d-3f2eaafe3ab5
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 71D8-2AA1
ID-1: swap-1 type: partition size: 34.39 GiB used: 13 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: f0d8855b-ef18-40e4-bf50-9eda255ef382
Device-1: 1-4:2 info: HP HyperX Cloud III type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
Device-2: 1-6:3 info: Logitech Webcam C310 type: video,audio
chip-ID: 046d:081b class-ID: 0102 serial: <filter>
Device-3: 1-10:4 info: Integrated Express RGB LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-1: 3-1:2 info: Microdia Dual Mode Camera (8006 VGA)
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
Device-2: 3-2:3 info: SteelSeries ApS Rival 5 type: HID,mouse
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 200mA chip-ID: 1038:183c class-ID: 0300
System Temperatures: cpu: 47.5 C mobo: 35.0 C gpu: nvidia temp: 44 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 54%
Processes: 348 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1963 pm: pacman pkgs: 1903 libs: 442 tools: pamac,yay pm: flatpak
pkgs: 32 pm: snap pkgs: 28 Compilers: clang: 19.1.7 gcc: 15.1.1 alt: 13/14
Shell: Zsh v: 5.9 default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.38
Here is the output from journalctl --system --boot=-1 |tail --lines=400
touko 25 10:06:10 computer NetworkManager[955]: <info> [1748156770.1190] device (enp4s0): state change: disconnected -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
touko 25 10:06:10 computer kernel: r8169 0000:04:00.0 enp4s0: Link is Down
touko 25 10:06:10 computer dhcpcd[960]: enp4s0: carrier lost
touko 25 10:06:10 computer systemd-resolved[870]: enp4s0: Bus client reset DNS server list.
touko 25 10:06:10 computer systemd[1]: Reached target Sleep.
touko 25 10:06:10 computer systemd[1]: Starting NVIDIA system suspend actions...
touko 25 10:06:10 computer suspend[452552]: nvidia-suspend.service
touko 25 10:06:10 computer logger[452552]: <13>May 25 10:06:10 suspend: nvidia-suspend.service
touko 25 10:06:11 computer systemd-resolved[870]: Switching to fallback DNS server 1.1.1.1#cloudflare-dns.com.
touko 25 10:06:13 computer systemd[1]: nvidia-suspend.service: Deactivated successfully.
touko 25 10:06:13 computer systemd[1]: Finished NVIDIA system suspend actions.
touko 25 10:06:13 computer systemd[1]: nvidia-suspend.service: Consumed 2.397s CPU time, 1.6G memory peak.
touko 25 10:06:13 computer systemd[1]: Starting System Suspend...
touko 25 10:06:13 computer systemd-sleep[452572]: User sessions remain unfrozen on explicit request ($SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=0).
touko 25 10:06:13 computer systemd-sleep[452572]: This is not recommended, and might result in unexpected behavior, particularly
touko 25 10:06:13 computer systemd-sleep[452572]: in suspend-then-hibernate operations or setups with encrypted home directories.
touko 25 10:06:13 computer systemd-sleep[452572]: Performing sleep operation 'suspend'...
touko 25 10:06:13 computer kernel: PM: suspend entry (deep)
touko 25 10:06:13 computer kernel: Filesystems sync: 0.667 seconds
touko 25 10:06:17 computer kernel: Freezing user space processes
touko 25 10:06:17 computer kernel: Freezing user space processes completed (elapsed 0.002 seconds)
touko 25 10:06:17 computer kernel: OOM killer disabled.
touko 25 10:06:17 computer kernel: Freezing remaining freezable tasks
touko 25 10:06:17 computer kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
touko 25 10:06:17 computer kernel: printk: Suspending console(s) (use no_console_suspend to debug)
touko 25 10:06:17 computer kernel: serial 00:04: disabled
touko 25 10:06:17 computer kernel: ACPI: PM: Preparing to enter system sleep state S3
touko 25 10:06:17 computer kernel: ACPI: PM: Saving platform NVS memory
touko 25 10:06:17 computer kernel: Disabling non-boot CPUs ...
touko 25 10:06:17 computer kernel: smpboot: CPU 11 is now offline
touko 25 10:06:17 computer kernel: smpboot: CPU 10 is now offline
touko 25 10:06:17 computer kernel: smpboot: CPU 9 is now offline
touko 25 10:06:17 computer kernel: smpboot: CPU 8 is now offline
touko 25 10:06:17 computer kernel: smpboot: CPU 7 is now offline
touko 25 10:06:17 computer kernel: smpboot: CPU 6 is now offline
touko 25 10:06:17 computer kernel: Spectre V2 : Update user space SMT mitigation: STIBP off
touko 25 10:06:17 computer kernel: smpboot: CPU 5 is now offline
touko 25 10:06:17 computer kernel: smpboot: CPU 4 is now offline
touko 25 10:06:17 computer kernel: smpboot: CPU 3 is now offline
touko 25 10:06:17 computer kernel: smpboot: CPU 2 is now offline
touko 25 10:06:17 computer kernel: smpboot: CPU 1 is now offline
touko 25 10:06:17 computer kernel: ACPI: PM: Low-level resume complete
touko 25 10:06:17 computer kernel: ACPI: PM: Restoring platform NVS memory
touko 25 10:06:17 computer kernel: LVT offset 0 assigned for vector 0x400
touko 25 10:06:17 computer kernel: Enabling non-boot CPUs ...
