I am just posting this because I thought that since Hibernate saves the system’s state, it would save data from applications and reopen them when I booted the machine back up, like sleep does. But when I set up Hibernation on my machine it seems to just power off, does some strange stuff to audio that a standard shutdown does not, and when I power it back up, and acts like I just booted it up from a shutdown and does not save applications. Is this exactly what it’s supposed to do? I am just trying to figure out if there is even a problem before I try to fix it.
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
#If you want to enable the save default function, uncomment the following
#line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#Preload both GPT and MBR modules so that they are not missed
#Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
#Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
#Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
#The resolution used on graphical terminal
#note that you can use only modes which your graphic card supports via VBE
#you can see them in real GRUB with the command 'videoinfo'
GRUB_GFXMODE=auto
#Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
#Uncomment if you want GRUB to pass to the Linux kernel the old parameter
#format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
#Uncomment to disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY=true
#Uncomment this option to enable os-prober execution in the grub-mkconfig command
GRUB_DISABLE_OS_PROBER=false
#Uncomment and set to the desired menu colors. Used by normal and wallpaper
#modes only. Entries specified as foreground/background.
#Uncomment one of them for the gfx desired, a image background or a gfxtheme
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
#Uncomment to ensure that the root filesystem is mounted read-only so that
#systemd-fsck can run the check automatically. We use 'fsck' by default, which
#needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
#removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
#See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
I just went through a lot of googling to figure out if I was using BTRFS or not because I saw /etc/default/grub-btrfs/
and panicked, because I saw in all the guides to setting up swap that BTRFS needs more steps, that I did not take, then I finally figured out what file system I am running, and it’s ext4.
So I did all the steps, and it still doesn’t work, and the logs give me the same errors. So I must have done the steps wrong, in /etc/default/grub, do I need to get rid of the “” around what I am supposed to add?
GRUB_TIMEOUT=5
GRUB_CMDLINE_LINUX="resume=UUID=f6898bf0-f23e-4f8c-8f59-2b16eaa17936"
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_GFXMODE=auto
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES=""
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=""
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No raid, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect block filesystems)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev block filesystems)
## This setup assembles a pata mdadm array with an encrypted root FS.
## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
# HOOKS=(base udev block mdadm encrypt filesystems)
## This setup loads an lvm2 volume group on a usb device.
# HOOKS=(base udev block lvm2 filesystems)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
HOOKS="base udev resume autodetect modconf block keyboard keymap consolefont filesystems fsck"
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
I ran that command and I hibernated the system, like they said in the thread, since I just realized that they are not the same thing, I am going to go do that now.
