The Breath Login theme has 2
Clock.qmls (duplicated), one is/usr/share/sddm/themes/breath/components/Clock.qmlthe other is/usr/share/sddm/themes/breath/Clock.qml -
The Chinese translation of this is missing, which should be “打开文件夹的方式”
Is it happening just after the update? In either case it would be better if you report it here:
But the first bug is definitely Manjaro Teams’ fault. The 2 files are different and I do not know what is Manjaro Team doing.
KDE Breeze SDDM has 1 Clock.qml
That is a bogus file, from previous version, is not used, it can be removed. Will be updated with the next package …
We do not develop Dolphin, nor we package it. That has to be reported upstream to KDE Plasma.
That file does nothing …
Why not use this one and remove the /usr/share/sddm/themes/breath/Clock.qml, it seems that the standard position is ./components/
He said exactly the same thing. It’s just a leftover, nothing too criminal. Thanks for the report, I didn’t catch it during the theme update. Will be fixed with the next version.