touko 25 10:06:17 computer kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
touko 25 10:06:17 computer kernel: CPU1 is up
touko 25 10:06:17 computer kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
touko 25 10:06:17 computer kernel: CPU2 is up
touko 25 10:06:17 computer kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
touko 25 10:06:17 computer kernel: CPU3 is up
touko 25 10:06:17 computer kernel: smpboot: Booting Node 0 Processor 4 APIC 0x8
touko 25 10:06:17 computer kernel: CPU4 is up
touko 25 10:06:17 computer kernel: smpboot: Booting Node 0 Processor 5 APIC 0xa
touko 25 10:06:17 computer kernel: CPU5 is up
touko 25 10:06:17 computer kernel: smpboot: Booting Node 0 Processor 6 APIC 0x1
touko 25 10:06:17 computer kernel: Spectre V2 : Update user space SMT mitigation: STIBP always-on
touko 25 10:06:17 computer kernel: CPU6 is up
touko 25 10:06:17 computer kernel: smpboot: Booting Node 0 Processor 7 APIC 0x3
touko 25 10:06:17 computer kernel: CPU7 is up
touko 25 10:06:17 computer kernel: smpboot: Booting Node 0 Processor 8 APIC 0x5
touko 25 10:06:17 computer kernel: CPU8 is up
touko 25 10:06:17 computer kernel: smpboot: Booting Node 0 Processor 9 APIC 0x7
touko 25 10:06:17 computer kernel: CPU9 is up
touko 25 10:06:17 computer kernel: smpboot: Booting Node 0 Processor 10 APIC 0x9
touko 25 10:06:17 computer kernel: CPU10 is up
touko 25 10:06:17 computer kernel: smpboot: Booting Node 0 Processor 11 APIC 0xb
touko 25 10:06:17 computer kernel: CPU11 is up
touko 25 10:06:17 computer kernel: ACPI: PM: Waking up from system sleep state S3
touko 25 10:06:17 computer kernel: xhci_hcd 0000:02:00.0: xHC error in resume, USBSTS 0x401, Reinit
touko 25 10:06:17 computer kernel: usb usb1: root hub lost power or was reset
touko 25 10:06:17 computer kernel: usb usb2: root hub lost power or was reset
touko 25 10:06:17 computer kernel: serial 00:04: activated
touko 25 10:06:17 computer kernel: nvme nvme0: 8/0/0 default/read/poll queues
touko 25 10:06:17 computer kernel: ata2: SATA link down (SStatus 0 SControl 330)
touko 25 10:06:17 computer kernel: ata5: SATA link down (SStatus 0 SControl 330)
touko 25 10:06:17 computer kernel: ata3: SATA link down (SStatus 0 SControl 330)
touko 25 10:06:17 computer kernel: ata4: SATA link down (SStatus 0 SControl 330)
touko 25 10:06:17 computer kernel: ata1: SATA link down (SStatus 0 SControl 330)
touko 25 10:06:17 computer kernel: usb 1-6: reset high-speed USB device number 3 using xhci_hcd
touko 25 10:06:17 computer kernel: usb 1-4: WARN: invalid context state for evaluate context command.
touko 25 10:06:17 computer kernel: usb 1-4: reset full-speed USB device number 2 using xhci_hcd
touko 25 10:06:17 computer kernel: ata6: failed to resume link (SControl 0)
touko 25 10:06:17 computer kernel: ata6: SATA link down (SStatus 0 SControl 0)
touko 25 10:06:17 computer kernel: usb 1-10: WARN: invalid context state for evaluate context command.
touko 25 10:06:17 computer kernel: usb 1-10: reset full-speed USB device number 4 using xhci_hcd
touko 25 10:06:17 computer kernel: OOM killer enabled.
touko 25 10:06:17 computer kernel: Restarting tasks ... done.
touko 25 10:06:17 computer kernel: random: crng reseeded on system resumption
touko 25 10:06:17 computer kernel: PM: suspend exit
touko 25 10:06:17 computer systemd-resolved[870]: Clock change detected. Flushing caches.
touko 25 10:06:17 computer systemd-sleep[452572]: System returned from sleep operation 'suspend'.
touko 25 10:06:19 computer systemd[1]: systemd-suspend.service: Deactivated successfully.
touko 25 10:06:19 computer systemd[1]: Finished System Suspend.
touko 25 10:06:19 computer systemd[1]: systemd-suspend.service: Consumed 1.495s CPU time, 3M memory peak.
touko 25 10:06:19 computer systemd[1]: Stopped target Sleep.
touko 25 10:06:19 computer systemd[1]: Reached target Suspend.
touko 25 10:06:19 computer systemd[1]: Starting NVIDIA system resume actions...
touko 25 10:06:19 computer systemd[1]: Stopped target Suspend.
touko 25 10:06:19 computer systemd-logind[959]: Operation 'suspend' finished.
