Sometimes when suspending the laptop (HP elitebook 840 G9) to s2idle I can’t wake it back up, I havent figured out the conditions when it happens.
When trying to wake it up I noticed that the laptop responds becasue the keyboard lights up hovewer any lightinging on the keyboard that is controlled by the system is not working (mic mute, capslock led not turning on).
The only way I can recover the laptop is by pressing the power button for 5sec and doing a hard reset.
Inxi:
Generated on 2023-06-27 16:29:1687876176
#################### inxi -Fxzc0 ########################
  Kernel: 6.3.5-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1 Desktop: GNOME v: 44.1
  Type: Laptop System: HP product: HP EliteBook 840 14 inch G9 Notebook PC v: N/A
    serial: <superuser required>
  Mobo: HP model: 8ABB v: KBC Version 20.5E.00 serial: <superuser required> UEFI: HP
    v: U71 Ver. 01.05.00 date: 01/04/2023
  ID-1: BAT0 charge: 37.8 Wh (94.5%) condition: 40.0/51.3 Wh (78.0%) volts: 12.1 min: 11.6
    model: Hewlett-Packard Primary status: discharging
  Info: 10-core (2-mt/8-st) model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
    arch: Alder Lake rev: 4 cache: L1: 928 KiB L2: 6.5 MiB L3: 12 MiB
  Speed (MHz): avg: 2325 high: 2500 min/max: 400/4400:3300 cores: 1: 2500 2: 2500 3: 400 4: 2500
    5: 2500 6: 2500 7: 2500 8: 2500 9: 2500 10: 2500 11: 2500 12: 2500 bogomips: 59916
  Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Hewlett-Packard driver: i915
    v: kernel arch: Gen-12.2 bus-ID: 00:02.0
  Device-2: Quanta HP 5MP Camera driver: uvcvideo type: USB bus-ID: 3-1:2
  Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1 driver: X: loaded: modesetting
    dri: iris gpu: i915 resolution: 1920x1200~60Hz
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Graphics (ADL GT2) direct-render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3
  API: ALSA v: k6.3.5-2-MANJARO status: kernel-api
  Server-1: sndiod v: N/A status: off
  Server-2: JACK v: 1.9.22 status: off
  Server-3: PipeWire v: 0.3.70 status: off
  Server-4: PulseAudio v: 16.1 status: active
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
  IF-ID-1: wwan0 state: down mac: N/A
  Device-1: Intel driver: btusb v: 0.8 type: USB bus-ID: 3-10:4
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
    hardware: no software: yes address: see --recommends
  Local Storage: total: 476.94 GiB used: 42.11 GiB (8.8%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLQ512HBLU-00BH1 size: 476.94 GiB temp: 25.9 C
  ID-1: / size: 451.56 GiB used: 42.06 GiB (9.3%) fs: ext4 dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 299.4 MiB used: 58.4 MiB (19.5%) fs: vfat dev: /dev/nvme0n1p1
  ID-1: swap-1 type: partition size: 16.8 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p3
  System Temperatures: cpu: 30.0 C mobo: N/A
  Processes: 298 Uptime: 11m Memory: available: 14.88 GiB used: 2.01 GiB (13.5%) Init: systemd
  Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1740 Client: gnome-shell v: 44.1 inxi: 3.3.27
Last 30min of logs from when the failed suspend happend:
cze 27 15:04:42 _user_ gnome-shell[5774]: #2   7ffed046bb00 b   resource:///org/gnome/gjs/modules/core/_signals.js:130 (1ad772491920 @ 126)
cze 27 15:04:42 _user_ gnome-shell[5774]: #3   7ffed046bbf0 b   resource:///org/gnome/gjs/modules/core/_signals.js:119 (1ad772491830 @ 286)
cze 27 15:04:42 _user_ gnome-shell[5774]: #4   7ffed046c330 b   resource:///org/gnome/shell/ui/sessionMode.js:208 (2f3f7db6f100 @ 283)
cze 27 15:04:42 _user_ gnome-shell[5774]: #5   55fc013da7f8 i   resource:///org/gnome/shell/ui/sessionMode.js:176 (2f3f7db6afb0 @ 142)
cze 27 15:04:42 _user_ gnome-shell[5774]: #6   55fc013da768 i   resource:///org/gnome/shell/ui/screenShield.js:544 (2f3f7db656f0 @ 79)
cze 27 15:04:42 _user_ gnome-shell[5774]: #7   55fc013da6e0 i   resource:///org/gnome/shell/ui/screenShield.js:535 (2f3f7db656a0 @ 17)
cze 27 15:04:42 _user_ gnome-shell[5774]: #8   55fc013da650 i   resource:///org/gnome/shell/gdm/authPrompt.js:678 (2f3f7db76290 @ 64)
cze 27 15:04:42 _user_ gnome-shell[5774]: #9   55fc013da5c0 i   resource:///org/gnome/shell/ui/unlockDialog.js:862 (2f3f7db85fb0 @ 59)
cze 27 15:04:42 _user_ gnome-shell[5774]: #10   55fc013da538 i   resource:///org/gnome/shell/ui/screenShield.js:535 (2f3f7db65650 @ 49)
cze 27 15:04:42 _user_ gnome-shell[5774]: #11   55fc013da4b0 i   resource:///org/gnome/shell/ui/screenShield.js:148 (2f3f7db60ba0 @ 13)
cze 27 15:04:42 _user_ gnome-shell[5774]: #12   7ffed046cd00 b   resource:///org/gnome/gjs/modules/core/_signals.js:130 (1ad772491920 @ 126)
cze 27 15:04:42 _user_ gnome-shell[5774]: #13   7ffed046cdf0 b   resource:///org/gnome/gjs/modules/core/_signals.js:119 (1ad772491830 @ 286)
cze 27 15:04:42 _user_ gnome-shell[5774]: #14   55fc013da408 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:152 (1ad7724856f0 @ 39)
cze 27 15:04:42 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:04:42 _user_ gnome-shell[5774]: #0   55fc013da950 i   resource:///org/gnome/shell/ui/calendar.js:1021 (60588528ab0 @ 80)
cze 27 15:04:42 _user_ gnome-shell[5774]: #1   7ffed046ba10 b   self-hosted:1115 (1ad7724c1ba0 @ 432)
cze 27 15:04:42 _user_ gnome-shell[5774]: Object .Gjs_ui_calendar_CalendarMessageList (0x55fbff9b5890), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:04:42 _user_ gnome-shell[5774]: #0   7ffed046b070 b   resource:///org/gnome/shell/ui/calendar.js:611 (60588527ec0 @ 79)
cze 27 15:04:42 _user_ gnome-shell[5774]: #1   55fc013daa80 i   resource:///org/gnome/shell/ui/calendar.js:449 (60588527bf0 @ 107)
cze 27 15:04:42 _user_ gnome-shell[5774]: #2   55fc013da9f0 i   resource:///org/gnome/shell/ui/dateMenu.js:949 (2f3f7db3e6f0 @ 69)
cze 27 15:04:42 _user_ gnome-shell[5774]: #3   55fc013da950 i   resource:///org/gnome/shell/ui/dateMenu.js:972 (2f3f7db3e790 @ 128)
cze 27 15:04:42 _user_ gnome-shell[5774]: #4   7ffed046ba10 b   self-hosted:1115 (1ad7724c1ba0 @ 432)
cze 27 15:04:42 _user_ gnome-shell[5774]: #5   7ffed046bb00 b   resource:///org/gnome/gjs/modules/core/_signals.js:130 (1ad772491920 @ 126)
cze 27 15:04:42 _user_ gnome-shell[5774]: #6   7ffed046bbf0 b   resource:///org/gnome/gjs/modules/core/_signals.js:119 (1ad772491830 @ 286)
cze 27 15:04:42 _user_ gnome-shell[5774]: #7   7ffed046c330 b   resource:///org/gnome/shell/ui/sessionMode.js:208 (2f3f7db6f100 @ 283)
cze 27 15:04:42 _user_ gnome-shell[5774]: #8   55fc013da7f8 i   resource:///org/gnome/shell/ui/sessionMode.js:176 (2f3f7db6afb0 @ 142)
cze 27 15:04:42 _user_ gnome-shell[5774]: #9   55fc013da768 i   resource:///org/gnome/shell/ui/screenShield.js:544 (2f3f7db656f0 @ 79)
cze 27 15:04:42 _user_ gnome-shell[5774]: Object .Gjs_ui_calendar_Calendar (0x55fbff99af10), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:04:42 _user_ gnome-shell[5774]: #10   55fc013da6e0 i   resource:///org/gnome/shell/ui/screenShield.js:535 (2f3f7db656a0 @ 17)
cze 27 15:04:42 _user_ gnome-shell[5774]: #11   55fc013da650 i   resource:///org/gnome/shell/gdm/authPrompt.js:678 (2f3f7db76290 @ 64)
cze 27 15:04:42 _user_ gnome-shell[5774]: #12   55fc013da5c0 i   resource:///org/gnome/shell/ui/unlockDialog.js:862 (2f3f7db85fb0 @ 59)
cze 27 15:04:42 _user_ gnome-shell[5774]: #13   55fc013da538 i   resource:///org/gnome/shell/ui/screenShield.js:535 (2f3f7db65650 @ 49)
cze 27 15:04:42 _user_ gnome-shell[5774]: #14   55fc013da4b0 i   resource:///org/gnome/shell/ui/screenShield.js:148 (2f3f7db60ba0 @ 13)
cze 27 15:04:42 _user_ gnome-shell[5774]: #15   7ffed046cd00 b   resource:///org/gnome/gjs/modules/core/_signals.js:130 (1ad772491920 @ 126)
cze 27 15:04:42 _user_ gnome-shell[5774]: #16   7ffed046cdf0 b   resource:///org/gnome/gjs/modules/core/_signals.js:119 (1ad772491830 @ 286)
cze 27 15:04:42 _user_ gnome-shell[5774]: #17   55fc013da408 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:152 (1ad7724856f0 @ 39)
cze 27 15:04:42 _user_ gnome-shell[5774]: #0   7ffed046b070 b   resource:///org/gnome/shell/ui/calendar.js:646 (60588527ec0 @ 428)
