Sometimes can't login after wakeup
I usually put my PC to sleep - and sometimes when I turn it on again, I cant login - I can type in password but enter nor the login button dont do anything - forcing me to restart the PC.
Plasma-desktop: 6.5.6-1.1
Hello @ElementRea and welcome to the Manjaro Community! :vulcan_salute:
We currently have no system information to work with. :wink: For us to provide advice or suggestions it will usually help if you provide your inxi output:
inxi -zv8
… please use the code formatting (the </> button at the top of the Reply window after highlighting the pasted Terminal output, or the three backticks ``` on lines above and below the pasted text).
Note: This output is privacy-filtered using the above command.
Hopefully the knowledgeable people on here will be able to assist, then. :wink:
Hello and thank you! Here you got the output of the command:
  Kernel: 6.18.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=3ecdca59-655b-496c-8a29-f5e3822ebd82 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.5.6 tk: Qt v: N/A info: frameworks v: 6.24.0
  Type: Desktop Mobo: Gigabyte model: B650 AORUS ELITE AX V2
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends LLC. v: F41a date: 03/11/2026
  System RAM: total: 64 GiB available: 60.44 GiB used: 10.59 GiB (17.5%)
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 32 GiB speed: 6000 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.SKILL
    part-no: F5-6000J3040G32G serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: Zen 5 gen: 5
    level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
    model-id: 0x44 (68) stepping: 0 microcode: 0xB404035
    smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 4074 min/max: 603/5272 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 4074 2: 4074 3: 4074
    4: 4074 5: 4074 6: 4074 7: 4074 8: 4074 9: 4074 10: 4074 11: 4074 12: 4074
    13: 4074 14: 4074 15: 4074 16: 4074 bogomips: 150108
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
    bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
    cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
    cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
    decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
    fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
    invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx
    ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
    perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni
    stibp succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale
    umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
  Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: vmscape mitigation: IBPB on VMEXIT
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
    XTX/7900 GRE/7900M] vendor: XFX driver: amdgpu v: kernel arch: RDNA-3
    code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1
    empty: DP-2,DP-3,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon Graphics]
    vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: HDMI-A-2 empty: DP-4, DP-5, DP-6, Writeback-2
    bus-ID: 12:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 40.0 C
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 6400x1440 display-ID: 0
  Monitor-1: DP-1 pos: center model: AOC Q27G2G4 serial: <filter>
    built: 2020 res: mode: 2560x1440 hz: 144 scale: 114% (1.15) to: 2226x1252
    dpi: 109 gamma: 1.2 chroma: red: x: 0.675 y: 0.314 green: x: 0.282
    y: 0.643 blue: x: 0.149 y: 0.067 white: x: 0.314 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 2560x1440, 1920x1080, 1280x1440, 1280x1024, 1440x900, 1280x720,
    1024x768, 832x624, 800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: HDMI-A-1 pos: right model: Samsung S24F350 serial: <filter>
    built: 2018 res: mode: 1920x1080 hz: 60 scale: 110% (1.1) to: 1745x982
    dpi: 94 gamma: 1.2 chroma: red: x: 0.651 y: 0.333 green: x: 0.318 y: 0.612
    blue: x: 0.153 y: 0.067 white: x: 0.314 y: 0.329
    size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
    1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
    640x480, 720x400
  Monitor-3: HDMI-A-2 pos: primary,left model: Samsung S24F350
    serial: <filter> built: 2018 res: mode: 1920x1080 hz: 60 scale: 110% (1.1)
    to: 1745x982 dpi: 94 gamma: 1.2 chroma: red: x: 0.651 y: 0.333 green:
    x: 0.318 y: 0.612 blue: x: 0.153 y: 0.067 white: x: 0.314 y: 0.329
    640x480, 720x400
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
    navi31 ACO DRM 3.64 6.18.18-1-MANJARO) device-ID: 1002:744c
    memory: 19.53 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 9 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7900 XT (RADV NAVI31) driver: mesa radv v: 26.0.2-arch1.1
    device-ID: 1002:744c surfaces: N/A device: 1 type: integrated-gpu name: AMD
    Ryzen 7 9800X3D 8-Core Processor (RADV RAPHAEL_MENDOCINO)
    driver: mesa radv v: 26.0.2-arch1.1 device-ID: 1002:13c0 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    bus-ID: 12:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Gigabyte
    bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Corsair ST100 Headset Output
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-3.2.1:7 chip-ID: 1b1c:0a32 class-ID: 0300
    serial: <filter>
  Device-5: SteelSeries ApS Arctis Nova 7X
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-3.2.4:9 chip-ID: 1038:2206 class-ID: 0300
  API: ALSA v: k6.18.18-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8852CE PCIe 802.11ax Wireless Network
    driver: rtw89_8852ce v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    port: d000 bus-ID: 09:00.0 chip-ID: 10ec:c852 class-ID: 0280
  IF: wlp9s0 state: down mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 0a:00.0
  IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5 chip-ID: 0bda:0852
  Report: rfkill ID: hci1 rfk-id: 4 state: up address: see --recommends
  Local Storage: total: 35.47 TiB used: 20.71 TiB (58.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SFYRD2000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 33.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST20000NM007D
    size: 18.19 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: EN01 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000DM008-2DM166
    size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC26 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST14000NE0008-2RX103
    size: 12.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: EN02 scheme: GPT
  ID-1: / raw-size: 382.86 GiB size: 382.86 GiB (100.00%)
    used: 122.4 GiB (32.0%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
    label: N/A uuid: 3ecdca59-655b-496c-8a29-f5e3822ebd82
  ID-2: /boot/efi raw-size: 501 MiB size: 497 MiB (99.20%)
    used: 26.3 MiB (5.3%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: 86E0-E7FD
  ID-3: /home raw-size: 382.86 GiB size: 382.86 GiB (100.00%)
  ID-4: /home/<filter>/pCloudDrive raw-size: N/A size: 2 TiB
    used: 778.32 GiB (38.0%) fs: fuse source: ERR-102
  ID-5: /mnt/datac raw-size: 350 GiB size: 350 GiB (100.00%)
    used: 259.64 GiB (74.2%) fs: ntfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: Syst\xc3\xa9m a programy uuid: A8ACE4B6ACE48064
  ID-6: /mnt/datad raw-size: 18.19 TiB size: 18.19 TiB (100.00%)
    used: 14.21 TiB (78.1%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Filmy,
    seri\xc3\xa1ly a OneDrive uuid: 02E0614EE061494D
  ID-7: /mnt/datae raw-size: 2.73 TiB size: 2.73 TiB (100.00%)
    used: 2.61 TiB (95.6%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18
    label: Hry HDD 1/2 uuid: DA9EB6DF9EB6B2FD
  ID-8: /mnt/dataf raw-size: 12.73 TiB size: 12.73 TiB (100.00%)
    used: 2.18 TiB (17.1%) fs: ntfs dev: /dev/sdc2 maj-min: 8:34
    label: Hry HDD 2/2 uuid: ACA0C3ACA0C37B7A
  ID-9: /mnt/datag raw-size: 1.1 TiB size: 1.1 TiB (100.00%)
    used: 590.62 GiB (52.3%) fs: ntfs dev: /dev/nvme0n1p3 maj-min: 259:3
    label: Hry M2 uuid: 01DCAFF37CC807F0
  ID-10: /var/cache raw-size: 382.86 GiB size: 382.86 GiB (100.00%)
  ID-11: /var/log raw-size: 382.86 GiB size: 382.86 GiB (100.00%)
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
  ID-3: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
  ID-4: /dev/sdc1 maj-min: 8:33 size: 16 MiB fs: <superuser required>
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 1-3:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Hub-3: 1-3.1:4 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
  Hub-4: 1-3.2:6 info: Corsair ST100 USB 2.0 Hub ports: 4 rev: 2.1
    chip-ID: 1b1c:0a36 class-ID: 0900
  Device-1: 1-3.2.1:7 info: Corsair ST100 Headset Output type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
    chip-ID: 1b1c:0a32 class-ID: 0300 serial: <filter>
  Device-2: 1-3.2.2:8 info: Corsair ST100 LED Driver type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1b1c:0a34 class-ID: 0300
    serial: <filter>
  Device-3: 1-3.2.4:9 info: SteelSeries ApS Arctis Nova 7X type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
  Device-4: 1-6:3 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-5: 1-9:5 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:0852 class-ID: e001 serial: <filter>
  Hub-5: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-6: 2-3:2 info: Realtek Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  Hub-7: 2-3.1:3 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
  Hub-8: 2-3.2:4 info: Corsair ST100 USB 3.1 Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 1b1c:0a33
  Hub-9: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-10: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-11: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-12: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-13: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-14: 7-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 7-1.1:3 info: Razer USA Basilisk V3 35K type: mouse,keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:00cb class-ID: 0300
  Device-2: 7-1.2:4 info: Telink ENDORFY Celeris 1800 CZ type: keyboard
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 3738:00bc class-ID: 0301
  Hub-15: 7-1.3:5 info: VIA Labs VL812 Hub ports: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2812
  System Temperatures: cpu: 45.1 C mobo: 38.0 C
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 40.0 C device: amdgpu temp: 52.0 C mem: 64.0 C
    fan: 61 watts: 33.00
  Packages: 1783 pm: pacman pkgs: 1769 libs: 419 tools: pamac,yay pm: flatpak
    pkgs: 14
    1: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    2: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    3: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    4: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    5: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    6: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    7: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    8: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    9: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    10: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    11: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
    12: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    13: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    14: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    15: https://manjaro.grena.ge/stable/$repo/$arch
