Hello,
I am trying to install VMWare WorkStation on Manjaro KDE guide on Wiki
I am failing at this step :
sudo systemctl enable --now vmware-hostd.service
Getting message :
Failed to enable unit: Unit file vmware-hostd.service does not exist
Also this
Created symlink /etc/systemd/system/multi-user.target.wants/vmware-
networks.service → /usr/lib/systemd/system/vmware-networks.service.
Job for vmware-networks.service failed because the control process
exited with error code.
See "systemctl status vmware-networks.service" and "journalctl -xe"
for details.
Nov 23 15:33:51 Manjaro-HQ vmware-networks[23827]: Failed to start DHCP service on vmnet8
Nov 23 15:33:51 Manjaro-HQ vmware-networks[23827]: Failed to start some/all services
Nov 23 15:33:51 Manjaro-HQ vmware-networks[23827]: Started Bridge networking on vmnet0
Nov 23 15:33:51 Manjaro-HQ vmware-networks[23827]: Enabled hostonly virtual adapter on vmnet1
Nov 23 15:33:51 Manjaro-HQ vmware-networks[23827]: Started DHCP service on vmnet1
Nov 23 15:33:51 Manjaro-HQ systemd[1]: vmware-networks.service: Control process exited, code=exited, status=1/FAILURE
Nov 23 15:33:51 Manjaro-HQ vmnetBridge[23845]: Stopped bridge enp8s0 to virtual network 0.
Nov 23 15:33:51 Manjaro-HQ vmnetBridge[23845]: Bridge process exiting.
Nov 23 15:33:51 Manjaro-HQ systemd[1]: vmware-networks.service: Failed with result 'exit-code'.
Nov 23 15:33:51 Manjaro-HQ systemd[1]: Failed to start VMware Networks.
journalctl -xe
Nov 23 15:40:48 Manjaro-HQ audit[28782]: USER_START pid=28782 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_>
Nov 23 15:40:48 Manjaro-HQ sudo[28782]: techxero : TTY=pts/2 ; PWD=/home/techxero ; USER=root ; COMMAND=/usr/bin/modprobe -a vmw_vmci vmmon
Nov 23 15:40:48 Manjaro-HQ sudo[28782]: pam_unix(sudo:session): session opened for user root(uid=0) by techxero(uid=0)
Nov 23 15:40:48 Manjaro-HQ sudo[28782]: pam_unix(sudo:session): session closed for user root
Nov 23 15:40:48 Manjaro-HQ audit[28782]: USER_END pid=28782 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_u>
Nov 23 15:40:48 Manjaro-HQ audit[28782]: CRED_DISP pid=28782 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_perm>
Nov 23 15:40:48 Manjaro-HQ kernel: audit: type=1106 audit(1606138848.853:214): pid=28782 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_cl>
Nov 23 15:40:48 Manjaro-HQ kernel: audit: type=1104 audit(1606138848.853:215): pid=28782 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred gr>
Nov 23 15:41:55 Manjaro-HQ nmbd[1455]: [2020/11/23 15:41:55.153773, 0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
Nov 23 15:41:55 Manjaro-HQ nmbd[1455]: query_name_response: Multiple (2) responses received for a query on subnet 192.168.1.69 for name WORKGROUP<1d>
Nov 23 15:41:55 Manjaro-HQ nmbd[1455]: This response was from IP 192.168.1.128, reporting an IP address of 192.168.1.128.
Nov 23 15:45:17 Manjaro-HQ plasmashell[1228]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15>
Nov 23 15:45:24 Manjaro-HQ kwin_x11[1175]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26642, resource id: 10486059, major code: 1>
Nov 23 15:45:33 Manjaro-HQ plasmashell[1228]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:494:39: QML StreamListItem: Binding loo>
Nov 23 15:47:02 Manjaro-HQ nmbd[1455]: [2020/11/23 15:47:02.589539, 0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
Nov 23 15:47:02 Manjaro-HQ nmbd[1455]: query_name_response: Multiple (2) responses received for a query on subnet 192.168.1.69 for name WORKGROUP<1d>
Nov 23 15:47:02 Manjaro-HQ nmbd[1455]: This response was from IP 192.168.1.128, reporting an IP address of 192.168.1.128.
Nov 23 15:51:57 Manjaro-HQ kwin_x11[1175]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33445, resource id: 123731969, major code: >
Nov 23 15:52:04 Manjaro-HQ nmbd[1455]: [2020/11/23 15:52:04.040555, 0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
Nov 23 15:52:04 Manjaro-HQ nmbd[1455]: query_name_response: Multiple (2) responses received for a query on subnet 192.168.1.69 for name WORKGROUP<1d>
Nov 23 15:52:04 Manjaro-HQ nmbd[1455]: This response was from IP 192.168.1.128, reporting an IP address of 192.168.1.128.
Nov 23 15:57:05 Manjaro-HQ nmbd[1455]: [2020/11/23 15:57:05.728952, 0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
Nov 23 15:57:05 Manjaro-HQ nmbd[1455]: query_name_response: Multiple (2) responses received for a query on subnet 192.168.1.69 for name WORKGROUP<1d>
Nov 23 15:57:05 Manjaro-HQ nmbd[1455]: This response was from IP 192.168.1.128, reporting an IP address of 192.168.1.128.
Nov 23 15:57:34 Manjaro-HQ kwin_x11[1175]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41991, resource id: 123731969, major code: >
I have no idea what to do next. I am a Linux n00b… So be gentle on me…