cze 27 15:04:42 _user_ gnome-shell[5774]: Object .Gjs_ui_calendar_Calendar (0x55fbff99af10), has been already disposed — impossible to get any property from it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:04:42 _user_ gnome-shell[5774]: JS ERROR: Exception in callback for signal: updated: TypeError: layout is null
                                         _rebuildCalendar@resource:///org/gnome/shell/ui/calendar.js:703:13
                                         setEventSource@resource:///org/gnome/shell/ui/calendar.js:449:14
                                         _setEventSource@resource:///org/gnome/shell/ui/dateMenu.js:949:24
                                         _sessionUpdated@resource:///org/gnome/shell/ui/dateMenu.js:972:14
                                         _callHandlers@resource:///org/gnome/gjs/modules/core/_signals.js:130:42
                                         _emit@resource:///org/gnome/gjs/modules/core/_signals.js:119:10
                                         _sync@resource:///org/gnome/shell/ui/sessionMode.js:208:14
                                         popMode@resource:///org/gnome/shell/ui/sessionMode.js:176:14
                                         _continueDeactivate@resource:///org/gnome/shell/ui/screenShield.js:544:30
                                         deactivate/<@resource:///org/gnome/shell/ui/screenShield.js:535:44
                                         finish@resource:///org/gnome/shell/gdm/authPrompt.js:678:13
                                         finish@resource:///org/gnome/shell/ui/unlockDialog.js:862:26
                                         deactivate@resource:///org/gnome/shell/ui/screenShield.js:535:26
                                         _getLoginSession/<@resource:///org/gnome/shell/ui/screenShield.js:148:24
                                         _convertToNativeSignal@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:152:19
cze 27 15:04:42 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Loading ...
cze 27 15:04:42 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Loading feature 'dndQuickToggleFeature'
cze 27 15:04:42 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Loading feature 'unsafeQuickToggleFeature'
cze 27 15:04:42 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Loading feature 'notificationsFeature'
cze 27 15:04:42 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Loading feature 'volumeMixerFeature'
cze 27 15:04:42 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Loading feature 'dateMenuFeature'
cze 27 15:04:42 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Loading feature 'buttonRemoverFeature'
cze 27 15:04:42 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Loading feature 'inputOutputFeature'
cze 27 15:04:42 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Loaded. 14ms taken
cze 27 15:04:42 _user_ gnome-shell[5774]: loading default theme (Adwaita)
cze 27 15:04:42 _user_ NetworkManager[725]: <info>  [1687871082.9964] agent-manager: agent[5fb0eb7cbdde8219,:1.178/org.gnome.Shell.NetworkAgent/1000]: agent registered
cze 27 15:04:43 _user_ gnome-shell[5774]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
cze 27 15:04:43 _user_ gnome-shell[5774]: Window manager warning: Overwriting existing binding of keysym 61 with keysym 61 (keycode 26).
cze 27 15:04:43 _user_ gnome-shell[5774]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
cze 27 15:04:48 _user_ systemd[1696]: app-gnome-caffeine-5723.scope: Consumed 33.807s CPU time.
cze 27 15:04:48 _user_ gnome-shell[5774]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying
                                         asyncCallback@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:114:23
cze 27 15:05:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:05:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:05:00 _user_ gnome-shell[5774]: #0   7ffed046cf50 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:05:00 _user_ gnome-shell[5774]: #1   55fc043c2338 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:05:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:05:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:05:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:05:11 _user_ systemd[1]: fprintd.service: Deactivated successfully.
cze 27 15:05:59 _user_ gnome-shell[5774]: Object St.BoxLayout (0x55fbff9c8420), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:05:59 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:05:59 _user_ gnome-shell[5774]: #0   55fc043c2918 i   resource:///org/gnome/shell/ui/calendar.js:1019 (60588528ab0 @ 40)
cze 27 15:05:59 _user_ gnome-shell[5774]: #1   7ffed046b1e0 b   self-hosted:1115 (1ad7724c1ba0 @ 432)
cze 27 15:05:59 _user_ gnome-shell[5774]: #2   7ffed046b2d0 b   resource:///org/gnome/gjs/modules/core/_signals.js:130 (1ad772491920 @ 126)
cze 27 15:05:59 _user_ gnome-shell[5774]: #3   55fc043c2858 i   resource:///org/gnome/gjs/modules/core/_signals.js:119 (1ad772491830 @ 286)
cze 27 15:05:59 _user_ gnome-shell[5774]: #4   7ffed046bdd0 b   resource:///org/gnome/shell/ui/sessionMode.js:208 (2f3f7db6f100 @ 283)
cze 27 15:05:59 _user_ gnome-shell[5774]: #5   55fc043c26e0 i   resource:///org/gnome/shell/ui/sessionMode.js:167 (2f3f7db6af60 @ 66)
cze 27 15:05:59 _user_ gnome-shell[5774]: #6   55fc043c2630 i   resource:///org/gnome/shell/ui/screenShield.js:617 (2f3f7db657e0 @ 206)
cze 27 15:05:59 _user_ gnome-shell[5774]: #7   55fc043c25a0 i   resource:///org/gnome/shell/ui/screenShield.js:336 (2f3f7db60fb0 @ 36)
cze 27 15:05:59 _user_ gnome-shell[5774]: #8   55fc043c24d0 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:05:59 _user_ gnome-shell[5774]: #9   55fc043c2448 i   resource:///org/gnome/shell/ui/lightbox.js:198 (1ad7724fcf10 @ 29)
cze 27 15:05:59 _user_ gnome-shell[5774]: #10   55fc043c23c0 i   resource:///org/gnome/shell/ui/environment.js:153 (1ad77247c4c0 @ 98)
cze 27 15:05:59 _user_ gnome-shell[5774]: #11   55fc043c2338 i   resource:///org/gnome/shell/ui/environment.js:240 (1ad77247c830 @ 14)
cze 27 15:05:59 _user_ gnome-shell[5774]: #0   55fc043c2918 i   resource:///org/gnome/shell/ui/calendar.js:1021 (60588528ab0 @ 80)
cze 27 15:05:59 _user_ gnome-shell[5774]: Object .Gjs_ui_calendar_CalendarMessageList (0x55fbff9b5890), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:05:59 _user_ gnome-shell[5774]: #0   7ffed046a790 b   resource:///org/gnome/shell/ui/calendar.js:611 (60588527ec0 @ 79)
cze 27 15:05:59 _user_ gnome-shell[5774]: #1   7ffed046a840 b   resource:///org/gnome/shell/ui/calendar.js:449 (60588527bf0 @ 107)
cze 27 15:05:59 _user_ gnome-shell[5774]: #2   55fc043c29b8 i   resource:///org/gnome/shell/ui/dateMenu.js:949 (2f3f7db3e6f0 @ 69)
cze 27 15:05:59 _user_ gnome-shell[5774]: #3   55fc043c2918 i   resource:///org/gnome/shell/ui/dateMenu.js:972 (2f3f7db3e790 @ 128)
cze 27 15:05:59 _user_ gnome-shell[5774]: #4   7ffed046b1e0 b   self-hosted:1115 (1ad7724c1ba0 @ 432)
cze 27 15:05:59 _user_ gnome-shell[5774]: #5   7ffed046b2d0 b   resource:///org/gnome/gjs/modules/core/_signals.js:130 (1ad772491920 @ 126)
cze 27 15:05:59 _user_ gnome-shell[5774]: #6   55fc043c2858 i   resource:///org/gnome/gjs/modules/core/_signals.js:119 (1ad772491830 @ 286)
cze 27 15:05:59 _user_ gnome-shell[5774]: #7   7ffed046bdd0 b   resource:///org/gnome/shell/ui/sessionMode.js:208 (2f3f7db6f100 @ 283)
cze 27 15:05:59 _user_ gnome-shell[5774]: #8   55fc043c26e0 i   resource:///org/gnome/shell/ui/sessionMode.js:167 (2f3f7db6af60 @ 66)
cze 27 15:05:59 _user_ gnome-shell[5774]: #9   55fc043c2630 i   resource:///org/gnome/shell/ui/screenShield.js:617 (2f3f7db657e0 @ 206)
cze 27 15:05:59 _user_ gnome-shell[5774]: #10   55fc043c25a0 i   resource:///org/gnome/shell/ui/screenShield.js:336 (2f3f7db60fb0 @ 36)
cze 27 15:05:59 _user_ gnome-shell[5774]: #11   55fc043c24d0 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:05:59 _user_ gnome-shell[5774]: #12   55fc043c2448 i   resource:///org/gnome/shell/ui/lightbox.js:198 (1ad7724fcf10 @ 29)
cze 27 15:05:59 _user_ gnome-shell[5774]: #13   55fc043c23c0 i   resource:///org/gnome/shell/ui/environment.js:153 (1ad77247c4c0 @ 98)
