When I save a file from brave-browser (for the first time after boot), and when I export images from GIMP (for the first time after boot), both of the applications become unresponsive for a few seconds.In case of brave-browser, the file is being downloaded in the background when its unresponsive.
Exporting files from audacity and Kdenlive doesn’t seem to have this problem yet. And saving files from vim, Kate (text editor) also doesn’t have this problem.
Kernel: 5.9.1-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=021ac587-2598-4e39-b7e0-5634da992ec8 rw apparmor=1
security=apparmor resume=UUID=3c820242-6b38-4805-ba9a-bda2db7c6952
udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: HP product: HP Pavilion Notebook
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8216 v: 83.18 serial: <filter> UEFI: Insyde v: F.52
date: 05/02/2019
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Device-2: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Topology: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9 microcode: D6
L2 cache: 4096 KiB
bogomips: 23209
Speed: 793 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 792 2: 773 3: 778
4: 792
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:5916
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Hewlett-Packard
driver: nvidia v: 455.28 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:134d
Device-3: Sunplus Innovation HP Wide Vision HD type: USB driver: uvcvideo
bus ID: 1-3:3 chip ID: 1bcf:2c87
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11
driver: modesetting,nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 75 s-size: 652x366mm (25.7x14.4")
s-diag: 748mm (29.4")
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: GeForce 940MX/PCIe/SSE2 v: 4.6.0 NVIDIA 455.28
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.9.1-1-MANJARO
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 3000 bus ID: 03:00.0 chip ID: 10ec:8136
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel port: 3000 bus ID: 05:00.0 chip ID: 8086:24fb
IF: wlo1 state: down mac: <filter>
IF-ID-1: eth0 state: down mac: <filter>
Local Storage: total: 2.26 TiB used: 693.50 GiB (30.0%)
ID-1: /dev/sda vendor: Seagate model: ST2000LM003 HN-M201RAD size: 1.82 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 0001 scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WDS480G2G0A-00JH30
size: 447.13 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 0400 scheme: GPT
ID-1: / raw size: 429.75 GiB size: 422.01 GiB (98.20%)
used: 86.05 GiB (20.4%) fs: ext4 dev: /dev/sdb2
ID-1: swap-1 type: partition size: 17.08 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb3
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 45 C
Processes: 229 Uptime: 1h 29m Memory: 15.53 GiB used: 3.22 GiB (20.8%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1380 lib: 372 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.05 ```
