Crashing now.
Download of qt5-doc (5.15.17-1) started
323,8 MB/7,0 GB About 9 minutes remainingTerminated
Crashing now.
Your post has been moved to a dedicated topic.
Please be more specific about your issue to encourage others to help. Additionally, feel free to rename the topic title to something that better describes your issue.
Once you have provided enough information, I’m sure someone will help when they are able.
While information from *-fetch
type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly;
Output of the inxi
command with appropriate parameters will achieve this (naturally, formatted according to forum guidelines) and will generally be more useful for those wishing to help:
inxi --filter --verbosity=8
or the short form:
inxi -zv8
It looks like a pamac CLI or GUI crashing during an update … But the update continues in background with pamac-daemon as can be seen with the Task Manager. This daemon disappears from TM when the job is done.
The good old joke:
Pilot: “Something” is broken
tech team: we fixed “something”
Sorry, couldn’t resist