touko 25 10:06:19 computer NetworkManager[955]: <info> [1748156779.3654] manager: sleep: wake requested (sleeping: yes enabled: yes)
touko 25 10:06:19 computer ModemManager[1019]: <msg> [sleep-monitor-systemd] system is resuming
touko 25 10:06:19 computer NetworkManager[955]: <info> [1748156779.3655] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
touko 25 10:06:19 computer systemd-resolved[870]: Closing all remaining TCP connections.
touko 25 10:06:19 computer systemd-resolved[870]: Resetting learnt feature levels on all servers.
touko 25 10:06:19 computer systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
touko 25 10:06:19 computer kernel: Generic FE-GE Realtek PHY r8169-0-400:00: attached PHY driver (mii_bus:phy_addr=r8169-0-400:00, irq=MAC)
touko 25 10:06:19 computer suspend[452660]: nvidia-resume.service
touko 25 10:06:19 computer logger[452660]: <13>May 25 10:06:19 suspend: nvidia-resume.service
touko 25 10:06:19 computer systemd[1]: nvidia-resume.service: Deactivated successfully.
touko 25 10:06:19 computer systemd[1]: Finished NVIDIA system resume actions.
touko 25 10:06:19 computer NetworkManager[955]: <info> [1748156779.5621] manager: NetworkManager state is now CONNECTED_LOCAL
touko 25 10:06:19 computer kernel: r8169 0000:04:00.0 enp4s0: Link is Down
touko 25 10:06:20 computer rtkit-daemon[1630]: Supervising 10 threads of 7 processes of 1 users.
touko 25 10:06:21 computer kernel: usb 1-6: Failed to query (GET_DEF) UVC control 12 on unit 2: 0 (exp. 4).
touko 25 10:06:22 computer dhcpcd[960]: enp4s0: carrier acquired
touko 25 10:06:22 computer NetworkManager[955]: <info> [1748156782.4300] device (enp4s0): carrier: link connected
touko 25 10:06:22 computer NetworkManager[955]: <info> [1748156782.4302] device (enp4s0): state change: unavailable -> disconnected (reason 'carrier-changed', managed-type: 'full')
touko 25 10:06:22 computer NetworkManager[955]: <info> [1748156782.4306] policy: auto-activating connection 'Wired connection 1' (79ea9fea-fc73-3483-a351-d32db1836606)
touko 25 10:06:22 computer NetworkManager[955]: <info> [1748156782.4308] device (enp4s0): Activation: starting connection 'Wired connection 1' (79ea9fea-fc73-3483-a351-d32db1836606)
touko 25 10:06:22 computer NetworkManager[955]: <info> [1748156782.4309] device (enp4s0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
touko 25 10:06:22 computer NetworkManager[955]: <info> [1748156782.4310] manager: NetworkManager state is now CONNECTING
touko 25 10:06:22 computer NetworkManager[955]: <info> [1748156782.4310] device (enp4s0): state change: prepare -> config (reason 'none', managed-type: 'full')
touko 25 10:06:22 computer NetworkManager[955]: <info> [1748156782.4313] device (enp4s0): state change: config -> ip-config (reason 'none', managed-type: 'full')
touko 25 10:06:22 computer kernel: r8169 0000:04:00.0 enp4s0: Link is Up - 1Gbps/Full - flow control off
touko 25 10:06:22 computer NetworkManager[955]: <info> [1748156782.4315] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds)
touko 25 10:06:22 computer dhcpcd[960]: enp4s0: IAID 3c:64:fb:30
touko 25 10:06:23 computer dhcpcd[960]: enp4s0: soliciting an IPv6 router
touko 25 10:06:23 computer ModemManager[1019]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.2/0000:03:09.0/0000:04:00.0': not supported by any plugin
touko 25 10:06:23 computer dhcpcd[960]: enp4s0: rebinding lease of 192.168.0.5
touko 25 10:06:23 computer dhcpcd[960]: enp4s0: probing address 192.168.0.5/24
touko 25 10:06:24 computer systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
touko 25 10:06:24 computer systemd[1]: Starting Network Manager Script Dispatcher Service...
touko 25 10:06:24 computer NetworkManager[955]: <info> [1748156784.4355] dhcp4 (enp4s0): state changed new lease, address=192.168.0.6, acd pending
touko 25 10:06:24 computer systemd[1]: Started Network Manager Script Dispatcher Service.
touko 25 10:06:24 computer NetworkManager[955]: <info> [1748156784.6282] dhcp4 (enp4s0): state changed new lease, address=192.168.0.6
touko 25 10:06:24 computer NetworkManager[955]: <info> [1748156784.6287] policy: set 'Wired connection 1' (enp4s0) as default for IPv4 routing and DNS
touko 25 10:06:24 computer systemd-resolved[870]: enp4s0: Bus client set default route setting: yes
touko 25 10:06:24 computer systemd-resolved[870]: enp4s0: Bus client set DNS server list to: 192.168.0.1
touko 25 10:06:24 computer NetworkManager[955]: <info> [1748156784.6309] device (enp4s0): state change: ip-config -> ip-check (reason 'none', managed-type: 'full')
touko 25 10:06:24 computer NetworkManager[955]: <info> [1748156784.6316] device (enp4s0): state change: ip-check -> secondaries (reason 'none', managed-type: 'full')
touko 25 10:06:24 computer NetworkManager[955]: <info> [1748156784.6316] device (enp4s0): state change: secondaries -> activated (reason 'none', managed-type: 'full')
touko 25 10:06:24 computer NetworkManager[955]: <info> [1748156784.6317] manager: NetworkManager state is now CONNECTED_SITE
touko 25 10:06:24 computer NetworkManager[955]: <info> [1748156784.6318] device (enp4s0): Activation: successful, device activated.
