I have been using Fcitx5 for a while, but recently, applications using Wayland no longer use Fcitx5.
From what I see, everything that tries to use Wayland by default doesn’t work and requires either GTK_IM_MODULE or QT_IM_MODULE to be set to fcitx.
For example, KDE/System software, such as Kate or System Settings, requires QT_IM_MODULE to be set, while Firefox requires GTK_IM_MODULE to be set. In contrast, Vivaldi won’t use Fcitx5 even when both are set.
From what I see from fcitx5-diagnose, unless GTK_IM_MODULE or QT_IM_MODULE are set, nothing even uses the Wayland dbus.
In my environment variables, I have only set XMODIFIERS=@im=fcitx, and I’m using Fcitx5 Wayland Launcher in virtual keyboard settings. From what I saw, these are the only required settings.
Has something changed that now requires both QT_IM_MODULE and GTK_IM_MODULE to be set?, and does anyone have any idea how to make Vivaldi use Fcitx5?
System Info
Kernel: 6.14.0-2-rt3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-rt-x86_64
root=UUID=e25eb414-7401-4086-851c-0725906b306f rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.17.0
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
serial: <superuser required>
Mobo: Gigabyte model: X570 AORUS ELITE serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F40d
date: 09/02/2024
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3706 min/max: 550/4654 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3706 2: 3706 3: 3706
4: 3706 5: 3706 6: 3706 7: 3706 8: 3706 9: 3706 10: 3706 11: 3706 12: 3706
bogomips: 88804
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
svm
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT / 7800
XT] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,DP-2 empty: HDMI-A-1,HDMI-A-2,Writeback-1
bus-ID: 0c:00.0 chip-ID: 1002:747e class-ID: 0300
Device-2: Logitech Brio 100 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 046d:094c
class-ID: 0102 serial: <filter>
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 5120x1440 display-ID: 0
Monitor-1: DP-1 pos: right model: Gigabyte M27Q X serial: <filter>
built: 2022 res: mode: 2560x1440 hz: 240 scale: 100% (1) dpi: 109 gamma: 1.2
size: 596x335mm (23.46x13.19") diag: 684mm (26.9") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
Monitor-2: DP-2 pos: primary,left model: Gigabyte M27Q serial: <filter>
built: 2024 res: mode: 2560x1440 hz: 170 scale: 100% (1) dpi: 93 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 801mm (31.5") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.1-arch1.4
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
navi32 LLVM 20.1.8 DRM 3.61 6.14.0-2-rt3-MANJARO) device-ID: 1002:747e
memory: 15.62 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 7800 XT (RADV NAVI32) driver: mesa radv v: 25.2.1-arch1.4
device-ID: 1002:747e surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: amdgpu_top,radeontop
wl: wayland-info,wlr-randr x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
bus-ID: 0c:00.1 chip-ID: 1002:ab30 class-ID: 0403
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech Brio 100 driver: snd-usb-audio,uvcvideo type: USB
Device-4: Audio-Technica AT2020USB+
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 5-4:2 chip-ID: 0909:001c class-ID: 0300
API: ALSA v: k6.14.0-2-rt3-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet 10-Gigabit X540-AT2 driver: ixgbe v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8 port: N/A bus-ID: 05:00.0
chip-ID: 8086:1528 class-ID: 0200
IF: enp5s0f0 state: down mac: <filter>
Device-2: Intel Ethernet 10-Gigabit X540-AT2 driver: ixgbe v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8 port: N/A bus-ID: 05:00.1
IF: enp5s0f1 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-3: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
IF-ID-1: mullvpn state: unknown speed: 10000 Mbps duplex: full mac: N/A
IF-ID-2: virbr0 state: down mac: <filter>
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 2357:0604
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 6.37 TiB used: 750.16 GiB (11.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7
temp: 52.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 48.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 750.16 GiB (40.9%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:7
used: 324 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
System Temperatures: cpu: 53.0 C mobo: 38.0 C gpu: amdgpu temp: 57.0 C
mem: 75.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 592
Memory: total: 32 GiB available: 31.26 GiB used: 9.59 GiB (30.7%)
Processes: 579 Power: uptime: 2h 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 2414 pm: dpkg pkgs: 0 pm: pacman pkgs: 2370 libs: 549
tools: pamac,yay pm: rpm pkgs: 0 pm: flatpak pkgs: 44 Compilers:
clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.3.3
running-in: konsole inxi: 3.3.39
