I am a newbie to Linux so I am sorry if I mismatch some terminology
So when I am booting my Manjaro, my HDD and SSD partitions starts unmounted - in Dolphin they show that orange disconnected icon - and for them to start working I need to click on them in Dolphin but when Steam auto launches it forgets the library folders that I set on them because it can’t see it so I need to set it manually each time I turn on my computer.
Is there a way to fix it? HDD shares some space with Windows but SSD is almost empty
Yes there is a way. You will need to edit the /etc/fstab file and add these partitions to it so they will get automounted on startup. https://wiki.archlinux.org/index.php/Fstab
Oh didn’t fully understand what those options dump and fsck means. Do they mean much?
I will be using those drives for mainly storing games and graphic projects
The explanation of those are linked in the archwiki entry i linked earlier. For completeness sake i will link them here aswell. What is the dump value
`<fsck>` sets the order for filesystem checks at boot time;
see [fsck(8)](https://jlk.fjfi.cvut.cz/arch/manpages/man/fsck.8).
For the root device it should be `1` .
For other partitions it should be `2` , or `0` to disable checking.
Yes, you will have to run a chown command once over them to claim ownership. The syntax for chown works like this: chown -R user:group direcory_to_be_changed
The -R options says to do it recursively for all folders and files aswell.
In this example with your user and group likely be named rafii the command would be: chown -R rafii:rafii /run/media/rafii/SSD