cze 27 15:05:59 _user_ gnome-shell[5774]: #14   55fc043c2338 i   resource:///org/gnome/shell/ui/environment.js:240 (1ad77247c830 @ 14)
cze 27 15:05:59 _user_ gnome-shell[5774]: #0   7ffed046a790 b   resource:///org/gnome/shell/ui/calendar.js:646 (60588527ec0 @ 428)
cze 27 15:05:59 _user_ gnome-shell[5774]: Object .Gjs_ui_calendar_Calendar (0x55fbff99af10), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:05:59 _user_ gnome-shell[5774]: Object .Gjs_ui_calendar_Calendar (0x55fbff99af10), has been already disposed — impossible to get any property from it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:05:59 _user_ gnome-shell[5774]: JS ERROR: Exception in callback for signal: updated: TypeError: layout is null
                                         pushMode@resource:///org/gnome/shell/ui/sessionMode.js:167:14
                                         activate@resource:///org/gnome/shell/ui/screenShield.js:617:34
                                         _onLongLightbox@resource:///org/gnome/shell/ui/screenShield.js:336:18
                                         onComplete@resource:///org/gnome/shell/ui/lightbox.js:198:18
                                         _makeEaseCallback/<@resource:///org/gnome/shell/ui/environment.js:153:13
                                         _easeActor/<@resource:///org/gnome/shell/ui/environment.js:240:64
cze 27 15:06:00 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Unloading ...
cze 27 15:06:00 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Unload feature 'dndQuickToggleFeature'
cze 27 15:06:00 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Unload feature 'unsafeQuickToggleFeature'
cze 27 15:06:00 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Unload feature 'notificationsFeature'
cze 27 15:06:00 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Unload feature 'volumeMixerFeature'
cze 27 15:06:00 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Unload feature 'dateMenuFeature'
cze 27 15:06:00 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Unload feature 'buttonRemoverFeature'
cze 27 15:06:00 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Unload feature 'inputOutputFeature'
cze 27 15:06:00 _user_ gnome-shell[5774]: [EXTENSION QSTweaks] Diabled. 3ms taken
cze 27 15:06:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:06:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:06:00 _user_ gnome-shell[5774]: #0   55fbfe6aeaa8 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:06:00 _user_ gnome-shell[5774]: #1   7ffed046d350 b   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:06:00 _user_ gnome-shell[5774]: #0   7ffed046c980 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:06:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:06:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:06:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:06:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:06:00 _user_ gnome-shell[5774]: Window manager warning: Overwriting existing binding of keysym 61 with keysym 61 (keycode 26).
cze 27 15:07:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:07:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:07:00 _user_ gnome-shell[5774]: #0   55fbfe6aeb78 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:07:00 _user_ gnome-shell[5774]: #1   55fbfe6aeaa8 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:07:00 _user_ gnome-shell[5774]: #0   7ffed046cf50 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:07:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:07:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:07:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:07:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:08:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:08:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:08:00 _user_ gnome-shell[5774]: #0   55fbfe6aeb78 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:08:00 _user_ gnome-shell[5774]: #1   55fbfe6aeaa8 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:08:00 _user_ gnome-shell[5774]: #0   7ffed046cf50 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:08:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:08:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:08:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:08:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:09:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:09:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:09:00 _user_ gnome-shell[5774]: #0   55fbff9d2c28 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:09:00 _user_ gnome-shell[5774]: #1   55fbff9d2b58 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:09:00 _user_ gnome-shell[5774]: #0   7ffed046cf50 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:09:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:09:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:09:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:09:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:10:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:10:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:10:00 _user_ gnome-shell[5774]: #0   55fbff9d2c28 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:10:00 _user_ gnome-shell[5774]: #1   55fbff9d2b58 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:10:00 _user_ gnome-shell[5774]: #0   7ffed046cf50 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:10:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:10:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:10:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:10:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:11:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:11:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:11:00 _user_ gnome-shell[5774]: #0   55fbff797628 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:11:00 _user_ gnome-shell[5774]: #1   7ffed046d350 b   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:11:00 _user_ gnome-shell[5774]: #0   7ffed046c980 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:11:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:11:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:11:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:11:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:12:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:12:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:12:00 _user_ gnome-shell[5774]: #0   55fc043c8358 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:12:00 _user_ gnome-shell[5774]: #1   55fc043c8288 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:12:00 _user_ gnome-shell[5774]: #0   7ffed046cf50 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:12:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:12:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:12:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:12:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:12:19 _user_ gnome-shell[5774]: JS ERROR: TypeError: this._settings is null
                                         _sync@resource:///org/gnome/shell/ui/dateMenu.js:766:28
                                         _updateCount@resource:///org/gnome/shell/ui/dateMenu.js:762:14
                                         _onSourceAdded@resource:///org/gnome/shell/ui/dateMenu.js:749:14
                                         _addSource@resource:///org/gnome/shell/ui/messageTray.js:983:14
                                         _onSourceEnableChanged@resource:///org/gnome/shell/ui/messageTray.js:1002:22
                                         add@resource:///org/gnome/shell/ui/messageTray.js:973:14
                                         _getSource@resource:///org/gnome/shell/ui/notificationDaemon.js:123:26
                                         NotifyAsync@resource:///org/gnome/shell/ui/notificationDaemon.js:190:27
                                         _handleMethodCall@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:373:35
