Feyko
19 February 2022 17:24
1
Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=97dd37d5-1395-4fe9-91a1-5c5335a75b8a rw quiet splash apparmor=1
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: ASUSTeK product: ROG Strix G733ZW_G733ZW v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G733ZW v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G733ZW.303 date: 12/27/2021
ID-1: BAT0 charge: 89.3 Wh (99.0%) condition: 90.2/89.5 Wh (100.8%)
volts: 17.6 min: 15.9 model: AS3GWYF3KC GA50358 type: Unknown
serial: <filter> status: Charging
RAM: total: 31.02 GiB used: 7.47 GiB (24.1%)
RAM Report:
Info: model: 12th Gen Intel Core i9-12900H bits: 64 type: MST AMCP
arch: Alder Lake family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x413
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2246 high: 3800 min/max: 400/6300:6400:3800 scaling:
driver: intel_pstate governor: performance cores: 1: 1220 2: 1106 3: 2033
4: 875 5: 2885 6: 2217 7: 2737 8: 2405 9: 3544 10: 1079 11: 2008 12: 3194
13: 1126 14: 1993 15: 1887 16: 2209 17: 3292 18: 3800 19: 1545 20: 3777
bogomips: 116780
arch_capabilities arch_lbr arch_perfmon art avx avx2 avx_vnni bmi1 bmi2 bts
cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault
cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
pcid pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36
pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni
smap smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tme tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic
Device-1: Intel Alder Lake-P Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 0000:00:02.0 chip-ID: 8086:46a6
class-ID: 0300
Device-2: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU] vendor: ASUSTeK
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm
bus-ID: 0000:01:00.0 chip-ID: 10de:24a0 class-ID: 0300
Display: x11 server: X.Org 1.21.1.3 compositor: gnome-shell driver:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
display-ID: :1 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0")
s-diag: 1245mm (49")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
Monitor-2: eDP-1-1 res: 2560x1440 hz: 240 dpi: 171
size: 381x214mm (15.0x8.4") diag: 437mm (17.2")
OpenGL: renderer: NVIDIA GeForce RTX 3070 Ti Laptop GPU/PCIe/SSE2
v: 4.6.0 NVIDIA 510.47.03 direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228b
class-ID: 0403
Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: 3000 bus-ID: 0000:2c:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp44s0 state: down mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 8087:0033 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 1.84 TiB used: 1.14 TiB (62.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 3400 MTFDKBA1T0TFH
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P7MA001 temp: 47.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: HGST (Hitachi)
model: HTS721010A9E630 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 7200 serial: <filter> scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
used: 419.54 GiB (44.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 97dd37d5-1395-4fe9-91a1-5c5335a75b8a
label: NO_LABEL uuid: 0641-9146
ID-3: /run/media/feyko/Backup raw-size: 930.96 GiB
size: 930.96 GiB (100.00%) used: 750.24 GiB (80.6%) fs: ntfs dev: /dev/sda3
maj-min: 8:3 label: Backup uuid: 149E6F05057A2D3A
ID-1: /dev/sda1 maj-min: 8:1 size: 450 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-3:2 info: ASUSTek N-KEY Device type: Keyboard
driver: asus,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 0b05:19b6 class-ID: 0301
Device-2: 3-6:3 info: Razer USA DeathAdder Elite type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:005c class-ID: 0300
Device-3: 3-10:4 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 4-2:2 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E SATA
6Gb/s bridge ASM1153 SATA 3Gb/s bridge ASM1153E SATA 6Gb/s bridge
type: Mass Storage driver: uas interfaces: 1 rev: 3.1 speed: 10 Gb/s
chip-ID: 174c:55aa class-ID: 0806 serial: <filter>
System Temperatures: cpu: 65.0 C mobo: N/A gpu: nvidia temp: 54 C
Processes: 476 Uptime: 48m wakeups: 3 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1361 pacman: 1346 lib: 427 flatpak: 6
snap: 9 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.12
Hi! I am having issues running games through Lutris. By default, games were using the iGPU to render, which resulted in very poor performance. For some of them, running on the dGPU by disabling the iGPU (with the method from the Optimus page on ArchWiki) or using PRIME GPU offloading results in the following error message in the log:
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 149 ()
Minor opcode of failed request: 4
Serial number of failed request: 304
Current serial number in output stream: 309
Games tested - runner - state:
Risk of Rain 2 - Steam (Proton Experimental) - Works
Albion Online - Native Linux version - Works
Trackmania 2020 - Lutris w/ wine lutris-fshack-7.1-x86_64 - Broken
Overwatch - Lutris w/ wine lutris-fshack-7.1-x86_64 - Broken
Note: For Risk of Rain 2, the game periodically slows down tremendously , to around 3 fps. Both my CPU and GPU drop usage considerably and my whole system slows down
Additionally, Risk of Rain 2 was using my dGPU to render by default. I believe I am getting better performance now that I have my iGPU disabled, but I can’t 100% confirm (haven’t verified with data)
Please help me get rid of this xrandr issue, I really want to play Trackmania and Overwatch again!
