Some Steam games not working
This might be a little long, but I’ll try to not be…
On manjaro-kde for 2 years, testing repos for 1 year, this issue is on the testing repos. (Linux user since 1998).
Absolutely love manjaro, thank you all involved.
AMD rx570 graphics, 8 cores amd processor, 16 g ram.
As of an update 2 days ago (I think) most of my steam games won’t play.
The games that no longer work are Path of Exile, Neverwinter Online, Oblivion. All of which played flawlessly until now.
The games that still work (that I’ve tried) Morrowind, Americas Army.
What I’ve tried…
Switching between Wayland and X.
Switching to a different kernel from 5.15.x and the LTS 5.10? I think.
Switching the games proton version between the last two stable versions, and experimental, and GE.
And yes, I have restarted the machine several times, including a couple complete turn offs, turn ons.
Starting the steam client in terminal and launching a game, seems to stop with Installing breakpad exception handler for appid(steam)/version(1639697812). All I can seem to find on breakpad exception handler seems to come back to nvidia drivers, but I’m on AMD so that’s not helpful.
Game process updated : AppID 238960 "RADV_PERFTEST=aco /home/buzz/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=238960 -- '/home/buzz/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/buzz/.local/share/Steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun  '/home/buzz/.local/share/Steam/steamapps/common/Path of Exile/PathOfExileSteam.exe' --nopatch", ProcID 90799, IP 0.0.0.0:0
Setting breakpad minidump AppID = 238960
SteamInternal_SetMinidumpSteamID:  Caching Steam ID:  76561198053214549 [API loaded no]
free(): invalid pointer
[2021-12-30 19:05:46] Background update loop checking for update. . .
[2021-12-30 19:05:46] Checking for available updates...
[2021-12-30 19:05:46] Downloading manifest: https://cdn.akamai.steamstatic.com/client/steam_client_publicbeta_ubuntu12
[2021-12-30 19:05:47] Download skipped by HTTP 304 Not Modified
[2021-12-30 19:05:47] Nothing to do
I greatly appreciate any help to hopefully get this working again and to make sure that it’s not a testing repo issue that’s going to end up in stable. It might even be I just need to wait for the next round of updates and all will magically be fixed, certainly possible. Until then I must admit I’m having fun revisiting MTG: Arena again for the first time in a long time (installed through Lutris), so that means Vulkan is working? idk.
What say’s Vulkaninfo ?
vulkaninfo
ERROR: [Loader Message] Code 0 : loader_scanned_icd_add: Could not get 'vkCreateInstance' via 'vk_icdGetInstanceProcAddr' for ICD libGLX_nvidia.so.0
zsh: abort (core dumped)  vulkaninfo
why nvidia? I don’t have nvidia.
Please post your system info as outlined here:
buzz-manjaro% inxi --admin --verbosity=7 --filter --width
  Kernel: 5.15.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=7e505c23-4dfb-4707-af15-cab23836e326 rw quiet apparmor=1
  Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_wayland vt: 2 dm: SDDM
  Type: Desktop System: MSI product: MS-7693 v: 4.0
    serial: <superuser required>
  Mobo: MSI model: 970 GAMING (MS-7693) v: 4.0 serial: <superuser required>
    BIOS: American Megatrends v: 22.4 date: 12/21/2015
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M525
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: Discharging
  RAM: total: 15.64 GiB used: 3.28 GiB (21.0%)
  RAM Report:
  Info: model: AMD FX-8350 bits: 64 type: MT MCP arch: Piledriver
    family: 0x15 (21) model-id: 2 stepping: 0 microcode: 0x6000852
  Topology: cpus: 1x cores: 8 smt: enabled cache: L1: 384 KiB
    desc: d-8x16 KiB; i-4x64 KiB L2: 8 MiB desc: 4x2 MiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1617 high: 2606 min/max: 1400/4000 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1399 2: 1400
    3: 1399 4: 1381 5: 1954 6: 2606 7: 1400 8: 1400 bogomips: 64016
  Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
    cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
    extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht
    hw_pstate ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
    msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni
    popcnt pse pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean
    vme vmmcall wdt xop xsave
    disabled, RSB filling
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67df
    class-ID: 0300
  Device-2: Microdia Webcam Vitade AF type: USB
    driver: snd-usb-audio,uvcvideo bus-ID: 2-2:3 chip-ID: 0c45:6366
    class-ID: 0102 serial: <filter>
  Display: wayland server: X.Org 1.21.1.4 compositor: kwin_wayland driver:
    loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
    display-ID: :1 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
    s-diag: 1055mm (41.5")
  Monitor-1: XWAYLAND0 res: 1920x1080 hz: 60 dpi: 81