    16: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    17: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    18: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    19: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    20: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    21: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    22: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    24: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    25: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    26: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    27: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    28: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    29: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    30: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    31: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    32: https://mirrors2.manjaro.org/stable/$repo/$arch
    33: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    34: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    35: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    36: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    37: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    38: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    39: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    40: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    41: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    42: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    43: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    44: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    45: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    46: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    47: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    48: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    49: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    50: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
    51: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    52: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    53: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    54: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    55: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    56: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    57: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    58: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    59: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    60: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    61: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    62: https://mirror.init7.net/manjaro/stable/$repo/$arch
    63: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    64: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    65: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    66: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    67: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    68: https://manjaro.ynh.ovh/stable/$repo/$arch
    69: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    70: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    71: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    72: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    73: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    74: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    75: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    76: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    77: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    78: https://mirror.23m.com/manjaro/stable/$repo/$arch
    79: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    80: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    81: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    82: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    83: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    84: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    85: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    86: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    87: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    88: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    89: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    90: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    91: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    92: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    93: https://linorg.usp.br/manjaro/stable/$repo/$arch
    94: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    95: https://mirror.rabisu.com/mirrors/manjaro/stable/$repo/$arch
    96: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    97: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    98: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    99: https://muug.ca/mirror/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 527
  1: cpu: 109% command: exe pid: 86448 mem: 648.4 MiB (1.0%)
  2: cpu: 8.0% command: vivaldi-bin pid: 5563 mem: 317.4 MiB (0.5%)
  3: cpu: 5.3% command: konsole pid: 108457 mem: 199.5 MiB (0.3%)
  4: cpu: 4.4% command: kwin_wayland pid: 1086 mem: 322.0 MiB (0.5%)
  5: cpu: 3.0% command: java pid: 106862 mem: 747.7 MiB (1.2%)
  Memory top: 5 of 527
  1: mem: 1198.7 MiB (1.9%) command: qbittorrent pid: 1767 cpu: 1.4%
  2: mem: 780.3 MiB (1.2%) command: plasmashell pid: 1334 cpu: 0.4%
  3: mem: 747.7 MiB (1.2%) command: java pid: 106862 cpu: 3.0%
  4: mem: 689.1 MiB (1.1%) command: vivaldi-bin pid: 8923 cpu: 1.9%
  5: mem: 648.4 MiB (1.0%) command: exe pid: 86448 cpu: 109%
  Processes: 527 Power: uptime: 9h 42m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 24.12 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.1 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.40