                                         _wrapJSObject/<@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:408:34
cze 27 15:12:19 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:12:19 _user_ gnome-shell[5774]: #0   7ffed046bb00 b   resource:///org/gnome/shell/misc/signalTracker.js:124 (240b50b824c0 @ 92)
cze 27 15:12:19 _user_ gnome-shell[5774]: #1   7ffed046bbc0 b   resource:///org/gnome/shell/misc/signalTracker.js:158 (1ad7724ce4c0 @ 51)
cze 27 15:12:19 _user_ gnome-shell[5774]: #2   7ffed046bcd0 b   resource:///org/gnome/shell/misc/signalTracker.js:246 (6058852bfb0 @ 763)
cze 27 15:12:19 _user_ gnome-shell[5774]: #3   7ffed046bdb0 b   resource:///org/gnome/shell/ui/environment.js:332 (1ad77247cab0 @ 121)
cze 27 15:12:19 _user_ gnome-shell[5774]: #4   55fc043c8890 i   resource:///org/gnome/shell/ui/calendar.js:840 (60588528510 @ 48)
cze 27 15:12:19 _user_ gnome-shell[5774]: #5   55fc043c87c0 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:12:19 _user_ gnome-shell[5774]: #6   55fc043c8718 i   resource:///org/gnome/shell/ui/messageTray.js:983 (60588521240 @ 116)
cze 27 15:12:19 _user_ gnome-shell[5774]: #7   55fc043c8678 i   resource:///org/gnome/shell/ui/messageTray.js:1002 (60588521380 @ 98)
cze 27 15:12:19 _user_ gnome-shell[5774]: #8   55fc043c85d8 i   resource:///org/gnome/shell/ui/messageTray.js:973 (605885211a0 @ 205)
cze 27 15:12:19 _user_ gnome-shell[5774]: #9   55fc043c8528 i   resource:///org/gnome/shell/ui/notificationDaemon.js:123 (2f3f7db5f150 @ 384)
cze 27 15:12:19 _user_ gnome-shell[5774]: #10   55fc043c8418 i   resource:///org/gnome/shell/ui/notificationDaemon.js:190 (2f3f7db5f1f0 @ 1630)
cze 27 15:12:19 _user_ gnome-shell[5774]: #11   55fc043c8338 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:373 (1ad772485f10 @ 945)
cze 27 15:12:19 _user_ gnome-shell[5774]: #12   55fc043c8288 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:408 (1ad77248c0b0 @ 34)
cze 27 15:12:19 _user_ gnome-shell[5774]: #0   7ffed046b530 b   resource:///org/gnome/shell/misc/signalTracker.js:124 (240b50b824c0 @ 92)
cze 27 15:12:19 _user_ gnome-shell[5774]: #1   7ffed046b5f0 b   resource:///org/gnome/shell/misc/signalTracker.js:158 (1ad7724ce4c0 @ 51)
cze 27 15:12:19 _user_ gnome-shell[5774]: #2   7ffed046b700 b   resource:///org/gnome/shell/misc/signalTracker.js:246 (6058852bfb0 @ 763)
cze 27 15:12:19 _user_ gnome-shell[5774]: #3   7ffed046b7e0 b   resource:///org/gnome/shell/ui/environment.js:332 (1ad77247cab0 @ 121)
cze 27 15:12:19 _user_ gnome-shell[5774]: #4   55fc043c87c0 i   resource:///org/gnome/shell/ui/calendar.js:840 (60588528510 @ 48)
cze 27 15:12:19 _user_ gnome-shell[5774]: #5   7ffed046c1a0 b   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:12:19 _user_ gnome-shell[5774]: Object .Gjs_ui_calendar_NotificationSection (0x55fbff9cf870), has been already disposed — impossible to connect to any signal on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:12:19 _user_ gnome-shell[5774]: Object .Gjs_ui_calendar_NotificationSection (0x55fbfe6bf4d0), has been already disposed — impossible to connect to any signal on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:12:19 _user_ gnome-shell[5774]: #0   7ffed046b510 b   resource:///org/gnome/shell/misc/signalTracker.js:124 (240b50b824c0 @ 92)
cze 27 15:12:19 _user_ gnome-shell[5774]: #1   7ffed046b5d0 b   resource:///org/gnome/shell/misc/signalTracker.js:158 (1ad7724ce4c0 @ 51)
cze 27 15:12:19 _user_ gnome-shell[5774]: #2   7ffed046b6e0 b   resource:///org/gnome/shell/misc/signalTracker.js:246 (6058852bfb0 @ 763)
cze 27 15:12:19 _user_ gnome-shell[5774]: #3   7ffed046b7d0 b   resource:///org/gnome/shell/ui/environment.js:332 (1ad77247cab0 @ 121)
cze 27 15:12:19 _user_ gnome-shell[5774]: #4   55fc043c8808 i   resource:///org/gnome/shell/ui/calendar.js:850 (60588528560 @ 150)
cze 27 15:12:19 _user_ gnome-shell[5774]: #6   55fc043c8760 i   resource:///org/gnome/shell/ui/messageTray.js:756 (60588520b00 @ 257)
cze 27 15:12:19 _user_ gnome-shell[5774]: #7   55fc043c86c8 i   resource:///org/gnome/shell/ui/messageTray.js:763 (60588520b50 @ 30)
cze 27 15:12:19 _user_ gnome-shell[5774]: #8   55fc043c8630 i   resource:///org/gnome/shell/ui/notificationDaemon.js:387 (2f3f7db5f6a0 @ 198)
cze 27 15:12:19 _user_ gnome-shell[5774]: #9   55fc043c8528 i   resource:///org/gnome/shell/ui/notificationDaemon.js:288 (2f3f7db5f290 @ 1426)
cze 27 15:12:19 _user_ gnome-shell[5774]: #10   55fc043c8418 i   resource:///org/gnome/shell/ui/notificationDaemon.js:191 (2f3f7db5f1f0 @ 1658)
cze 27 15:12:19 _user_ gnome-shell[5774]: #0   55fc043c8808 i   resource:///org/gnome/shell/ui/calendar.js:871 (60588528560 @ 311)
cze 27 15:12:19 _user_ gnome-shell[5774]: #1   7ffed046c1a0 b   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:12:19 _user_ gnome-shell[5774]: #2   55fc043c8760 i   resource:///org/gnome/shell/ui/messageTray.js:756 (60588520b00 @ 257)
cze 27 15:12:19 _user_ gnome-shell[5774]: #3   55fc043c86c8 i   resource:///org/gnome/shell/ui/messageTray.js:763 (60588520b50 @ 30)
cze 27 15:12:19 _user_ gnome-shell[5774]: #4   55fc043c8630 i   resource:///org/gnome/shell/ui/notificationDaemon.js:387 (2f3f7db5f6a0 @ 198)
cze 27 15:12:19 _user_ gnome-shell[5774]: #5   55fc043c8528 i   resource:///org/gnome/shell/ui/notificationDaemon.js:288 (2f3f7db5f290 @ 1426)
cze 27 15:12:19 _user_ gnome-shell[5774]: #6   55fc043c8418 i   resource:///org/gnome/shell/ui/notificationDaemon.js:191 (2f3f7db5f1f0 @ 1658)
cze 27 15:12:19 _user_ gnome-shell[5774]: #7   55fc043c8338 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:373 (1ad772485f10 @ 945)
cze 27 15:12:19 _user_ gnome-shell[5774]: #8   55fc043c8288 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:408 (1ad77248c0b0 @ 34)
cze 27 15:12:19 _user_ gnome-shell[5774]: #0   55fc043c8968 i   resource:///org/gnome/shell/ui/messageList.js:598 (6058852ac90 @ 22)
cze 27 15:12:19 _user_ gnome-shell[5774]: #1   55fc043c88b8 i   resource:///org/gnome/shell/ui/messageList.js:614 (6058852ae20 @ 17)
cze 27 15:12:19 _user_ gnome-shell[5774]: #2   55fc043c8808 i   resource:///org/gnome/shell/ui/calendar.js:871 (60588528560 @ 316)
cze 27 15:12:19 _user_ gnome-shell[5774]: #3   7ffed046c1a0 b   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:12:19 _user_ gnome-shell[5774]: #4   55fc043c8760 i   resource:///org/gnome/shell/ui/messageTray.js:756 (60588520b00 @ 257)
cze 27 15:12:19 _user_ gnome-shell[5774]: #5   55fc043c86c8 i   resource:///org/gnome/shell/ui/messageTray.js:763 (60588520b50 @ 30)
cze 27 15:12:19 _user_ gnome-shell[5774]: #6   55fc043c8630 i   resource:///org/gnome/shell/ui/notificationDaemon.js:387 (2f3f7db5f6a0 @ 198)
cze 27 15:12:19 _user_ gnome-shell[5774]: #7   55fc043c8528 i   resource:///org/gnome/shell/ui/notificationDaemon.js:288 (2f3f7db5f290 @ 1426)
cze 27 15:12:19 _user_ gnome-shell[5774]: #8   55fc043c8418 i   resource:///org/gnome/shell/ui/notificationDaemon.js:191 (2f3f7db5f1f0 @ 1658)
cze 27 15:12:19 _user_ gnome-shell[5774]: #9   55fc043c8338 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:373 (1ad772485f10 @ 945)
cze 27 15:12:19 _user_ gnome-shell[5774]: #10   55fc043c8288 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:408 (1ad77248c0b0 @ 34)
cze 27 15:12:19 _user_ gnome-shell[5774]: #0   55fc043c88b8 i   resource:///org/gnome/shell/ui/messageList.js:634 (6058852ae20 @ 383)
cze 27 15:12:19 _user_ gnome-shell[5774]: #1   55fc043c8808 i   resource:///org/gnome/shell/ui/calendar.js:871 (60588528560 @ 316)
cze 27 15:12:19 _user_ gnome-shell[5774]: #2   7ffed046c1a0 b   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:12:19 _user_ gnome-shell[5774]: #3   55fc043c8760 i   resource:///org/gnome/shell/ui/messageTray.js:756 (60588520b00 @ 257)
cze 27 15:12:19 _user_ gnome-shell[5774]: Object .Gjs_ui_calendar_NotificationSection (0x55fbff9cf870), has been already disposed — impossible to get any property from it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:12:19 _user_ gnome-shell[5774]: #4   55fc043c86c8 i   resource:///org/gnome/shell/ui/messageTray.js:763 (60588520b50 @ 30)