touko 25 10:06:24 computer NetworkManager[955]: <info> [1748156784.7065] manager: NetworkManager state is now CONNECTED_GLOBAL
touko 25 10:06:29 computer dhcpcd[960]: enp4s0: leased 192.168.0.5 for 7200 seconds
touko 25 10:06:29 computer dhcpcd[960]: enp4s0: adding route to 192.168.0.0/24
touko 25 10:06:29 computer dhcpcd[960]: enp4s0: adding default route via 192.168.0.1
touko 25 10:06:34 computer systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
touko 25 10:06:36 computer dhcpcd[960]: enp4s0: no IPv6 Routers available
touko 25 10:09:07 computer rtkit-daemon[1630]: Supervising 10 threads of 7 processes of 1 users.
touko 25 10:14:08 computer rtkit-daemon[1630]: Supervising 10 threads of 7 processes of 1 users.
touko 25 10:19:08 computer rtkit-daemon[1630]: Supervising 10 threads of 7 processes of 1 users.
touko 25 10:23:22 computer systemd-resolved[870]: Clock change detected. Flushing caches.
touko 25 10:23:22 computer systemd-timesyncd[396]: Contacted time server 89.190.6.36:123 (0.manjaro.pool.ntp.org).
touko 25 10:24:10 computer rtkit-daemon[1630]: Supervising 10 threads of 7 processes of 1 users.
touko 25 10:26:09 computer rtkit-daemon[1630]: Supervising 10 threads of 7 processes of 1 users.
touko 25 10:28:15 computer systemd[1]: Started Getty on tty3.
touko 25 10:28:15 computer kernel: fbcon: Taking over console
touko 25 10:28:15 computer systemd[1]: systemd-vconsole-setup.service: Deactivated successfully.
touko 25 10:28:15 computer systemd[1]: Stopped Virtual Console Setup.
touko 25 10:28:15 computer systemd[1]: Stopping Virtual Console Setup...
touko 25 10:28:15 computer systemd[1]: Starting Virtual Console Setup...
touko 25 10:28:15 computer kernel: Console: switching to colour frame buffer device 240x67
touko 25 10:28:15 computer systemd[1]: Finished Virtual Console Setup.
touko 25 10:28:22 computer login[463989]: pam_unix(login:session): session opened for user ruby(uid=1000) by ruby(uid=0)
touko 25 10:28:22 computer systemd-logind[959]: New session 4 of user ruby.
touko 25 10:28:22 computer systemd[1]: Started Session 4 of User ruby.
touko 25 10:28:22 computer login[463989]: LOGIN ON tty3 BY ruby
touko 25 10:28:24 computer kernel: usb 1-6: Failed to query (GET_DEF) UVC control 12 on unit 2: 0 (exp. 4).
touko 25 10:28:34 computer sddm[1088]: Signal received: SIGTERM
touko 25 10:28:34 computer systemd[1]: Stopping Simple Desktop Display Manager...
touko 25 10:28:34 computer sddm-helper[1459]: Signal received: SIGTERM
touko 25 10:28:34 computer sddm-helper[1459]: [PAM] Closing session
touko 25 10:28:34 computer sddm-helper[1459]: pam_unix(sddm:session): session closed for user ruby
touko 25 10:28:34 computer sddm-helper[1459]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_close_session
touko 25 10:28:34 computer sddm-helper[1459]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
touko 25 10:28:34 computer sddm-helper[1459]: [PAM] Ended.
touko 25 10:28:34 computer kernel: ksecretd[1481]: segfault at 631fd22a7 ip 00006fffb5f29d6e sp 00007fffcdfcc810 error 4 in libqca-qt6.so.2.3.10[6ed6e,6fffb5f18000+a6000] likely on CPU 0 (core 0, socket 0)
touko 25 10:28:34 computer kernel: Code: c0 7e 71 55 48 89 e5 48 83 ec 10 80 3f 00 74 34 48 8b 47 18 48 85 c0 74 53 48 8b 78 10 48 8b 30 48 89 45 f8 8b 50 0c 48 8b 0f <ff> 51 08 48 8b 7d f8 be 18 00 00 00 c9 ff 25 17 fc 0c 00 0f 1f 80
touko 25 10:28:34 computer sddm[1088]: Auth: sddm-helper exited with 255
touko 25 10:28:34 computer sddm[1088]: Socket server stopping...
touko 25 10:28:34 computer sddm[1088]: Socket server stopped.
touko 25 10:28:34 computer sddm[1088]: Display server stopping...
touko 25 10:28:34 computer systemd-logind[959]: Session 2 logged out. Waiting for processes to exit.
touko 25 10:28:34 computer systemd-coredump[464478]: Process 1481 (ksecretd) of user 1000 terminated abnormally with signal 11/SEGV, processing...
