As in the title: each time wifi disconnects (reboot, logout, lock) I have to type in the password. I tried typing it in Connections > Wifi Security both as “store for this user” and “all users” and it goes blank after reboot.
Here’s my network card info:
`Network:`
`Device-1: Intel Wireless-AC 9462/9560 driver: iwlwifi v: kernel port: 4000`
`bus ID: 00:14.3 chip ID: 8086:06f0 class ID: 0280`
`IF: wlo1 state: up mac: <filter>`
Any ideas?
EDIT: A solution found somewhere on the forum did not work:
“you have to open an empty file called wifi_rand_mac.conf on the following directory /etc/NetworkManager/conf.d/
and write the following:
[device]
wifi.scan-rand-mac-address=no”
EDIT 2: Solution if anyone ever encounters this problem: seems like KDE wallet was the culprit. Even though it was disabled, I had to open Wallet Manager and clear the keys there and then key in the password one last time under Connections > Wifi security. This seems to be what helped.
