Below my system specs
Kernel: 6.1.53-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet Desktop: i3 v: 4.20.1-98-ga70b89a7 info: polybar vt: 7
dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X521IA_M533IA
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X521IA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X521IA.300 date: 04/13/2020
ID-1: BAT0 charge: 32.3 Wh (98.8%) condition: 32.7/50.0 Wh (65.3%)
power: 5.2 W volts: 11.9 min: 11.9 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: discharging cycles: 536
Info: 8-core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64
type: MCP smt: <unsupported> arch: Zen 2 rev: 1 cache: L1: 512 KiB L2: 4 MiB
L3: 8 MiB
Speed (MHz): avg: 1473 high: 2000 min/max: 1400/2000 boost: enabled cores:
1: 2000 2: 1397 3: 1398 4: 1400 5: 1397 6: 1400 7: 1400 8: 1397
bogomips: 31958
Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
pcie: speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 36.0 C
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 3-3:3 chip-ID: 13d3:56a2
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0 driver: X:
loaded: amdgpu dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: LG Display 0x0563 res: 1920x1080
hz: 60 dpi: 142 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") modes:
max: 1920x1080 min: 640x480
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.53-1-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.80 status: off with: pipewire-media-session
status: off
type: plugin
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A pcie: speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 01:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 bus-ID: 3-2:2 chip-ID: 13d3:3530
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 4.2
lmp-v: 8 class-ID: 10c
Local Storage: total: 476.94 GiB used: 423.66 GiB (88.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLQ512HALU-00000
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: FXV7000Q temp: 19.9 C scheme: GPT
ID-1: / size: 459.43 GiB used: 423.66 GiB (92.2%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
dev: /dev/nvme0n1p3
System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 36.0 C
Fan Speeds (rpm): cpu: 0
Processes: 240 Uptime: 15m wakeups: 2264 Memory: total: 16 GiB note: est.
available: 15.05 GiB used: 3.19 GiB (21.2%) Init: systemd v: 254
default: graphical Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 2071 Shell: Zsh v: 5.9 running-in: alacritty inxi: 3.3.30
It’s been a while that some of the keyboard keys are not working (not functionality keys, just ordinary ones as p,',ò,- and up/right arrow). The problem arises at the startup and persists for a while but eventually they work fine. Anyway the amount of time needed to the keys to start working again could be long.
I cannot figure out if it’s a software or a hardware issue.
I tried searching over the forum but I could not find anything related to my experience. Any advice would be appreciated.