touko 25 10:28:34 computer systemd[1]: Started Process Core Dump (PID 464478/UID 0).
touko 25 10:28:34 computer systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
touko 25 10:28:34 computer polkitd[958]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.52, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8) (disconnected from bus)
touko 25 10:28:34 computer systemd-coredump[464523]: Process 1847 (Discord) of user 1000 terminated abnormally with signal 5/TRAP, processing...
touko 25 10:28:34 computer systemd[1]: Started Process Core Dump (PID 464523/UID 0).
touko 25 10:28:34 computer systemd[1]: systemd-coredump@3-464478-0.service: Deactivated successfully.
touko 25 10:28:34 computer systemd[1]: session-2.scope: Deactivated successfully.
touko 25 10:28:34 computer systemd[1]: session-2.scope: Consumed 8.160s CPU time, 207M memory peak.
touko 25 10:28:34 computer systemd-logind[959]: Removed session 2.
touko 25 10:28:34 computer rtkit-daemon[1630]: Supervising 10 threads of 7 processes of 1 users.
touko 25 10:28:34 computer sddm[1088]: Display server stopped.
touko 25 10:28:34 computer sddm[1088]: Running display stop script QList("/usr/share/sddm/scripts/Xstop")
touko 25 10:28:34 computer systemd-coredump[464594]: Process 464560 (xdg-desktop-por) of user 1000 terminated abnormally with signal 6/ABRT, processing...
touko 25 10:28:34 computer systemd-coredump[464593]: Process 464532 (ksecretd) of user 1000 terminated abnormally with signal 6/ABRT, processing...
touko 25 10:28:34 computer systemd-coredump[464592]: Process 72865 (node) of user 1000 terminated abnormally with signal 6/ABRT, processing...
touko 25 10:28:34 computer systemd[1]: sddm.service: Deactivated successfully.
touko 25 10:28:34 computer systemd[1]: Stopped Simple Desktop Display Manager.
touko 25 10:28:34 computer systemd[1]: sddm.service: Consumed 15min 3.043s CPU time, 321.6M memory peak.
touko 25 10:28:34 computer systemd[1]: Started Simple Desktop Display Manager.
touko 25 10:28:34 computer kernel: node[15370]: segfault at 1800000018 ip 00007f734c7848d7 sp 00007ffc26371f70 error 4 in libgcc_s.so.1[208d7,7f734c768000+23000] likely on CPU 1 (core 1, socket 0)
touko 25 10:28:34 computer kernel: Code: b8 48 89 df 49 89 85 a0 00 00 00 e9 43 fe ff ff 3c 04 0f 85 d7 37 fe ff bf 18 00 00 00 e9 cb fd ff ff 90 49 8b 85 98 00 00 00 <80> 38 48 0f 85 38 ff ff ff 48 ba c7 c0 0f 00 00 00 0f 05 48 39 50
touko 25 10:28:34 computer systemd[1]: Started Process Core Dump (PID 464594/UID 0).
touko 25 10:28:34 computer systemd-coredump[464598]: Process 6161 (node) of user 1000 terminated abnormally with signal 6/ABRT, processing...
touko 25 10:28:34 computer systemd-coredump[464600]: Process 15370 (node) of user 1000 terminated abnormally with signal 11/SEGV, processing...
touko 25 10:28:34 computer systemd-coredump[464600]: Failed to get EXE, ignoring: No such process
touko 25 10:28:34 computer systemd[1]: Started Process Core Dump (PID 464593/UID 0).
touko 25 10:28:34 computer systemd[1]: Started Process Core Dump (PID 464592/UID 0).
touko 25 10:28:34 computer systemd[1]: Started Process Core Dump (PID 464598/UID 0).
touko 25 10:28:34 computer systemd[1]: Started Process Core Dump (PID 464600/UID 0).
touko 25 10:28:34 computer sddm[464597]: Initializing...
touko 25 10:28:34 computer sddm[464597]: Starting...
touko 25 10:28:34 computer sddm[464597]: Logind interface found
touko 25 10:28:34 computer sddm[464597]: Adding new display...
touko 25 10:28:34 computer sddm[464597]: Loaded empty theme configuration
touko 25 10:28:34 computer sddm[464597]: Xauthority path: "/run/sddm/xauth_EnTqWK"
touko 25 10:28:34 computer sddm[464597]: Using VT 1
touko 25 10:28:34 computer sddm[464597]: Display server starting...
touko 25 10:28:34 computer sddm[464597]: Writing cookie to "/run/sddm/xauth_EnTqWK"
touko 25 10:28:34 computer sddm[464597]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /run/sddm/xauth_EnTqWK -noreset -displayfd 16
touko 25 10:28:35 computer systemd-coredump[464604]: Failed to initialize pidref: No such process
touko 25 10:28:35 computer systemd[1]: systemd-coredump@7-464592-0.service: Deactivated successfully.
touko 25 10:28:35 computer systemd-coredump[464608]: Failed to initialize pidref: No such process
touko 25 10:28:35 computer systemd[1]: systemd-coredump@9-464600-0.service: Deactivated successfully.
touko 25 10:28:35 computer systemd[1]: systemd-coredump@6-464593-0.service: Deactivated successfully.
