Some mentioned packages in the `iso-profiles` repo are actually absent in Manjaro packages repos
Hi!
I found as absent the next ones (at least):
the file:
shared/Packages-Root-dbus-x11
archlinux32-keyring
crda
ipw2100-fw
ipw2200-fw
manjaro-firmware
manjaro
gcc-libs-multilib
crda
manjaro-firmware
shared/Packages-Mhwd
linux60-rt3562sta
linux60-virtualbox-guest-modules
shared/Packages-Live-Xorg
linux60-rt3562sta
shared/Packages-Desktop
xdg-su
xf86-input-keyboard
xf86-input-mouse
xorg-server-utils
xorg-utils
manjaro/kde/Packages-Desktop
libcanberra-pulse
lib32-libcanberra-pulse
adobe-source-sans-pro-fonts
pamac-snap-plugin
pamac-flatpak-plugin
octopi-cachecleaner
octopi-repoeditor
pamac-qt
gtk3-print-backends
gnome-themes-standard
kdenetwork-kget
kipi-plugins
vlc-nightly
manjaro-documentation-en
manjaro/kde/Packages-Mhwd
linux60-rt3562sta
manjaro/kde/Packages-Root
gcc-libs-multilib
crda
manjaro-firmware
Please re-check and remove them as garbage.
Thanks!
Indeed. Those are unmaintained profiles. The nightly ISOs build.
unmaintained, but actulally used profiles?
perhaps shared is shared between all DEs.
kde used for kde DE ISO image.
I used this repo to build user ISO with my current command of
buildiso -p kde -a x86_64 -b unstable -k linux61 -v -t ~/Desktop
(described here: Build Manjaro ISOs with buildiso - Manjaro)
and I found that mentioned packages are absent in every of 4 Manjaro repos.
Perhaps could be removed as garbage by these days.
The best approach would be to create issues on Gitlab.
“Moved” to:
Thanks!