can you add kernel linux 516
sudo mhwd-kernel i -linux516
check prefs in Steam for version proton , see with version 7.01
Feyko
19 February 2022 20:45
3
Added the 516 kernel, rebooted, no difference (proper command was sudo mhwd-kernel -i linux516 btw)
I’m not sure what you meant with the second part of your message
After checking the log for the game again (Overwatch), there are a lot of these:
(wine:3389): GStreamer-WARNING **: 21:38:04.898: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib/gstreamer-1.0/libgstspeex.so': libspeex.so.1: wrong ELF class: ELFCLASS64
Maybe that is the real issue?
Here are some other errors I missed before
[0219/213804.984:ERROR:network_change_notifier_win.cc(142)] WSALookupServiceBegin failed with: 0
err: Failed to create surface
[0219/213829.741:ERROR:angle_platform_impl.cc(40)] rx::SwapChain11::reset(615): Could not create additional swap chains or offscreen surfaces, HRESULT: 0x80070057
[0219/213829.741:ERROR:gl_surface_egl.cc(787)] EGL Driver message (Critical) eglCreateWindowSurface: Bad allocation.
[0219/213829.741:ERROR:gl_surface_egl.cc(1394)] eglCreateWindowSurface failed with error EGL_BAD_ALLOC
[0219/213829.741:ERROR:in_process_command_buffer.cc(450)] ContextResult::kSurfaceFailure: Failed to create surface.
I’ll paste the full log in case someone can find more than I can:
Started initial process 3226 from gamemoderun /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/bin/wine /home/feyko/Games/overwatch/drive_c/Program Files (x86)/Battle.net/Battle.net.exe --exec=launch Pro
Start monitoring process.
gamemodeauto:
esync: up and running.
MESA-INTEL: warning: Performance support disabled, consider sysctl dev.i915.perf_stream_paranoid=0
[0219/213803.919:ERROR:network_change_notifier_win.cc(142)] WSALookupServiceBegin failed with: 0
info: Game: Battle.net.exe
info: DXVK: v1.9.4-1-g03234ffc
info: Found config file: /home/feyko/Games/overwatch/dxvk.conf
info: Effective configuration:
info: dxgi.nvapiHack = False
info: Built-in extension providers:
info: Win32 WSI
info: OpenVR
info: OpenXR
info: OpenVR: could not open registry key, status 2
info: OpenVR: Failed to locate module
info: Enabled instance extensions:
info: VK_KHR_get_surface_capabilities2
info: VK_KHR_surface
info: VK_KHR_win32_surface
info: NVIDIA GeForce RTX 3070 Ti Laptop GPU:
info: Driver: 510.47.3
info: Vulkan: 1.3.194
info: Memory Heap[0]:
info: Size: 8192 MiB
info: Flags: 0x1
info: Memory Type[7]: Property Flags = 0x1
info: Memory Type[10]: Property Flags = 0x7
info: Memory Heap[1]:
info: Size: 23819 MiB
info: Flags: 0x0
info: Memory Type[0]: Property Flags = 0x0
info: Memory Type[1]: Property Flags = 0x0
info: Memory Type[2]: Property Flags = 0x0
info: Memory Type[3]: Property Flags = 0x0
info: Memory Type[4]: Property Flags = 0x0
info: Memory Type[5]: Property Flags = 0x0
info: Memory Type[6]: Property Flags = 0x0
info: Memory Type[8]: Property Flags = 0x6
info: Memory Type[9]: Property Flags = 0xe
info: Intel(R) Graphics (ADL GT2):
info: Driver: 21.3.5
info: Vulkan: 1.2.195
info: Flags: 0x1
info: Memory Type[0]: Property Flags = 0xf
[0219/213804.396:ERROR:dxva_video_decode_accelerator_win.cc(1397)] DXVAVDA fatal error: could not LoadLibrary: msmpeg2vdec.dll: Module not found. (0x7E)
[0219/213804.397:ERROR:dxva_video_decode_accelerator_win.cc(1405)] DXVAVDA fatal error: could not LoadLibrary: msvproc.dll: Module not found. (0x7E)
info: Win32 WSI
info: OpenVR
info: OpenXR
info: Flags: 0x1
info: Flags: 0x0
info: Flags: 0x1
info: D3D11CoreCreateDevice: Probing D3D_FEATURE_LEVEL_11_1
info: D3D11CoreCreateDevice: Using feature level D3D_FEATURE_LEVEL_11_1
info: Device properties:
info: Device name: : NVIDIA GeForce RTX 3070 Ti Laptop GPU
info: Driver version : 510.47.3
info: Enabled device extensions:
info: VK_EXT_4444_formats
info: VK_EXT_conservative_rasterization
info: VK_EXT_custom_border_color
info: VK_EXT_depth_clip_enable
info: VK_EXT_extended_dynamic_state
info: VK_EXT_host_query_reset
info: VK_EXT_robustness2
info: VK_EXT_shader_demote_to_helper_invocation
info: VK_EXT_shader_viewport_index_layer
info: VK_EXT_transform_feedback
info: VK_EXT_vertex_attribute_divisor
info: VK_KHR_create_renderpass2
info: VK_KHR_depth_stencil_resolve
info: VK_KHR_draw_indirect_count
info: VK_KHR_driver_properties
info: VK_KHR_image_format_list
info: VK_KHR_sampler_mirror_clamp_to_edge
info: VK_KHR_shader_float_controls
info: VK_KHR_swapchain
info: Device features:
info: robustBufferAccess : 1
info: fullDrawIndexUint32 : 1
info: imageCubeArray : 1
info: independentBlend : 1
info: geometryShader : 1
info: tessellationShader : 1
info: sampleRateShading : 1
info: dualSrcBlend : 1
info: logicOp : 1
info: multiDrawIndirect : 1
info: drawIndirectFirstInstance : 1
info: depthClamp : 1
info: depthBiasClamp : 1
info: fillModeNonSolid : 1
info: depthBounds : 1
info: multiViewport : 1
info: samplerAnisotropy : 1
info: textureCompressionBC : 1
info: occlusionQueryPrecise : 1
info: pipelineStatisticsQuery : 1
info: vertexPipelineStoresAndAtomics : 1
info: fragmentStoresAndAtomics : 1
info: shaderImageGatherExtended : 1
info: shaderStorageImageExtendedFormats : 0
info: shaderStorageImageReadWithoutFormat : 1
info: shaderStorageImageWriteWithoutFormat : 1
info: shaderClipDistance : 1
info: shaderCullDistance : 1
info: shaderFloat64 : 1
info: shaderInt64 : 1
info: variableMultisampleRate : 1
info: formatA4R4G4B4 : 1
info: formatA4B4G4R4 : 1
info: customBorderColors : 1
info: customBorderColorWithoutFormat : 1
info: depthClipEnable : 1
info: extendedDynamicState : 1
info: hostQueryReset : 1
info: VK_EXT_memory_priority
info: memoryPriority : 0
info: robustBufferAccess2 : 1
info: robustImageAccess2 : 1
info: nullDescriptor : 1
info: shaderDemoteToHelperInvocation : 1
info: transformFeedback : 1
info: geometryStreams : 1
info: vertexAttributeInstanceRateDivisor : 1
info: vertexAttributeInstanceRateZeroDivisor : 1
info: VK_KHR_buffer_device_address
info: bufferDeviceAddress : 0
info: Queue families:
info: Graphics : 0
info: Transfer : 1
info: DXVK: Read 0 valid state cache entries
info: DXVK: Using 13 compiler threads
[0219/213804.563:ERROR:dxva_video_decode_accelerator_win.cc(1320)] DXVAVDA fatal error: Could not load msmpeg2vdec.dll: Module not found. (0x7E)
(wine:3389): GStreamer-WARNING **: 21:38:04.577: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstadder.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstadder.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.577: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstcolormanagement.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstcolormanagement.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.577: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvideofilter.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvideofilter.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.577: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstrtpmanagerbad.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstrtpmanagerbad.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.577: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvideoscale.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvideoscale.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.577: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaccurip.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaccurip.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.577: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaudioparsers.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaudioparsers.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.578: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvideoparsersbad.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvideoparsersbad.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.578: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiolatency.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiolatency.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.578: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstfestival.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstfestival.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.578: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgsttheora.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgsttheora.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.578: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstinterlace.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstinterlace.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.579: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgsty4mdec.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgsty4mdec.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.579: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaudioconvert.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaudioconvert.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.579: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstxingmux.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstxingmux.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.579: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstogg.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstogg.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.579: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstsndfile.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstsndfile.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.580: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstgaudieffects.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstgaudieffects.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.580: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdeinterlace.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdeinterlace.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.580: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstsegmentclip.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstsegmentclip.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.580: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstbayer.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstbayer.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.580: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdvbsubenc.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdvbsubenc.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.580: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgsttranscode.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgsttranscode.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.581: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstclosedcaption.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstclosedcaption.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.581: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdebug.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdebug.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.581: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstshm.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstshm.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.581: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstipcpipeline.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstipcpipeline.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.581: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstsubenc.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstsubenc.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.582: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgsttypefindfunctions.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgsttypefindfunctions.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.582: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstv4l2codecs.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstv4l2codecs.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.582: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstmpg123.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstmpg123.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.582: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstjpeg.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstjpeg.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.582: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstsdpelem.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstsdpelem.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.583: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstrfbsrc.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstrfbsrc.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.583: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstmatroska.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstmatroska.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.583: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstnvcodec.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstnvcodec.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.583: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstrealmedia.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstrealmedia.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.583: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstpbtypes.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstpbtypes.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.584: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstadpcmdec.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstadpcmdec.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.584: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstremovesilence.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstremovesilence.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.584: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiomixmatrix.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiomixmatrix.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.584: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstflv.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstflv.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.584: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstjp2kdecimator.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstjp2kdecimator.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.585: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstivfparse.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstivfparse.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.585: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvorbis.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvorbis.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.585: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstid3tag.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstid3tag.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.585: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstfreeverb.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstfreeverb.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.585: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstinter.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstinter.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.585: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstautoconvert.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstautoconvert.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.585: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstsmooth.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstsmooth.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.586: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdvbsuboverlay.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdvbsuboverlay.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.586: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstautodetect.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstautodetect.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.586: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstsiren.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstsiren.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.586: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstsctp.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstsctp.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.586: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstpnm.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstpnm.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.587: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstmpegtsdemux.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstmpegtsdemux.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.587: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstmidi.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstmidi.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.587: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdebugutilsbad.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdebugutilsbad.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.587: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstisomp4.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstisomp4.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.587: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstmpegpsdemux.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstmpegpsdemux.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.587: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaiff.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaiff.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.588: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgsttimecode.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgsttimecode.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.588: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstrist.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstrist.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.588: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstapp.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstapp.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.588: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdvb.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdvb.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.588: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstttmlsubs.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstttmlsubs.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.588: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvmnc.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvmnc.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.589: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgsthls.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgsthls.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.589: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdash.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdash.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.589: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstadpcmenc.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstadpcmenc.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.589: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstmpegpsmux.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstmpegpsmux.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.589: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaudioresample.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaudioresample.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.589: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstflxdec.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstflxdec.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.590: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstlegacyrawparse.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstlegacyrawparse.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.590: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdtls.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdtls.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.590: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdvdspu.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdvdspu.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.590: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiofxbad.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiofxbad.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.590: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstopenal.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstopenal.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.590: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstwavparse.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstwavparse.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.591: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstcoretracers.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstcoretracers.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.591: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstjpegformat.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstjpegformat.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.591: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstrtmp2.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstrtmp2.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.591: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstcamerabin.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstcamerabin.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.591: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstproxy.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstproxy.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.591: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstlibav.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstlibav.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.592: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstcoreelements.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstcoreelements.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.592: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstasfmux.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstasfmux.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.592: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvideoframe_audiolevel.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvideoframe_audiolevel.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.592: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiovisualizers.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiovisualizers.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.592: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstwaylandsink.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstwaylandsink.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.592: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdvdsub.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdvdsub.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.593: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstuvch264.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstuvch264.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.593: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstnetsim.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstnetsim.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.593: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstgdp.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstgdp.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.593: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstopusparse.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstopusparse.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.593: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstasf.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstasf.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.593: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstpcapparse.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstpcapparse.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.594: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgsty4menc.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgsty4menc.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.594: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstfieldanalysis.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstfieldanalysis.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.594: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiobuffersplit.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiobuffersplit.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.594: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstplayback.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstplayback.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.594: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstflac.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstflac.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.594: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstcoloreffects.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstcoloreffects.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.594: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstspeex.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstspeex.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.595: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstrawparse.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstrawparse.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.595: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvideoconvert.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvideoconvert.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.595: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstopus.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstopus.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.595: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvideofiltersbad.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvideofiltersbad.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.595: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstbz2.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstbz2.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.595: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstfaceoverlay.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstfaceoverlay.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.596: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstavi.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstavi.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.596: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstfrei0r.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstfrei0r.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.596: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstswitchbin.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstswitchbin.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.596: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstsmoothstreaming.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstsmoothstreaming.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.596: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstmpegtsmux.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstmpegtsmux.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.596: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstivtc.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstivtc.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.597: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdvdlpcmdec.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstdvdlpcmdec.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.597: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvideobox.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvideobox.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.597: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstid3demux.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstid3demux.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.597: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstmxf.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstmxf.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.597: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstspeed.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstspeed.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.597: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstgeometrictransform.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstgeometrictransform.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.597: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvideosignal.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstvideosignal.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.598: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstrtponvif.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstrtponvif.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.598: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstnavigationtest.so': /home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib64/gstreamer-1.0/libgstnavigationtest.so: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.630: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib/gstreamer-1.0/libgstv4l2codecs.so': libgudev-1.0.so.0: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.885: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib/gstreamer-1.0/libgstlibav.so': libspeex.so.1: wrong ELF class: ELFCLASS64
(wine:3389): GStreamer-WARNING **: 21:38:04.891: Failed to load plugin '/home/feyko/.local/share/lutris/runners/wine/lutris-fshack-7.1-x86_64/lib/gstreamer-1.0/libgstuvch264.so': libgudev-1.0.so.0: wrong ELF class: ELFCLASS64
Current serial number in output stream: 310
info: Win32 WSI
info: OpenVR
info: OpenXR
info: Flags: 0x1
info: Flags: 0x0
info: Flags: 0x1
info: D3D11CoreCreateDevice: Probing 49408
info: D3D11CoreCreateDevice: Probing 49152
info: logicOp : 1
info: Graphics : 0
info: Transfer : 1
info: Device name: : Intel(R) Graphics (ADL GT2)
info: Driver version : 21.3.5
info: VK_EXT_shader_stencil_export
info: logicOp : 1
info: shaderStorageImageReadWithoutFormat : 0
info: shaderFloat64 : 0
info: formatA4B4G4R4 : 0
info: Graphics : 0
info: Transfer : 0
[0219/214004.341:ERROR:dxva_video_decode_accelerator_win.cc(1397)] DXVAVDA fatal error: could not LoadLibrary: msmpeg2vdec.dll: Module not found. (0x7E)
[0219/214004.342:ERROR:dxva_video_decode_accelerator_win.cc(1405)] DXVAVDA fatal error: could not LoadLibrary: msvproc.dll: Module not found. (0x7E)
Caught signal 15
gamemodeauto:
Killing PID 3226 with SIGTERM
Killing PID 3234 with SIGTERM
Killing PID 3240 with SIGTERM
Killing PID 3243 with SIGTERM
Killing PID 3251 with SIGTERM
Killing PID 3253 with SIGTERM
Killing PID 3282 with SIGTERM
Killing PID 3288 with SIGTERM
Killing PID 3294 with SIGTERM
Killing PID 3304 with SIGTERM
Killing PID 3353 with SIGTERM
Killing PID 3356 with SIGTERM
Killing PID 3389 with SIGTERM
Killing PID 3481 with SIGTERM
Killing PID 3693 with SIGTERM
--terminated processes--
Monitored process exited.
Initial process has exited (return code: 15)
Exit with return code 15
Feyko
20 February 2022 11:19
4
Back with some more info. Got rid of the gstreamer warnings (dirtily… symlinked the 32b version of the libs into the 64b lib folder. Still no idea why wine doesn’t go looking for the right version of the lib)
Still having the issue. I checked and the errors at the top of my message above appear before I even try to start the game (Overwatch uses the Battle .net launcher)
So the issue is certainly the xrandr BadMatch error. But I have no idea what is causing that. Hope someone can chime in!
Feyko
24 February 2022 12:26
5
Tried to use optimus-manager instead of my current solution and it broke my install. After uninstalling it, I’m no longer having this issue… oh well!
system
Closed
27 February 2022 02:27
6
