Hello! Recently I’ve been running into errors when installing some AUR packages.
Today, I tried reinstalling ‘cava’ via sudo pamac install cava but at the end the output returns:
Makefile.am: installing './depcomp'
mkdir: cannot create directory ‘/.config’: Read-only file system
cp: cannot create regular file '/.config/cava/config': No such file or directory
==> ERROR: A failure occurred in build().
Aborting...
Finished with result: exit-code
Main processes terminated with: code=exited/status=4
This is strange because the first time I installed cava I ran into no issues. This error seems to be happening with numerous packages recently.
An attempt to install ‘spotify-tui’ via sudo pamac install spotify-tui returns a similar error.
==> Starting build()...
error: failed to get `anyhow` as a dependency of package `spotify-tui v0.24.0 (/var/cache/private/pamac/spotify-tui/src/spotify-tui-0.24.0)`
Caused by:
failed to create directory `/.cargo/registry/index/github.com-1ecc6299db9ec823`
Caused by:
Read-only file system (os error 30)
Aborting...
A look with journalctl -p3 -b -0 and I find:
Aug 22 13:20:01 system systemd[1]: Failed to start /usr/bin/makepkg -cCf --nosign PKGDEST=/var/cache/pamac/cava PKGEXT=.pkg.tar.
Aug 22 13:21:44 system systemd[1]: Failed to start /usr/bin/makepkg -cCf --nosign PKGDEST=/var/cache/pamac/spotify-tui PKGEXT=.pkg.tar.
Some packages like audio-recorder still can be installed, so I’m not sure whats causing these packages to fail during installation.
Here’s what inxi --full --verbosity=7 --filter --no-host outputs just in case:
System: Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2
info: i3bar, polybar wm: i3 4.19.1 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401IV_GA401IV v: 1.0 serial: <filter>
Mobo: ASUSTeK model: GA401IV v: 1.0 serial: <filter> UEFI: American Megatrends v: GA401IV.219 date: 12/30/2020
Battery: ID-1: BAT0 charge: 15.9 Wh (22.9%) condition: 69.3/76.0 Wh (91.2%) volts: 15.8 min: 15.8
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Charging
Memory: RAM: total: 15.06 GiB used: 2.94 GiB (19.5%)
CPU: Info: 8-Core model: AMD Ryzen 9 4900HS with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 rev: 1 cache:
L2: 4 MiB bogomips: 95854
Speed: 1397 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1397 3: 1397 4: 1397 5: 1397
6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397 12: 1398 13: 1397 14: 1395 15: 1397 16: 1397
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev
sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
Graphics: Device-1: NVIDIA TU106M [GeForce RTX 2060 Max-Q] vendor: ASUSTeK driver: nvidia v: 470.63.01 bus-ID: 01:00.0
chip-ID: 10de:1f12 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Renoir vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 04:00.0
chip-ID: 1002:1636 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: picom v: git-dac85 driver: loaded: amdgpu,ati,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa resolution: 1920x1080~120Hz s-dpi: 96
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.11-1-MANJARO LLVM 12.0.1) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASUSTeK driver: N/A
bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000 bus-ID: 02:00.0 chip-ID: 8086:2723
class-ID: 0280
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 5-4:3 chip-ID: 8087:0029 class-ID: e001
Logical: Message: No logical block device data found.
RAID: Message: No RAID data found.
Drives: Local Storage: total: 953.87 GiB used: 24.54 GiB (2.6%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN530 SDBPNPZ-1T00-1002 size: 953.87 GiB speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 21106000 temp: 44.9 C scheme: GPT
Partition: ID-1: / size: 122.48 GiB used: 24.52 GiB (20.0%) fs: ext4 dev: /dev/nvme0n1p6 label: N/A
uuid: 32f960f9-6bab-483b-a810-610df61ebcc7
ID-2: /boot/efi size: 256 MiB used: 25.5 MiB (10.0%) fs: vfat dev: /dev/nvme0n1p1 label: SYSTEM uuid: 6403-7909
Swap: Alert: No swap data was found.
Unmounted: ID-1: /dev/nvme0n1p2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 size: 808.22 GiB fs: ntfs label: OS uuid: B4E20553E2051AEE
ID-3: /dev/nvme0n1p4 size: 900 MiB fs: ntfs label: RECOVERY uuid: C0CC329CCC328CA2
ID-4: /dev/nvme0n1p5 size: 19.5 GiB fs: ntfs label: RESTORE uuid: 1E5665A356657D01
USB: Hub-1: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 3-3:2 info: ASUSTek N-KEY Device type: Keyboard driver: asus,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0b05:1866 class-ID: 0301
Hub-2: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 5-3:2 info: Shenzhen Goodix FingerPrint type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:521d class-ID: ff00
Device-2: 5-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-4: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Sensors: System Temperatures: cpu: 44.9 C mobo: 44.0 C
Fan Speeds (RPM): cpu: 2500
Info: Processes: 389 Uptime: 38m wakeups: 198 Init: systemd v: 248 Compilers: gcc: 11.1.0 Packages: 1371 pacman: 1363
flatpak: 5 snap: 3 Shell: Bash v: 5.1.8 running-in: alacritty inxi: 3.3.06
Any help on this issue will be appreciated!