cze 27 15:12:19 _user_ gnome-shell[5774]: #5   55fc043c8630 i   resource:///org/gnome/shell/ui/notificationDaemon.js:387 (2f3f7db5f6a0 @ 198)
cze 27 15:12:19 _user_ gnome-shell[5774]: #6   55fc043c8528 i   resource:///org/gnome/shell/ui/notificationDaemon.js:288 (2f3f7db5f290 @ 1426)
cze 27 15:12:19 _user_ gnome-shell[5774]: #7   55fc043c8418 i   resource:///org/gnome/shell/ui/notificationDaemon.js:191 (2f3f7db5f1f0 @ 1658)
cze 27 15:12:19 _user_ gnome-shell[5774]: #8   55fc043c8338 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:373 (1ad772485f10 @ 945)
cze 27 15:12:19 _user_ gnome-shell[5774]: #9   55fc043c8288 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:408 (1ad77248c0b0 @ 34)
cze 27 15:12:19 _user_ gnome-shell[5774]: Object St.BoxLayout (0x55fbff9cfda0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:12:19 _user_ gnome-shell[5774]: Object .Gjs_ui_calendar_NotificationSection (0x55fbfe6bf4d0), has been already disposed — impossible to get any property from it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:12:19 _user_ gnome-shell[5774]: Object St.BoxLayout (0x55fbfe6bfcc0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
                                         countUpdated@resource:///org/gnome/shell/ui/messageTray.js:695:14
                                         pushNotification@resource:///org/gnome/shell/ui/messageTray.js:758:14
                                         showNotification@resource:///org/gnome/shell/ui/messageTray.js:763:14
                                         processNotification@resource:///org/gnome/shell/ui/notificationDaemon.js:387:18
                                         _notifyForSource@resource:///org/gnome/shell/ui/notificationDaemon.js:288:16
                                         NotifyAsync@resource:///org/gnome/shell/ui/notificationDaemon.js:191:14
                                         _onNotificationShow@resource:///org/gnome/shell/ui/messageTray.js:1044:22
                                         showNotification@resource:///org/gnome/shell/ui/messageTray.js:769:18
cze 27 15:12:27 _user_ gnome-shell[5774]: JS ERROR: TypeError: this._settings is null
                                         _onNotificationDestroy@resource:///org/gnome/shell/ui/messageTray.js:740:14
                                         destroy@resource:///org/gnome/shell/ui/messageTray.js:493:14
                                         CloseNotification@resource:///org/gnome/shell/ui/notificationDaemon.js:295:36
                                         _handleMethodCall@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:329:38
                                         _onSourceRemoved@resource:///org/gnome/shell/ui/dateMenu.js:754:14
                                         _removeSource@resource:///org/gnome/shell/ui/messageTray.js:989:14
                                         _addSource/<@resource:///org/gnome/shell/ui/messageTray.js:981:35
                                         destroy@resource:///org/gnome/shell/ui/messageTray.js:779:14
                                         destroy@resource:///org/gnome/shell/ui/notificationDaemon.js:437:15
                                         _onNotificationDestroy@resource:///org/gnome/shell/ui/messageTray.js:743:18
cze 27 15:12:27 _user_ gnome-shell[5774]: Object St.BoxLayout (0x55fbff9cfda0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:12:27 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:12:27 _user_ gnome-shell[5774]: #0   55fc043c8798 i   resource:///org/gnome/shell/ui/messageList.js:598 (6058852ac90 @ 22)
cze 27 15:12:27 _user_ gnome-shell[5774]: #1   55fc043c86f0 i   resource:///org/gnome/shell/ui/messageList.js:677 (6058852b060 @ 21)
cze 27 15:12:27 _user_ gnome-shell[5774]: #2   55fc043c8660 i   resource:///org/gnome/shell/ui/messageList.js:627 (6058852ae70 @ 18)
cze 27 15:12:27 _user_ gnome-shell[5774]: #3   55fc043c85d0 i   resource:///org/gnome/shell/ui/messageList.js:390 (6058852a5b0 @ 22)
cze 27 15:12:27 _user_ gnome-shell[5774]: #4   55fc043c8550 i   resource:///org/gnome/shell/ui/calendar.js:773 (60588528150 @ 44)
cze 27 15:12:27 _user_ gnome-shell[5774]: #5   55fc043c84b0 i   resource:///org/gnome/shell/ui/messageTray.js:493 (605885200b0 @ 69)
cze 27 15:12:27 _user_ gnome-shell[5774]: #6   55fc043c8418 i   resource:///org/gnome/shell/ui/notificationDaemon.js:295 (2f3f7db5f420 @ 94)
cze 27 15:12:27 _user_ gnome-shell[5774]: #7   55fc043c8338 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:329 (1ad772485f10 @ 185)
cze 27 15:12:27 _user_ gnome-shell[5774]: #8   55fc043c8288 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:408 (1ad77248c0b0 @ 34)
cze 27 15:12:27 _user_ gnome-shell[5774]: Object St.BoxLayout (0x55fbfe6bfcc0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:12:27 _user_ gnome-shell[5774]: #0   7ffed046ab00 b   resource:///org/gnome/shell/ui/messageList.js:598 (6058852ac90 @ 22)
                                         _onNotificationDestroy@resource:///org/gnome/shell/ui/messageTray.js:1020:22
cze 27 15:13:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:13:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:13:00 _user_ gnome-shell[5774]: #0   55fc043c8288 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:13:00 _user_ gnome-shell[5774]: #1   7ffed046d350 b   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:13:00 _user_ gnome-shell[5774]: #0   7ffed046c980 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:13:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:13:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:13:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:13:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:14:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:14:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:14:00 _user_ gnome-shell[5774]: #0   55fc043c8358 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:14:00 _user_ gnome-shell[5774]: #1   55fc043c8288 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:14:00 _user_ gnome-shell[5774]: #0   7ffed046cf50 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:14:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:14:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:14:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:14:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:15:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:15:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:15:00 _user_ gnome-shell[5774]: #0   55fc043c8358 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:15:00 _user_ gnome-shell[5774]: #1   55fc043c8288 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:15:00 _user_ gnome-shell[5774]: #0   7ffed046cf50 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:15:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:15:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:15:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:15:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:16:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:16:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:16:00 _user_ gnome-shell[5774]: #0   55fc043c8358 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:16:00 _user_ gnome-shell[5774]: #1   55fc043c8288 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:16:00 _user_ gnome-shell[5774]: #0   7ffed046cf50 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:16:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:16:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:16:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:16:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:16:02 _user_ snapd[683]: storehelpers.go:769: cannot refresh: snap has no updates available: "code", "core", "core20", "core22", "node", "snapd"