touko 25 10:28:35 computer systemd[1]: systemd-coredump@5-464594-0.service: Deactivated successfully.
touko 25 10:28:35 computer systemd-coredump[464644]: Process 5487 (node) of user 1000 terminated abnormally with signal 6/ABRT, processing...
touko 25 10:28:35 computer systemd[1]: Started Process Core Dump (PID 464644/UID 0).
touko 25 10:28:35 computer systemd-coredump[464647]: Failed to initialize pidref: No such process
touko 25 10:28:35 computer systemd[1]: systemd-coredump@10-464644-0.service: Deactivated successfully.
touko 25 10:28:35 computer systemd[1]: systemd-coredump@8-464598-0.service: Deactivated successfully.
touko 25 10:28:35 computer systemd[1]: systemd-coredump@8-464598-0.service: Consumed 366ms CPU time, 122.4M memory peak.
touko 25 10:28:36 computer sddm[464597]: Setting default cursor
touko 25 10:28:36 computer sddm[464597]: Running display setup script "/usr/share/sddm/scripts/Xsetup"
touko 25 10:28:36 computer systemd-coredump[464666]: Process 464646 (xdg-desktop-por) of user 1000 terminated abnormally with signal 6/ABRT, processing...
touko 25 10:28:36 computer sddm[464597]: Display server started.
touko 25 10:28:36 computer sddm[464597]: Socket server starting...
touko 25 10:28:36 computer sddm[464597]: Socket server started.
touko 25 10:28:36 computer sddm[464597]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
touko 25 10:28:36 computer sddm[464597]: Greeter starting...
touko 25 10:28:36 computer systemd[1]: Started Process Core Dump (PID 464666/UID 0).
touko 25 10:28:36 computer sddm-helper[464670]: [PAM] Starting...
touko 25 10:28:36 computer sddm-helper[464670]: [PAM] Authenticating...
touko 25 10:28:36 computer sddm-helper[464670]: [PAM] returning.
touko 25 10:28:36 computer sddm-helper[464670]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=964) by (uid=0)
touko 25 10:28:36 computer systemd-logind[959]: New session c2 of user sddm.
touko 25 10:28:36 computer systemd[1]: Created slice User Slice of UID 964.
touko 25 10:28:36 computer systemd[1]: Starting User Runtime Directory /run/user/964...
touko 25 10:28:36 computer systemd[1]: Finished User Runtime Directory /run/user/964.
touko 25 10:28:36 computer systemd[1]: Starting User Manager for UID 964...
touko 25 10:28:36 computer (systemd)[464675]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
touko 25 10:28:36 computer (systemd)[464675]: pam_unix(systemd-user:session): session opened for user sddm(uid=964) by sddm(uid=0)
touko 25 10:28:36 computer systemd-logind[959]: New session 5 of user sddm.
touko 25 10:28:36 computer 30-systemd-environment-d-generator[464680]: /usr/lib/environment.d/99-environment.conf:7: invalid variable name "export VISUAL", ignoring.
touko 25 10:28:36 computer 30-systemd-environment-d-generator[464680]: /usr/lib/environment.d/99-environment.conf:8: invalid variable name "export EDITOR", ignoring.
touko 25 10:28:36 computer systemd[1]: systemd-coredump@11-464666-0.service: Deactivated successfully.
touko 25 10:28:36 computer systemd-coredump[464694]: Process 464690 (xdg-desktop-por) of user 1000 terminated abnormally with signal 6/ABRT, processing...
touko 25 10:28:36 computer systemd[1]: Started Process Core Dump (PID 464694/UID 0).
touko 25 10:28:36 computer systemd[464675]: Queued start job for default target Main User Target.
touko 25 10:28:36 computer systemd[464675]: Created slice User Application Slice.
touko 25 10:28:36 computer systemd[464675]: Reached target Paths.
touko 25 10:28:36 computer systemd[464675]: Reached target Timers.
touko 25 10:28:36 computer systemd[464675]: Starting D-Bus User Message Bus Socket...
touko 25 10:28:36 computer systemd[464675]: Listening on GnuPG network certificate management daemon.
touko 25 10:28:36 computer systemd[464675]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
touko 25 10:28:36 computer systemd[464675]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
touko 25 10:28:36 computer systemd[464675]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
touko 25 10:28:36 computer systemd[464675]: Listening on GnuPG cryptographic agent and passphrase cache.
touko 25 10:28:36 computer systemd[464675]: Listening on GnuPG public key management service.
touko 25 10:28:36 computer systemd[464675]: Listening on p11-kit server.
touko 25 10:28:36 computer systemd[464675]: Listening on PipeWire PulseAudio.
touko 25 10:28:36 computer systemd[464675]: Listening on PipeWire Multimedia System Sockets.
touko 25 10:28:36 computer systemd[464675]: Listening on D-Bus User Message Bus Socket.
touko 25 10:28:36 computer systemd[464675]: Reached target Sockets.
touko 25 10:28:36 computer systemd[464675]: Reached target Basic System.
touko 25 10:28:36 computer systemd[1]: Started User Manager for UID 964.
touko 25 10:28:36 computer systemd[464675]: Starting Update XDG user dir configuration...
touko 25 10:28:36 computer systemd[1]: Started Session c2 of User sddm.
