I’ve noticed that some Systemd services are taking quite a bit longer to start now.
These two are the top of my systemd-analyse blame
1.546s systemd-modules-load.service
1.304s systemd-random-seed.service
Only /etc/modules-load.d/mhwd-gpu.conf
is loaded, no? My /etc/modules-load.d/modules.conf
is empty.
I didn’t even notice that my boot times were longer. Just happened to check, since I haven’t run the command in a while.
Contents of /etc/modules-load.d/mhwd-gpu.conf
## Generated by mhwd - Manjaro Hardware Detection
nvidia
nvidia-drm
This file has been in my system since February 3rd, while the system is two years old.
Here’s what the service tells me:
systemctl status systemd-modules-load.service ✔
● systemd-modules-load.service - Load Kernel Modules
Loaded: loaded (/usr/lib/systemd/system/systemd-modules-load.service; static)
Active: active (exited) since Fri 2022-06-10 10:30:45 EEST; 6h ago
Docs: man:systemd-modules-load.service(8)
man:modules-load.d(5)
Process: 347 ExecStart=/usr/lib/systemd/systemd-modules-load (code=exited, status=0/SUCCESS)
Main PID: 347 (code=exited, status=0/SUCCESS)
CPU: 1.432s
kesä 10 10:30:43 jp-gentoo systemd-modules-load[347]: Inserted module 'crypto_user'
kesä 10 10:30:43 jp-gentoo systemd-modules-load[347]: Inserted module 'sg'
kesä 10 10:30:43 jp-gentoo systemd-modules-load[347]: Inserted module 'ipmi_devintf'
kesä 10 10:30:44 jp-gentoo systemd-modules-load[347]: Inserted module 'nvidia'
kesä 10 10:30:44 jp-gentoo systemd-modules-load[347]: Inserted module 'nvidia_drm'
kesä 10 10:30:45 jp-gentoo systemd-modules-load[347]: Inserted module 'nvidia_uvm'
kesä 10 10:30:45 jp-gentoo systemd-modules-load[347]: Inserted module 'uinput'
kesä 10 10:30:45 jp-gentoo systemd[1]: Finished Load Kernel Modules.
Notice: journal has been rotated since unit was started, output may be incomplete.
Is this normal?
Random seed service doesn’t take an unusally long time to start anymore.
Jaypee:
Is this normal?
Sure, why wouldn’t it be?
So the service taking this long to load is normal? I see many users on this forum where it takes 1/10 of the time to load.
I’m trying to understand what the concern is? Where is the actual problem?
I try to understand why systemd-modules-load.service
takes one and a half seconds to load, which hasn’t been the case in the past. And if this is normal behaviour for this service.
Here’s mine, if it means anything.
I’m “winning” by 0.246 seconds!
1.300s systemd-modules-load.service
This allows me to cook my food and enjoy my breakfast just a bit longer, in all the time I saved not waiting for systemd-modules-load.service
to take precious moments from my glorious life.
Good to know that it might be normal.
I tried browsing the forums, but only saw similar times with people who had problems with other services taking 10 seconds or more to load
I’m jealous of you, because you’re winning by a larger margin with your godlike random seed generation speeds!
1.884s systemd-random-seed.service
Life is not fair!
It has gotten much much lower since I made that post:
6ms systemd-random-seed.service
zbe
10 June 2022 17:06
11
54ms systemd-modules-load.service
Basically mwhd will load your GPU drivers, and I should say AMD drivers are loading as fast as 100-200 ms, and random seed is faster on better cpu systems (as it is faster calculating it), or when you do your randomness by pressing random keys and moving your mouse. I saw that linux also uses this in random number generator to be more random.
Just Nvidia Things™ then, I guess
It really sticks out
1.676s systemd-modules-load.service
329ms dev-sda2.device
191ms tlp.service
129ms systemd-journal-flush.service
107ms apparmor.service
93ms ModemManager.service
89ms systemd-udev-trigger.service
89ms ldconfig.service
85ms user@1000.service
79ms lm_sensors.service
79ms polkit.service
68ms lvm2-monitor.service
63ms systemd-udevd.service
53ms avahi-daemon.service
49ms dbus.service
47ms boot-efi.mount
47ms systemd-logind.service
43ms udisks2.service
41ms systemd-resolved.service
41ms cups.service
35ms NetworkManager.service
32ms systemd-sysusers.service
32ms systemd-journald.service
31ms systemd-tmpfiles-clean.service
29ms upower.service
27ms systemd-tmpfiles-setup.service
24ms systemd-timesyncd.service
24ms systemd-tmpfiles-setup-dev.service
23ms systemd-fsck-root.service
17ms systemd-fsck@dev-disk-by\x2duuid-B5D2\x2d5542.service
17ms systemd-fsck@dev-disk-by\x2duuid-9477a9d1\x2d47fc\x2d4f4b\x2da05f\x2d24cd2755ab8e.service
15ms mnt-faaast.mount
14ms pamac-daemon.service
12ms modprobe@fuse.service
8ms alsa-restore.service
7ms dev-hugepages.mount
7ms dev-mqueue.mount
7ms systemd-journal-catalog-update.service
7ms sys-kernel-debug.mount
6ms sys-kernel-tracing.mount
6ms kmod-static-nodes.service
6ms modprobe@drm.service
6ms modprobe@configfs.service
5ms systemd-remount-fs.service
5ms linux-module-cleanup.service
5ms systemd-binfmt.service
4ms systemd-update-utmp.service
4ms mnt-faaast-swap.swap
3ms user-runtime-dir@1000.service
2ms systemd-sysctl.service
2ms systemd-user-sessions.service
2ms systemd-update-done.service