cze 27 15:17:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:17:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:17:00 _user_ gnome-shell[5774]: #0   55fc00bc9318 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:17:00 _user_ gnome-shell[5774]: #1   7ffed046d350 b   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:17:00 _user_ gnome-shell[5774]: #0   7ffed046c980 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:17:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:17:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:17:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:17:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:18:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:18:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:18:00 _user_ gnome-shell[5774]: #0   55fc00b72628 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:18:00 _user_ gnome-shell[5774]: #1   55fc00b72558 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:18:00 _user_ gnome-shell[5774]: #0   7ffed046cf50 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:18:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:18:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:18:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:18:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:19:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:19:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:19:00 _user_ gnome-shell[5774]: #0   55fc00b72628 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:19:00 _user_ gnome-shell[5774]: #1   55fc00b72558 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:19:00 _user_ gnome-shell[5774]: #0   7ffed046cf50 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:19:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:19:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:19:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:19:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:20:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:20:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:20:00 _user_ gnome-shell[5774]: #0   55fc00503508 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:20:00 _user_ gnome-shell[5774]: #1   7ffed046d350 b   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:20:00 _user_ gnome-shell[5774]: #0   7ffed046c980 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:20:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:20:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:20:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:20:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:20:12 _user_ gnome-shell[5774]: JS ERROR: TypeError: this._settings is null
cze 27 15:20:12 _user_ gnome-shell[5774]: Object .Gjs_ui_calendar_NotificationSection (0x55fbff9cf870), has been already disposed — impossible to connect to any signal on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:20:12 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:20:12 _user_ gnome-shell[5774]: #0   55fc00503c70 i   resource:///org/gnome/shell/misc/signalTracker.js:124 (240b50b824c0 @ 92)
cze 27 15:20:12 _user_ gnome-shell[5774]: #1   55fc00503bb8 i   resource:///org/gnome/shell/misc/signalTracker.js:158 (1ad7724ce4c0 @ 51)
cze 27 15:20:12 _user_ gnome-shell[5774]: #2   7ffed046b130 b   resource:///org/gnome/shell/misc/signalTracker.js:246 (6058852bfb0 @ 763)
cze 27 15:20:12 _user_ gnome-shell[5774]: #3   7ffed046b210 b   resource:///org/gnome/shell/ui/environment.js:332 (1ad77247cab0 @ 121)
cze 27 15:20:12 _user_ gnome-shell[5774]: #4   55fc00503b10 i   resource:///org/gnome/shell/ui/calendar.js:840 (60588528510 @ 48)
cze 27 15:20:12 _user_ gnome-shell[5774]: #5   55fc00503a40 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:20:12 _user_ gnome-shell[5774]: #6   55fc00503998 i   resource:///org/gnome/shell/ui/messageTray.js:983 (60588521240 @ 116)
cze 27 15:20:12 _user_ gnome-shell[5774]: #7   55fc005038f8 i   resource:///org/gnome/shell/ui/messageTray.js:1002 (60588521380 @ 98)
cze 27 15:20:12 _user_ gnome-shell[5774]: #8   55fc00503858 i   resource:///org/gnome/shell/ui/messageTray.js:973 (605885211a0 @ 205)
cze 27 15:20:12 _user_ gnome-shell[5774]: #9   55fc005037a8 i   resource:///org/gnome/shell/ui/notificationDaemon.js:123 (2f3f7db5f150 @ 384)
cze 27 15:20:12 _user_ gnome-shell[5774]: #10   7ffed046c910 b   resource:///org/gnome/shell/ui/notificationDaemon.js:190 (2f3f7db5f1f0 @ 1630)
cze 27 15:20:12 _user_ gnome-shell[5774]: #11   55fc005035b8 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:373 (1ad772485f10 @ 945)
cze 27 15:20:12 _user_ gnome-shell[5774]: #12   55fc00503508 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:408 (1ad77248c0b0 @ 34)
cze 27 15:20:12 _user_ gnome-shell[5774]: Object .Gjs_ui_calendar_NotificationSection (0x55fbfe6bf4d0), has been already disposed — impossible to connect to any signal on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:20:12 _user_ gnome-shell[5774]: #0   7ffed0469e90 b   resource:///org/gnome/shell/misc/signalTracker.js:124 (240b50b824c0 @ 92)
cze 27 15:20:12 _user_ gnome-shell[5774]: #1   7ffed046a580 b   resource:///org/gnome/shell/misc/signalTracker.js:158 (1ad7724ce4c0 @ 51)
cze 27 15:20:12 _user_ gnome-shell[5774]: #2   7ffed046ab70 b   resource:///org/gnome/shell/misc/signalTracker.js:246 (6058852bfb0 @ 763)
cze 27 15:20:12 _user_ gnome-shell[5774]: #3   7ffed046ac60 b   resource:///org/gnome/shell/ui/environment.js:332 (1ad77247cab0 @ 121)
cze 27 15:20:12 _user_ gnome-shell[5774]: #4   55fc00503a88 i   resource:///org/gnome/shell/ui/calendar.js:850 (60588528560 @ 150)
cze 27 15:20:12 _user_ gnome-shell[5774]: #5   7ffed046b630 b   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:20:12 _user_ gnome-shell[5774]: #6   55fc005039e0 i   resource:///org/gnome/shell/ui/messageTray.js:756 (60588520b00 @ 257)
cze 27 15:20:12 _user_ gnome-shell[5774]: #7   55fc00503948 i   resource:///org/gnome/shell/ui/messageTray.js:763 (60588520b50 @ 30)
cze 27 15:20:12 _user_ gnome-shell[5774]: #8   55fc005038b0 i   resource:///org/gnome/shell/ui/notificationDaemon.js:387 (2f3f7db5f6a0 @ 198)
cze 27 15:20:12 _user_ gnome-shell[5774]: #9   55fc005037a8 i   resource:///org/gnome/shell/ui/notificationDaemon.js:288 (2f3f7db5f290 @ 1426)
cze 27 15:20:12 _user_ gnome-shell[5774]: #10   7ffed046c910 b   resource:///org/gnome/shell/ui/notificationDaemon.js:191 (2f3f7db5f1f0 @ 1658)
cze 27 15:20:12 _user_ gnome-shell[5774]: #0   55fc00503a88 i   resource:///org/gnome/shell/ui/calendar.js:871 (60588528560 @ 311)
cze 27 15:20:12 _user_ gnome-shell[5774]: #1   7ffed046b630 b   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:20:12 _user_ gnome-shell[5774]: #2   55fc005039e0 i   resource:///org/gnome/shell/ui/messageTray.js:756 (60588520b00 @ 257)
cze 27 15:20:12 _user_ gnome-shell[5774]: #3   55fc00503948 i   resource:///org/gnome/shell/ui/messageTray.js:763 (60588520b50 @ 30)
cze 27 15:20:12 _user_ gnome-shell[5774]: #4   55fc005038b0 i   resource:///org/gnome/shell/ui/notificationDaemon.js:387 (2f3f7db5f6a0 @ 198)
cze 27 15:20:12 _user_ gnome-shell[5774]: #5   55fc005037a8 i   resource:///org/gnome/shell/ui/notificationDaemon.js:288 (2f3f7db5f290 @ 1426)
cze 27 15:20:12 _user_ gnome-shell[5774]: #6   7ffed046c910 b   resource:///org/gnome/shell/ui/notificationDaemon.js:191 (2f3f7db5f1f0 @ 1658)
cze 27 15:20:12 _user_ gnome-shell[5774]: #7   55fc005035b8 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:373 (1ad772485f10 @ 945)
cze 27 15:20:12 _user_ gnome-shell[5774]: #8   55fc00503508 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:408 (1ad77248c0b0 @ 34)
cze 27 15:20:12 _user_ gnome-shell[5774]: #0   55fc00503b38 i   resource:///org/gnome/shell/ui/messageList.js:598 (6058852ac90 @ 22)
cze 27 15:20:12 _user_ gnome-shell[5774]: #1   7ffed046ac70 b   resource:///org/gnome/shell/ui/messageList.js:614 (6058852ae20 @ 17)
cze 27 15:20:12 _user_ gnome-shell[5774]: #2   55fc00503a88 i   resource:///org/gnome/shell/ui/calendar.js:871 (60588528560 @ 316)
cze 27 15:20:12 _user_ gnome-shell[5774]: #3   7ffed046b630 b   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:20:12 _user_ gnome-shell[5774]: #4   55fc005039e0 i   resource:///org/gnome/shell/ui/messageTray.js:756 (60588520b00 @ 257)
