I think this goes back a few updates, but some folders in a NTFS partition are read-only. Why only some, and how do I fix this?
As they should be. Thereâs nothing to fix.
Those folders belong to another Windows User, and not the current Linux User; even if they are both you. These protected folders are within a Windows Userâs profile folder (or, seem to be), and need special permissions to be set (from within Windows) to allow access from Linux.
Trying to manipulate those permissions from Linux shouldnât work, without messing up Windows permissions; read: they might even become inaccessible from within Windows.
If you just want to access files between Linux and Windows, you could create a shared partition for that purpose formatted with either ntfs
, fat32
or exfat
; an exfat
filesystem is the most trouble-free, and permissions are not an issue.
If you have no clue how to do this, just ask; Iâm sure someone will point you in the right direction. Cheers.
Itâs actually just cosmetic in my case, if I just click on one of this âlockedâ folders, I can still access their content without any problem.
It might indeed have recently changed, I never noticed that before, but itâs a long time since I last had to get or modify a file of my Windows user from inside ManjaroâŚ
And I never ever had a permission error or a file that âbecame inaccessibleâ doing so, just saying
Iâve never tripped over a cat, either, but many people have.
Itâs always better to be fore warned;
Iâm sure you wonât disagree with that â just saying.
However, Iâm sure that when the Poster states that the folders are âread-onlyâ, he/she is not pulling that information from the ether.
Linux canât actually see the windows ACL permissions and does not care about them.
It is of course possible to mount specific folders with speciffic permissions as a protection, but this is something that the linux user decides (what mount options to use) and not windows enforced.
Or perhaps itâs just because the folders âlook like read-onlyâ, but are not in reality, like I said before?
For the rest, thatâs 20 years that Iâm manipulating files and folders between my Windows and my Linux users on NTFS partitions that are NOT read-only âAs they should beâ, without having âspecial permissions to be set (from within Windows) to allow access from Linuxâ and Iâm still waiting to see a file or a folder that âmight even become inaccessible from within Windowsâ, but letâs forget it, this is a bug report and not the right place to discuss thisâŚ
⌠and yet, you managed a lengthy paragraph, regardless; but, I digress.
I donât know. Ask the OP if you need that clarification.
Bach to the original question: if you donât know where the default thunar mounting options are (i donât, and it is probably a bad idea to mess them), you have to mount manually with permissions of your will.
Or, if you rarely have to write on the windows drive, just start Thunar as root as a workaround.
The OP didnât specify Thunar; at least, Not that I can find. Although, the icons do seem similar to what I remember on Thunar.
I finnicked with NTFS permissions on the Windows side but that did nothing.
Fixed by doing something I shouldâve done years ago - put it on fstab so it just gets mounted as rw.
I always mounted it manually upon logging in so no reason to not just have it there.
Thatâs probably better than having the manual hassle every time. I mount a separate partition - much like I suggested above. In this way, I can reasonably prevent any unintended interference to the Windows system drive. Though, in my case, i have Users on a separate partition, so potential system damage as a result of my blunders is minimal, at least.
Now that this thread has been moved out of the Update thread, and, because Iâm feeling particularly pedantic, Iâll leave the following for general consumption:
Viewing a Windows filesystem from Dolphin
Note:- I have used Dolphin as an example, because thatâs what I use. Dolphin can be substituted for whatever File Manage is used on Linux.
These lock icons are visual indicators that help quickly identify folders with specific access restrictions, or special permissions. They remind us that modifying or deleting some folders can potentially have undesirable results. For example:
Some folders have limited access permissions. Windows uses Access Control Lists (ACLs) to define who can read, write, or modify files and folders. Dolphin reflects these permissions by displaying a lock icon on folders that are not universally accessible.
Encrypted folders using BitLocker or another encryption, typically require an encryption key or password; When accessing network shares, folders might require authentication; Windows system folders often have enhanced security settings to prevent accidental changes; So-called special folders need proper permissions for interaction.
In all of these cases, a lock icon is displayed.
In summary, when using Dolphin to view a Windows filesystem, you should always exercise caution when working with them to avoid unintended consequences.
Cheers.