touko 25 10:28:36 computer sddm-helper[464670]: Writing cookie to "/tmp/xauth_rJmgNF"
touko 25 10:28:36 computer sddm-helper[464670]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-qbPDzr --theme /usr/share/sddm/themes/breath"
touko 25 10:28:36 computer sddm[464597]: Greeter session started successfully
touko 25 10:28:36 computer systemd[464675]: Finished Update XDG user dir configuration.
touko 25 10:28:36 computer systemd[464675]: Reached target Main User Target.
touko 25 10:28:36 computer systemd[464675]: Startup finished in 200ms.
touko 25 10:28:36 computer sddm-greeter-qt6[464703]: High-DPI autoscaling not Enabled
touko 25 10:28:36 computer sddm-greeter-qt6[464703]: QColorSpace attempted constructed from invalid primaries: QPointF(0.313477,0.329102) QPointF(0.680664,0.320313) QPointF(0.265625,0.69043) QPointF(0.150391,0.0605469)
touko 25 10:28:36 computer sddm-greeter-qt6[464703]: Reading from "/usr/share/wayland-sessions/plasmawayland.desktop"
touko 25 10:28:36 computer sddm-greeter-qt6[464703]: Reading from "/usr/share/xsessions/plasma.desktop"
touko 25 10:28:36 computer sddm-greeter-qt6[464703]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
touko 25 10:28:36 computer systemd[464675]: Created slice User Core Session Slice.
touko 25 10:28:36 computer systemd[464675]: Starting D-Bus User Message Bus...
touko 25 10:28:36 computer dbus-broker-launch[464707]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
touko 25 10:28:36 computer dbus-broker-launch[464707]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
touko 25 10:28:36 computer dbus-broker-launch[464707]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
touko 25 10:28:36 computer dbus-broker-launch[464707]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +31: Eavesdropping is deprecated and ignored
touko 25 10:28:36 computer dbus-broker-launch[464707]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
touko 25 10:28:36 computer systemd[464675]: Started D-Bus User Message Bus.
touko 25 10:28:36 computer dbus-broker-launch[464707]: Ready
touko 25 10:28:36 computer sddm-greeter-qt6[464703]: Connected to the daemon.
touko 25 10:28:36 computer sddm[464597]: Message received from greeter: Connect
touko 25 10:28:36 computer systemd[1]: systemd-coredump@4-464523-0.service: Deactivated successfully.
touko 25 10:28:36 computer systemd[1]: systemd-coredump@4-464523-0.service: Consumed 1.941s CPU time, 1G memory peak.
touko 25 10:28:36 computer systemd[1]: systemd-coredump@12-464694-0.service: Deactivated successfully.
touko 25 10:28:36 computer sddm-greeter-qt6[464703]: Loading file:///usr/share/sddm/themes/breath/Main.qml...
touko 25 10:28:36 computer systemd-coredump[464723]: Process 464719 (xdg-desktop-por) of user 1000 terminated abnormally with signal 6/ABRT, processing...
touko 25 10:28:36 computer systemd[1]: Started Process Core Dump (PID 464723/UID 0).
touko 25 10:28:36 computer systemd[1]: systemd-coredump@13-464723-0.service: Deactivated successfully.
touko 25 10:28:36 computer systemd-coredump[464739]: Process 464737 (xdg-desktop-por) of user 1000 terminated abnormally with signal 6/ABRT, processing...
touko 25 10:28:36 computer systemd[1]: Started Process Core Dump (PID 464739/UID 0).
touko 25 10:28:36 computer sddm-greeter-qt6[464703]: Adding view for "HDMI-1" QRect(0,0 2560x1440)
touko 25 10:28:37 computer systemd[1]: systemd-coredump@14-464739-0.service: Deactivated successfully.
touko 25 10:28:37 computer rtkit-daemon[1630]: Supervising 6 threads of 3 processes of 1 users.
touko 25 10:28:37 computer sddm-greeter-qt6[464703]: Adding view for "HDMI-0" QRect(2560,0 1920x1080)
touko 25 10:28:37 computer sddm-greeter-qt6[464703]: Message received from daemon: Capabilities
touko 25 10:28:37 computer sddm-greeter-qt6[464703]: Message received from daemon: HostName
touko 25 10:28:39 computer sddm-greeter-qt6[464703]: file:///usr/share/sddm/themes/breath/Main.qml:230:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
touko 25 10:28:39 computer sddm-greeter-qt6[464703]: Reading from "/usr/share/xsessions/plasma.desktop"
touko 25 10:28:39 computer sddm[464597]: Message received from greeter: Login
touko 25 10:28:39 computer sddm[464597]: Reading from "/usr/share/xsessions/plasma.desktop"
touko 25 10:28:39 computer sddm[464597]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11" for VT 1
touko 25 10:28:39 computer sddm-helper[464769]: [PAM] Starting...
touko 25 10:28:39 computer sddm-helper[464769]: [PAM] Authenticating...
touko 25 10:28:39 computer sddm-helper[464769]: [PAM] Preparing to converse...
touko 25 10:28:39 computer sddm-helper[464769]: [PAM] Conversation with 1 messages
touko 25 10:28:40 computer sddm-helper[464769]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
touko 25 10:28:40 computer sddm-helper[464769]: [PAM] returning.