cze 27 15:20:12 _user_ gnome-shell[5774]: #5   55fc00503948 i   resource:///org/gnome/shell/ui/messageTray.js:763 (60588520b50 @ 30)
cze 27 15:20:12 _user_ gnome-shell[5774]: #6   55fc005038b0 i   resource:///org/gnome/shell/ui/notificationDaemon.js:387 (2f3f7db5f6a0 @ 198)
cze 27 15:20:12 _user_ gnome-shell[5774]: #7   55fc005037a8 i   resource:///org/gnome/shell/ui/notificationDaemon.js:288 (2f3f7db5f290 @ 1426)
cze 27 15:20:12 _user_ gnome-shell[5774]: #8   7ffed046c910 b   resource:///org/gnome/shell/ui/notificationDaemon.js:191 (2f3f7db5f1f0 @ 1658)
cze 27 15:20:12 _user_ gnome-shell[5774]: #9   55fc005035b8 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:373 (1ad772485f10 @ 945)
cze 27 15:20:12 _user_ gnome-shell[5774]: #10   55fc00503508 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:408 (1ad77248c0b0 @ 34)
cze 27 15:20:12 _user_ gnome-shell[5774]: Object .Gjs_ui_calendar_NotificationSection (0x55fbff9cf870), has been already disposed — impossible to get any property from it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:20:12 _user_ gnome-shell[5774]: #0   7ffed046ac70 b   resource:///org/gnome/shell/ui/messageList.js:634 (6058852ae20 @ 383)
cze 27 15:20:12 _user_ gnome-shell[5774]: #1   55fc00503a88 i   resource:///org/gnome/shell/ui/calendar.js:871 (60588528560 @ 316)
cze 27 15:20:12 _user_ gnome-shell[5774]: #2   7ffed046b630 b   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:20:12 _user_ gnome-shell[5774]: #3   55fc005039e0 i   resource:///org/gnome/shell/ui/messageTray.js:756 (60588520b00 @ 257)
cze 27 15:20:12 _user_ gnome-shell[5774]: #4   55fc00503948 i   resource:///org/gnome/shell/ui/messageTray.js:763 (60588520b50 @ 30)
cze 27 15:20:12 _user_ gnome-shell[5774]: #5   55fc005038b0 i   resource:///org/gnome/shell/ui/notificationDaemon.js:387 (2f3f7db5f6a0 @ 198)
cze 27 15:20:12 _user_ gnome-shell[5774]: #6   55fc005037a8 i   resource:///org/gnome/shell/ui/notificationDaemon.js:288 (2f3f7db5f290 @ 1426)
cze 27 15:20:12 _user_ gnome-shell[5774]: #7   7ffed046c910 b   resource:///org/gnome/shell/ui/notificationDaemon.js:191 (2f3f7db5f1f0 @ 1658)
cze 27 15:20:12 _user_ gnome-shell[5774]: #8   55fc005035b8 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:373 (1ad772485f10 @ 945)
cze 27 15:20:12 _user_ gnome-shell[5774]: #9   55fc00503508 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:408 (1ad77248c0b0 @ 34)
cze 27 15:20:12 _user_ gnome-shell[5774]: Object St.BoxLayout (0x55fbff9cfda0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:20:12 _user_ gnome-shell[5774]: #0   7ffed046a9a0 b   resource:///org/gnome/shell/misc/signalTracker.js:124 (240b50b824c0 @ 92)
cze 27 15:20:12 _user_ gnome-shell[5774]: #1   7ffed046aa60 b   resource:///org/gnome/shell/misc/signalTracker.js:158 (1ad7724ce4c0 @ 51)
cze 27 15:20:12 _user_ gnome-shell[5774]: Object .Gjs_ui_calendar_NotificationSection (0x55fbfe6bf4d0), has been already disposed — impossible to get any property from it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:20:12 _user_ gnome-shell[5774]: Object St.BoxLayout (0x55fbfe6bfcc0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:21:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:21:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:21:00 _user_ gnome-shell[5774]: #0   55fc008d3308 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:21:00 _user_ gnome-shell[5774]: #1   55fc008d3238 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:21:00 _user_ gnome-shell[5774]: #0   7ffed046cf50 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:21:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:21:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:21:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:21:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:22:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:22:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:22:00 _user_ gnome-shell[5774]: #0   55fc008d3308 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:22:00 _user_ gnome-shell[5774]: #1   55fc008d3238 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:22:00 _user_ gnome-shell[5774]: #0   7ffed046cf50 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:22:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:22:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:22:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:22:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:23:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:23:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:23:00 _user_ gnome-shell[5774]: #0   55fc008d3238 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:23:00 _user_ gnome-shell[5774]: #1   7ffed046d350 b   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:23:00 _user_ gnome-shell[5774]: #0   7ffed046c980 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:23:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:23:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:23:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:23:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:24:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:24:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:24:00 _user_ gnome-shell[5774]: #0   55fc008d3308 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:24:00 _user_ gnome-shell[5774]: #1   55fc008d3238 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:24:00 _user_ gnome-shell[5774]: #0   7ffed046cf50 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:24:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:24:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:24:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:24:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:25:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:25:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:25:00 _user_ gnome-shell[5774]: #0   55fbff9d2c28 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:25:00 _user_ gnome-shell[5774]: #1   55fbff9d2b58 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:25:00 _user_ gnome-shell[5774]: #0   7ffed046cf50 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:25:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:25:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:25:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:25:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:26:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:26:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:26:00 _user_ gnome-shell[5774]: #0   55fbff01b1d8 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:26:00 _user_ gnome-shell[5774]: #1   7ffed046d350 b   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:26:00 _user_ gnome-shell[5774]: #0   7ffed046c980 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:26:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:26:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:26:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:26:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:27:00 _user_ gnome-shell[5774]: Object St.Label (0x55fbff449460), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:27:00 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:27:00 _user_ gnome-shell[5774]: #0   55fbffdd97d8 i   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:27:00 _user_ gnome-shell[5774]: #1   55fbffdd9708 i   self-hosted:1115 (1ad7724c1ba0 @ 463)
cze 27 15:27:00 _user_ gnome-shell[5774]: #0   7ffed046cf50 b   resource:///org/gnome/shell/ui/dateMenu.js:489 (2f3f7db37a10 @ 165)
cze 27 15:27:00 _user_ gnome-shell[5774]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:27:00 _user_ gnome-shell[5774]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:27:00 _user_ gnome-shell[5774]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
cze 27 15:27:00 _user_ gnome-shell[5774]: Object St.Label (0x55fc04294400), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:27:42 _user_ systemd-logind[687]: The system will suspend now!