    size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
  Monitor-2: XWAYLAND1 res: 1920x1080 hz: 60 dpi: 81
  OpenGL: renderer: AMD Radeon RX 570 Series (POLARIS10 DRM 3.42.0
    5.15.11-1-MANJARO LLVM 13.0.0)
    v: 4.6 Mesa 21.3.2 direct render: Yes
  Device-1: AMD SBx00 Azalia vendor: Micro-Star MSI driver: snd_hda_intel
    v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 01:00.1
    chip-ID: 1002:aaf0 class-ID: 0403
  Device-3: Microdia Webcam Vitade AF type: USB
  Device-4: Samson G-Track Pro microphone type: USB driver: snd-usb-audio
    bus-ID: 4-3:3 chip-ID: 17a0:0241 class-ID: 0102 serial: <filter>
  Sound Server-1: ALSA v: k5.15.11-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.42 running: yes
  Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet
    vendor: Micro-Star MSI driver: alx v: kernel port: d000 bus-ID: 05:00.0
    chip-ID: 1969:e091 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
    bus-ID: 1-4.1:5 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
  Local Storage: total: 1.49 TiB used: 626.46 GiB (41.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
    type: SSD serial: <filter> rev: 2B6Q scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD6400AAKS-22A7B0 size: 596.17 GiB block-size: physical: 512 B
    logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 3B01
    scheme: MBR
  ID-1: / raw-size: 931.51 GiB size: 915.89 GiB (98.32%)
    used: 626.46 GiB (68.4%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 7e505c23-4dfb-4707-af15-cab23836e326
  ID-1: /dev/sdb1 maj-min: 8:17 size: 596.17 GiB fs: ext4 label: BackUp
    uuid: 4642b374-80b3-4004-b3a5-45061db5cc70
  Hub-1: 1-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
  Hub-2: 1-4:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-4.1:5 info: Broadcom BCM20702A0 Bluetooth 4.0 type: Bluetooth
    driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:21e8
  Hub-3: 2-0:1 info: Full speed or root hub ports: 5 rev: 2.0
  Device-1: 2-2:3 info: Microdia Webcam Vitade AF type: Video,Audio
    power: 500mA chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
  Hub-4: 3-0:1 info: Full speed or root hub ports: 4 rev: 2.0
  Hub-5: 4-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
    chip-ID: 1d6b:0001 class-ID: 0900
  Device-1: 4-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
    power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 4-3:3 info: Samson G-Track Pro microphone type: Audio
    driver: snd-usb-audio interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 240mA
  Hub-6: 5-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
  Device-1: 5-1:2 info: Razer USA BlackWidow Ultimate 2016
    type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s power: 500mA chip-ID: 1532:0214 class-ID: 0300
  Hub-7: 6-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
  Hub-8: 7-0:1 info: Full speed or root hub ports: 4 rev: 1.1 speed: 12 Mb/s
  Hub-9: 8-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-10: 8-1:2 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    power: 100mA chip-ID: 2109:3431 class-ID: 0900
  Hub-11: 9-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  Hub-12: 10-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-13: 10-1:2 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  Hub-14: 11-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 30.4 C mobo: N/A gpu: amdgpu temp: 55.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1010
  Processes: 289 Uptime: 14h 1m wakeups: 50 Init: systemd v: 250
  tool: systemctl Compilers: gcc: 11.1.0 alt: 10 clang: 13.0.0 Packages: 1713
  pacman: 1692 lib: 489 flatpak: 15 snap: 6 Shell: Zsh v: 5.8 default: Bash
  v: 5.1.12 running-in: yakuake inxi: 3.3.11
buzz-manjaro%
What NVIDIA? :thinking:
My vulkaninfo returns error with
Do you have vulkan-icd-loader & lib32-vulkan-icd-loader installed? For an AMD GPU you’ll also want vulkan-radeon & lib32-vulkan-radeon.
Are Steam not use Vulkan
What? Run that by us again in a complete, coherent sentence this time. Some Proton games do indeed use Vulkan.
buzz-manjaro% pamac install vulkan-icd-loader lib32-vulkan-icd-loader vulkan-radeon lib32-vulkan-radeon
Preparing...
Warning: lib32-vulkan-radeon-21.3.2-1 is up to date -- skipping
Warning: vulkan-radeon-21.3.2-1 is up to date -- skipping
Warning: vulkan-icd-loader-1.2.202-1 is up to date -- skipping
Warning: lib32-vulkan-icd-loader-1.2.202-1 is up to date -- skipping
Nothing to do.
Just got an update today and all is working again. Kind of as I thought, but was hoping to narrow it down more for the stable repos. Now I have…
Preparing...
Warning: lib32-vulkan-radeon-21.3.3-1 is up to date -- skipping
Warning: vulkan-radeon-21.3.3-2 is up to date -- skipping
Nothing to do.
I also got an update to mesa, so it was either vulkan or mesa. Sorry I couldn’t narrow it down more.