touko 25 10:28:40 computer sddm[464597]: Authentication for user "ruby" successful
touko 25 10:28:40 computer sddm-greeter-qt6[464703]: Message received from daemon: LoginSucceeded
touko 25 10:28:40 computer sddm-helper[464769]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
touko 25 10:28:40 computer sddm-helper[464769]: pam_unix(sddm:session): session opened for user ruby(uid=1000) by ruby(uid=0)
touko 25 10:28:40 computer systemd-logind[959]: New session 6 of user ruby.
touko 25 10:28:40 computer systemd[1]: Started Session 6 of User ruby.
touko 25 10:28:40 computer sddm-helper[464769]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
touko 25 10:28:40 computer sddm-helper[464769]: Writing cookie to "/tmp/xauth_mAmFyh"
touko 25 10:28:40 computer sddm-helper[464769]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
touko 25 10:28:40 computer sddm[464597]: Session started true
touko 25 10:28:40 computer sddm-helper[464670]: [PAM] Closing session
touko 25 10:28:40 computer sddm-helper[464670]: pam_unix(sddm-greeter:session): session closed for user sddm
touko 25 10:28:40 computer sddm-helper[464670]: [PAM] Ended.
touko 25 10:28:40 computer sddm[464597]: Auth: sddm-helper exited successfully
touko 25 10:28:40 computer sddm[464597]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
touko 25 10:28:40 computer systemd[1]: session-c2.scope: Deactivated successfully.
touko 25 10:28:40 computer systemd[1]: session-c2.scope: Consumed 1.026s CPU time, 222.7M memory peak.
touko 25 10:28:40 computer systemd-logind[959]: Session c2 logged out. Waiting for processes to exit.
touko 25 10:28:40 computer systemd-logind[959]: Removed session c2.
touko 25 10:28:42 computer kernel: usb 1-6: Failed to query (GET_DEF) UVC control 12 on unit 2: 0 (exp. 4).
touko 25 10:28:50 computer systemd[1]: Stopping User Manager for UID 964...
touko 25 10:28:50 computer systemd[464675]: Activating special unit Exit the Session...
touko 25 10:28:50 computer systemd[464675]: Stopped target Main User Target.
touko 25 10:28:50 computer systemd[464675]: Stopped target Basic System.
touko 25 10:28:50 computer systemd[464675]: Stopped target Paths.
touko 25 10:28:50 computer systemd[464675]: Stopped target Sockets.
touko 25 10:28:50 computer systemd[464675]: Stopped target Timers.
touko 25 10:28:50 computer systemd[464675]: Closed GnuPG network certificate management daemon.
touko 25 10:28:50 computer systemd[464675]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
touko 25 10:28:50 computer systemd[464675]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
touko 25 10:28:50 computer systemd[464675]: Closed GnuPG cryptographic agent (ssh-agent emulation).
touko 25 10:28:50 computer systemd[464675]: Closed GnuPG cryptographic agent and passphrase cache.
touko 25 10:28:50 computer systemd[464675]: Closed GnuPG public key management service.
touko 25 10:28:50 computer systemd[464675]: Closed p11-kit server.
touko 25 10:28:50 computer systemd[464675]: Closed PipeWire PulseAudio.
touko 25 10:28:50 computer systemd[464675]: Closed PipeWire Multimedia System Sockets.
touko 25 10:28:50 computer dbus-broker[464708]: Dispatched 157 messages @ 1(±3)μs / message.
touko 25 10:28:50 computer systemd[464675]: Stopping D-Bus User Message Bus...
touko 25 10:28:50 computer systemd[464675]: Stopped D-Bus User Message Bus.
touko 25 10:28:50 computer systemd[464675]: Removed slice User Core Session Slice.
touko 25 10:28:50 computer systemd[464675]: Closed D-Bus User Message Bus Socket.
touko 25 10:28:50 computer systemd[464675]: Removed slice User Application Slice.
touko 25 10:28:50 computer systemd[464675]: Reached target Shutdown.
touko 25 10:28:50 computer systemd[464675]: Finished Exit the Session.
touko 25 10:28:50 computer systemd[464675]: Reached target Exit the Session.
touko 25 10:28:50 computer systemd-logind[959]: Removed session 5.
touko 25 10:28:50 computer (sd-pam)[464678]: pam_unix(systemd-user:session): session closed for user sddm
touko 25 10:28:50 computer systemd[1]: user@964.service: Deactivated successfully.
touko 25 10:28:50 computer systemd[1]: Stopped User Manager for UID 964.
touko 25 10:28:50 computer systemd[1]: Stopping User Runtime Directory /run/user/964...
touko 25 10:28:50 computer systemd[1]: run-user-964.mount: Deactivated successfully.
touko 25 10:28:50 computer systemd[1]: user-runtime-dir@964.service: Deactivated successfully.
touko 25 10:28:50 computer systemd[1]: Stopped User Runtime Directory /run/user/964.
touko 25 10:28:50 computer systemd[1]: Removed slice User Slice of UID 964.
touko 25 10:28:50 computer systemd[1]: user-964.slice: Consumed 1.227s CPU time, 229.2M memory peak.