cze 27 15:27:42 _user_ NetworkManager[725]: <info>  [1687872462.5064] manager: sleep: sleep requested (sleeping: no  enabled: yes)
cze 27 15:27:42 _user_ gnome-shell[5774]: == Stack trace for context 0x55fbfe1a5d80 ==
cze 27 15:27:42 _user_ gnome-shell[5774]: #0   55fbffdd9c18 i   resource:///org/gnome/shell/ui/messageList.js:598 (6058852ac90 @ 22)
cze 27 15:27:42 _user_ gnome-shell[5774]: #1   55fbffdd9b70 i   resource:///org/gnome/shell/ui/messageList.js:677 (6058852b060 @ 21)
cze 27 15:27:42 _user_ gnome-shell[5774]: #2   55fbffdd9ae0 i   resource:///org/gnome/shell/ui/messageList.js:627 (6058852ae70 @ 18)
cze 27 15:27:42 _user_ gnome-shell[5774]: #3   55fbffdd9a50 i   resource:///org/gnome/shell/ui/messageList.js:390 (6058852a5b0 @ 22)
cze 27 15:27:42 _user_ gnome-shell[5774]: #4   55fbffdd99d0 i   resource:///org/gnome/shell/ui/calendar.js:773 (60588528150 @ 44)
cze 27 15:27:42 _user_ gnome-shell[5774]: #5   55fbffdd9930 i   resource:///org/gnome/shell/ui/messageTray.js:493 (605885200b0 @ 69)
cze 27 15:27:42 _user_ gnome-shell[5774]: #6   55fbffdd9898 i   resource:///org/gnome/shell/ui/notificationDaemon.js:295 (2f3f7db5f420 @ 94)
cze 27 15:27:42 _user_ gnome-shell[5774]: #7   7ffed046c900 b   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:329 (1ad772485f10 @ 185)
cze 27 15:27:42 _user_ gnome-shell[5774]: #8   55fbffdd9708 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:408 (1ad77248c0b0 @ 34)
cze 27 15:27:42 _user_ gnome-shell[5774]: #0   7ffed046a460 b   resource:///org/gnome/shell/ui/messageList.js:598 (6058852ac90 @ 22)
cze 27 15:27:42 _user_ ModemManager[737]: <info>  [sleep-monitor-systemd] system is about to suspend
cze 27 15:27:42 _user_ surfsharkd.js[1707]: {"event":"NM_state_changed","state":{"network_manager_state":10,"openvpn_vpn_state":7,"openvpn_active_connection_state":4,"wg_active_connection_state":4,"user_locked":false,"active_physical_connections":[{"id":"WIFI_JE_F","type":"802-11-wireless","uuid":"4ea865b8-faa5-499c-961f-f5f13ca627d4","internal_networks":[],"interface_name":"wlp0s20f3"}],"conflicting_active_connections":[],"current_physical_connections":{"id":"WIFI_JE_F","type":"802-11-wireless","uuid":"4ea865b8-faa5-499c-961f-f5f13ca627d4","internal_networks":[],"interface_name":"wlp0s20f3"}}}
cze 27 15:27:42 _user_ surfsharkd.js[1707]: {"event":"active_physical_connections_changed","state":{"network_manager_state":10,"openvpn_vpn_state":7,"openvpn_active_connection_state":4,"wg_active_connection_state":4,"user_locked":false,"active_physical_connections":[{"id":"WIFI_JE_F","type":"802-11-wireless","uuid":"4ea865b8-faa5-499c-961f-f5f13ca627d4","internal_networks":[{"gateway":"192.168.0.1","protocol":"ipv4","address":"192.168.0.123","family":24,"_compliant":true}],"interface_name":"wlp0s20f3"}],"conflicting_active_connections":[],"current_physical_connections":{"id":"WIFI_JE_F","type":"802-11-wireless","uuid":"4ea865b8-faa5-499c-961f-f5f13ca627d4","internal_networks":[],"interface_name":"wlp0s20f3"}},"reason":0}
cze 27 15:27:42 _user_ NetworkManager[725]: <info>  [1687872462.5065] device (p2p-dev-wlp0s20f3): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
cze 27 15:27:42 _user_ dbus-daemon[681]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=725 comm="/usr/bin/NetworkManager --no-daemon")
cze 27 15:27:42 _user_ NetworkManager[725]: <info>  [1687872462.5066] manager: NetworkManager state is now ASLEEP
cze 27 15:27:42 _user_ NetworkManager[725]: <info>  [1687872462.5067] device (wlp0s20f3): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
cze 27 15:27:42 _user_ gnome-shell[5774]: JS ERROR: TypeError: this._settings is null
cze 27 15:27:42 _user_ gnome-shell[5774]: Object St.BoxLayout (0x55fbff9cfda0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:27:42 _user_ gnome-shell[5774]: Object St.BoxLayout (0x55fbfe6bfcc0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
cze 27 15:27:42 _user_ systemd[1]: Starting Network Manager Script Dispatcher Service...
cze 27 15:27:42 _user_ dbus-daemon[681]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
cze 27 15:27:42 _user_ systemd[1]: Started Network Manager Script Dispatcher Service.
cze 27 15:27:42 _user_ kernel: wlp0s20f3: deauthenticating from 78:98:e8:69:89:5c by local choice (Reason: 3=DEAUTH_LEAVING)
cze 27 15:27:42 _user_ wpa_supplicant[856]: wlp0s20f3: CTRL-EVENT-DISCONNECTED bssid=78:98:e8:69:89:5c reason=3 locally_generated=1
cze 27 15:27:42 _user_ wpa_supplicant[856]: wlp0s20f3: CTRL-EVENT-DSCP-POLICY clear_all
cze 27 15:27:42 _user_ NetworkManager[725]: <info>  [1687872462.6757] device (wlp0s20f3): supplicant interface state: completed -> disconnected
cze 27 15:27:42 _user_ NetworkManager[725]: <info>  [1687872462.6758] device (wlp0s20f3): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
cze 27 15:27:42 _user_ NetworkManager[725]: <info>  [1687872462.6918] dhcp4 (wlp0s20f3): canceled DHCP transaction
cze 27 15:27:42 _user_ NetworkManager[725]: <info>  [1687872462.6918] dhcp4 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
cze 27 15:27:42 _user_ NetworkManager[725]: <info>  [1687872462.6918] dhcp4 (wlp0s20f3): state changed no lease
cze 27 15:27:42 _user_ NetworkManager[725]: <info>  [1687872462.7327] device (wlp0s20f3): set-hw-addr: set MAC address to 56:7A:84:8B:F4:62 (scanning)
cze 27 15:27:42 _user_ NetworkManager[725]: <info>  [1687872462.7991] device (wlp0s20f3): supplicant interface state: disconnected -> interface_disabled
cze 27 15:27:42 _user_ NetworkManager[725]: <info>  [1687872462.7991] device (wlp0s20f3): supplicant interface state: interface_disabled -> disconnected
cze 27 15:27:42 _user_ NetworkManager[725]: <info>  [1687872462.7992] device (wlp0s20f3): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
cze 27 15:27:42 _user_ NetworkManager[725]: <info>  [1687872462.9403] device (wlp0s20f3): set-hw-addr: reset MAC address to F8:9E:94:2A:79:48 (unmanage)
cze 27 15:27:42 _user_ wpa_supplicant[856]: p2p-dev-wlp0s20: CTRL-EVENT-DSCP-POLICY clear_all
cze 27 15:27:42 _user_ systemd[1]: Reached target Sleep.
cze 27 15:27:42 _user_ wpa_supplicant[856]: nl80211: deinit ifname=p2p-dev-wlp0s20 disabled_11b_rates=0
cze 27 15:27:42 _user_ systemd[1]: Starting System Suspend...
cze 27 15:27:43 _user_ systemd-sleep[10961]: Entering sleep state 'suspend'...
